Go Back   IH8MUD Forums > Toyota Tech Forums > HardCore Corner
Old 01-13-08, 10:22 AM   #31
I've probably built 500 cages, mostly for land cruisers. I have never had a failure with the HREW tubing. I have literally made thousands, perfhaps tens of thousands of bends with that tubing from 1" to 2" diameters and never seen a tube split no matter the location of the seam. I have, however seen DOM fail during bending. The reason is the DOM proces work hardens the material making it less elastic. Most people are unaware that it is available in a "normalized" condition, or stress relieved. I have seen 1 1/2 DOM tear on the outside radius during bending. CroMo is also prone to this. If you use either DOM or CroMo be sure to specify "normalized" tubing. Most yards only bring in standard DOM so they will probably need to order it.
Oh and by the way I usually stick to 2" .120 wall for a truck as heavy as a cruiser. It's not worth the wieght savings to go undersize. A basic cage would use less than 60 feet of tube . An elaborate cage, seatcradles, dash bars, gussets all over, would exceed 100 feet. 100 feet 2" 120 is about 240 lb, 100 feet
1 3/4 is about 210, and 1 1/2 about 180lb
lcwizard is offline   Reply With Quote
Old 01-13-08, 10:36 AM   #32
Medusa's Avatar
I was shooting for 2" x.25 chromoly. Yeah I know $$$ so hope 2"x.25 DOM will be sufficient.
I am curious...how do you plan on bending 2" x .250 tube (forget chromoly, even mild steel)?????
A lot of the discussion above has focused on the HREW vs DOM debate. IMO more consideration ought to be give to wall thickness and strength vs weight tradeoffs. For a chassis I think the best combination is 1.5" with a 0.156 wall. I think a cage or roll bar in 1.750 x 0.156 would also work well. For parts that take a real beating (e.g., sliders) I have been using 1.75 DOM with a 0.188 wall. It has, however, been difficult finding shops able and/or willing to bend that thick of tube. LT and Tydes are the only two friends I still have after that kind of bending request
Got Rice?
Medusa is offline   Reply With Quote
Old 01-13-08, 12:44 PM   #33
4rnr's Avatar
TLCA# pfft
So are you claiming that HREW is in someway superior to DOM or Cromo??
1988 4runner 3.0 5spd soft top stock DD
1990 fj62 stock
1992 4runner 3.4, auto, dual inchworms (5:1, chromo output, twinstick, 10*) marlin sas, 5.29's, lockrite's, 30 spline longs, hydro assist, custom exo, 37" PBR's, DIY beadlocks, hs9500i/synthetic, AWshifting electronic shifters...
4rnr is online now   Reply With Quote
Old 01-13-08, 02:39 PM   #34
no, just a better all around material. It does have a lower tensile strength but it doesn't work harden like moly so it will go far longer without cracking. A moly chassis should be replaced in three or four seasons less if it's run a lot. The material work hardens with vibration and cracks. I see a lot of people weld moly with standard steel wire so the weld points offer no advantage. To handle moly correctly tig or pulsed mig is the only way to go. Along with the proper wire and gas. Then to get the true advantage moly offers the whole part needs to be annealed or the areas near the weld are brittle.
DOM is a goog choice for a guy with Mig capabilities as long as you specify
"normalized" DOM when you order. Factor in the cost the the gain is little if the HREW does the job well.
I've built cages from simple offroad to full race quarter mile cars and seen them roll dozens of times, never any failures
Old 01-13-08, 03:33 PM   #35
PKP80's Avatar
TLCA# 14900
Brute Muscle strength...I've been hitting the gym real hard and eating all my veggies, lol.
Hydraulically via some fancy overpriced bender. I'm learning about bending, a friend is instructing me on the how to.
Sam Shaya
96' FZJ80 convertable
4x4 Labs Rear end, Bengels Offroad front bumper, roll cage, etc.
other goodies, but you get the idea.
