LinkBack (5) | Thread Tools | Display Modes |
1FZ-FE engine into a FJ60
I am considering an engine swap for my 87 FJ60 and would like to keep it an all Toyota product, and like the idea of a straight 6. It seams the 1FZ-FE was the ultimate in power and tourque from the Toyota straight 6s. Has anyone done this swap that can let me know what problems need to be overcome? I would want to use a H55 transmission. Any other suggestions would be welcome as well... remember I would like to stick with a Toyota engine. Thanks.
Never done it, but anything can be done with enough time, skill or money, as they say. Pore over the factory manual and wiring diagrams. There are a lot of little solenoids, relays and ECU's for the 1FZ-FE attached on the firewall, fenders and even the interior. I'm sure not all are needed, but if you leave an essential item out, it can be annoying at the least, disabling at the worst. Swaps like this is best done with a mechanically/electrically complete donor vehicle sitting in your driveway ready to give up the parts or harness that you need.
By the way, the 1FZ-FE never came mated to an H55. Toyota has already had the H151 by the time the engine came out. You may have to make a bellhousing to fit it, or find an H151 from Specter, GScruiserparts, etc. Dave |
For the capitol outlay, may as well buy an 80.
__________________ Darren M. "There's a gigantic grey area between good moral behaviour and outright felonious activities. I call that the Weasel Zone and it's where most of life happens." -Scott Adams 02 KZJ95TDI 285 MTRs ARB Secondairs Engel Shower GPS |
First off - Australians are lucky enough to have 5 speed transmissions. In the US, we have been stuck with automatics since 1988. So, just buying an 80 Series will not get me what I want.
Secondly, when I entered this area, the subject said somthing about high cost projects, far-reaching dream projects, etc. Why would anyone replying to a project in this section be such a negitive dream stealer? |
Maybe what Darren said was you might as well as buy a whole damaged rig and harvest the parts one by one. If you ever need to go back to the junkyard for the little parts you didn't get the first time, it will add up fast. It can be done and you will be one of the first ones to do it!
BTW, TLC4x4 has done it: ![]() Dave |
The quick brown fox .....
>> BTW, TLC4x4 has done it <<
And with a S/C no less. Is that the $65k rig they put a 60 body on an 80 chassis? Kinda looks like that one to me. -B- __________________ 97 FZJ80 - Wing Nut MAF, locked, 315 Toyos, 4.88s, Slee 4", George's sliders, Slee bumpers, M12000, OBA, Outback drawers + other stuff. Transformation in progress... Sometimes you find yourself in the middle of nowhere. And sometimes in the middle of nowhere, you find yourself. |
Beowulf-
I E-mailed TLC to ask about this truck, and they did tell me that this one was made by placing a 60 body on an 80 chassis. So, I'm still looking for someone who has switched this engine into a FJ60 and married it up with a 5 speed manual transmission... |
#8 | |
Firstly, its not hard to get hold of one... Secondly, if your that concerned and put off so easily, perhaps you should just buy a truck, rather than attempt building one....... Thirdly, yes buy an 80 thats knocked around and swap eveything is easier. __________________ Darren M. "There's a gigantic grey area between good moral behaviour and outright felonious activities. I call that the Weasel Zone and it's where most of life happens." -Scott Adams 02 KZJ95TDI 285 MTRs ARB Secondairs Engel Shower GPS |
OK Shed Guy-
Please educate me as to how 'not hard' it is to get a hold of a 5 speed Land Cruiser with a 1FZ-FE engine in it. Also, it seams you just don't think building a truck is a good idea, or am I misunderstanding you? |
#10 |
well One of my friend, had maid this convertion on a 60 also a 40 its not hard if you have everything, but sorry its cannot be mate to a h55... but problably SOR have the original 5 speed for the 1fz ... here in Venezuela can find one for 480us$ with 15000 miles. with the tranfer..
__________________ FJ40 83/ARB front rear/PTO winch/35 mtr/ dual gas tank. FZJ70 97/ARB front,rear/warn 8274/ dual gas tank/headers/mtr 33 ON SALES!!!! FZJ80 94/ stock.........www.bt4x4.com |
#11 |
Pocholin-
Thank you for the info. That is good to know about the transmission. |
#12 |
Parts Shaman (per Romer)
Have you ever wheeled with an automatic?
