Go Back   IH8MUD Forums > Toyota Tech Forums > HardCore Corner
Old 09-10-04, 07:33 AM   #1
milesstarkey's Avatar
minimum rollcage tube size
i'm going to build a custom cage, and wondering how small would still be safe?
milesstarkey is offline   Reply With Quote
Old 09-10-04, 07:37 AM   #2
Admin
woody's Avatar
TLCA# 1548
for the A-hoop, B-hoop, and two outside stringers, 1-3/4 x .120 wall DOM is the minimum....you could consider 1-1/2", but I'd only do that if your rig will end up in the 3500# or less range. If you do a C-hoop family cage, then keep it .120 as well...if just straight bars back from the B-hoop, .095 1-3/4 is fine.
For any hoop v-bars, seat mounts and such, 1-1/2" x .120 or .095 works well....I'd keep .120 overhead tho, .095 dents a bit too quickly (BTDT)
Personally, I'd stick with DOM for material too...good strength to price ratio, CroMo is boo much $$$ and HREW/CREW is a bit under strength for me....
next opinion??
Brian 'woody' Swearingen
1974 FJ40 'The Raisin' - Pitbull Rockers, 30-spline Longfields, SOA - 1/4 ellip
1996 FZJ80 'Gretchen' - MetalTech, ARB, OME, IPOR, 4x4Labs
2003 2500HD Duramax - Edge/Juice/Attitude, 285 Nitto Terra Grapplers, 4" exhaust
Forum Questions? Click Here!
'America will never be destroyed from the outside. If we falter and lose our freedoms, it will be because we destroyed ourselves.' Abraham Lincoln
Old 09-10-04, 08:37 AM   #3
what he said
Mace's Avatar
Woody is right, although I see no reason to stray from Hrew..
The strength increase is not that great..
I am kinda gay.......
My Myspace
Old 09-10-04, 10:51 AM   #4
In saying the DOM would make a good cage at 1 3/4 with .120 wall, what would a tube chasis be built with?
Would be cool to have a coloured cage in the Tech section with heading showing material choices, dimensions, wall thickness.
And add lower links along with it with vehicle weights.
Come and visit us in Duncan, BC
www.raddcruisers.ca
--> 60 Series Cable Lockers available - 4.11s or 3.70s - handles and cables included
--> in stock and ready to go.
Old 09-10-04, 11:58 AM   #5
Former Wheeler
Gumby's Avatar
TLCA# 5658
I thought the big reason to stay away from HREW is just the difficulty in bending it.
War Pig and the nameless 45lv
"Don't you know, Stan, it's always between a Giant Douche and a Turd Sandwich."
Gumby is offline   Reply With Quote
Old 09-10-04, 12:03 PM   #6
Admin
woody's Avatar
TLCA# 1548
tube chassis can actually get away in some cases with smaller diameters, since the weight usually runs in the 3000# range. hard part in a tube project is ensureing the wall thickness of some of the lower mount points is enuf...almost need .250 in some places to keep things from tearing thru.
Old 09-10-04, 01:47 PM   #7
what he said
Mace's Avatar
Most cages are built from HREW
It bends just fine. You just usually have to make sure that the seam is on the INSIDE of the bend..
My Myspace
Old 09-10-04, 02:58 PM   #8
Can someone expalin me waht is HREW???
BJ40 3B is offline   Reply With Quote
Old 09-10-04, 03:00 PM   #9
cruiserrg's Avatar
For my entire chassis I used (no weight yet as I am not done, but will be heavier than a comp rig):
1.75"OD 0.120wall DOM 1020 mild steel for chassis frame, cage, and upper links
2.00"OD 0.250wall DOM 1020 mile steel for lower links
1.25"OD 0.120wall DOM 1020 mild steel for window tubes
1.00"OD 0.120wall DOM 1020 mild steel for gussets
Now if I was going to make it again and lighter I would use 1.50"OD 0.120 wall DOM 1020 for the six point cage and frame rails, and then 1.50 and 1.25" OD 0.95 wall DOM 1020 for everything else.
