Old 04-17-08, 09:07 AM   #1
Quiet there's a J**P
JONNYFJ's Avatar
TLCA# 18337
How hard is it to Cut and Turn a Front Axle
Hey guys my friends mini has the worst drive line angle I have ever seen. We just put an new front 8" on it (cause he thought he was at monster jam and ramped a cobalt) it trashed the front end of the mini, so back to the ? how hard is it to cut and turn the axle to correct the pinion angle I have a torch a mig welder and could build a jig what more do I need
69 FJ40 383 Stroker SM420 3Speed Toyota T-Case SOA ARBs 35 MTRs and more
84 Mini Truck 22RE Stock Tranny Duel T-Cases Flat Bed 35s
JONNYFJ is offline   Reply With Quote
Old 04-17-08, 09:37 AM   #2
boots4's Avatar
There are two popular ways to cut into the housing: a large pipe cutter or an angle grinder. I think it would be hard to regulate depth with a torch so you don't want to use that. When Cn'T you are only cutting through the axle housing and not the knuckle that is inserted into the housing. I used a grinder and cut down a little more than 1/4" and used a long BFL to spin the knuckle in the housing.
Now that adjusts the caster but not the pinion angle. For the pinion angle you need to either rotate the spring perches by cutting them off and re-welding or use angled shims to rotate that pinion up or down, which ever way you need to go. This should be done first with the weight of the rig on the axle and then the Cn'T should be adjusted to the desired caster angle.
It really is pretty easy, just need to make a few good measurements and you are golden. There are several threads on Cn'T showing this in more detail.
85 FJ60, testing, Cummins 4BTA, manual 4L80E, 203 to splitcase doubler, SOA, 38s, some other stuff.
build-up: Family Haulin' FJ60
boots4 is online now   Reply With Quote
Old 04-17-08, 09:50 AM   #3
Tougher'n a $2 steak
HawkDriver's Avatar
TLCA# 15861
In the tech links up top Woody has an excellent article under the front SOA section with great pictures for reference. Boots summed it up though.
Here's the article
1975 FJ40, it's like having a second job.
2000 UZJ100, what a truck!
President: Fort Rucker Wheelers
HawkDriver is offline   Reply With Quote
Old 04-17-08, 11:21 AM   #4
CreeperSleeper's Avatar
TLCA# 15577
I've watched it being done and I couldn't believe how simple it was. I wouldn't hesitate to do it on my own rig (or my wife's for that matter...).
Chad
Cascade Cruisers- President
KE7VSA
Views from the Creeper
MetalTech
Originally Posted by DanKunz View Post
You stacked rocks to climb your porch......HA!!!
CreeperSleeper is offline   Reply With Quote
Old 04-17-08, 12:02 PM   #5
JONNYFJ's Avatar
TLCA# 18337
Damn it must be easy if you would tap into the wife's rig. Question is would she be willing throw her rig on the chopping block
Old 04-17-08, 01:00 PM   #6
Not very difficult. Disassembly half a day. Cut, Turn Weld half a day. Reassembly half a day. Could be done in a weekend for sure. I spread mine out over two nights after work and a saturday. Cleaning the nuckle stuff was the most time consuming part. I did mine bolted to the truck. Much easier this way. Once the cut is deep enough and you bang the housing to release the slip fit a bit it turns fairly easy with a big lever.
CRZA1 is offline   Reply With Quote
Old 04-17-08, 04:38 PM   #7
bustanutley's Avatar
Its as hard as the name implies, cut, then turn.
FJ-40 on FO-DEEs
just a lil guy
HOMEGROWN
bustanutley is offline   Reply With Quote
Old 04-19-08, 05:46 AM   #8
Ramblin Wreck
CruisinGA's Avatar
Woah man, stop being so helpful.
