Old 04-09-08, 11:25 AM   #1
mookie's Avatar
rear steer?'s
this may be the most idiotic idea ever, i'm really not sure.... but would a front fj60 or 40 axle work as a rear steering axle? first of all is a built (30 spline longfields etc.) landcruiser front stronger or weaker than the rear axle, or is it about the same? can you flip it around so that the pinion is in the right place and it still work ok? and would it be necessary to cut and turn the knuckles to adjust the caster angle?
This is your life, and it's ending one minute at a time...
'71 FJ55
'74 FJ40
mookie is offline   Reply With Quote
Old 04-09-08, 11:39 AM   #2
Pacer's Avatar
It can be done, Wayne at Up and Over Innovations here in PA runs one like that in his comp rock buggy I know one of his axles is a flipped mini truck axle and the other is from an 80, also flipped. I can't remember which one he is running in the rear tho. I'll ask and post back up.
What are you planning to run it in? His buggy is light!
Pacer
1972 r75/5
1974 r90/6
1989 fj62
2002 325xit
Pacer is offline   Reply With Quote
Old 04-09-08, 11:43 AM   #3
mookie's Avatar
the fj40 in my sig, which is heavy as hell lol...
'71 FJ55
'74 FJ40
Old 04-09-08, 12:15 PM   #4
bustanutley's Avatar
bad idea for anything over 2500lbs. You need the strongest parts available for a d60 to make it live in a rear steer application.
The guy in this thread did it Project Lo-budget Pimpin - Pirate4x4.Com Bulletin Board
That thing is way light, he is still concerned about the rear axle.
FJ-40 on FO-DEEs
just a lil guy
HOMEGROWN
bustanutley is offline   Reply With Quote
Old 04-09-08, 09:10 PM   #5
Eskimo's Avatar
I wouldn't do it.. guy i run with has one, but his buggy is 2600lbs, and powered by a propane 22R = no power.
Rich in NC
FJ - '73 FJ-40 Cruggy - LSx/4-wheel steer Rockwells/4-link/coilovers/42's
Build thread --> http://forum.ih8mud.com/hardcore-corner/124040-keeping-low-rockwells-k-under-knife-again.html
'01 Chevy 2500HD 8.1 Allison Lux-o-tow
Eskimo is offline   Reply With Quote
Old 04-12-08, 09:46 AM   #6
I've seen it done in a FJ40 using a 40 front axle. If you had Longfields and restricted how sharp it turns I'd think you'd be fine. Unless you modify your spring width and body tub your steering angles would have to be limited anyway.
I've only ever heard of people breaking Birthfields when the wheels are near full lock.
my .02
bikersmurf is offline   Reply With Quote
Mortgages | Free Music Downloads | Charity | Synchronization fast and easy | American Flags
