oh no you didn't
More 10 / 22 Questions...
I have a fairly new 10 / 22. I have probably put no more than 4-500 rounds through it.
Ever since I pulled it out of the box, it seems to have an unusually high number of misfires. Maybe 1 per 10 round clip. Over the weekend, we examined the shell casings from my gun and another guy's 10 / 22 and the marks on his casings seemed a bit deeper, harder hit. I have cleaned the gun, etc. Still the same. Any ideas or fixes? Anyone experienced this? __________________ 1993 FZJ80 1973 FJ40 oh no you didn't "...mud is a hotbed of leftist chat/activity." - swank |
I have had some problems with my 10-22. Most of the time it was my fault. Too light of trigger job, loose barrel, aftermarket clip(ramline=junk) or just bad ammo.
__________________ 68 Fj40 M101 Trailer 05Tundra 07 Fj |
#3 | |
oh no you didn't
Ammo is not it... I have used multiple different kinds good rounds with same issues. Clips are not it, three different kinds including 2 different factory clips. I have never touched the trigger or the barrel aside from cleaning. __________________ 1993 FZJ80 1973 FJ40 oh no you didn't "...mud is a hotbed of leftist chat/activity." - swank |
You have pretty much narrowed it down to the hammer, hammer spring, or firing pin. Cant be anything else if you eliminated all that you said
oh no you didn't
So, replace all that? How involved is that?
Beagles Rule!
Mine missfires depending on the ammo.
I use the "something" creek metal lips clips. __________________ Cruiser Dan at American Toyota Phone is 1-800-432-6668 ext. 8 (I am not cruiser Dan) My Tow Rig = http://forum.ih8mud.com/hardcore-cor...g-tow-rig.html |
oh no you didn't
I have been using Remington ammo for the most part. But tried Federal, Winchester, etc. All do the same thing.
I am experiencing the same issue with my new 10/22 , random misfires plus I`m having occasional shell ejection issues too.. I`ve tried several different brands/rounds with the same average failure rate ..
__________________ 2000 UZJ100 OME 2" HD lift + "L" shocks, 305/70/16 Toyo MT`s , Slee diff drop, ARB front Bull-bar,Slee rear w/carrier, Custom exhaust, AO roof rack and drawer system, Various custom dents and scratches.... |
Did you buy them from Wally World? Just wondering because I've seen on other forums where people seem to have more issues with the guns from wal-mart then their local gun shops.
#10 |
oh no you didn't
I bought mine new in box from a guy who won his at a Ducks Unlimited dinner.
#11 |
Drive-by Poster
Here's a great 10/22 forum:
RimfireCentral.com - Hobby and Info Source For All Rimfire Caliber Ammo and Firearms Should help. Bolt work and the such is pretty easy! __________________ Mark 76 FJ40-- Weekend Warrior.. ...97 Tacoma-- Daily.. ..My (not so much mine) Finish thread… My Rubithon 08 Hollister Hills Fun Day |
#12 |
And just for gun talk clarification the 10-22 feeds ammo with a magazine not a clip. A stripper "clip" is used to feed ammo into a magazine. (Smiley dot)
And my 10-22 did the same thing. I tried several brands of ammo until I found a brand that worked consistant. __________________ Third generation Californian! If you don't like it here, leave. And take your fat wife and screeming kids with you. |
#13 | |
I have a 10/22 and have put countless thousands of round through it........using the 10 rnd clip and anyone of my 3-25 round Butler Creek Hot Lips magazines. I will have the occasional misfire but I just chalk it up to the ammo and go with it......occasionally I will have a mis-eject but those are even more rare. I don't clean my .22 nor to I baby it. My trigger needs work but you would too had you been pulled quickly many 1000 times(no sexual innuendo here). lunyou __________________ 1968 FJ-40 - 4.3 Chevy V6 and 3 spd*PICS ADDED(JUNE 01, 2008) 1985 FJ-60 - SPEEDY -My DD settin' on 33s and a rusty frame -parting out 1986 FJ-60 - is now topless THE BUILD UP |
#14 |
GreatBasinCustomHomes.com
Is the extractor claw on the bolt stuck or jammed? Is it even there? This is a very common 10/22 problem and mine was the same way. You should be able to get an aftermarket extractor or even find the that the factory part is missing and replace it and see if that helps.
