06-20-06, 10:47 AM
#91 (permalink)
Supporting Vendor
Orderd an Aussie locker
Wrap bar material will be orderd asap..
A Cage is the Next Project
I like the way yours came out!
06-21-06, 11:19 AM
#92 (permalink)
Originally Posted by isotel
thx man, yea those Taurus fans fit like Gloves..
Proportioning valve is done, Just to Confirm w/ the experts, I took out the Small Black piece in the photo and replaced with the Proportioining, This is all i need to do? or do i need to tear apart the Master Cyl? 76 MC by the way
Behind The Mast Cylinder Of The Brake... The Brake Booster I Belive*.... You Can Swap It Out With A Mini Booster, Give You Some More Room And Power, From What I Have Seen.....
And The Tractionbars/ Anti Wrap Bars.... Very Easy To Do, Go To Your Local Farm Suply Store And Pickup To Link Arm Bars ( Two Threaded Hiems, Threaded Into A Pipe) Somyhing Like What Skys Sells.... The Weld A Bracket On The Bottom Of Your Frame, And One 90 Degrees Pointing To The Bottom Of The Axle..... Why Not Top? Top Is For Reverse, Its All About The Movemnt Of The Axle..... By The Way You Will Need Two Arms For This Job.....
11-28-06, 04:07 PM
#93 (permalink)
TLCA# Don't have one yet :)
Always love a flat belly! Darn good lookin' rig there!
11-29-06, 12:03 PM
#94 (permalink)
Supporting Vendor
its comming along, Thanks Jeff,
Thanks for Reviving the Dead thread, Im cleaning up my garage so i can get the Cruiser back into it and do some more work on it!
Plans for the near future-
Fixing my Rear Crossmember, (cracking right under the tranny mount)
Wrap Bar
Cage
Skid plate
Front Locker/Longs
New PS Box 4 turns Taped for Hydro
new Steering U-joints w/ Slip Shaft
Tube fenders
Sliders
Body Work
Paint
fixing some small leaks
Engine is still Blowing a VSS Code !!
12-10-06, 04:40 PM
#95 (permalink)
Supporting Vendor
An update
This weekend i got some work done on the truck..
ManJerk came over and i pulled the Crossmember, I had to do some reinforcement as it was starting to crack right under the center mount. The driveshaft was grinding on the crossmember, so i also notched out a section for that
After that Manjerk, me and some freinds went down to JT Customs in Fountain to watch the Primer of the Newest Muchado Productions Movie "All my Dirty Freinds 2"
http://www.muchadoproductions.com/index.html - Pretty sweet movie with nice footage from the XRRA Events, The hammers, Moab, Kansas, ect..
12-10-06, 07:44 PM
#96 (permalink)
Glad you got it together. I'm really getting the hang of the whole "drink beer and watch people work".
01-27-07, 11:39 PM
#97 (permalink)
where did you get the twin stick boot I have been looking everywhere for one of those.
1988 FJ62 - Budget Build in progress: 1 tons, 110" wheel base, caged, 39's or something like that.
1997 FZJ80 - Collector's Edition (wife's)
1992 Tercel - ugly beater DD! 35mpg!
01-28-07, 11:18 AM
#98 (permalink)
I got mine from some bronco guy on ebay...like 20 bucks or so...might try that
Tim Coffey
87 FJ60 SBC 350 SOA and some other stuff SOLD 5-15-07
94 80 with some stuff New to me 04-28-08
TLCA # 6947
Parts and Carb Rebuilds
http://www.marksoffroad.net
01-30-07, 01:13 AM
#99 (permalink)
Kick ass rig i cant wait for more. ANd of course to do mine.
01-30-07, 01:18 PM
#100 (permalink)
Supporting Vendor
i got the twin stick boot from Mad 4WD it came with my Twin Stick!
Not the best quality, i think its already ripped
A bit of an update,
I spent 3 nights working on the truck to get ready for a Snow run with Colorado Land Cruisers.. Fixed a bunch of little things, Like my Headlights  , and Put in a CD player and got my XM working again  So nice to have Music in the truck again! Then the POS would not start, so i didint get to go.
I am getting some 27 spline longs from a fellow Mud Member "joefj" Thanks!
01-30-07, 02:22 PM
#101 (permalink)
Turbo Diesel Lover
dude .. awesome proyect and huge improvements for your cruiser .. so one question why use a mini truck axle and not the Cruiser axle . ?
HJ-60 2H-T Intercooled Tencha
Originally Posted by crushers
01-30-07, 03:44 PM
#102 (permalink)
Supporting Vendor
I made a Mini truck/Cruiser Hybrid Axle.. It uses Minitruck Shafts and the outer parts of the mini housing, and uses the Cruiser Center section of the housing, and a Cruiser 3rd member.
http://forum.ih8mud.com/showpost.php...85&postcount=9
Although if i was to do it all over again, i would not hesitate to put in a stock Mini truck Axle. Id keep the Drums(that way i would have a parking brake), and the minitruck 3rds hold up to alot of abuse.. Gears are cheaper, and spare parts easier to come by, plus you get a bit more ground clearance..
thanks for the compliments guys, i have alot more work do do Before Cruise Moab!