If I was going for ultra light weight (like a comp rig single seater):
Chromoly alloy steel A 519 grade 4130 1.50” OD with .090 minimum wall for roll cage and chassis
Chromoly alloy steel A 519 grade 4130 1.00” OD with .083 minimum wall
Solid 1.75"OD 7075 T-651 aluminum for upper links, and Solid 2.00"OD 7075 T-651 aluminum
Reuben Gosewisch AKA: cruiserrg
http://webpages.charter.net/cruiserrg
Pics of my Tree Stand or otherwise known as my Tube Chassis rockcrawler project: http://webpages.charter.net/cruiserr.../toypuproject/
cruiserrg is offline   Reply With Quote
Old 09-10-04, 03:51 PM   #10
what he said
Mace's Avatar
hrew = hot rolled electric weld
Dom is just HREW that has been passed through a mandrel to make it consistant.
My Myspace
Old 09-10-04, 03:52 PM   #11
Former Wheeler
Gumby's Avatar
TLCA# 5658
I'm sure there are those who know better, but my understanding is that it is Hot Rolled Electric Welded, meaning it is flat hot rolled steed formed into a tube and welded electrically. It has a seam that is difficult to bend.
Old 09-10-04, 06:50 PM   #12
cruiserrg's Avatar
One thing to consider in the discussion of HREW and DOM is the properties (and the fact the HREW you buy at suppliers is usually 1010 and not 1020):
1020 DOM STEEL TUBE
1020 is normally used in the manufacturing of small-diameter or thin-wall DOM steel tube. DOM is formed from strip and electric-resistance welded, then cold drawn to size. The cold drawing process causes the weld line to virtually disappear.
American Specifications: ASTM A513 Type 5
British Specifications: 040 A 20, 070 M 20
Applications: Mechanical, hydraulic cylinders, shaft, tight tolerance requirements
Size Range: 1/4" - 14&1/2" (6 mm - 368 mm) OD; .035" - .625" (.9 mm - 16 mm) wall
Typical Chemical Analysis: C .15-.25
Mn .30-.60
P .040 max
S .050 max
Typical Mechanical Properties: Tensile strength (ksi) 80
Yield point (ksi) 70
Elongation (% in 2") 15
Rockwell hardness RB80
1018 COLD DRAWN AND HOT FINISHED SEAMLESS TUBE
1018 is normally used in the manufacturing of cold drawn and hot finished seamless tube. The production of seamless tube is generally made by piercing a hot rolled bar. Hot finished is generally furnished in the unannealed condition, whereas cold drawn seamless is supplied in the unannealed or S/R annealed conditions, depending on the size.
American Specifications: ASTM A519
British Specifications: 070 M 20, 080 A 15
Applications: Axles, shafts, gears, bearings
Size Range: 1/8" - 24" (3 mm - 610 mm) OD; .0218" - 3.00" (.6 mm - 76 mm) wall
Typical Chemical Analysis: C .15-.20
Mn .60-.90
P .040 max
S .050 max
Typical Mechanical Properties: CDS HFS
Tensile strength (ksi) 80 60
Yield point (ksi) 60 35
Elongation (% in 2") 15 30
Rockwell hardness RB88 RB60
1010 ELECTRIC WELD STEEL TUBE
1010 is normally used in the manufacturing of electric-resistance welded tube. The product is available normally in cold rolled strip (16 gauge and lighter), and hot rolled strip (.083" wall and heavier). The product can be obtained in the as-welded condition (flash-in) or in the flash-controlled condition.
