toyota axles- floating vs. non-floating
i am slowly making plans and starting to accumulate parts to 4-link the rear of my fj40....part of that plan for me is to put a wider and hopefully stronger rear axle in place of my fj40 rear.....i am bound and determined to keep my rig toyota axled and i really don't care if it costs more........so i guess the main question that i want to ask is if a full floater axle holds up any better than semi-floating? i understand the differences between the two and the advantages that the floater has, and i know that the axle shafts are no bigger in diameter than in the full floater. i also know that some axles just have an intrinsic ability to take a beating better than others (like the mini-truck rear) do any of you have in your rigs or know of folks running 60 series full floaters and how are they holding up compared to semi-floaters?
60 series full floater- with which i could reuse my 3rd member, i would upgrade studes and dowels and plan on sending my r&p and axle shafts to longfield for treatment and no i don't want a freaking 14 bolt lol __________________ This is your life, and it's ending one minute at a time... '71 FJ55 '74 FJ40 Last edited by mookie; 05-15-08 at 11:58 AM. Reason: bad grammer |
oh and also what about fzj80 rears? could i use my fj40 3rd member in one of those? are they considered to be any stronger than the older rear axles? would the centered chunk give me driveshaft problems?
__________________ This is your life, and it's ending one minute at a time... '71 FJ55 '74 FJ40 |
KI6MIE
You could use an 80 rear and your 3rd. It's wider than a 60 axle and has disc brakes. With poly axle shafts, it's fairly strong. Not a bad choice. It's not centered, by the way. It's PS drop like all cruisers.
If I were building a super hardcore rig, I think I'd look at a stronger axle, though. A custom D60 comes to mind. __________________ Andrew 1971 FJ-40 Rubicon tested, 2F powered, some mods 1976 FJ40 Rusting slowly in the back yard 1984 FJ-60 H55f, 4.11, OME, Daily Driver 1989 FJ-62 117k-son's driver for now-low and slow 1997 FZJ-80 Driveway queen |
Or maybe a ford 9" ..
But talking about Cruiser axles .. I don't think that the FF it's really much more strong that a SF axle .. taliking about 40 and 60 axles .. coz I broke my longer shaft on my SF with 37" and 2 mates broke a FF with 33" and other with 35" I thought it all depends on care of the FF more things to care BTW .. but definatelly an advantage to have a FF .. At least IMOP .. it I would go with a hard core rig .. FF without doubt .. and if I can afford a 80 series FF much better ... |
isn't there an issue with the 80 series disk brakes not fitting wheels under 17" or something? i've got 15" beadlocks with 2" backspacing....can you change out the rotors to a smaller ones or anything? as wide as those axles are i don't think i would want to run wheel spacers...
edit....apparently you can grind the calipers a couple millimeters to make 15" wheels fit __________________ This is your life, and it's ending one minute at a time... '71 FJ55 '74 FJ40 Last edited by mookie; 05-15-08 at 12:00 PM. |
#6 | |
KI6MIE
Stock wheels are 16, I don't know about running 15s. __________________ Andrew 1971 FJ-40 Rubicon tested, 2F powered, some mods 1976 FJ40 Rusting slowly in the back yard 1984 FJ-60 H55f, 4.11, OME, Daily Driver 1989 FJ-62 117k-son's driver for now-low and slow 1997 FZJ-80 Driveway queen |
Id say Full Float (Toyota Parts) is a Disadvantage for a 40.. Just more Stuff to Break. the full float guys are sheering off the Pins/Studs.. Id rather just carry a Spare Semi Float Shaft. with my Rear Axle the Right and Left Sides are the same so it works out just fine!
I did manage to Twist the Splines on a mini truck shaft, so im going to need to look for something stronger pretty soon. Maybe a 14 Bolt
__________________ 1976 FJ40 TBI350 700R4 D300 SOA Locked 37" PBR's Protected by REDLINEColorado Land Cruisers - Club Redline Land Cruisers - Safety First CrAwLoRadO.com - Just Check it out
arent my best option .. here is a mate that do it and add wheel spacers without problems right now. Maybe smallers calipers should be a option .. ?