The reason I ask is because I have used both. I prefer the auto. __________________ Original owner 93 FZJ80,locked,blown,water/methanol injected(like a WWII fighter aircraft),lifted,winched,snorkeled,slidered,Sleeed ,moneypit. Balanced on a pin head. 95 FZJ80 trail truck (hers), 94 FZJ80 320K with a knock and a lumpy old Dodge car.
#13 | |
I looked at doing this swap in my FJ40 a few years ago. I had found a rolled 1996 FZJ80 with 110,000 miles on it that I wanted to use as a donor for $5800. I then started doing research. I called SPector, and found out that the H55 tranny would not bolt behind the motor, you needed an H151. It also has it's own t-case. You needed a specific FLywheel, TO fork, TO bearing, clutch master and slave cylinder, and bellhousing. All of these things were available, and could be had, but it would be about 4-6 months before they could be delivered (MArv was bringing them over in a shipment from Australia, along with other goodies). Then I asked how much. Well, the bill from Spector was going to be nearly $6500. But that included rebuild kits for both the tranny and t-case, new slave cylinder, bearing and clutch kit as well as the pedal, clutch master, and hydraulic lines (this was a kit to put a manual into a NAS FZJ80), and low mileage take out H151 and t-case. (my choice full time or part time!) From there I was going to need a new radiator, motor mounts, custom PS lines, rad hoses. Not to mention all of the other nickel and dime BS that was going to be needed for such a conversion. In the end I decided that I would probably be money ahead by simply ripping the body off of the 80 series, and building my own FZJ-45 troopie, and retaining the AT (autos are NICE to wheel with, by the way). Well, I lost my job about the time I was going to do this, and so I never went through. Personally, I think that you would be better off getting a rolled 80 series, and putting your FJ60's tub on the frame. |
#14 |
Guest
Posts: n/a
Put in a 12-ht or 13-bt motor. G&S can or does have them. It will bolt up to a h55 and is a direct fit into a 60. Do a little work on the motor and you will have more than enough power and torque with alot less hassle.
#15 |
Former Wheeler
I'd just put in an auto. Better yet, just put the 60 body on the 80 frame. Then you get coils as well.
__________________ War Pig and the nameless 45lv "Don't you know, Stan, it's always between a Giant Douche and a Turd Sandwich." |
#16 |
Cruiserdan-
I have had the auto vs. stick discussion with many of my friends over the years. I admit that there are many legitimate reasons to opt for the automatic over the stick especially when four wheeling. But, I think that mostly it just comes down to personal preference and I happen to prefer the stick. I think that most of my rational for preferring the stick comes from regular driving (not from four wheeling) where I find driving an automatic just really boring. But, that is just my opinion. Burger- I am open to putting a diesel in the truck, but the specs on the 12HT engine is only 135 HP which is the same as the 2F that is in there now. I wouldn't want to go through the effort of an engine swap, only to end up at my starting point as far as HP. You spoke of doing some things to the engine to end up with more HP and torque... how much more HP are we talking about? |
#17 |
Tigerstripe40-
That is the kind of info I have been looking for. Thank you very much for that. Just a few questions: what necessitated getting a new radiator? Do you think a swap into a 60 would still require a new radiator? I assume most of the cost of SOR bill would have been for the transmission and transfer. If I can get a H151 with transfer from Venezuela for $500 (and I don't rebuild them before install) how much more do you think I would spend for the other stuff I would need? |
#18 | |
grown up MOD
Agreed..................but good luck, would be a fun project. __________________ "If it wasn't a Landcruiser and hadn't been built the way it was you do realize you would be DEAD." VA State Police Officer |
#19 | |
#20 | |
