Old 04-22-08, 07:09 PM   #31
dacicci's Avatar
TLCA# 14639
dacicci is on a distinguished road
i made a square slip in a round shaft using an adapter from ts and it works great will spin on rock and is farely balanced and can double in length strong and no noticeable vibration, adapter is about $50 had about $40 in tube and $10 balence job at local drive shaft joint. runs great i use a tom woods custom cv high ange in the front, had to change pinion flange thow. but my round with sqaure slip rear runs great maybe an option
HOLD THE MAYO, AND GIVE ME A SIDE OF BULLS**T
dacicci is offline   Reply With Quote
Old 04-22-08, 07:51 PM   #32
boots4's Avatar
boots4 is on a distinguished road
Have any pics you could share?
85 FJ60, testing, Cummins 4BTA, manual 4L80E, 203 to splitcase doubler, SOA, 38s, some other stuff.
build-up: http://forum.ih8mud.com/showthread.php?t=160807
boots4 is offline   Reply With Quote
Old 04-26-08, 03:50 PM   #33
OpTimuS is on a distinguished road
x2
pics would be great
Thanks friend but I'm not calculating anything. Im just going on the "if I can get it to fit" calculator
You don't need adaptor plates. That's what gaffer tape was invented for.
OpTimuS is offline   Reply With Quote
Old 04-26-08, 03:52 PM   #34
Originally Posted by Mace View Post
Tom woods unis are only good for a 1310, 1350 and I believe 1410 units..
No toy stuff..
thats bad news...... maybe will have to go with the TG uni's......
Old 04-26-08, 03:56 PM   #35
Originally Posted by bustanutley View Post
Why don’t you just build your own? You are a machinist correct? 2.5” sch 40 is a damn near perfect fit for yota flanges. I just made one last week, 8ft length of pipe cost me all of $30.
Maybe even a thicker wall section so that I cn machine down 2 lips, one on either end of the spacer.......
That is a bloody beaut idea.
Standard double cardon's front and rear, with standard slider spline inners and custom length outers.
Old 04-26-08, 04:32 PM   #36
what he said
Mace's Avatar
Mace is an unknown quantity at this point
Custom length outers? You mean the tube of the shaft itself?
I am kinda gay.......
My Myspace
Old 04-26-08, 11:05 PM   #37
Yeah Mace.
essentially I mean that (on the rear for example) I would have the standard double cardon joint bolted to the outputs shaft, the have the standard (early) L/C slip-joint inner. For the outer slip shaft I will shorten it. To shorten it (by say 4") cut a 6" length out of the shaft then machine a 1" shoulder inside of the shaft on both halves (and a 45deg chamfer on the outer edge/lip, and slide in a sleeve (2 1/8" long, 1" of sleeve in each half, with a 1/8" between the shaft to aid in weld penetration) into both halves of the shaft (interference fit), and weld the shaft together and to the sleeve. Does that explain more?
Does it make sense?
Old 05-09-08, 06:24 AM   #38
Albin is on a distinguished road
Square driveshafts are cheap, easy and work well, especially up front. I put a couple ounces of sand in mine to help with the balance and I've had mine up to at least 40 mph with no out of balance or noise issues.
My paper on doing my square driveshaft might help: http://www.rocketcityrockcrawlers.co...%20Project.pdf
Good luck.
Al
'85 4Runner
Albin is offline   Reply With Quote
Old 05-09-08, 03:23 PM   #39
slickrock's Avatar
TLCA# 18284
slickrock is on a distinguished road
go to post 19 http://forum.ih8mud.com/ca-central-v...ings-done.html
8/73 FJ40, 4" tweaked front flipped extended wheel base SUA, rear SOA, 35 Cooper STT Discoverers, fully locked, 1.5" Marlin wheel spacers, 60 series power steering, just under 100" wheel base, full cage, 60 series ignition, roof rack and custome awning, Syrius sat. radio, and a whole bunch of electrionic toys to get GPS directions and keep me in touch with other rigs in case something like the movie "Red Dawn" happens.
www.centralvalleycrawlers.org
slickrock is offline   Reply With Quote
Old 05-15-08, 05:14 AM   #40
cheers mate. homemade round I like it.
