#31 |
This looks like the same buddy as a few posts up
__________________ www.tachedoutoffroad.com http://forum.ih8mud.com/hardcore-cor...ined-taco.html Project: Dead Lined Taco http://forum.ih8mud.com/expedition-b...ml#post3376062 Ultimate East Coast Places To Go |
#32 |
That's him, UpNOver, I'll let him chime in on last year's buggy specs. I know it has an 80 front axle and a Mini Truck front axle (I don't remember which is where on the buggy) both running Longs and no bump stops. He has been running these axles for years, and as he said, all he is braking is R&Ps.
The axle housings are seriously trussed and his steering arms are super beefy, one offs that plug into both the top and bottom knuckle studs. Yes Mace, I do understand that there is a major difference between this rig and a full bodied LC, but it depends on what you are going to put it through, I don't see a full bodied rig climbing a 15' wall while roasting 39"s and the like..... Back on topic here, OpTimUs, I see nothing wrong with your Axle specs. Diamond makes some super bling gear, but with some work, the Yota housings can hold up to lots of abuse. Either way.... just add $$$. Flame suit is on. __________________ Pacer 1972 r75/5 1974 r90/6 1989 fj62 2002 325xit |
#33 |
To extend on what I said, I like the Toyota gear, but I like it because it is cheep to make strong. Throwing a ton of money all at once into an axle that has size limitation is kinda silly.
Optimus, specs are good, what tires are you planning on? The 6 stud arms are a band-aid for people that don’t keep up on tightening their knuckles, and I guarantee if they get loose they will shear 6 studs just as easy as they shear 4.. The other recommendation I have is stick with 4.11 gears. Brian makes dope housings and I’m thinking about getting one myself for the front since I already have all these parts My housing is bent.Last edited by bustanutley; 05-07-08 at 10:09 AM. |
#34 |
I had to look to see if they make lockers for this diff and they do! A Detroit isn't uber expensive either. Maybe if I get a front diamond made I’ll make it for the 8.4 since I’ll be running one in the rear.
#35 | |
I like this statement .. and I'm share the same idea ..
__________________ HJ-60 2H-T Intercooler Tencha HDJ-80 1HD-T not stock at all ! Marilu FZJ-80 1FZ-FE ready to Play ( wife rig ! ) Quote:
#36 | |
what he said
The diamond housings are really nice. The 8.4 is nice because of the supports on the main bearing caps. The stock 8.4 shafts snap like twigs (more often than the stock mini shafts for some reason) If he is going to build this axle. I see no reason to dump 5K into a yota axle. Get the 8.4 and whatever locker he wants (most of the cost is the 8.4 locker/ring gear) Beef the living crap out of the housing with some scrap steel being VERY carefull not to warp the housing while welding. (not expensive) Make a set of the spacers to make the axles wider (very simple if he has access to a lathe..) Call bobby and get the proper length 30 spline longs and inners. ($635 on sale right now) Add the 5th stud steering knuckle conversion. (a piece of angle Iron does wonders for those who do not torque often enough) Go wheel it. ![]() I just saved him probably 2.5K. If that axle breaks, then he will realize the reasons for not using yota parts in a heavy pig.. If it never breaks, then he will come back on here and tell me that D60's and 14bolts are overkill.. ![]() __________________ I am kinda gay....... My Myspace http://profile.myspace.com/index.cfm...endid=75712409 "Mary Poppins: In every job that must be done, there is an element of fun. You find the fun and - SNAP - the job's a game." |
#37 | |
![]() __________________ www.tachedoutoffroad.com http://forum.ih8mud.com/hardcore-cor...ined-taco.html Project: Dead Lined Taco http://forum.ih8mud.com/expedition-b...ml#post3376062 Ultimate East Coast Places To Go |
#38 | |
![]() How many have you really seem? Do you thnk its because you pay attention more to the Tacos on the trail, or because the diff is stronger and the breakage goes to the axles, or because the trucks/4runners are heavier than old, or becasue of the extra 50-90 HP in the 2.7/3.4? Ive just never seem one in person and the ones Ive heard of were 3.4L 4runners which could break a mini truck rear axle too. __________________ www.tachedoutoffroad.com http://forum.ih8mud.com/hardcore-cor...ined-taco.html Project: Dead Lined Taco http://forum.ih8mud.com/expedition-b...ml#post3376062 Ultimate East Coast Places To Go |
