Go Back   IH8MUD Forums > Toyota Tech Forums > HardCore Corner
Old 05-13-08, 09:51 AM   #61
bustanutley's Avatar
Originally Posted by OpTimuS View Post
Bustanutley has said that the lower R&P are stronger than the higher ratio R&P, however he ha not said why. I can guess and say that it is due to the amount of steel and dia of gears in the pinion head.
Yep, well you wrote it backwards but you get it. The teeth are bigger on the ring gear, and the pinion is bigger. We have gone thru a bunch of lower gears. Our experience is that the higher gears hold up a lot better, 4.11 is as low as I would go.
FJ-40 on FO-DEEs
just a lil guy
HOMEGROWN
bustanutley is online now   Reply With Quote
Old 05-14-08, 06:33 AM   #62
Thanx for the update Bustanutley.
If I was to useother R&P than 4.88 I would run 4.11 because they are so common (common=cheap)
Thanks friend but I'm not calculating anything. Im just going on the "if I can get it to fit" calculator
You don't need adaptor plates. That's what gaffer tape was invented for.
OpTimuS is offline   Reply With Quote
Mortgage | Fast Loans | Moneygram | Debt Consolidation | Bad Credit Mortgages