Old 05-19-08, 09:54 PM   #41
88chevota's Avatar
88chevota is on a distinguished road
Just thought I'd chime in.
Picked up a Mini 45 degree Double Cardan joint at a local yard for $50 and had it lengthened and balanced for $70. They even used the slip section from the LC d-shaft. I just redrilled my flange at the t-case and done. Plenty of travel and strong as can be. $120 is pretty cheap for a great drive shaft.
1988 FJ62 - Chevy 350 TBI, SM465 tranny, NP205 t-case, cruiser/minitruck hybrid rear axle, SOA, shackle reversal, 35" Maxxis Bighorns, 14" travel shocks all around. check out the build. All done!!! http://forum.ih8mud.com/showthread.php?t=164109
1997 FZJ80 - Collector's Edition (wife's)
88chevota is offline   Reply With Quote
Old 05-20-08, 01:37 AM   #42
Isotel's Avatar
TLCA# 16898
Isotel is on a distinguished road
You sure tony, my square shaft uses about 6-7" of its travel with stock springs Sprung over and Shackles reversed.
Most of the Travel is out when the PS tire drops away and forward
1976 FJ40 TBI350 700R4 Dana300 SOA Locked 37" PBR's
Colorado Land Cruisers
Redline Land Cruisers
CrAwLoRadO.com
FJ-40 Family Cage Ready for Sale!
Old 05-20-08, 05:19 AM   #43
So if I am going t link my front end I may not even need a long travel driveshaft?
Old 05-20-08, 08:14 AM   #44
what he said
Mace's Avatar
Most likely, no. That is one of hte nice things about running links. I use about 3" of slip in my 40. Stock U joints work just fine.
My Myspace
Old 05-20-08, 08:46 AM   #45
88chevota's Avatar
Yep checked it out the other day. everything looked pretty good.
Old 05-21-08, 10:33 PM   #46
slickrock's Avatar
TLCA# 18284
Hey Isotel, how much compression do you have available sitting at stock height? All the research when I did my shaft ,said I only need a little over an inch for compression (SOA height) on the front shaft. Now am thinking I might need to shorten the shaft a bit to get more compression.
Old 05-22-08, 08:22 PM   #47
shahrislamic radical
Gumby's Avatar
TLCA# 5658
Gumby is on a distinguished road
Bottoming out is potentially a lot more costly than pulling apart.
War Pig and Cerdito
"Don't you know, Stan, it's always between a Giant Douche and a Turd Sandwich."
Gumby is offline   Reply With Quote
Old 05-22-08, 11:23 PM   #48
slickrock's Avatar
TLCA# 18284
yeah no kidding (sorry bout the hyjack by the way). How much slip do you have available (figure your SOA?)
Old 05-23-08, 08:40 AM   #49
Gumby's Avatar
TLCA# 5658
In the front I have about 16" of slip. I'm running a four spline up front. I use a lot of it with a SOA and pretty extreme shackle angles.
In the rear I use about 2" of travel because I have a four link. I found that being really twisted up could cause my bumpstop to be completely compressed and the drive shaft would punch out the front of the transfer case.
War Pig and Cerdito
Old 05-30-08, 10:58 PM   #50
lcwizard is on a distinguished road
Or...you could buy reciever hitch 2.5" .25 square , seam removed.
Anyway, please tell me the only reason to run square is the cost.
If you want drag it on rocks they do make heavy wall DOM round. Round is far stronger in twist loads.
I've never seen a gun drilled square axle in a drag car
Originally Posted by Arya Ebrahimi View Post
This really isn't that hard. It sounds like you already have all the answers, so why are you asking?
For the inner tube I would highly recommend using 2" 1/4" wall and just grinding a small groove in the one side that aligns with the weld seam on the inside of the outer tube. Clear as mud?
lcwizard is offline   Reply With Quote
Mortgages | Loans | Loans | Cheap Car Insurance | Car Finance
