03-30-06, 07:29 AM
#31 (permalink)
your rig will soooooo be on the trail before mine.
when your done, drive north a bit and come wrench on mine for me
nice work travis
btw, the more you weld the better you'll get.....fo sho
04-04-06, 09:54 PM
#32 (permalink)
Supporting Vendor
Taurus fan is mounted along with the tranny cooler..
No camera still!!
working on mounting relays, switch and sender for controling the fan!
oh yea and Jim, Its Trevor, not Travis.. lol
dont worry man the first time i met you i asked your wife if Tim was home..
04-05-06, 07:06 PM
#33 (permalink)
Originally Posted by isotel
Thanks for the info, nice setup, Georg is sending me a nice Stacked plate style cooler.. Whats the Story on that Beefy Steering U-Joint. My Afco U-joints are Junk,only got a year of use out of them :(
It cost me $72 from steering rod to box at Tractor Supply. It is a PTO shaft. I also liked the sticker on the shaft.
Jeff Blumenthal
TLCA# 9883
KE5RST
Austin, Tx
1/71 FJ40 Dulcinea 350/700R4/NP203/TLC3SP/SO/FSR/RSR/RSHR
95 FZJ80 DeFlared, DeRunning Boarded, 33s, more to come
www.lslc.org/austin
04-09-06, 09:47 PM
#34 (permalink)
Supporting Vendor
Better Photos
1. Crossmember bolted up under the Tranny using a Poly Mount, then bushings at the frame.
2. Crossmember mount
3. Motor Mounts
04-09-06, 09:50 PM
#35 (permalink)
Supporting Vendor
Tranny Cooler Mounted
tranny cooler mounted up, (thanks again Orange 45)
Ford Taurus Fan all mounted up.. This thing Pulls alot of air
04-09-06, 09:57 PM
#36 (permalink)
Supporting Vendor
Rear Springs
got everything all done on the rear axle this weekend..
The Springs are FJ60 Rear Leafs Flipped and redrilled. This puts my wheelbase right over 100"
Spring hangers are made of 4x4 1/4 wall Sq tubing..
04-09-06, 10:08 PM
#37 (permalink)
Supporting Vendor
shock and brake line mounts are from AA-mfg
04-11-06, 09:42 PM
#38 (permalink)
Supporting Vendor
Tranny cooler lines
Got the tranny lines run and hooked up..
3/8 hard line, i bent it up with a HF Bender..
Put a 1/2 Flare in the end at the rubber side so it all stays snug.. i dont know what to call it, but i started to make a flare, so i got a small bubble so the rubber line dosent slip off
04-11-06, 09:55 PM
#39 (permalink)
Supporting Vendor
i decided to use studs in the T-case, but they are not long enughf to pull the t-case flush on the adapter, so i got take 2 or 3 out and use bolts..
even a ratchet strap couldint pull them flush
04-11-06, 11:40 PM
#40 (permalink)
i hope my fj comes out as good as yours. thanks for the pic of the taurus fan got my mounted to day
04-12-06, 03:22 PM
#41 (permalink)
Supporting Vendor
thx man, yea those Taurus fans fit like Gloves..
Proportioning valve is done, Just to Confirm w/ the experts, I took out the Small Black piece in the photo and replaced with the Proportioining, This is all i need to do? or do i need to tear apart the Master Cyl? 76 MC by the way
04-14-06, 08:34 AM
#42 (permalink)
I did not use a valve. The one that was in there (I have the same year) works just fine. Pre-disk brake setups - you need the valve.
I just put my rear disk brake axle on and away I went.
1996 -80
1977 -40
1963 -45
04-14-06, 03:20 PM
#43 (permalink)
Your proportioning valve looks to be set up properly.
How much snow do you see? I honestly never have a problem with the rear locking up unless it's on snow. I tend to do a quick brake adjustment in the spring and fall to let more fluid back there in the summer.
'76 FJ40, "GIR". A bigger money pit than my tuition!
04-14-06, 03:25 PM
#44 (permalink)
Supporting Vendor
cool, I will drive it in the snow a bit, only when the DOT Shuts down the city, and i go recoving stuck jeeps  but mostly just snow runs in the mountains.. not around town.. Thx for the input.
04-14-06, 10:47 PM
#45 (permalink)
Supporting Vendor
Tarus fan Wiring
After reading every thing i could on the net i came up with my own design for wiring up the Taurus Fan.. Termostat From Summit, Treaded type in the head. Relays are 40 amp Bosch..
I found a Nifty 3 relay holder at the junkyard in a Lincon.
my first atempt at a wiring diagram
04-17-06, 04:37 PM
#46 (permalink)
hey travis
looks like it comin along nicely
bwahaha
tim
04-18-06, 01:16 AM
#47 (permalink)
Supporting Vendor
LOL, yea little by little i just keep knocking things off the list.. alot of little stuff now!
Found some Treasures at the junkyard.. Driveshafts, ect.. looks like a minitruck IFS Shaft is the perfect length for my rear Shaft..
Thanks woody for figuring that out Saves me $100.. $400 more and i got a front Shaft! lol
04-19-06, 09:15 PM
#48 (permalink)
Looks Good
I so wish I would have built motor mounts like those. I hate the AA rubber bushing mounts.
