Go Back   IH8MUD Forums > Toyota Tech Forums > HardCore Corner
Old 11-29-04, 01:37 PM   #1
TLCA# 11276
3FE, A440F and FJ-62 T-case into a 75' FJ-55?
I am thinking of putting my FJ-62 drive line and motor in my FJ-55. I have an extra 3FE+A440F+T-case and all electrical from an FJ-62 and I want to put it in my 75 FJ-55 which has no motor or tranny in it. Has anyone tried this? and if so were there any problems with clearances? frame being too narrow? or anything else that you ran into? Can I set it up like the FJ-62 or do I need to use the bellhousing mounts? Can the frame take the A440F?
Andrew
75' FJ-55
88' FJ-62
97' FZJ-80
01" TRD Taco
Aseif007 is offline   Reply With Quote
Old 11-30-04, 12:16 PM   #2
TLCA# 11276
WOW, it seems as I am the only person who has ever planned to do this. I guess I will post when I am finished.
Old 11-30-04, 04:15 PM   #3
Ramblin Wreck
CruisinGA's Avatar
I don't think you are the only one....
I know of others that were/are planning to do it, and I'm sure it has been done somewhere.
It also might take more than a day for someone with that sort of specific information to see the thread.
Sorry, I do not have any specific information that would be of help.
Bailey Quintrell
'74 FJ40--37 Irocks-32 Bolt 'Locks-SM420-ARB-XD9000i-FJ60 PS-MetalTech Cage
'93 FZJ80-DD-Part Time 4wd-locked-5" lifted-snorkel-bullbar-315 AT's
'97 FZJ80
'98 UZJ100-OEM RR locker
ΣΧ
CruisinGA is offline   Reply With Quote
Old 11-30-04, 07:50 PM   #4
Wise One
Texican's Avatar
I have the same setup going into a 40/buggy as soon as I can get to it. you can't use the bell housing mounts so you must fab one under the trans. I would be afraid eve if you could the auto is too heavy for this, frame is way strong enough......
There is a good thread over o POR now where a guy installed the motor only in a 40, hooked it to the 4 spd.
Butch
_______________
Conflict is inevitable.....
Combat is optional....
Lone Star Land Cruisers
REAL TEXAS MUSIC
Texican is online now   Reply With Quote
Old 12-01-04, 12:00 AM   #5
orangefj45's Avatar
the 55 frame can definetly take it. lotsa guys out there with domestic V8s in them with no problems.
i say go for it.
orangefj45 is offline   Reply With Quote
Old 12-01-04, 07:48 AM   #6
dd113's Avatar
I am moving that smae direction with a 3F-A440F in a 55. It will more or less drop in. You will need to cut off the old bellhousing mounts and add the 62 TC support. I am ditching the EFI for carb. The biggest issue I see is heat, the 3FE is a HOT motor. You will need to get a bigger rad but it should be a simple swap. Throttle will need to be reworked. I think I will go with the 62 pedal assy.
David Dearborn
www.urbanlandcruisers.com
Foreign Minister for life of the White Trash of the Elwood Chapter.
I collect Hello Kitty
dd113 is offline   Reply With Quote
Old 12-22-04, 10:32 PM   #7
tea LC's Avatar
go for it
Black 1997 FZJ80 ~ 146,000 ish miles
Photos
"Chuck Norris ate a Rubik’s cube and pooped it out solved."
tea LC is offline   Reply With Quote
Myspace Layouts | Books | Loans | Loan | Cell Phones