#39 | |
#40 | |
what he said
Three, one of which was mine as I was letting off the clutch in my 40. Not even giving it much gas. 38.5" SX's and 140:1. The only nice thing was that the Taco diff is not a C clip unit, so I drove back to camp. The second it snapped, a 14 bolt was swapped in.. Been beating the living daylights out of it since. The 8.4 is also a misnomer. It is not really an 8.4 heck, it really is almost no larger (ring gear) than a 8" unit. But the cap supports are nice ![]() __________________ I am kinda gay....... My Myspace http://profile.myspace.com/index.cfm...endid=75712409 "Mary Poppins: In every job that must be done, there is an element of fun. You find the fun and - SNAP - the job's a game." Last edited by Mace; 05-07-08 at 12:01 PM. |
#41 |
I used to put "8.4" all the time but my fingers got lazy
![]() Regardless, if I get a Diamnd front, it will have an "8.4" in it. __________________ www.tachedoutoffroad.com http://forum.ih8mud.com/hardcore-cor...ined-taco.html Project: Dead Lined Taco http://forum.ih8mud.com/expedition-b...ml#post3376062 Ultimate East Coast Places To Go |
#42 | |
#43 |
Tached out
woa that cool. Is that toyota junk? __________________ Thanks friend but I'm not calculating anything. Im just going on the "if I can get it to fit" calculator You don't need adaptor plates. That's what gaffer tape was invented for. Last edited by OpTimuS; 05-08-08 at 01:07 AM. Reason: dunce |
#44 | |
1: what is flame suit? 2: Where do I get some of his steering arms? 3: The diamond axles are Bling but I did find a thread the other day and some builder was using 6mm wall 50x75 RHS to truss the housing. That is some thick trussing! __________________ Thanks friend but I'm not calculating anything. Im just going on the "if I can get it to fit" calculator You don't need adaptor plates. That's what gaffer tape was invented for. |
#45 |
Bustanutley I plan on running 38.5x11 boggers
![]() __________________ Thanks friend but I'm not calculating anything. Im just going on the "if I can get it to fit" calculator You don't need adaptor plates. That's what gaffer tape was invented for. |
#46 |
The buggy making the jump is a friend of Nutleys too.
It has a Tundra 4.7L V8, built (top secret ) dual cases, Diamonds rear with custom 35 spline LC 9.5" ring gear, Diamond front with HP 8" and 30 spline Longfields. Pitbull is sponcering him in the XRRA and hes running 42"s.The Raisin goes under the knife to get a heart transplant - Pirate4x4.Com Bulletin Board The raisin in Albq, New Mexico XRRA - Pirate4x4.Com Bulletin Board I cant ever see myself driving an automatic but its super cool that hes still running leaf springs ![]() __________________ www.tachedoutoffroad.com http://forum.ih8mud.com/hardcore-cor...ined-taco.html Project: Dead Lined Taco http://forum.ih8mud.com/expedition-b...ml#post3376062 Ultimate East Coast Places To Go |
#47 |
The auto in that truck is awsome, I wouldn't have it any other way. With the power you are aways going so fast you would never have time to shift, and yeah you can see more the raisins early days in my homegrown link
Ben is my homieyou should have no worries running 38's on yota junk but I still wouldn't drop 3g's into one but that may just be me. Last edited by bustanutley; 05-08-08 at 08:30 AM. |
#48 |
heya bustanutley, I am feeling that for just a trail rig diamonds may be tooo expensive.
![]() But in one of your threads I read something about staying with 4.11 gears why is that? Is it because of the increased flex? I can't stay with 4.11 R&P because 80 series chunks (I will have an 80 series rear) dont have gears made in 4.11. __________________ Thanks friend but I'm not calculating anything. Im just going on the "if I can get it to fit" calculator You don't need adaptor plates. That's what gaffer tape was invented for. |
#49 |
what he said
how is the gear ratio related to flex???
#50 | |
Rev limiter abuser
a Toyota axle that doesn't come in 4.10?__________________ Rich in NC FJ - '73 FJ-40 Cruggy - LSx/4-wheel steer Rockwells/4-link/coilovers/42's Build thread --> http://forum.ih8mud.com/showthread.php?t=124040 '01 Chevy 2500HD 8.1 Allison Lux-o-tow |
#51 | |
#52 | |
#53 |
yessiree boss, 60 series cruisers come in 4.11...... I don't know if that is good or bad.......
#54 |