Everything looks good.
J.R.
04-23-06, 06:59 PM
#49 (permalink)
Cool post! Keep'em comin.
1978 fj-40 88,000 mi. BFG MT 33x12.50's and lockrite in the rear. 4 in. HFS finally installed, a Metal Tech profile cage, and a Orion HD 4:1 waiting to be installed.
1997 Tacoma 225,000 mi.
" Woooh Pig Sooooie "
04-23-06, 07:47 PM
#50 (permalink)
The Taurus fan will definatly do the trick, but be cautious of paralleling 2 Bosche relays or any relay for that matter. There will always be a weaker one and it will draw more load than the other eventually killing both of them on such a heavy load. I found that using a thermostat switch allows a lot of temperature fluctuation and causes the fans to turn off and on to often. If you run the low side to ign and the high side to the temp switch it will keep the temps more constant. I have done this mod many times both ways and the low speed on Ign works the best for me. Also, the startup amp draw is really high even on low speed. If you are going to use a normal realy system, look at the 70A Bosche relay. These will work on low and high and will live for a long time.
My .02 for what its worth
Gary
Gary Waggoner
Golden, Co
1989 FJ62 SOA, 502 Mercruiser, ARBs Sold
1987 HJ61 SOA, Cable Locks, 39k miles Sold
1965 FZJ45 Pickup on Slee'd 80 chassis, plan B with 4.7 V8
2003 Tacoma, ARB, OME, SC, TRD Sold
2007 100 series, ARB, OME, Slee'd
TLCA 10689
LSLC 2000
Rising Sun 2007
www.powerplayracing.net
04-23-06, 08:17 PM
#51 (permalink)
Supporting Vendor
Cool, thanks for the info on the relay setup.. It seems everyone has their own expireinces with these suckers, lots of different oppinions out their. after watching your build i respect the hell out of yours  I will carry spares for now, and change up the setup as needed..
i am just dealing with tying up the loose ends.. Lots of little stuff to do all taking multiple trips to the store, ect.. Its amazing how much little bolts, gaskets, fluids etc can add up..
04-23-06, 08:31 PM
#52 (permalink)
Supporting Vendor
3rd member issues
My old 3rd was welded using woodys method
It didint hold up  .. Welds where cracked at every location, and im glad it didint come apart on my last wheelin trip..
I Figured i could use an Fzj80 Rear Gear set to go Fine Spline,  nope Denied..
overall an unsuccesfull weekend..
05-01-06, 01:55 AM
#53 (permalink)
Supporting Vendor
Fenders are Trimmed
Making some room for the added 5" of wheelbase..
My new Dog, "FJ"  he is a BullMastif
05-01-06, 02:00 AM
#54 (permalink)
Supporting Vendor
Ramshorn manifolds hooked up to the infamous Walker Y-pipe.. Sounds good, but i still need the rest
Finaly Scored a 3rd member thanks to Uncle Ben!! Fine Spline Pinnion.. Flange is from Trail-Gear.com
Pricy Parts from High Angle Driveline  32 spline Toyota Flange
05-01-06, 03:42 AM
#55 (permalink)
Sorry for the hijack but what program did you use for that wiring diagram? I've got to draw some diagrams up for work and I can't seem to find any programs that are any good.
BTW, cool build up, been watching it with interest. I like what you have done so far.
90 HZJ80 GXL, DTS turbo, 285/75R16 MTR's, 4" OME, Safari snorkel, ARB airlocker, ARB bullbar, ARB dual pivot rear bar, dual batts, etc.... SOLD
99 HZJ105R GXL standard for now.....
99 DR650SE
05-01-06, 10:05 PM
#56 (permalink)
is it time to cut on the tub  have you cut the rockers.the tub look  good.
05-01-06, 10:56 PM
#57 (permalink)
Not a total purist, but living in my part of the world its hard to see a clean cruiser get chopped up.
In saying that, your build is coming along nicely.
Rob
Come and visit us in Duncan, Vancouver Island, BC
www.raddcruisers.ca
Monday - Friday 08:00 - 17:00
05-01-06, 10:58 PM
#58 (permalink)
From what I've seen of his passenger's side, I would most definately not call it a 'clean cruiser'!
05-02-06, 12:01 AM
#59 (permalink)
Supporting Vendor
i figured i would piss off some Purist's  i can ebay the section i cut off if you guys want
i try not to let the photos of the passenger side reach the net
Finaly Got the last Piece to the PIE.. a VSS from Jags that Run..
Jeep thread on one side, Toyota on the other  and a Pulse generator to run my GM tbi computer..
This was a custom part, Dont expect it quick, but they where happy to make it for me!
05-02-06, 03:24 PM
#60 (permalink)
Hey stupid question but an directions to the VSS??? Got the same one and was wondering if I wired it up right...Thanks...
Tim Coffey
87 FJ60 SBC 350 SOA and some other stuff SOLD 5-15-07
94 80 with some stuff New to me 04-28-08
TLCA # 6947
Parts and Carb Rebuilds
http://www.marksoffroad.net