I also went back to using factory 10 round "magazines" and that seemed to help. The newer aftermarket "Hot Lips" are supposedly better than the Ramline POS I used to have. I rarely shoot the 10/22 anymore, .17 caliber rimfires are just so much more accurate I think I am going to pool my 10/22 into a gatling gun kit for jackrabbit spotlighting
__________________ '76 FJ40 - 2F,SO,SR,RDB,PS,4.88,Q78TSL,earlydizzy,mod'd carb,Aussie'd front,weld'd rear,MetalTech'd...still too fast in 4LO Great Basin Custom Homes |
#15 |
the bulk ammo of almost any brand has issues.....Try some CCI mini mags, CCI standard velocity, or federal automatch. The blue box federal is also pretty good for baseline ammo.
Remington bulk (golden bullet 550 round pack at wally world) should be shoved up the anus of the person who created it. I had tons of misfeeds, fail to fires, and fail to ejects when using remington bulk ammo. It's also very dirty compared to other ammo. Accuracy is not consistent with it either (adds to the frustration factor very quickly)... My .22 rifles all seem to shoot very tight with CCI standard velocity ammo. I picked up a brick of eley match (red box, all same lot #) at a local gun show this weekend. im anxious to see how tightly it groups. __________________ 97 LX-450, 119k, Dual Batteries, Pin7/CDL mod, Slee harness/HIR's, LED's inside, no factory roof rack, some other homebrew mods, Airlift helper bags, and 285/75/16 geolander II's. |
#16 |
Skillet,
Sounds like your firing pin isn't striking the primer hard enough. I haven't heard of cosmoline being used too much on 10/22s, but that stuff will gum up the works and prevent the firing pin from full mobility in some weapons. I would pull the bolt carrier apart and make sure that no cosmoline or other grease is in there. My $.02. __________________ 93 FZJ-80 214k, bone stock. 07 Taco DC 4x4 Looking for a 100 |
#17 | |
And when my trigger isn't acting up I can hold very tight groups with the "golden bullet" just as well as the other bullets. lunyou __________________ 1968 FJ-40 - 4.3 Chevy V6 and 3 spd*PICS ADDED(JUNE 01, 2008) 1985 FJ-60 - SPEEDY -My DD settin' on 33s and a rusty frame -parting out 1986 FJ-60 - is now topless THE BUILD UP |
#18 | |
I can't even say it. I......agree.......with........................... .........lunyou. __________________ "It was a blend from italy, not cheap, and absolutely superb!" - Judge Smails. |
#19 |
oh no you didn't
Quoted.
#20 |
While I was researching your problem I came across this. Ruger 10-22 charger. It comes with bipod. I just ordered one.
#21 |
As far as ammo goes....I agree with lunyou as well. I buy the 550 bricks all the time and can't remember the last time I had an issue with a jam.
As far as guns go, I only referenced what others had said. I've never personally bought a gun from wal-mart and so therefore, can't say from experience. I must say, I've purchased almost everything else at WalMart and enjoy shopping at the local Superstore. |
#23 | |
#24 | |
#25 |
I thought we fired some of those misfires in the single shot..........I thought they shot ok out of it
__________________ 1972 FJ55 "Geirdriful" named after one of the Valkyries Check out my build thread: http://forum.ih8mud.com/fj55-iron-pig-preservation-society/165633-build-up-progress-my-piggie.html Some more good pics of the Pig here too: http://forum.ih8mud.com/fj55-iron-pi...-iron-pig.html Maid Marion, "Why, you speak treason!" Robin Hood, "Fluently." Last edited by nat; 03-13-08 at 10:32 PM. |
#26 | |
__________________ Georgia Cruisers Upstate Cruisers http://www.upstatecruisers.net/ TLCA 6149 86 FJ60 - first and RIP 95 FZJ 80 - second RIP 97 LX 450 - Current locked, ARB, 850J's Front and 863's rear, slee drop blocks, 315's, and M12000, Devo sliders, Iron Pig rear bumper, skid on garge floor 98 LX 470 - wifes Last edited by informationjunky; 03-14-08 at 07:52 AM. |