American Specifications: ASTM A513 Type 1 and Type 2
British Specifications: 040 A 10, 045 A 10
Applications: Machinery stands, exhaust tubes, handles, hand rails, display stands, conveyor rollers
Size Range: 1/4" - 10" (6 mm - 254 mm) OD; .028" - .375" (.7 mm - 10 mm) wall
Typical Chemical Analysis: C .08-.13
Mn .30-.60
P .035 max
S .035 max
Typical Mechanical Properties: Tensile strength (ksi) 45
Yield point (ksi) 32
Elongation (% in 2") 15 min
Rockwell hardness RB55 min
1026 STEEL TUBE
1026 grade is normally used in the manufacturing of DOM, cold drawn seamless and hot finished seamless. This grade normally furnished over 2" OD, with walls heavier than .156". A variety of thermal treatments can be supplied, depending on the type and size of material.
American Specifications: ASTM A519 (SMLS), ASTM A513 Type 5 (DOM)
British Specifications: 070 M 26
Size Range: 1/8" - 24" (3 mm - 610 mm) OD; .028" - 3.00" (.7 mm - 76 mm) wall
Typical Chemical Analysis: C .22-.28
Mn .60-.90
P .040 max
S .050 max
Typical Mechanical Properties: CDS DOM HFS
Tensile strength (ksi) 87 80 70
Yield point (ksi) 72 70 47
Elongation (% in 2") 10 10 28
Rockwell hardness RB89 RB85 RB78
The above was from a thread on pirate4x4.com http://www.pirate4x4.com/forum/showt...ight=hrew+1020
Old 09-10-04, 07:23 PM   #13
Now thats the information I was looking for......
Good work
www.raddcruisers.ca
Old 12-08-07, 09:00 AM   #14
xjnation's Avatar
I called a local steel shop yesterday pricing some HREW. He said "hold on" and I heard him ask somebody what HREW was. Time to find a new supplier.
1973 FJ40 currently frame off, getting 4.3 CFi/4L60E/NP-205 and FJ-62 power steering. SOA, 35x12.50 MT/Rs, FJ62 FDB. Brought back from the grave(traded a shotgun for it, if that tells you anything). Turning out to be a sick 40!!
Buildup Thread: ALMOST DONE!!!!!
http://forum.ih8mud.com/40-55-series...up-thread.html
Sanity is over-rated!!
xjnation is offline   Reply With Quote
Old 01-11-08, 12:15 PM   #15
chappysfj40's Avatar
TLCA# 9188
so is this why they say DOM is seemless??? the way it is constructed.
- Iam home now from the SUCK !!!!!!!
VJ60 700R4 33's 203 doubler, ARB's 4.56, OME and just a awesome truck!!!!!!!!!!
- RUBITHON 2008 TESTED
GOD ASKED FOR 10 DAYS TO CREATE EARTH, CHUCK NORRIS GAVE HIM 7..
chappysfj40 is offline   Reply With Quote
Old 01-11-08, 12:31 PM   #16
brokenparts's Avatar
TLCA# 16127
I called our local steel yard here to get some pricing on DOM and HREW. His first question was why DOM? I told him I was thinking about building some armor or cage for my 60. He said he'd be happy to sell me the DOM but there really was no reason for th DOM unless it I was running an axle through it or was in a Race Car application. If its a questionable area I would run DOM but I see plenty of cage applications where people have no problems with HREW.
brokenparts is online now   Reply With Quote
Old 01-11-08, 01:00 PM   #17
what he said
Mace's Avatar
Yea, but DOM does have a seam..
And brokenparts has it. DOM is nice but lots of safe cages out there are made out of HREW.
My Myspace
Old 01-11-08, 01:59 PM   #18
TLCA# 9188
yes, but is it a seem but commonly refered to as seem less?
Old 01-11-08, 02:30 PM   #19
In the garage
John Smith's Avatar
TLCA# 9074
I am curious as to the price difference between the two per foot?
79 FJ40 & 78 FJ55
John Smith is offline   Reply With Quote
Old 01-11-08, 02:55 PM   #20
TLCA# 16127
HREW commonly sells for about $3 a foot and DOM $6.50 a foot.
