Can I improve on this Diff?
Hey guys just asking for some help, and ideas here on a Diff I woud like to build, and if anyone has any opinions on how I can buld it?
This will be going under my 60-series ute, with (soon-to-be) 3-link front with coil-overs. Diamond housing 5.5" wider than standard. lcwizards longer inner 30-spline shafts. 30-spline long birf's. TG 6-shooter knuckles. ARP studs. TG Creeper flanges. 1.5" wheels spacers. Anything I can do to further strengthen or improve this setup I would like to do. If you guys have any ideas please post em up. ![]() __________________ Thanks friend but I'm not calculating anything. Im just going on the "if I can get it to fit" calculator You don't need adaptor plates. That's what gaffer tape was invented for. |
Young and Dumb apparently
"pin" the ring gear, use 80 series birfs/knuckles..........run a 609 (D60 outers, Ford 9" center)
__________________ '92 - 3FE POWER'D! -- Slee 6"/OME 863J, Pro-Comp 14" ES3000/N74L, Gen. 2 Slee Front Control Arms, T-G Sliders, Ext. Diff. Breathers, Slee SS Brake Lines, 5.29s, Aussie Locker'd rear, 35" TrXus STS Street/38.5x11 Boggers Trail, 180k. '85 Honda Accord - 55MPG!!! -- No air filter, Custom Burple (blue and purple) Paint. Upstate Cruisers |
Hang on!!
Misunderstanding. I mean how canI keep my car relatively still 'toyota' (no 9" or D60 gear). Alkaline what do you mean by pin the ring gear? Also I believe bobby long's gear is better than the 80-series parts, and easier to get. ![]() __________________ Thanks friend but I'm not calculating anything. Im just going on the "if I can get it to fit" calculator You don't need adaptor plates. That's what gaffer tape was invented for. |
what he said
Why in the world would you plan to run a diamond housing and wheel spacers????
LC stuff is nice, but in the end, you will have spent way more money on this axle than a D60 and still only have a front axle that is 30 spline.. __________________ I am kinda gay....... My Myspace http://profile.myspace.com/index.cfm...endid=75712409 "Mary Poppins: In every job that must be done, there is an element of fun. You find the fun and - SNAP - the job's a game." |
#5 | |
"Pin" the ring gear - can't find the thread, it was on here or pirate4x4, but what you do is support the ring gear where it meshes with the pinion, then there can't be deflection reducing the chances of breakage. 80 series birfs are larger than mini/40/60....and Bobby Long makes upgraded 80's birfs. If you're already doing a diamond housing, get them to put FJ80 knuckles on it.... __________________ '92 - 3FE POWER'D! -- Slee 6"/OME 863J, Pro-Comp 14" ES3000/N74L, Gen. 2 Slee Front Control Arms, T-G Sliders, Ext. Diff. Breathers, Slee SS Brake Lines, 5.29s, Aussie Locker'd rear, 35" TrXus STS Street/38.5x11 Boggers Trail, 180k. '85 Honda Accord - 55MPG!!! -- No air filter, Custom Burple (blue and purple) Paint. Upstate Cruisers |
#6 | |
Rev limiter abuser
I'm also with mace on NOT running wheel spacers with a custom width housing.. Why would you do that? __________________ Rich in NC FJ - '73 FJ-40 Cruggy - LSx/4-wheel steer Rockwells/4-link/coilovers/42's Build thread --> http://forum.ih8mud.com/showthread.php?t=124040 '01 Chevy 2500HD 8.1 Allison Lux-o-tow |
#7 | |
'Pinning the ring gear' however sounds pretty difficult. __________________ Thanks friend but I'm not calculating anything. Im just going on the "if I can get it to fit" calculator You don't need adaptor plates. That's what gaffer tape was invented for. |
#8 | |
LC stuff is nice. ![]() And yes I will most likely spend $2700-$3000US on the front diff alone, However for me to get a built, locked, 35-spline, high-steer Dynatrac to Darwin in Aus would cost much more initially, and exponentially more to maintain. Now as for the wheel spacers I can not understand why it would be a bad choice to use them? I was thinking that by widening the front housing 5 1/2" and using an 'average' offset wheel (standard 16x8" LC 80-series wheel) I will be able to get some sort of a longer life span out of my wheel, and king-pin bearings. ![]() Then by using 1 1/2" wheel spacers that would be giving me almost 8" wider wheel track. This very wide wheel track combine with the lower roof line, and lower chassis will create a heaps better CoG. ![]() __________________ Thanks friend but I'm not calculating anything. Im just going on the "if I can get it to fit" calculator You don't need adaptor plates. That's what gaffer tape was invented for. |
It's only two bolts and a steel block about .5mm from the back side of the ring gear beside where the pinion contacts the ring gear. I wish I could find the pic, it looked extremely easy.