Bailey Quintrell
'74 FJ40--37 Irocks-32 Bolt 'Locks-SM420-ARB-XD9000i-FJ60 PS-MetalTech Cage
'93 FZJ80-DD-Part Time 4wd-locked-5" lifted-snorkel-bullbar-315 AT's
'97 FZJ80
'98 UZJ100-OEM RR locker
ΣΧ
CruisinGA is offline   Reply With Quote
Old 04-19-08, 09:17 AM   #9
What can I say, i'm a really a teacher at heart
FJ-40 on FO-DEEs
just a lil guy
HOMEGROWN
Old 04-22-08, 02:11 PM   #10
IH8MUD wanabe
zuluzeugma's Avatar
The first time it is kind of nerve racking if you have never watched anyone else doing it. Once you have done it once, its very very easy... Go for it, read articles and threads here FIRST, then go for it.
83' FJ60 - Mint Condition which is now FOR SALE
72' FJ55 - SOA, SR, DB, FJ62 PS, Webber, Header, H.E.I., 37 X 12.5 X 15 MT/R's, Savanah-heat air freshener.
07' FJC - Atrac Hack - DD
03' Matrix Xrs - It's her's
08' Tundra, 4.7 2WD - Company Truck
Originally Posted by axlechassis View Post
If you want your cruiser to handle like a car then buy a Corolla.
If you want your cruiser to handle the trail better buy a locker and do a SOA.
zuluzeugma is offline   Reply With Quote
Old 04-22-08, 10:41 PM   #11
TLCA# 18484
A lot of people say you need heat to turn the knuckle. When I did mine, I just grabbed the smallest part of the knuckle with my really big channel locks, and tapped the handle with a dead blow. I was able to turn the knuckles very slowly, and make small adjustments to get them just where I wanted them. Unless you have a really big bench vise, bolted in the truck is probably easiest. I pulled my axle out of the truck, did all of the cutting, then bolted it back in the truck to turn the knuckle. Hope that helps.
'74 FJ40
'78 Motor & Tranny
SOA
4.56 locked front & rear
36X12.5X15 TSL's
Rancho 9000
8274
supermanrs is offline   Reply With Quote
Old 04-27-08, 12:41 PM   #12
Vortec_Cruiser's Avatar
TLCA# 5659
Be sure to use an angle finder (digital), so both sides are turned the same amount.
Ed Gilbert - TLCA #5659
Formula 4 Toy #F006 build in-progress
1977 FJ40 - So. California
vorteccruiser@charter.net
Vortec_Cruiser is offline   Reply With Quote
Old 04-27-08, 05:57 PM   #13
IH8MUD Poser
Jakes40's Avatar
the hardest part is geting the two sides the same deg. IMO I used a pipe cuter it worked like a champ just finished mine!
1969 FJ40 - SOA, 75 disc brake, Scout PS, FJ55 rear springs, rear discs, on 35's
My Build Up Thread
73 FJ40 w/trans F, back halfed "Thanks Mother Nature"
1986 F150 parts runner
Nothing is getting done sitting at the computer.
Go! get to work!
Jakes40 is offline   Reply With Quote
Old 05-05-08, 07:16 AM   #14
Diesel for blood
roscoFJ73's Avatar
Whats the approximate degrees you need to turn them? I know it varies from rig to rig,so what is a ballpark figure
FJ73+1HZ Diesel NEW GEARBOX
33 in BFG A/T
Volvo 740 GL
Old 05-05-08, 07:36 AM   #15
Admin
woody's Avatar
TLCA# 1548
measure before you turn, and you'll find they aren't the same stock....
mine was a total of about 14 degrees....once the perches went back on, it ended up 12 at the pinion and 2 at the knuckle (final knuckle was +3 caster, versus +1 caster for stock)
....course that was a LONG time ago....'best' accurate method is to set under the rig, full weight on it (jackstands) and set the pinion to where you want it to be...lock into place then turn the knuckles....unless you are gonna continue to run 235 tires with a spring over (hahaha), you'll want more than the factory +1 caster (upper trunion bearing 1* back of the lower trunion bearing...put a stick thru the holes and the point on the ground is ahead of the axle) - odds are you'll want +3 or +4....
Brian 'woody' Swearingen
Bad Credit Loan | Montana Music | Synchronization fast and easy | Bad Credit Mortgages | Earth for Energy
