Go Back   IH8MUD Forums > Toyota Tech Forums > HardCore Corner
Old 07-28-06, 08:30 PM   #31
Well I have been thinking alot bout the 6 stud knuckle. It is really a long road to a short answer. The dana 60 king pin style axle uses 4 bolts/ studs also. IMO the dana 60 has more scrub force which means more force on the same 4 studs. At a 1/2 " stud they do well , with the 9/16 they do well. It would follow that the studs on Toyota need to be upsized. I realize it causes the arm to be redrilled and countersunk but thats is cheap.
John on the hawgs
peesalot is offline   Reply With Quote
Old 07-29-06, 06:01 AM   #32
66fj40x2's Avatar
TLCA# 10749
I got my Front Range studs Friday, very nice!
"A government big enough to give you everything you want, is big enough to take away everything you have." ~ Thomas Jefferson
And yes, I'm on of those "Rural American's" that clings to his guns and his religion!
66fj40x2 is offline   Reply With Quote
Old 07-29-06, 12:40 PM   #33
Tigerstripe40's Avatar
Red locktite isn't that tough to remove.
Hit whatever you're taking apart with a propane torch for a couple of seconds, it doesn't take long, and it will come right apart.
James Henry
Wasatch Cruisers
TLCA 11233
76 FJ40 'SeldomSeen'
91 VZN130 'CanOWorms'
Tigerstripe40 is offline   Reply With Quote
Old 01-27-08, 10:25 AM   #34
warpdriv's Avatar
Hi Everyone,
Thought I would resurrect this thread for a question I had. I have been out wheeling a couple of times since the install and noticed these come loose easier than the stock ones I had. I have been torque'n them to 90 before I go out and notice I had to retorque them at lunch. Has anyone else seen this? Do I need to torque them down more?
Thank you,
Jeff Blumenthal
TLCA# 9883
KE5RST
Austin, Tx
1/71 FJ40 Dulcinea 350/700R4/NP203/TLC3SP/SO/FSR/RSR/RSHR
95 FZJ80 All Stock (hers)
www.lslc.org/austin
warpdriv is offline   Reply With Quote
Old 01-27-08, 03:40 PM   #35
what he said
Mace's Avatar
how tight are you torquing them to?
I crank the living hell out of them..
I am kinda gay.......
My Myspace
Old 01-27-08, 04:02 PM   #36
Oh...Durka Durka Durka.
Poser's Avatar
TLCA# 1856
Originally Posted by warpdriv View Post
Hi Everyone,
Thank you,
I would suspect that the threads in the knuckle housing are distorted....
Old 01-27-08, 04:47 PM   #37
kling-on's Avatar
TLCA# 15374
Hi Everyone,
Thank you,
as you well know I had the same problem till I put in the APR studs .. BUt I havent wheeled with the hydro yet so time will tell if that gets me back to re torqin ..I still have it in the truck and do torq em every run now but none loose since
82 FJ60 OME Heavy 33BFG's 410's , ARB bull & side bars
85 FJ60 Trail beater SM 420 crawler box lockers 456,38's bobed & choped with a Metal Tech cage
85 SR5 new DD
GIT-R-DONE!!!!
TLCA #15374
low riders want SWITCHES... 4 wheelers want SHIFTERS
www.jkcustoms.com
kling-on is offline   Reply With Quote
Old 01-31-08, 12:52 PM   #38
bustanutley's Avatar
ARP Torq numbers
"Knuckle stud nuts should be torqued to 110-120 ft-lbs
Hub stud nuts should be torqued to 28-30 ft-lbs.
Both studs should be installed snug into the hub or knuckle, only the nut should be torqued."
FJ-40 on FO-DEEs
just a lil guy
HOMEGROWN
bustanutley is offline   Reply With Quote
Old 01-31-08, 08:36 PM   #39
too tall's Avatar
I have found that the toyota studs with the torx heads on them aren't as strong as the old style factory ones . I've broken both , now I'm using ARP's and they seem to be holding up .
1977 fj40
1985 bj60 for sale
1993 80 series
too tall is offline   Reply With Quote
Old 02-03-08, 10:39 AM   #40
warpdriv's Avatar
Originally Posted by bustanutley View Post
ARP Torq numbers
Thx. I'll run'em down and see what happens.
Jeff Blumenthal
TLCA# 9883
KE5RST
Austin, Tx
www.lslc.org/austin
Virtual pets | Mortgage Loans | Personal Car Finance | Home Loan | MySpace Layouts
