Go Back   IH8MUD™ Forums > General Forums > IH8MUD.com Help Corner
Old 01-10-08, 09:04 AM   #1
D'OH!
yooper's Avatar
TLCA# 13011
Search is generating bad URLs
The search function is intermittently generating bad URLs.
For example, this search: IH8MUD.com Forum - Search Results , searching for posts by semlin containing "fucked", generates this URL as its first result: http://forum.ih8mud.com/chit-chat-se...ml#post2915988
which generates a 400 "Bad Request" error
The problem is repeatable, i.e. that particular search always generates bad URLs. Furthermore all of the results for that particular search are bad. But not all searches are doing this, only a small minority.
I haven't investigated rigorously but so far I don't see a pattern. It's not just semlin, we recently saw a similar failure in TUT when searching for an old grrlscout89FJ62 post.
If you're not part of the solution, you're part of the precipitate.
'99 UZJ100 "The Iron Hippo" / '82 FJ40 "Mustard" / '73 FJ40
Originally Posted by gladly View Post
fuck with their circadian rhythms and make them your bitch
Originally Posted by Jman View Post
Some people deserve a good beating!
Originally Posted by WristPin View Post
we got logos and shit.
yooper is offline   Reply With Quote
Old 01-10-08, 09:13 AM   #2
Admin
woody's Avatar
TLCA# 1548
I'll wager that the "%" sign in the url is the problem....results from the SEO plugin....not sure that's a fixable issue however, but i'll look into it....
nice search term
Brian 'woody' Swearingen
Old 01-10-08, 09:16 AM   #3
D'OH!
yooper's Avatar
TLCA# 13011
Originally Posted by woody View Post
nice search term
I thought you'd appreciate that. But it was a real search I did.
Old 01-21-08, 01:35 PM   #4
D'OH!
yooper's Avatar
TLCA# 13011
Still happening. Pretty big PITA, makes search worthless for most users.
A useful search function I would think is more important that automatic parsing of URLs....I vote for dumping the SEO plugin if it's the culprit...
Old 01-21-08, 01:47 PM   #5
Admin
woody's Avatar
TLCA# 1548
give me some specific search term examples...non-curse ones please....
Old 01-21-08, 02:13 PM   #6
D'OH!
yooper's Avatar
TLCA# 13011
All posts by DSRTRDR containing the word "secret"
Old 01-21-08, 02:13 PM   #7
D'OH!
yooper's Avatar
TLCA# 13011
If you manually edit out the % then it works...
Old 01-21-08, 02:35 PM   #8
Admin
woody's Avatar
TLCA# 1548
so, the bug only applies to threads with a % in them?
"believe" I have it fixed....but it may take a day to populate things....
Old 01-21-08, 03:20 PM   #9
D'OH!
yooper's Avatar
TLCA# 13011
could be. I just checked that search I posted and some of the links work...
Old 01-21-08, 07:07 PM   #10
gladly's Avatar
TLCA# 16087
the one strange thing that I have found with search is that if I do an advanced search in 'title only' for "ultimate", I get:
Fatal error: Allowed memory size of 67108864 bytes exhausted (tried to allocate 71 bytes) in /home/forum/search.php on line 1123
(BTW I get the same result with 'thread' and '35%')
It's not The Adequate Thread.
_______________________________________
1975 fj40
gladly is online now   Reply With Quote
Old 01-21-08, 07:21 PM   #11
Admin
woody's Avatar
TLCA# 1548
likely because there are 300,000+ posts with that in the title.....guaranteed crash....
Old 01-21-08, 07:50 PM   #12
gladly's Avatar
TLCA# 16087
that could be an issue...
1975 fj40
Old 01-21-08, 07:51 PM   #13
gladly's Avatar
TLCA# 16087
though I was looking for threads, not posts
1975 fj40
Old 01-21-08, 10:06 PM   #14
Drive-by Poster
yzftaco's Avatar
TLCA# yes
I'm searching for "60 series rear springs" in the 40 section
and I get this:
Fatal error: Allowed memory size of 67108864 bytes exhausted (tried to allocate 71 bytes) in /home/forum/search.php on line 1033
Mark
76 FJ40-- Weekend Warrior.....
97 Tacoma-- Daily.. ..
My (not so much mine) Finish thread…
My Rubithon 08
Hollister Hills Fun Day
yzftaco is offline   Reply With Quote
Old 01-22-08, 07:01 AM   #15
Admin
woody's Avatar
TLCA# 1548
sounds like it's time for some memory adjustments again.....thanks!
Old 01-23-08, 08:52 PM   #16
D'OH!
yooper's Avatar
TLCA# 13011
Still getting some bad URLs.
IH8MUD.com Forum - Search Results is a search for "Linda Carter" in TUT #26. Only one result, bad URL.
Old 01-24-08, 12:16 PM   #17
Admin
woody's Avatar
TLCA# 1548
they it's still a % issue....i'll try and find a solution, but if it's just that thread....well....lol
Old 01-30-08, 11:16 AM   #18
...pig searching...
hks3sgte's Avatar
when I search for "part time" in the 100 tech, i get:
Fatal error: Allowed memory size of 67108864 bytes exhausted (tried to allocate 82 bytes) in /home/forum/includes/functions.php on line 51
hks3sgte is offline   Reply With Quote
Old 01-30-08, 11:33 AM   #19
Admin
woody's Avatar
TLCA# 1548
yep, discovered that issue this week as well...thus far, the solution's that should work aren't....
Old 01-30-08, 02:58 PM   #20
Dive on in...
NaterGator's Avatar
TLCA# 18767
The original issue with the broken search link is because of the percent (%) sign. It is not being properly URL escaped and se the vbSEO rewrite rule breaks the link back to the correct path.
The percent sign's urlcode is %25, so simply adding the number 25 behind the offending % sign works. This seems to be (yet another) vbSEO bug.
The memory allocation on the search function... I dunno. Either vbSEO applied a modification that runs on large objects in memory (such as some sort of complicated url translation on all search results) or they are not freeing memory as they are done with stuff. 64mb of memory is way more than enough to perform a search
'96 LX450, 33" Revos, OME lifted, etc, etc
Love the life you live, live the life you love. -Bob Marley
Selfishness is not living as one wishes to live, it is asking others to live as one wishes to live. -Oscar Wilde
Firefox users, get your youtube on!
NaterGator is offline   Reply With Quote
