JY-sourced lift for a 62
Warning! Softcore tech follows!
I'm askin the hardcore crowd, as y'all are the most comfortable away from off-the-shelf stuff. If a guy were to lift a 62 3-4", with the main goal of increasing offroad prowess, while using scrounged springs from a boneyard, where would he look? I would use new u-bolts, shackles, etc, just looking for spring sources from anyone who might have already travelled down a similar bend.
__________________ ="Are you gonna sit there on that friggin computer all day or what?"The desert dwellin, roadrunner chasin, soooper-genius! '90 FJ 62, '08 Scion head unit, chopped quarters and rockers, bedlined exterior, and mostly stock. My soft wheeler and DD. '85 Dodge Ramcharger a little built, and a little beat. My hard wheeler. |
Young and Dumb apparently
Are you prepared for cutting/welding to relocate spring hangers and shackle mounts?
__________________ '92 - 3FE POWER'D! -- Slee 6"/OME 863J, Pro-Comp 14" ES3000/N74L, Gen. 2 Slee Front Control Arms, T-G Sliders, Ext. Diff. Breathers, Slee SS Brake Lines, 5.29s, Aussie Locker'd rear, 35" TrXus STS Street/38.5x11 Boggers Trail, 180k. '85 Honda Accord - 55MPG!!! -- No air filter, Custom Burple (blue and purple) Paint. Upstate Cruisers |
#3 | ||
Yes I am... More input on this please. I know people have run fullsize 63" springs on the rear of many Cruisers.... from? Quote:
http://forum.ih8mud.com/hardcore-cor...ly-haulin.html __________________ Pacer 1972 r75/5 1974 r90/6 1989 fj62 2002 325xit |
#4 | |
I'll check out Boots' thread, thanks. __________________ ="Are you gonna sit there on that friggin computer all day or what?"The desert dwellin, roadrunner chasin, soooper-genius! '90 FJ 62, '08 Scion head unit, chopped quarters and rockers, bedlined exterior, and mostly stock. My soft wheeler and DD. '85 Dodge Ramcharger a little built, and a little beat. My hard wheeler. |
Are you staying SUA or are you going SOA?
__________________ 85 FJ60, testing, Cummins 4BTA, manual 4L80E, 203 to splitcase doubler, SOA, 38s, some other stuff. build-up: Family Haulin' FJ60 |
Just go look in a junkyard for a set of high arch springs from whatever truck/van/suv you like and make fit, add/remove leaves as needed...
Def. stayin SUA.
Just lookin to see if I can narrow my jy searching based upon other folks' experiences. __________________ ="Are you gonna sit there on that friggin computer all day or what?"The desert dwellin, roadrunner chasin, soooper-genius! '90 FJ 62, '08 Scion head unit, chopped quarters and rockers, bedlined exterior, and mostly stock. My soft wheeler and DD. '85 Dodge Ramcharger a little built, and a little beat. My hard wheeler. |
#8 | |
I've tested out chevy 63" before and am very happy with their performance for the rear and depending on how you mount them to the frame you probably could get the height you're looking for. They certainly ride better than stock. For the fronts you don't have to stick with "front" packs. You can use whatever you can fit and I'd definitely try for something longer. If 60 and 62 springs are the same length then the fronts are ~44" and the rears are ~47" There's just too much room underneath not to take advantage of longer springs. __________________ 85 FJ60, testing, Cummins 4BTA, manual 4L80E, 203 to splitcase doubler, SOA, 38s, some other stuff. build-up: Family Haulin' FJ60 |
I know I could wander the yard w/ a tape measure, but I wanted to be spoon-fed the easy answer, sheez!
Could one of you guys come over and pull em off the donor truck for me, too. heheThe 63" chebbies would require new u-bolt plates due to their increased width when compared to 60/62 springs, right? I wouldn't necessarily mind, as a u-bolt flip could be done at the same time. To take this idea to a new but similar direction, how would a new lift spring pack for said chebbie springs compare in $ to the 60 specific ones from OME? I'd just make my own shackles, sway bar link extensions, shock mounts. etc. if I were to adapt a chebbie-specific lift onto my Cruza. Anyone gone this direction? I know I can get custom spings from Deaver, Alcan, etc, but wonder about the above none-the-less. __________________ ="Are you gonna sit there on that friggin computer all day or what?"The desert dwellin, roadrunner chasin, soooper-genius! '90 FJ 62, '08 Scion head unit, chopped quarters and rockers, bedlined exterior, and mostly stock. My soft wheeler and DD. '85 Dodge Ramcharger a little built, and a little beat. My hard wheeler. Last edited by Wile E Coyote; 05-01-08 at 12:10 PM. |
#10 |
Chevy 63" Rear Spring Swap FAQ
This applies to Taco's and earlier Toy mini's but it should lay some great groundwork for a newb like me. Whatchoo say? Whaddaya mean search the www, THEN post any lingering questions? Pshaw! __________________ ="Are you gonna sit there on that friggin computer all day or what?"The desert dwellin, roadrunner chasin, soooper-genius! '90 FJ 62, '08 Scion head unit, chopped quarters and rockers, bedlined exterior, and mostly stock. My soft wheeler and DD. '85 Dodge Ramcharger a little built, and a little beat. My hard wheeler. |
#11 |
The only stock springs I can think of that have any sort of "significant" arc are Z71 springs off an s10. I believe Leaf springs are made pretty flat for a reason.
Maybach cars | Mortgage | Finance News | Credit Cards | Blog5 Game Cheats |
