Go Back   IH8MUD™ Forums > General Tech Forums > Hunting & Fishing
Old 04-03-08, 12:49 PM   #1
MALIS NOCEMUS
wierdbeard's Avatar
TLCA# 18253
M1A gunsmitth needed
I have a M1A from springfield, its had less than 200 rds through it and i'm in the need of a GOOD gunsmith/armorer to do some work on it, its having some feed problems as well as the bolt carrier is jamming to the rear when cycling. Also need to have the rings done properly for the scope as the gent i used initially didn't seem to know that much about them. Im in Nor Cal.
thanks
Three men can keep a Secret if two are dead...
I don't watch Zombie movies... I live them.
Alice - 1997 40th Anniversary, E-Lockers, George's LED's, D light don't work, HIR lowbeams, Slee harness, Hella horns, ARB w/XD9000, 240 Blitz, Safari snorkel, OME 2.5 heavy, National Luna dual Battery, CDL switch, Metal Tech sliders, BFG AT 305/70R/16, and a tree on the mirror so the cruiser don't smell
wierdbeard is offline   Reply With Quote
Old 04-03-08, 01:12 PM   #2
Home
I verified his valid FFL with the BATFE a month or so ago.
'73 Datsun PL510 2 Door Saloon
'97 FZJ 80 Locked Mall Cruiser.
Cube Dweller is offline   Reply With Quote
Old 04-06-08, 03:09 PM   #3
I'm really very humble
photogod's Avatar
One of the best if your serious.
M1-M1A-AR15.COM ... Clint Fowler Rifles ... Custom Riflesmithing ... M1/M1A Garand, AR15
Look into an ARMS 18 mount. It enables you to remove and reattach your scope without a rezero. The best.
A.R.M.S., Inc Base
A.R.M.S., Inc Rings
94 FZJ80, factory locked with mods worth more than the truck.
photogod is offline   Reply With Quote
Old 04-10-08, 10:22 AM   #4
offroad_nomad's Avatar
TLCA# 14082
Check out Fulton Armory, they worked on my Garand.
M14 Rifle Services—including M1A® and all M14-type rifles
Ian
'01 4Runner - An Evolving Expedition and Search and Rescue Response Vehicle
SAR Field Team Leader - Shenandoah Mountain Rescue Group
offroad_nomad is offline   Reply With Quote
Old 04-10-08, 07:47 PM   #5
MarkReye1's Avatar
Hi,
I would google California Highpower or Nationalmatchus.com and they will steer you to an M1A rifle plumber.
Mark
MarkReye1 is offline   Reply With Quote
Old 04-13-08, 02:22 PM   #6
Pin_Head's Avatar
Remove the stock and op rod spring and do the gravity slide test by tilting it up and down 45 degrees as outlined in the USGI M14 tech manual to find out where it is binding. You may be able to find a pdf of this manual on line. Basically you strip it to just the op rod and keep adding back parts until you find what makes it bind.
If you really want someone else to do it here is a list of M1A gubsmiths:
Gunsmiths / Armorers who work on M-14 type rifles. - M-14 Firing Line Public Forum
Pin_Head is offline   Reply With Quote
Zelfstandig ondernemen | Mortgage Calculator | Cheap Magazines | Pay Day Loans | Free Advertising
