Location: the bush, Coombs, Vancouver Island, B.C. Canada
chopped my bj60
chopped the rear hatch and roof with more to come....needs so much body work and i'm not into it..also it's a vehicle i bought solely for 4wheelin' so i'm modifying the body to get some tire room and approach angles ...some lift, tires and lock the diffs etc.. ideas welcome
poser pics ![]() ![]()
__________________ "legalize wheelin" ![]() moterra@telus.net bj60 RIP 71'fj40/3b 6061 aluminum tub in progress
Looks awesome!
You may want to add a roll bar for saftey. __________________ "if the asparagus is over 4 inches in height then you have to go for the broccoli spring over roll with oppressive shackle reversal" - PhilC64 |
check out kling-on's 60 chop/bob/build...
http://forum.ih8mud.com/60-series-wa...d-60-16in.html __________________ jonathan malphrus -- 72fj40 the only pinstriping i'll ever have on my cruiser will be after i hit a ny yankee 'these are my awards, mother, from army. the seal is for marksmanship and the gorilla is for sand racing.' ...build-up here (stalled)... |
The Anti-Leafer
Yeahhhh! that's what I did to my 55. You have any closeup pics of how you boxed in the sheet metal sides & behind the rear doors/ roof? You going to make a custom canvas cover? How bout an inner cage? I'd start shaving the rear corner bottoms/ under tailgate for an increased departure angle.
__________________ '72 FJ55 http://forum.ih8mud.com/fj55-iron-pig-preservation-society/76835-pig-chebby-avalanche-trim-%3D.html '73 FJ40 http://s132.photobucket.com/albums/q...&addtype=local '78 FJ40 - future crawler in pieces '93 Ram W350 5 spd. SRW CTD '99 Ram 3500 4X4 5 spd. DRW CTD '74 BMW 3.0CS future project
kling-on is a nice build I read it all......
I will have more pics soon of the sheet metel work as well as a shortening and narrowing the rear section, narrowed tailgate, fender trim, roof rack refit, soft top w/rear window and then more stuff like tires, lift. etc...never ends does it.. maybe inner cage or .....full on tube buggy if i save for some DOM till next year hahahad to go wheel it just bent the roof down and went out..... needs tires bad.... solo wheelin poser pics ![]()
going to have to address the rear section this week think i'll cut out the rear doors and go two door p/u conversion with a fuel cell...
The Anti-Leafer
You could run a 90's S-10 20 gal. tank under the bed, that's what I did. The inlet is on the right side same as yours'. Build a skid & post up more progress pics
__________________ '72 FJ55 http://forum.ih8mud.com/showthread.php?t=76835 '73 FJ40 http://s132.photobucket.com/albums/q...&addtype=local '78 FJ40 - future crawler in pieces '93 Ram W350 5 spd. SRW CTD '99 Ram 3500 4X4 5 spd. DRW CTD '74 BMW 3.0CS future project
removed the rear doors this evening...will post pics when I cut it some more this week. won't be much left but a truggy when i'm done with it... and I might have to make a custom frame soon too mines almost toast :(
thinking of a boat fuel cell 22 gal for 60 bucks..but i'll keep that in mind...cheers lc hamma also found some 35's to run... __________________ "legalize wheelin" ![]() moterra@telus.net bj60 RIP 71'fj40/3b 6061 aluminum tub in progress
Nice .. want to see that soft top ..
#10 |
spring plates
found out what was clunking when my leaf flexed....broken u bolt plates...
#11 |
![]() still runnin boat tank in mine __________________ 82 FJ60 OME Heavy 33BFG's 410's , ARB bull & side bars 85 FJ60 Trail beater SM 420 crawler box lockers 456,38's bobed & choped with a Metal Tech cage 85 SR5 new DD GIT-R-DONE!!!! TLCA #15374 low riders want SWITCHES... 4 wheelers want SHIFTERS www.jkcustoms.com |
#12 |
nice...another islander! rig looks wicked, if im ever up that way we should find a trail to run. are there many good trails up there?
nothing wrong with runnen a boat tank...thats how we move the 45 around i thought it worked pretty well...scary part is i just ran it through the "floor" without any cutting....
__________________ '74 FJ40- disc brakes, saginaw,8274. SM420 sitten in the shop just waiting (in pieces) '78 FJ45 project rig (not even under the knife yet) x2 '81 BJ42 (DD) the list goes on... |
#13 |
you could do what I did:
![]() This is before paint:
__________________ Thanks friend but I'm not calculating anything. Im just going on the "if I can get it to fit" calculator You don't need adaptor plates. That's what gaffer tape was invented for. |
#14 |
i think i will i like a two seater for what i do........... i need to back half mine at very least or do the new frame out of 2x3 the rust is gaining on me...
#15 |
#16 |
time for a spring over dude.
__________________ 1977 fj40 1985 bj60 for sale 1993 80 series |
#17 |
#18 |
#19 |
![]() ![]() weld the back of the cab back on as a crewcab I wish I still had mine ... dam rollovers
#20 |
I might have to go two seater with lots of tubes... mine is so rusty, but i do like the crew cab look...
going to finish the front end weight reduction...later __________________ "legalize wheelin" ![]() moterra@telus.net bj60 RIP 71'fj40/3b 6061 aluminum tub in progress
#21 |
What weight reduction?
#22 |
the 3-or 400 pounds off metal thats no good on the trail....picture a 60 at a junk yard thats kinda how it looks now....haha trying to sort out materials and a welder for my custom straight rail frame i'm building for it. but will have more pics soon
#23 |
#24 |
Yep, that should fit between our tight BC trails...
__________________ Come and visit us in Duncan, BC www.raddcruisers.ca --> 60 Series Cable Lockers available - 4.11s or 3.70s - handles and cables included --> 12HT & H55F combos available - complete & running --> in stock and ready to go. |
#25 |
oh hell ya !!
![]() ![]() ![]() ![]() *update* began to chop out the old rockers and most of the front fenders today removed most of the rust and started to weld it back up...** hey radd cruisers you got cable lockers eh hmmmmmmmm soon very soon __________________ "legalize wheelin" ![]() moterra@telus.net bj60 RIP 71'fj40/3b 6061 aluminum tub in progress
#26 |
fabbing a new frame from scratch so if anyone has any helpful tips on fabbing one up let me know... using 5x2 rect stock and it will be a tube buggy mostly with only the fire wall/ front inner fenders left intact.