Admin
yeah, I'm a fan of the stock semi-float Toyota stuff.....IMO, the only reason I'd switch to a fullfloat toyota is weight carrying....don't much need that in my FJ40.....
__________________ Brian 'woody' Swearingen |
#10 | |
I too have been looking the options I have of upgrading the 60 series diff in my truck build-up. What I figured out (which may not suit everyone) was my best option is the following: 80 series housing, axles, brakes and hubs. 60 series chunk (or 40, 45, 70, 75 serieschunk), ( I am 99% cerain it will fit, I have measured everything offered 80 series axles to it, and even bolted opposing driveshafts to it, the only thing I have not checked is offerign the chunk up to th diff housing). 60 series detriot locker whatever gearing is chosen (I will be using 4.88 R&P). This is somthing I have been looking into for a while and this is a thread link I have from another forum. DARWIN4X4.NET - THE TOP END'S 4X4 ONLINE COMMUNITY :: View topic - your ultimate 80 diff? Cheers Davo __________________ Thanks friend but I'm not calculating anything. Im just going on the "if I can get it to fit" calculator You don't need adaptor plates. That's what gaffer tape was invented for. |
#11 |
Young and Dumb apparently
80 series FF? If so, must use FF chunk (40/60 series FF should work), use Poly Performance axle shafts, and ARP studs, Aussie Locker (cheap, and STRONG), stock 80 rear brakes clear 15" wheels w/o grinding if 2.XX or less back spacing, so 2" will clear for sure, so whatever you want to do there.
__________________ '92 - 3FE POWER'D! -- Slee 6"/OME 863J, Pro-Comp 14" ES3000/N74L, Gen. 2 Slee Front Control Arms, T-G Sliders, Ext. Diff. Breathers, Slee SS Brake Lines, 5.29s, Aussie Locker'd rear, 35" TrXus STS Street/38.5x11 Boggers Trail, 180k. '85 Honda Accord - 55MPG!!! -- No air filter, Custom Burple (blue and purple) Paint. Upstate Cruisers |
#12 |
The Anti-Leafer
The new Tundra is what you may need to consider & per this thread:
http://forum.ih8mud.com/hardcore-cor...-5-w-pics.html you'd need to find out if there is a 4.88, or whatever you're running, ratio available. It also says an ARB is in the "works". At this point, I'd send CTM one of the ARB side gears so he can custom spline a pair of 4340 SF shafts for it. If you want to take another baby step, cut off the ends & use Dana 60 or 14 bolt spindles, buy 6 lug hubs for either, then have CTM rebroach the ARB side gears for 35 spline & run SF or FF, your choice. You're runnin on borrowed time for the front diff. Good luck there
__________________ '73 FJ55 http://forum.ih8mud.com/fj55-iron-pig-preservation-society/76835-pig-chebby-avalanche-trim-%3D.html '73 FJ40 http://s132.photobucket.com/albums/q...&addtype=local '78 FJ40 - future crawler in pieces '93 Ram W350 5 spd. SRW CTD '99 Ram 3500 4X4 5 spd. DRW CTD '74 BMW 3.0CS future project
#13 | |
#14 | |
KI6MIE
Huh? Same splines. You can run a semifloat 3rd in a FF axle. You can't run a FF 3rd member in a semifloat axle since the side gears would not have the relief for the c-clip. __________________ Andrew 1971 FJ-40 Rubicon tested, 2F powered, some mods 1976 FJ40 Rusting slowly in the back yard 1984 FJ-60 H55f, 4.11, OME, Daily Driver 1989 FJ-62 117k-son's driver for now-low and slow 1997 FZJ-80 Driveway queen |
#15 |
yeah mate also some of the SF have the 10-splines.
#16 |
what he said
Not since like 1969 or so...
__________________ I am kinda gay....... My Myspace http://profile.myspace.com/index.cfm...endid=75712409 "Mary Poppins: In every job that must be done, there is an element of fun. You find the fun and - SNAP - the job's a game." |
#17 |
Learned something new today...
Coupon | Mortgage Calculator | TV News | Cheap Car Insurance | US Business Directory |