Call Sign KI6KNB
"Team Pull-OUT"
Phi Kappa Psi
PKP80 is offline   Reply With Quote
Old 01-13-08, 10:22 PM   #36
Rookie with a torch.
awp_cruiser's Avatar
muddogbob,
I am in Seattle. Where did you get tube from?
Thanks!
1973 FJ40 -
Rimrock - 2
FJ40 - 0
awp_cruiser is offline   Reply With Quote
Old 01-14-08, 12:36 PM   #37
Medusa's Avatar
Please let us know when you identify this bender.
Got Rice?
Old 01-14-08, 12:48 PM   #38
what he said
Mace's Avatar
Jack, I have used a JD Squared manual bender with a long ass bar to bend both 1.5" .25 wall and 2" .25 wall. Both bends were ~45*, the bender did NOT like it but it did work.. The biggest thing with the manual benders is making the stand sturdy enough.. These benders can bend the tubing, but honestly over time they will break. They are not rated for that kind of abuse.
I am kinda gay.......
My Myspace
Old 01-14-08, 01:05 PM   #39
Isotel's Avatar
TLCA# 16898
Redline's Bender is up to the task , but 2" .25 wall Chromo is just Silly.. Bigger is not always better.
1976 FJ40 TBI350 700R4 D300 SOA Locked 37" PBR's Protected by REDLINE
Colorado Land Cruisers - Club
Redline Land Cruisers - PM me for info on our products or to order!
CrAwLoRadO.com
Old 01-16-08, 05:51 PM   #40
This will be longish - and I hope not to much of a hi-jack but related -
So I am ready to start my cage building project. I've read a lot of threads here and on Pirate. There seems to be no end to the discussion or debate. The most frustrating thing is the slang vs the techincal.
Based on what I've read I've decided to build my cage with the following:
1.75x.120 DOM for the main structure.
1.75x.095 HREW for infill, diagonals, spreaders, etc.
So I go to get a price and source the material. I call the large and very reputable source in Seattle. They don't carry DOM but they can get it. They refer me to their supplier and tell me to pick what I want and let them know and they'd price and order it for me.
Earle M. Jorgensen Company ® - Products - Stock List
Now... DOM or Seamless? 1010 or 1020? Or is it A513? Normalized is which? I am not looking for a chemical brakdown of these materials, but what is it I am looking for again?!!
Then HREW... 1010 is the stuff I am looking for?
Specifically, in techincal terms, does anyone have a suggestion as to what material I should order?
Let's discuss the tube, thickness, and design later.
Thanks!
1973 FJ40 -
Rimrock - 2
FJ40 - 0
Old 01-16-08, 09:07 PM   #41
LandC1973's Avatar
FYI - Because of the link below (and others) and computer modeling I went with 2" standard schedule 40 pipe for my cage because of price, welding considerations, and I not racing fast on dirt tracks.
tube strength vs schedule pipe
Is schedule 40 pipe strong enough? [Archive] - CK5 Forums
pipe sizes
Lighting Pipe Sizes
'70 Dodge Charger
'73 FJ 40
'75 Kawasaki H1
Toys are a good thing
'94 Ford Ranger/'08 Tow Dolley/'04 Trailer/+++
LandC1973 is offline   Reply With Quote
Old 01-16-08, 09:51 PM   #42
Metal supermarkets in Woodinville
metal supermarkets loc: Woodinville, WA - Google Maps
muddogbob is offline   Reply With Quote
Old 01-17-08, 12:16 AM   #43
Taz
Horse Wisperer
Taz's Avatar
2" .120 Dom will hold up just fine in a violent 80 roll (multiple) as long as the cage is built right. I beleive Nascar only allows Dom to be used because chromo is too brittle?
Mark
97 FJ 80 locked
supercharged, 4" slee lift, 37/12.5/17MTR, ARB front bumper, 4x4+ rear bumper, custom 26 gallon aux fuel cell, Slee step sliders, etc.
