Old 05-07-08, 07:09 AM   #31
TachedOutOffRoad's Avatar
TachedOutOffRoad is on a distinguished road
This looks like the same buddy as a few posts up
TachedOutOffRoad is offline   Reply With Quote
Old 05-07-08, 08:41 AM   #32
Pacer's Avatar
Pacer is on a distinguished road
That's him, UpNOver, I'll let him chime in on last year's buggy specs. I know it has an 80 front axle and a Mini Truck front axle (I don't remember which is where on the buggy) both running Longs and no bump stops. He has been running these axles for years, and as he said, all he is braking is R&Ps.
The axle housings are seriously trussed and his steering arms are super beefy, one offs that plug into both the top and bottom knuckle studs.
Yes Mace, I do understand that there is a major difference between this rig and a full bodied LC, but it depends on what you are going to put it through, I don't see a full bodied rig climbing a 15' wall while roasting 39"s and the like.....
Back on topic here, OpTimUs, I see nothing wrong with your Axle specs. Diamond makes some super bling gear, but with some work, the Yota housings can hold up to lots of abuse.
Either way.... just add $$$.
Flame suit is on.
Pacer
1972 r75/5
1974 r90/6
1989 fj62
2002 325xit
Pacer is online now   Reply With Quote
Old 05-07-08, 09:17 AM   #33
bustanutley's Avatar
bustanutley
To extend on what I said, I like the Toyota gear, but I like it because it is cheep to make strong. Throwing a ton of money all at once into an axle that has size limitation is kinda silly.
Optimus, specs are good, what tires are you planning on? The 6 stud arms are a band-aid for people that don’t keep up on tightening their knuckles, and I guarantee if they get loose they will shear 6 studs just as easy as they shear 4..
The other recommendation I have is stick with 4.11 gears.
Brian makes dope housings and I’m thinking about getting one myself for the front since I already have all these parts My housing is bent.
FJ-40 on FO-DEEs
just a lil guy
HOMEGROWN
bustanutley is offline   Reply With Quote
Old 05-07-08, 09:25 AM   #34
bustanutley
Originally Posted by TachedOutOffRoad View Post
When I get a Diamond made it will have the "8.4" Tacom rear 3rd in the front and rear of my truck. I have a HP front now, which is good (and I hope that I can resale ) but I want to get back to the swappable option I had in the begining.
I had to look to see if they make lockers for this diff and they do! A Detroit isn't uber expensive either. Maybe if I get a front diamond made I’ll make it for the 8.4 since I’ll be running one in the rear.
FJ-40 on FO-DEEs
just a lil guy
HOMEGROWN
Old 05-07-08, 10:04 AM   #35
Tapage's Avatar
Tapage is on a distinguished road
Originally Posted by bustanutley View Post
The 6 stud arms are a band-aid for people that don’t keep up on tightening their knuckles, and I guarantee if they get loose they will shear 6 studs just as easy as they shear 4...
I like this statement .. and I'm share the same idea ..
HJ-60 2H-T Intercooler Tencha
Originally Posted by pygpen
Old 05-07-08, 10:14 AM   #36
what he said
Mace's Avatar
Mace is an unknown quantity at this point
That's the point, I do..
The diamond housings are really nice.
The 8.4 is nice because of the supports on the main bearing caps.
The stock 8.4 shafts snap like twigs (more often than the stock mini shafts for some reason)
If he is going to build this axle. I see no reason to dump 5K into a yota axle.
Get the 8.4 and whatever locker he wants (most of the cost is the 8.4 locker/ring gear)
Beef the living crap out of the housing with some scrap steel being VERY carefull not to warp the housing while welding. (not expensive)
Make a set of the spacers to make the axles wider (very simple if he has access to a lathe..)
Call bobby and get the proper length 30 spline longs and inners. ($635 on sale right now)
Add the 5th stud steering knuckle conversion. (a piece of angle Iron does wonders for those who do not torque often enough)
Go wheel it.
I just saved him probably 2.5K.
If that axle breaks, then he will realize the reasons for not using yota parts in a heavy pig..
If it never breaks, then he will come back on here and tell me that D60's and 14bolts are overkill..
I am kinda gay.......
My Myspace
Old 05-07-08, 10:38 AM   #37
Ive got a couple of Taco diffs if you need one. No 410s though
Old 05-07-08, 10:44 AM   #38
Pics?
How many have you really seem?
Do you thnk its because you pay attention more to the Tacos on the trail, or because the diff is stronger and the breakage goes to the axles, or because the trucks/4runners are heavier than old, or becasue of the extra 50-90 HP in the 2.7/3.4?
Ive just never seem one in person and the ones Ive heard of were 3.4L 4runners which could break a mini truck rear axle too.
Old 05-07-08, 10:54 AM   #39
bustanutley
True story, the neck down is quite a bit bigger on those shafts. Polys are pretty cheep though
FJ-40 on FO-DEEs
just a lil guy
HOMEGROWN
Old 05-07-08, 11:39 AM   #40
what he said
Mace's Avatar
Pics?