#10 |
so the block acts like a support/guide for when the ring deflects under strain? good idea.........
#11 |
Exactly it....maybe it was ncttora forums....
#12 | |
Something clever
If you want to be 8" wider, just make the housing 8" wider. The way to make your wheel and trunion bearings last longer is to keep the wheel/tire tucked up to the knuckle. __________________ HOKIES UNITED Arya Ebrahimi '94 FZJ80 200k miles, locked, 285 Revo's, ARB Bullbar, Hella 4000's, homemade drawers My mini-truck buildup thread...updated 9/10 Mini-truck's first trip!! With PICS! 11/10 |
#13 | |
I bloody agree with what you say about the trunion bearings last longer is to keep the wheel/tire tucked up to the knuckle. LCWIZARD can supply me 2 5/8" longer inner and outer 30-spline shafts (then I don't have to get custom ones). Also when I run the wheel spacers I can take them off as I wish. Use wheel spacers for Rock crawling, Take them off for higher-speed mud racing. ![]() __________________ Thanks friend but I'm not calculating anything. Im just going on the "if I can get it to fit" calculator You don't need adaptor plates. That's what gaffer tape was invented for. |
#14 |
Rev limiter abuser
You also turn tighter without wheel spacers... Scrub radius!
#15 |
Not the thread/article I remember, but it's the same idea (yet better IMO).....
True Hi9 high pinion Ford 9 inch third members richmond __________________ '92 - 3FE POWER'D! -- Slee 6"/OME 863J, Pro-Comp 14" ES3000/N74L, Gen. 2 Slee Front Control Arms, T-G Sliders, Ext. Diff. Breathers, Slee SS Brake Lines, 5.29s, Aussie Locker'd rear, 35" TrXus STS Street/38.5x11 Boggers Trail, 180k. '85 Honda Accord - 55MPG!!! -- No air filter, Custom Burple (blue and purple) Paint. Upstate Cruisers |
#16 |
66.5" wms/wms is uber wide. I don't think you will need the spacers..
There is no way I would drop just north of 3G on a yota axle. I have seen plenty of nice d60s 35spline thru-out with a Detroit going for around $2500. What maintience costs? Are you talking about the $2 nylon kingpin bushing that rarely will ever need to replaced? D60s are great, put them in, forget about em. I pissed I have as much money in my yota front as I do, around 1500, but double that? I haven’t had too many problems with it but it is always on my mind and it is about clapped out. Oh and my buddy just got a 609 bling everything (sunray knucles 50deg turning) for around 5G |
#17 |
Damn Nutley!! Not you too
Cheaper is not always better right?!?!?!?![]() What 3rd are you using? When I get a Diamond made it will have the "8.4" Tacom rear 3rd in the front and rear of my truck. I have a HP front now, which is good (and I hope that I can resale ) but I want to get back to the swappable option I had in the begining.__________________ www.tachedoutoffroad.com http://forum.ih8mud.com/hardcore-cor...ined-taco.html Project: Dead Lined Taco http://forum.ih8mud.com/expedition-b...ml#post3376062 Ultimate East Coast Places To Go |
#18 |
You can run the factory housing just truss it really well and support the outer balls.
Wayne |
#19 |
remember Clay, I just put in a big t-case
![]() I'm over breaking parts, I'm a wheeling not a builder. But if it makes you feel better, yota axles are sticking around till them completly disintegrate, or I run into a pile of money. Oh and the F motor is in for the long haul as well ![]() Last edited by bustanutley; 05-05-08 at 08:15 PM. |
#20 |
o.k. so that is a very good reason against wheel spacers
#21 | |
The 3rd I will be using will be my ARB 4.88 centre I have lying around. For what it is worth ($500 for gears, $1700 for locker), I see it would be silly to not splash out on longs a diamond, and 6-bolt TG's. __________________ Thanks friend but I'm not calculating anything. Im just going on the "if I can get it to fit" calculator You don't need adaptor plates. That's what gaffer tape was invented for. |
#22 | |
just space balls out with LCWIZARD spacers. ![]() __________________ Thanks friend but I'm not calculating anything. Im just going on the "if I can get it to fit" calculator You don't need adaptor plates. That's what gaffer tape was invented for. |
#23 |
Location: the bush, Coombs, Vancouver Island, B.C. Canada
truss the axle up to keep the housing from flexing....you got the rest covered
#24 | |
Wayne knows his stuff, and wheels his Yota junk very hard!! ![]() __________________ Pacer 1972 r75/5 1974 r90/6 1989 fj62 2002 325xit |
#25 | ||
Rear off set ( centered D300/Mini Truc 4.7 t-case ? rear output .. ) more nice .. __________________ HJ-60 2H-T Intercooler Tencha HDJ-80 1HD-T not stock at all ! Marilu FZJ-80 1FZ-FE ready to Play ( wife rig ! ) Quote:
