Go Back   IH8MUD Forums > Toyota Tech Forums > HardCore Corner
Old 05-21-08, 04:36 PM   #1
Tapage's Avatar
2UZ Key and Speedo
Hi guys .. I'm in the process ( helping really ) to swap a 2UZ onto 80 series with a H150 or R151 tranny ( manual )
Now I get the engine .. but have few question, maybe someone can help me here ( promise pics this weekend )
1. Those engines ( ECU ) need the factory key to start ?
2. It's the acelerator ( pedal ) an electronic device ( potenciometer ) ? I have other option to run the skiny pedal ?
thanks .. !
HJ-60 2H-T Intercooler Tencha
Originally Posted by pygpen
Old 05-21-08, 07:27 PM   #2
fj40peru's Avatar
thanks .. !
Im doing the same convertion in a FJ62... Please Help us... the Engine is araiving to Peru in 1 month, but I need to Know how to start it!!!
THX
=== FJ40 84 ===
===FJ60 81===
===FJ25 56===
www.LandCruiserPERU.com
fj40peru is offline   Reply With Quote
Old 05-22-08, 11:38 AM   #3
Tapage's Avatar
THX
Que tranny tienes pensado usar .. ?
Are you selected a tranny to use . ?
Old 10-06-08, 06:33 PM   #4
Tapage's Avatar
Hey guys .. I'm still in the road with this swap .. ( involved in other proyects too ) I'm dealing with the gass pedal that looks to be easy to solve with any Toyota DBW gass pedal and harness ..
But there is a issue with the ECU ( ECM ) that looks if I don't have the cilinder with the right key don't gonna start ..
So I'm searching for tracks and recomendations on why can help me with the Electronics on this unit ..
Apreciated any advice ..
Old 10-07-08, 03:13 PM   #5
Incredibly random
Rix86's Avatar
Getting a non-transponder ecu might be the easiest... unless you can get the correct transponder key.
What year engine are you working with here?
Rix86 is offline   Reply With Quote
Old 10-07-08, 04:11 PM   #6
Tapage's Avatar
Thanks Ric ... 2UZ out from a 2003 Tundra ( non VVTi ) .. can you share some direction to search for this ECU .. if it's simplest ECU to me it's better ..
I read in the UZswaps forum that this engine only need a few cables and sensors to run ..
Old 10-07-08, 09:56 PM   #7
Incredibly random
Rix86's Avatar
I'll try to remember to look and see what's what tomorrow...
Old 10-08-08, 01:24 PM   #8
Tapage's Avatar
Thanks dude .. I'm still searching on eBay any tundra or cruiser that's been in partingout session, with luck I can source the complete combo, cilinder, key and ECU ..
Old 10-10-08, 06:41 PM   #9
sleeoffroad's Avatar
Tapage, you do not need a pedal. All the drive by wire is inside the throttle body. The pedal is a simple cable to the throttle body.
Christo Slee
www.sleeoffroad.com
2002 Turbo Charged 100 Series - $23000
sleeoffroad is online now   Reply With Quote
Old 10-10-08, 08:07 PM   #10
Tapage's Avatar
but if you saw here ..
There is no cable out from the gas pedal .. so at the TB of the engine there is only a plug ( that goes to the main harness ) ..
your help it's higly apreciated Christo ..
Old 10-10-08, 09:09 PM   #11
Incredibly random
Rix86's Avatar
the late-ish ones used no cable at all....
I have the manual at work, forgot to bring it home...
I'll try to get some info for you tomorrow, sorry.
Old 10-10-08, 09:16 PM   #12
Tapage's Avatar
that's ok Rix .. will await for your info ..
Old 10-16-08, 04:49 PM   #13
ToyotaDon's Avatar
<picture>
That is right, on 2003 and newer there is no throttle cable. It looks like you have that part figured out, David (I sent you an email some time back showing that.)
Now, I'm trying to figure out if the 2003 Tundra had the immobiliser system or not. Can anybody with an '03 Tundra verify that they have a "fat" key.
There are thieves out there who know how to bypass it, because I've seen the results. The only way I know how to make it work is the way Toyota designed it.
I'll get back to this.
Donal
Originally Posted by fish2live View Post
Where have you been??
Thanks TDon - stick around and help for a bit, won't you?
Originally Posted by tcb View Post
Thanks!
ToyotaDon is offline   Reply With Quote
Old 10-16-08, 05:24 PM   #14
Tapage's Avatar
I was searching on the web plenty about that .. with not definitive answer for my question, so I only gotta waste some money and buy the 2004 ECM, steering column with a valet key and give a try ..
There is a Guy in Kenya that said for 1k bucks can re write the ECM to work with a RAV4 key and starter cilinder ..
Old 10-18-08, 10:39 AM   #15
Incredibly random
Rix86's Avatar
Sorry tapage, I was sick all week.
If I make it to work today I'll take a looksie.
There's got to be a better way.
If you have a non vvt engine, I'd imagine you could swap the electronics and throttle body to a little older model.
Old 10-18-08, 10:22 PM   #16
Tapage's Avatar
yes dude ... mine it's a non VVTi engine .. ( thought they start from 2005 and on ) anycase I will report the process and how it's all going here with the swap ..
wish me luck !
Old 10-20-08, 03:46 PM   #17
ToyotaDon's Avatar
...so I only gotta waste some money and buy the 2004 ECM, steering column with a valet key and give a try ...
Does your current ECM happen to say "Immobilizer" on it? If you know someone at a Toyota dealership, they can reset the ECM to accept any immobilizer key as long as the cylinder, etc. is correct. You wouldn't need another ECM that way.
Since I'm no longer at the dealership, I can't access all the Immobilizer information, they have quite a bit available. One thing is a chart of what vehicles have which system and whether they can be reset without a master key. The other is a bulletin about an ECM replacement program, where Toyota sends the dealer a remanufactured ECM at no charge, and you just pay the labor to install it and program 2 new keys.
Hope this helps.
Donal
Thanks!
Old 10-20-08, 04:35 PM   #18
Tapage's Avatar
Hope this helps.
Helps a lots ... I don't have any contact at USA dealer ( useless any contact down here ) I know there is to be a way to re flash .. just did'nt found any contact to do that .. at least not yet.
Actually I thought there it's must be a way to let the ECM with the security inmobiliser desactivated .. ?
Old 10-20-08, 07:03 PM   #19
ToyotaDon's Avatar
The vehicle would actually have to be at the dealership for the reset to work.
I also recall there was an aftermarket tool available for this. I believe a customer had a locksmith try to reset theirs and ended up causing more problems. You may want to check with a reputable locksmith, also, since they could come to where the vehicle is.
Donal
Thanks!
Old 10-21-08, 04:00 PM   #20
Tapage's Avatar
seems to be little complicated go with the vehicle to the place ( dealer ) even if one here in Panamá can do that ..
I can't believe there is no aftermarket flash procedure for those ECM .. much more if you proove that isn't a stolen vehicle ..
Old 10-22-08, 02:34 PM   #21
ToyotaDon's Avatar
Okay, I called a guy I know at the dealership and he looked it up for me. In the USA, the Tundra did not have a factory starter interruptor (immobiliser) system until at least 2006. However, the Sequoia did have immobiliser available much sooner, as early as 2003. Is it possible you have a Sequoia ECU? Could you post up what the ECU part number is? We can look it up on http://www.toyodiy.com/parts/ if we have the VIN or Model Number (example: UCK31L-PRSLKA).
It's still possible you are dealing with another issue here. If so, could you describe the symptoms and we can recommend some things to check?
Donal
Thanks!
Old 10-22-08, 05:17 PM   #22
Tapage's Avatar
here is the ECU part number .. and come from a 2004 Tundra ..
89661-0C390
Old 10-22-08, 07:16 PM   #23
ToyotaDon's Avatar
The picture you posted in Chat shows a non-immobiliser key. It's bare metal, no rubber/plastic to house a "chip."
You should not need to worry about this system getting in the way of starting the truck. What is happening when you try to start it with the 2003 ECU connected, or do you not have this ECU?
It will be hard to look up the correct part # without knowing the model number, there are 53 different model numbers for the Tundra.
Donal
Thanks!
Old 10-22-08, 08:28 PM   #24
Incredibly random
Rix86's Avatar
parts computer is showing a bunch of ecus for 03, but no notes about transponder (immobiliser) or non....
As stated above though, that metal key isn't a transponder key....
Old 10-23-08, 06:12 PM   #25