That said, the FJ60 radiator would probably work just fine, as it's wider than an FJ40 radiator. Most of the SOR bill was the Tranny, Transfer, and bellhousing. But the other parts aren't inexpensive either. ALot of the parts you will need can realistically only be sources from Spector. You can get other parts from your Toy dealership, but be prepared for sticker shock, long waits, and parts counter guys throwing their arms up in frustration. As far as getting a tranny/t-case from South America, I would not make the mistake of not rebuilding and inspecting it beforehand. In other parts of the world, Land Cruisers are generall driven --->HARD<---. That $500 venezualen tranny may only have 40,000 miles on it, but if it came out of a mine truck (most likely with that few miles) it will have led a VERY hard life. I think it VERY unwise to not rebuild the tranny before putting it in your DD. Also, if the tranny you got from SA needs anything but bearings and seals, you are pretty much up a creek without a paddle. Gears, and shafts for an H151 aren't readily available in the US. They CAN be obtained, but they will cost lots of $$$. OK, now that I am off my soapbox, I will tell you what I figured out from the research I did. 1. the 1FZ-Fe -H151 is a cool combo, however, you will be dealing with a transmission with an unknown history, with parts that are unobtainium. 2. A 3FE-H55 woudl be a better choice. -a. primarily, because the engine aned transmission will BOLT RIGHT INTO the truck. -b. you;ve got most of what you need already sitting there (bellhousing, flywheel, t-case, etc) -c Parts are MUCH more easily obtained in the US. -d you get fuel injection. 3. IF you need more power than a 3FE has to offer, you are money ahead to get an EFI Chev 350 V8. Mate it to an NV4500 with an AA to the t-case you already have. If you know people in junkyards, and can do the work yourslef, you can do this for 1/3 - 1/2 the cost of the 1FZ-FE H151 T-case. 4. If you want a 1FZ-FE keep it mounted behind the Auto transmission. If you want part time t-case, get the kit to change it to part time. In light of all oif this, I know, it's a bitter pill to swallow., I am DREAMING of putting a 1FZ-Fe into my FJ40. Now that I know that a Crawl box is available for the 1FZ-FE A442 combo, that would make me more likely to put this in my own truck. I really hope this helps. -James |
#21 |
That helps a great deal... Thank you for you suggestions.
#22 |
"It also has it's own t-case."
I am installing a 1FZ in my 55 with an H150F. The trans is floating here soon. I have been told the transfer from the auto would bolt up. What is the difference? Definitely buy a whole wrecked 80 and part out the rest to recoupe It is nice to have the vehicles side by side for the swap __________________ '94 FZJ80 e-lockers DD with black powdercoated wheels and mucho tree rash '91 FJ80 Project Truck, goin' diesel Lots o' 80, 62, 60, 55 parts! TLCA#12336 Jeepster Commando, mostly Toyota |
#23 |
tiger,
not to nit pick on you but the conversion kit for the part time 4 wheel drive ( from marks in aus ) is only available for the 91-92 model 80 series. not the fzj (93+) the earlier trucks use a spider gear set in the transfer. the laters use a viscous coupler. So if you get the older model transfer then you also have the 3FE wich while a slightly more powerful than your 2F will still have the issues of mating to the trans. There are a few of the 80 guys running with a manually locked cdl and lockouts on the front end, however this entails dropping the driveline most of the time so It can be a royal pain in the neck. this gets you into the 1fz motor but not really a selectabel transfer case. FWIW, I would love to see a rolled fzj with e lockers decorated like a 60. coils are good and Christo Slee and co. are doing some cool things as far as springs and caster correction. I know it gives you the sluch box but having coils instead of leafs seems a small price to pay. Dave __________________ "The time has come" the Walrus said," To talk of many things.." In the Trees.... OH 80 fj40, 2.5 OME Dakaar springs, 33" bfgs. "Charlie Brown" 88 fj62 Bone stock, Wifeys snow cruiser "Moby" |
#24 | |
I drove a Venezualan spec FZJ80 with a EFI 1FZ-FE automatic trans and PART TIME transfercase. When I did my research, I was talking to Marv at Specter offroad. He was telling me that the only H151 transmission availabe was part time, I guess that is what he had in stock at the time. |
LinkBack to this Thread: http://forum.ih8mud.com/hardcore-corner/26480-1fz-fe-engine-into-fj60.html
| Streetracing.pl - Drag, Drift & Time Attack > Toyota Hilux 4WD 88r - jaki silnik?? | This thread | Refback | 06-29-08 05:23 AM | |
| Toyota Hilux 4WD 88r - jaki silnik?? - Streetracing.pl - Drag, Drift & Time Attack | This thread | Refback | 05-19-08 12:19 PM | |
| Toyota Hilux 4WD 88r - jaki silnik?? - Streetracing.pl | This thread | Refback | 01-27-08 02:44 PM | |
| fj80 5speed?'s - Pirate4x4.Com Bulletin Board | This thread | Refback | 12-29-07 12:55 PM | |
| www.streetracing.pl :: Zobacz temat - Toyota Hilux 4WD 88r - jaki silnik?? | This thread | Refback | 12-17-07 06:36 AM | |