2005 d-max 3500 stock
2006 WR450F Desert Ready
Taz is offline   Reply With Quote
Old 01-17-08, 01:26 AM   #44
PKP80's Avatar
TLCA# 14900
Mark was that the size for the Baja80 you boys built?
Sam Shaya
Call Sign KI6KNB
"Team Pull-OUT"
Phi Kappa Psi
Old 01-18-08, 12:44 AM   #45
Taz
Horse Wisperer
Taz's Avatar
yes it was...as required by SCORE ... It saved a few lives
Mark
97 FJ 80 locked
Old 01-18-08, 02:03 AM   #46
cruzerman350's Avatar
i built my whole cage out of 1 7/8" schedule 40 i believe, i rolled it and it didnt budge. you just have to put gussets in the right places and keep as many bars straight as you can. i only have 4 bends on my entire cage. also if you use an exhaust bender it makes a stronger tighter bend. thats what i was told and it worked for me.
"cruzerman that thing looks like it takes no prisoners...straight up black, the grim reaper of Toyotas"
-CruisinMT
72 FJ-40 with a 350 and fj60 trans and t-case. custom cage, belly pan, bilstien 7100s, and some badass paint
cruzerman350 is offline   Reply With Quote
Old 01-18-08, 09:16 AM   #47
what he said
Mace's Avatar
please don't use an exhaust bender......
My Myspace
Old 01-18-08, 09:56 AM   #48
Ride On...
lowtideride's Avatar
TLCA# 14891
It depends I think on how big of a dick you are to people.
If your a big dick= sch 40 PVC
Not a dick= DOM/HREW
So to decide what you should make your cage out of, you must first find out how big of a dick you are
www.NFCruiserheads.org 1983 SR5 Hilux...
has had no peers for 50 years...
lowtideride is offline   Reply With Quote
Old 01-18-08, 10:32 AM   #49
bustanutley's Avatar
A cage is not something to cheep out on...
FJ-40 on FO-DEEs
just a lil guy
HOMEGROWN
bustanutley is offline   Reply With Quote
Old 01-18-08, 01:32 PM   #50
Isotel's Avatar
TLCA# 16898
Have you read this article on Pirate??
Pirate4x4.com - The largest off roading website in the world.
Its mostly about Suspension Links but has some good info on differences in steel , Somewhere there is an article on the bible of metal strength, but i cant find it now
You mean i shouldn't build a cage out of Poop Pipe (Sch 40) with a Harbor Freight Kinker ?? Its just a Safety Item
CrAwLoRadO.com
Old 01-18-08, 06:11 PM   #51
Thanks Isotel.
I hadn't seent that article. That is exactly what I was looking for.
Muddogbob, I appreciate the lead. I'll give 'em a call.
Andy
1973 FJ40 -
Rimrock - 2
FJ40 - 0
Old 01-19-08, 11:41 AM   #52
LandC1973's Avatar
lowtideride -- Wait…who the hel- said PVC (Polyvinyl chloride) pipe would work. Yes that is a really, really bad idea. I’m talking about Steel Sch 40 NOT PVC Sch 40.
PVC = Death
'70 Dodge Charger
'73 FJ 40
'75 Kawasaki H1
Old 01-19-08, 12:08 PM   #53
Ride On...
TLCA# 14891
PVC = Death
Yulp I Know what I said.
It was a joke.
Old 01-19-08, 12:43 PM   #54
LandC1973's Avatar
On “Trucks” (the TV show on Spike TV) they actually got an old Bronco and someone used PVC to make the roll cage and painted it black. That’s why I didn’t know if you were joking or not, it’s happened before.
DOM and HREW are definitely stronger per the weight but Pipe is easyer to bend, weld, and cheaper per the strength… If you don’t care to much about the weight Sch 40 or 80 could be a good option.
'70 Dodge Charger
'73 FJ 40
'75 Kawasaki H1