Old 01-11-08, 03:29 PM   #21
Isotel's Avatar
TLCA# 16898
Red line's Circle Track Cages are all HREW .095, That is the Standard for the Racing Circuits that use our Cages..
on our 40 cages we will be going with .120 HREW with a DOM Upgrade option.
Remember that Cage Design, Gussets, and Triangulation are more important than the DOM vs Hrew Debate..
1976 FJ40 TBI350 700R4 D300 SOA Locked 37" PBR's Protected by REDLINE
Colorado Land Cruisers - Club
Redline Land Cruisers - PM me for info on our products or to order!
CrAwLoRadO.com
Old 01-11-08, 07:34 PM   #22
I'm currently building my internal cage out of 1.75" .120 wall DOM. I paid $3.95/ft here in the Seattle Jan of '08. The best price I could find on HREW was $2.95/ft.
muddogbob is offline   Reply With Quote
Old 01-11-08, 08:24 PM   #23
TLCA# 16127
wow u got a smoking deal...
Old 01-11-08, 08:39 PM   #24
80s muncher
2badfjs's Avatar
Hmmmm, i get my 2" HREW in 20ft sticks .120 wall for just under $40. which is $2. per foot.
but, if you look at your invoice, the steel shop should have a weight on it. this is really how steel is sold.
so if a 20ft x 2" x .120 tube runs $40. and weighs 40lbs, $1.00 per lbs.
either way
as far as cages go.
i've been burning the candle at both ends and been working/installing a Metal tech cage for a friend in his 40.
the "A" pillars are DOM 2"X.120
the rest is HREW, but, the seams are not on the inside bends. this is a old cage so maybe Mark has changed his bending skillz since.
my .02
SOLID ROCK OFF-ROAD
http://www.solidrockoff-road.com/
1991-92 80 series sliders available, WITH CAT PROTECTION!
It's how YOU want it, i'm just here to build it for you.
SLIDERS FOR 40s' 60s' and 80s' plus a little bit more
2badfjs is offline   Reply With Quote
Old 01-11-08, 11:29 PM   #25
Bret's Avatar
Definately call around and try to get a group buy together. It seems the breakover to the cheaper prices was 500 ft. We got a deal at $1.20/ft for HREW that was 1.75 X .120 in 20' sticks. But we had to buy 500' of it. We went to the yard and picked it up with a trailer so delivery wasn't charged either.
Bret is offline   Reply With Quote
Old 01-12-08, 03:16 AM   #26
PKP80's Avatar
TLCA# 14900
I hope this is not hijacking the the thread but two questions.
1. Having read this thread so far, Is 4130 chromo completely unnecessary for an internal 80 cage? I was shooting for 2" x.25 chromoly. Yeah I know $$$ so hope 2"x.25 DOM will be sufficient.
2. If you add cage to body gussets (similar to prerunner style trucks) down the Apiller, how does that affect the body and bending in a roll over? I'd imagine that you'd get virtually No bend in the A piller (just a matter of changing the front wind shield. I am planning on a 3 way gussets two down the A-pillers to the cage and open across the whole top roof line (3/16ths plate dimple died)
Sam Shaya
96' FZJ80 convertable
4x4 Labs Rear end, Bengels Offroad front bumper, roll cage, etc.
other goodies, but you get the idea.
Call Sign KI6KNB
"Team Pull-OUT"
Phi Kappa Psi
PKP80 is offline   Reply With Quote
Old 01-12-08, 11:19 AM   #27
what he said
Mace's Avatar
1. Oh my god yes... If you want chromoly you can actually go to a 1.75 x .090. You gotta remember that the 80's roof adds a lot of protection. Personaly I would do 1.75 x.120 HREW (or dom). It will give you more routing ability and be less intrusive..
2. If you have a significant roll the windshield will basically never fit well again. I would not bother, but that is me..
My Myspace
Old 01-12-08, 12:02 PM   #28
