02-20-06, 09:28 PM
| | Site Addict
| Belly up! This weekend, thanks to a prototype clocking ring from BudBuilt, I got to do what I've really been wanting to.. a flat, flush skidplate.
In this pic, you can see that the skid angles down towards the rear.. approx 2" below the frame at the rearmost edge. (There is 1" angle welded around the perimeter, that's why it doesn't look like much)
When we made the crossmembers for the transmission/skid/wrap bar/carrier bearing/etc.. we designed in this slope, to help support the skid.. Well, in order to go belly up, both of them needed to be re-made, along with a ton of other little things that took the better part of 20 hours.
But now, the skid is right against the frame - a 2" gain in ground clearance... The skid is ~36" long, for reference.
rear u-joint angles did go from 20° to 27°, but it's worth it. I might just run a regular 2-joint shaft and live with the vibes if needed, but I run a center limit strap anyway, we'll see. |
02-20-06, 10:58 PM
| | Forum Lifer
Join Date: Sep 2002 Location: Vancouver Island BC Canada
| Nice and flat, should not hook any more bolders.......
__________________ Come and visit us in Duncan, Vancouver Island, BC www.raddcruisers.ca
Monday - Friday 08:00 - 17:00 |
02-20-06, 10:58 PM
| | Tall Walkin Texas Trash
Join Date: Dec 2004 Location: 86 miles from Elwood, Texas
| Sexy. |
02-21-06, 05:40 AM
| | Forum Lifer
| Still no Moly in those axles ?  Just kidding, very cool! |
02-21-06, 05:49 AM
| | Site Addict
| I wish my belly was that flat
bk
__________________ bk
KJ4HFL
646 and repeat |
02-21-06, 06:30 AM
| | Site Addict
| Quote: |
Originally Posted by wngrog Still no Moly in those axles ?  Just kidding, very cool! | No, you're right. I really NEED some Cromo.. I'm hoping to limp this junk along until the swap later in the year. Swapping wider axles is cheaper than narrowing the rig |
02-21-06, 06:53 AM
| | THC
| Looks great! |
02-21-06, 09:03 AM
| | 250+ Club
| looks good, but I would try and protecte those bolts holding it on a little better. Possibly even wrapping the plate up the sides of the frame to bolt it to the side. It would suck to try to get it off if the heads of the bolts were all screwed up from hitting or dragging them.
__________________ Yeah Buddy
76 FJ40, H41, Orion, 33s, no flex, and two tons o' fun
97 FZJ80, locked and stocked w/ LEDs, CDL and Pin-7, ridin' dirty |
02-21-06, 10:57 AM
| | Site Addict
| Quote: |
Originally Posted by 76BigheadFJ40 looks good, but I would try and protecte those bolts holding it on a little better. Possibly even wrapping the plate up the sides of the frame to bolt it to the side. It would suck to try to get it off if the heads of the bolts were all screwed up from hitting or dragging them. | That's why i use regular 1/2" bolts instead of the fashionable flush head ones... I can just take a file and quickly restore the 6 sides enough to get a socket on 'em.
Try that with a countersink allen head when there's a burr covering 1/2 the hole..
Oh, and it's 22 1/2" to the skid, but my tires are up at ~25psi. Should be around 21 at trail pressure. |
02-21-06, 11:03 AM
#10 (permalink)
| | Site Addict
| just wondering. How much does that plate weigh?
__________________ 71fj40-350,SM465,3SPD L/C T-Case,4 WDB's,SAGINAW 83fj60 ,gay bumper i'm cereal. |
02-21-06, 01:43 PM
#11 (permalink)
| | Forum Lifer
| Rich, looks really good. I would like to do something like that with my 80.
Why not cut a v-notch out of the plate so the driveshaft could move down/up through it?
__________________ 95' FZJ80 OME med./J lift, ARB rack, ARB Bull Bar w/tmax 12,500, 35" truxus, Aussie locker-rear, Center Diff Lock, Sliders, IPOR Skid, IPOR rear bumper, upgraded slee sticker, custom dents, more to come. . .
Go 80, or go unsatisfied |
02-21-06, 02:24 PM
#12 (permalink)
| | Site Addict
| Quote: |
Originally Posted by concretejungle Why not cut a v-notch out of the plate so the driveshaft could move down/up through it? | Don't need to. 2-piece driveshaft.. stays out of the rocks (mostly). The length of a 1-piece driveshaft would be ~50" long, and would be a TOTAL rock magnet.
The 2-piece driveshaft was made by Universal Driveline in Concord, NC.. the front has something stupid like 13" of usable slip, and the tubing is .120 or .188 wall, for when it does get into the rocks.
I think the skid weighs (without all the angle for reinforcement I don't need anymore) right around 60lbs. |
02-21-06, 06:08 PM
#13 (permalink)
| | Forum Lifer
| Very cool. I wish it was a little easier to clock the 80 series cases. I would do it while I am apart.
__________________ Gary Waggoner
Golden, Co
1989 FJ62 SOA, 502 Mercruiser, ARBs Sold
1987 HJ61 SOA, Cable Locks, 39k miles Sold
1965 FZJ45 Pickup on Slee'd 80 chassis, plan B with 4.7 V8
2003 Tacoma, ARB, OME, SC, TRD Sold
2007 100 series, ARB, OME, Slee'd
TLCA 10689
LSLC 2000
Rising Sun 2007 www.powerplayracing.net |
02-21-06, 06:55 PM
#14 (permalink)
| | Site Addict
| Not trying to pimp him out, but Bud did a clocking ring for a Tacoma automatic t-case as well.. I bet if he had a donor case, he could figure something out... The man is very creative... |
02-21-06, 08:36 PM
#15 (permalink)
| | Forum Lifer
| Purchased a bunch of SS hot rod stye rounded bolts, they would slide good, they have allen heads.
Rob Quote: |
Originally Posted by Eskimo That's why i use regular 1/2" bolts instead of the fashionable flush head ones... I can just take a file and quickly restore the 6 sides enough to get a socket on 'em.
02-22-06, 05:49 AM
#16 (permalink)
| | Forum Lifer
| I am with Eskimo on this, just use regular bolts, all the rounder/recessed ones I have tried have gotten so buggered. It is easier to just get a vice grip on the regular head ones. |
02-22-06, 08:42 AM
#17 (permalink)
| | Forum Lifer
| Now how am I supposed to siphon gas from your 40 to my gas sucking 80 on the way to the Roundup if you're running on propane...?
TJK
__________________ Todd J. Kaderabek
TLCA # 9280, Fairview, NC |
02-22-06, 09:11 AM
#18 (permalink)
| | Site Addict
| instead of running bolts on the bottom, put some ears on the plate and fasten them through the sides of the frame rails, they will be exposed to less abuse there....
bk
KJ4HFL
646 and repeat |
02-22-06, 09:13 AM
#19 (permalink)
| | what he said
| And shear off/dent and break.. Most SS bolts are not quite equivilant to Grade 5....
__________________ I am kinda gay.......
I've set the bar, don't trip over it....
"Mary Poppins: In every job that must be done, there is an element of fun. You find the fun and - SNAP - the job's a game." |
