Old 04-23-08, 06:34 AM   #1
mookie's Avatar
another cut and turn ???
how neccessary is it to do a cut and turn if you have a trail only rig? i had it done on my current fj40 axle but i've got a 62 housing now that i want to swap in, if i point my pinion up without cutting and turning will it make my steering weird or limit my turning radius? or just wear out my bearings really fast?
This is your life, and it's ending one minute at a time...
'71 FJ55
'74 FJ40
mookie is offline   Reply With Quote
Old 04-23-08, 07:55 AM   #2
boots4's Avatar
If you are SO, which you sig looks like you are, and you go with high steer (good idea to get the tie rod out of harm's way) then you could run into clearance problems with the leaf pack when pointing the pinion up. It really isn't that much more work and it will steer better. Even when making a trail rig I'd make sure I wasn't building in defects.
85 FJ60, testing, Cummins 4BTA, manual 4L80E, 203 to splitcase doubler, SOA, 38s, some other stuff.
build-up: Family Haulin' FJ60
boots4 is offline   Reply With Quote
Old 04-23-08, 08:02 AM   #3
KI6MIE
Cruiserdrew's Avatar
TLCA# 11734
With your caster set like this, the truck will be dangerous on the street at street speeds. You can probably get away with it off road, but even then any kind of speed will make it handle really funky. The only way to get both a good pinion angle and proper caster is to cut and turn.
Now with an FJ62 axle, the relationship between the pinion angle and the knuckle angle is slightly different, and your pinion angle might be acceptable setting the caster properly. In any case, set up the caster right. You don't want surprises or dangerous handling. You are going to be doing enough fab work to get the wider axles under there, the CnT is not that big a deal.
Andrew
1997 FZJ-80 Driveway queen
Cruiserdrew is online now   Reply With Quote
Old 04-23-08, 08:10 AM   #4
bustanutley's Avatar
With what you want to do, the tie rod will most likely need to go thru the springs, won't work, along with it being just being dumb for steering angles. C&T adds like a day to the process.
FJ-40 on FO-DEEs
just a lil guy
HOMEGROWN
bustanutley is offline   Reply With Quote
Old 04-23-08, 08:18 AM   #5
mookie's Avatar
cool....i'll just uh, "knuckle up" and do it lol...
'71 FJ55
'74 FJ40
Old 04-23-08, 09:11 AM   #6
Tapage's Avatar
I thought if going to be a trail ( only ) rig .. and you aren't really between clouds ( of lift ) you can keep it as is .. with the knowledge that you are driving without proper caster settings ..
Other think that come to my mind it's the front diff goes down when you go forward .. it means if you keep it down ( the pinion angle ) to safe little caster, at traction momentum the u joint angle sould be high ..
Just some ideas .. .00002 cents.
HJ-60 2H-T Intercooler Tencha
Originally Posted by pygpen
Old 04-28-08, 12:31 PM   #7
IH8MUD wanabe
zuluzeugma's Avatar
For what its worth: If it is STRICTLY a trail rig, meaning, you never ever plan on going over 20 MPH, its not nessesary to C&T. Positive caster make the vehicle track straight. Negative caster make the vehicle turn easier. It would actaully be easier on your PS pump to have negative caster. Now, saying that, if you do try and drive it on the road with 10 deg. negative caster, it will be a scary scary ride...
83' FJ60 - Mint Condition which is now FOR SALE
72' FJ55 - SOA, SR, DB, FJ62 PS, Webber, Header, H.E.I., 37 X 12.5 X 15 MT/R's, Savanah-heat air freshener.
07' FJC - Atrac Hack - DD
03' Matrix Xrs - It's her's
08' Tundra, 4.7 2WD - Company Truck
zuluzeugma is offline   Reply With Quote
Old 04-28-08, 01:01 PM   #8
A cut and turn is so easy... even for a trail only rig I would do it again in a heartbeat.
also, as others have stated on my SOA with high-steer the drag link would have been in the middle of the spring pack for it to work.
73 fj40 (frame-off); ram jet 350 (MEFI 4), sm465, 3sp tc, SR, SOA, cut & turn, 55 springs in rear, PS, 4:88's, detroits front & rear, longfields, 38.5 x 14.5 sx swampers, mini disks, homemade "PowerTank," custom snorkel & Kong's high steer http://www.nwcruisers.com/rigs/michael_borg/borg.html
FredTheMonster is offline   Reply With Quote
Personal Car Finance | Electricity | Loans | Apply for Credit Card | Free Ringtones