Three, one of which was mine as I was letting off the clutch in my 40. Not even giving it much gas. 38.5" SX's and 140:1. The only nice thing was that the Taco diff is not a C clip unit, so I drove back to camp.
The second it snapped, a 14 bolt was swapped in..
Been beating the living daylights out of it since.
The 8.4 is also a misnomer. It is not really an 8.4 heck, it really is almost no larger (ring gear) than a 8" unit. But the cap supports are nice
My Myspace
Old 05-07-08, 11:58 AM   #41
I used to put "8.4" all the time but my fingers got lazy
Regardless, if I get a Diamnd front, it will have an "8.4" in it.
Old 05-07-08, 01:20 PM   #42
bustanutley
Dammit man we need 4.10 diffs
FJ-40 on FO-DEEs
just a lil guy
HOMEGROWN
Old 05-08-08, 12:51 AM   #43
OpTimuS is on a distinguished road
Tached out
woa that cool.
Is that toyota junk?
Thanks friend but I'm not calculating anything. Im just going on the "if I can get it to fit" calculator
You don't need adaptor plates. That's what gaffer tape was invented for.
OpTimuS is offline   Reply With Quote
Old 05-08-08, 05:10 AM   #44
Flame suit is on.
o.k.
1: what is flame suit?
2: Where do I get some of his steering arms?
3: The diamond axles are Bling but I did find a thread the other day and some builder was using 6mm wall 50x75 RHS to truss the housing. That is some thick trussing!
Old 05-08-08, 05:13 AM   #45
Bustanutley I plan on running 38.5x11 boggers
Old 05-08-08, 06:16 AM   #46
Originally Posted by OpTimuS View Post
Tached out
woa that cool.
The buggy making the jump is a friend of Nutleys too.
It has a Tundra 4.7L V8, built (top secret) dual cases, Diamonds rear with custom 35 spline LC 9.5" ring gear, Diamond front with HP 8" and 30 spline Longfields. Pitbull is sponcering him in the XRRA and hes running 42"s.
The Raisin goes under the knife to get a heart transplant - Pirate4x4.Com Bulletin Board
The raisin in Albq, New Mexico XRRA - Pirate4x4.Com Bulletin Board
I cant ever see myself driving an automatic but its super cool that hes still running leaf springs
Old 05-08-08, 08:17 AM   #47
bustanutley
The auto in that truck is awsome, I wouldn't have it any other way. With the power you are aways going so fast you would never have time to shift, and yeah you can see more the raisins early days in my homegrown link Ben is my homie
you should have no worries running 38's on yota junk but I still wouldn't drop 3g's into one but that may just be me.
FJ-40 on FO-DEEs
just a lil guy
HOMEGROWN
Old 05-08-08, 10:31 PM   #48
heya bustanutley, I am feeling that for just a trail rig diamonds may be tooo expensive.
But in one of your threads I read something about staying with 4.11 gears why is that? Is it because of the increased flex?
I can't stay with 4.11 R&P because 80 series chunks (I will have an 80 series rear) dont have gears made in 4.11.
Old 05-08-08, 11:40 PM   #49
what he said
Mace's Avatar
how is the gear ratio related to flex???
My Myspace
Old 05-09-08, 09:41 AM   #50
Rev limiter abuser
Eskimo's Avatar
Eskimo
whaaaaa? a Toyota axle that doesn't come in 4.10?
Rich in NC
FJ - '73 FJ-40 Cruggy - LSx/4-wheel steer Rockwells/4-link/coilovers/42's
Build thread --> http://forum.ih8mud.com/showthread.php?t=124040
'01 Chevy 2500HD 8.1 Allison Lux-o-tow
Eskimo is offline   Reply With Quote
Old 05-09-08, 10:42 AM   #51
bustanutley
4.11s are stronger than lower gear sets. have to agree with wtf no 4.10/4.11 option? 80 series here have 4.11s factory. they run a higher gear set because everything is diesel?
FJ-40 on FO-DEEs
just a lil guy
HOMEGROWN
Old 05-09-08, 12:30 PM   #52
CreeperSleeper's Avatar
TLCA# 15577
CreeperSleeper is on a distinguished road
I have my factory 4.10's if you would like them...
Chad
Cascade Cruisers- President
Views from the Creeper
MetalTech
Originally Posted by DanKunz View Post
You stacked rocks to climb your porch......HA!!!
CreeperSleeper is offline   Reply With Quote
Old 05-09-08, 04:30 PM   #53
yessiree boss, 60 series cruisers come in 4.11...... I don't know if that is good or bad.......
Old 05-09-08, 04:34 PM   #54
Bustanutley has said that the lower R&P are stronger than the higher ratio R&P, however he ha not said why. I can guess and say that it is due to the