03-18-07, 11:36 PM
#103 (permalink)
Supporting Vendor
Skid Plate
This weekend i got some time in on the cruiser.. i got a little 110 welder and this is what i came up with.. The frame is made from 3/16" flat stock, and the bottom is 1/8" sheet.. its still light enughf that my Skinny ass can put it in by myself
The Rear is 2" square tubing that i will attach to the frame with a couple of more bolts, it will make a good spot for my wrap bar to attach to!
the square part in the rear is where the t-case hangs low
03-18-07, 11:38 PM
#104 (permalink)
Supporting Vendor
this is how it attaches to the frame, w/stock mounting bolts
It sits 1" below the frame
the little gussets should help protect the mounting bolts from getting taken out
ignore the booger welds..
03-19-07, 11:23 AM
#105 (permalink)
Good idea! The flat bottom is sweet.
You might want to put in a cross bracing between the ribs. Those will want to fold over if there is much pressure on them. Simply add a strip across the top and tack in place on each rib to keep them from buckling. Will make that much stronger while it might add 1 pound overall...
And drainage, poke a few holes for water to drain...
1973 FJ40 -
Rimrock - 2
FJ40 - 0
03-19-07, 11:48 AM
#106 (permalink)
Supporting Vendor
thanks, good ideas on the drain and cross support!
03-19-07, 12:07 PM
#107 (permalink)
Your welcome. Hope you don't mind when you see a similar creation under my rig!
Andy
1973 FJ40 -
Rimrock - 2
FJ40 - 0
03-19-07, 01:29 PM
#108 (permalink)
nice work on this
03-19-07, 08:02 PM
#109 (permalink)
thanx for sharing this buildup with us - it has answered a few of my long sought questions.........I have a 89 donor truck with a new gm crate 350 mated to the 700r4 and have been wanting to swap it but have limited fab skills but with your thread and some pro help I may be able to pull it off. Any regrets with your setup?
03-19-07, 08:47 PM
#110 (permalink)
Supporting Vendor
I wish i had 4.88 or 5.28 gears.. both on the street and offroad
The Lokar Shifter SUCKS.. id rather have an Art Carr or somthing, still have issue with it, it wont go into 1st gear
Andy
not at all!
03-19-07, 10:31 PM
#111 (permalink)
Looks good Trev. Sorry I couldn't make it over but I was elbow deep in a stupid car all weekend.
03-19-07, 10:40 PM
#112 (permalink)
looks good but why 1/8"? If you land on that thing once and it is going to be f-ed
the stiffeners should help a lot but still
03-20-07, 06:43 PM
#113 (permalink)
i love the flat belly. i got hung up on my t-case guard pretty bad at roundup. the truck looks awesome
Matthew Armstrong
Proffitt's Cruisers Custom 69' FJ40, SOA front w/ Bilsteins, 4-link rear w/ Sway-a-Way Air Shocks, 5.3 ltr. Vortec 350 efi, Th400 auto, Atlas twin stick 4.3, ARB front, Detroit rear, Dana 60 F/14-bolt R, 35 splines all around, hydro assist, 42" IROC's. "Meanie"
03-29-07, 12:44 AM
#114 (permalink)
Supporting Vendor
Thanks guys, its getting there..
Nutley, I almost went 3/16", i guess time will tell.. As long as my Tranny/t-case are protected im happy..
a Bit of Progress..
I found a new PS Box - 4 turn this time around.. Rebuilt it and Taped it for Hydro Assist.. Put Plugs in for now.. but when i decide i need it all i need to do is pull the plugs and connect the lines..
All my parts are in for my Wrap Bar.. just need to build it..
I finaly sourced a Door and have everything i need to fix the tub on the passenger side!
Should be getting access to a plasma cutter this weekend so i can chop out the bad section and the rear sill..
04-01-07, 11:57 PM
#115 (permalink)
Supporting Vendor
Wrap Bar
pretty basic, i used 2" square tube, 3/16" wall..
3 bushings, an axle bracket, and a Flex Joint.. - from Ballisticfab
i made the shackle with some 2" flat stock i had.. 9/16" bolts
the flex joint attaches to the rear of the skid plate..
oh, and i need taller jackstands  (im just using it to unload the suspension)
04-02-07, 08:34 AM
#116 (permalink)
If I were you I would push that JJ off the skid until that shackle is straight up and down. How it is now it will still get wrap. If you climb a ledge and your tires lose traction you are going to get some wicked hopping.
Looks really good otherwise.
04-02-07, 11:18 AM
#117 (permalink)
Metal Tech
Yeah my current traction bar has the shackle at an angle and my wrap is terrible. Moab made it really clear that my traction bar wasn't set up right. All that will go away with a 4 link
Propane Powered 2f.
04-02-07, 01:39 PM
#118 (permalink)
Supporting Vendor
 maybe next year
So your saying, Push it back to make the Shackle 90Degrees with the frame rail??
The way i did it, i put it at 90 degrees to the plane of the center line of the axle up to the top of the shackle.. I knew i should have gone to Engineering school
BTW these photos are taken with the truck lifted up about 5" above where ride height is.. When the weight of the truck is set back down on the axle it dose go forward a bit, but not all the way..
04-02-07, 02:14 PM
#119 (permalink)
Ideally it should be tangent from the circle from the center of the axle tube. It may be ok, run it and see, just thought I would mention the possibility. The connection point on the frame side is a bit high for my tastes giving it a high antisquat # but you don’t really have much option.
04-02-07, 03:49 PM
#120 (permalink)
Supporting Vendor
thanks Zach, thats what i was aiming for, Its hard as hell to get it dead on without the use of an adjustable link on the frame side.. ill shoot a pic when i get everything back together at ride height.. im putting in some new rear shackle hangers to fix the Bootyfab, and my shackle angle..
