1+ ton FJ62
![]() front: 64.5" d60, yukon chromo inners/outers/kingpins, yukon 4.88, CTM, arb rear: 63" d70ff, yukon chromo shafts and 4.88, arb 4wheel discs using camaro z28 m/c. hardened high angle driveshafts fr/rr. 37" on 15x8 3.5BS 8 lug Allieds The inside has been rhinolined and we're building a rear drawer/storage setup. its been a long time in the making. she rides smooth as butter at 65-70mph and stops on a dime (or maybe a quarter ). With the extra width and heavier drivetrain, the pig is super stable compared to the stock axle SOA.still need to open the front fenders a bit, exo, rear carrier, etc. My goal is to have a bomber expedition vehicle as I plan to drive with some bros thru central america next year. hope you like
1+ ton FJ62
another poseur shot showing her private parts
1+ ton FJ62
here is one showing the width
1+ ton FJ62
and for the picture whores like me, another
1+ ton FJ62
Wow that's bad ass.
![]() What's up with the steering damper on the high steer though ??? Also what springs are you running? All in all that thing is saweet.
1+ ton FJ62
actually, the picture is deceiving because the drag link is overlapping. the steering setup is basically a stock setup, for now. i plan on going hydro assist soon, tho, so screw the dampener
the springs are ome 11s in the front and ome 1131 that I removed a leaf. |
1+ ton FJ62
[quote author=gkhal1 link=board=12;threadid=7257;start=msg60435#msg6043 5 date=1068254346]
another poseur shot showing her private parts ![]() [/quote] [glow=red,2,300]DEAD SEXY[/glow] |
Spit my last breath
Re:1+ ton FJ62
me either
#10 |
Ramblin Wreck
Re:1+ ton FJ62
me three
#11 |
1+ ton FJ62
![]() me four. don't know what's up. they've been visible for days. that sucks. i'll see if i can re-upload the pics. |
#12 |
1+ ton FJ62
![]() huh. that works. well, here are some more. i'm almost done with the dual batts. those stainlesstrays.com are real nice!
#13 |
1+ ton FJ62
still need to open the fenders some, etc... :slap:
#14 |
1+ ton FJ62
another
#15 |
1+ ton FJ62
![]() if the other images reappear. oh, well... |
#16 |
Spit my last breath
Re:1+ ton FJ62
now i see them
#17 |
Kool Arrow
1+ ton FJ62
FAWKIN DROOOOOOOOL
can you email me those full size... what did you do to them and what are tha axles out of... ie narrowned or super custome s??? kling-on@pirate4x4.com |
#19 |
1+ ton FJ62
![]() Cool!! Glad you guys like it. I'm f-in stoked. I started with a junk yard pass. side drop chevy dually d60 front that was 69.5" w/o the dually hubs. The driver's side was retubed. The pass. side knuckle was removed using heat/cooling to separate from tube. Then we tacked some perches on, set the vehicle down to allow springs to settle, and determined pinion angle. Then used heat/cooling to press knuckles back on Also re-arched the front springs.The rear was a centered FFD70 out of a ford motorhome that was 79" The driver's side was retubed and pass. side narrowed to match the offset of the splitcase. The brake m/c was replaced with 69 camaro z28 m/c (new) with 1 1/8" bore. The pedal is high and responsive as hell. Can easily lock the tires up on gravel. The trans. crossmember was knotched a bit. The front cv driveline inner and outer tube is hardened and splined the entire length for long travel. The rear cv driveline inner tube is hardened. This pic is before the front spring re-arching. 37" SSRs I'll send you some pics tonight. |
#20 |
Kool Arrow
1+ ton FJ62
[quote author=gkhal1 link=board=12;threadid=7257;start=msg61348#msg6134 8 date=1068503844]
![]() ... Then we tacked some perches on, set the vehicle down to allow springs to settle, and determined pinion angle. .....[/quote] so your not using the pumkin sprin mounts??? but 2 new welded spring mounts cool |
#21 |
Re:1+ ton FJ62
thats a beauty good job
#22 |
Re:1+ ton FJ62
Sweeeet! Very nicely done. Can't wait to hear how that setup works on the trail!
#23 | |
1+ ton FJ62
'ppreciate the compliments.
#24 |
Tank Buster
1+ ton FJ62
What have I missed? What are you running for an engine?
If you're going south for the winter you might think of putting a diesel in her. Nice rig for sure. Seems to me you could have saved big bucks by just changing out the R&P's and adding disks to the stock axles. I have a rear full floater with disks (factory toyota) in my HJ60. TB |
#25 | |
1+ ton FJ62
![]() Yeah, I reeeeeeeeeally want a diesel. Once the 3FE tires some more, I'll look into a 1HZ/HD. Still need to do some research to work out the details of the conversion. Quote:
Its like driving a completely different rig |
#26 |
1+ ton FJ62
looks great!
good job |
#28 |
1+ ton FJ62
Sweet 62! Did you get all new hard lines for the brakes or just adapt the toyota lines to that master? I ask cause I have a GM60 and 14 bolt with disc in my 87 FJ60 and my brakes suck! I mated a K30 master to the toyota booster and adapted the toyota lines and the brakes are still soft >:(making me mad!
#29 |
1+ ton FJ62
I gotta say, I never did have any love for the 60-62's but this pic is making me think otherwise! Very nice setup!
![]() Keep the pics coming and maybe I will be swayed to make the addition to the family sooner then later! |
#30 |
1+ ton FJ62
[quote author=Goebeler link=board=12;threadid=7257;start=msg69933#msg6993 3 date=1070331249]
I gotta say, I never did have any love for the 60-62's but this pic is making me think otherwise! Very nice setup! ![]() Keep the pics coming and maybe I will be swayed to make the addition to the family sooner then later! [/quote] Are you kidding me? not a fan of 60s and 62s. What are you some kinda commie or somthing We are all entitled to our opinions but that does not meen I gotta like it.
