Go Back   IH8MUD Forums > Toyota Tech Forums > HardCore Corner
Old 04-08-08, 07:51 AM   #1
Z()LTAN's Avatar
Castor for 39's
Castor angle for my cruiser?
what Castor should i run for 39" tires?
positive how much?
Lock, Stomp and Steer, No Fear
Z()LTAN is offline   Reply With Quote
Old 04-08-08, 08:18 AM   #2
am i missing somthing ??thought you had 37"pro comps. and had allready done the c&t,why would the castor angle need to be changed for bigger tyres??
88 vx sahara 12ht auto twin factory lockers 4"lift 37"mtr's
ausvx60 is offline   Reply With Quote
Old 04-08-08, 08:21 AM   #3
Z()LTAN's Avatar
im going to have 40's or bigger later. (trying to break things)
i have cut the knuckles but i havnt welded them up yet as i want to get the castor a1
Old 04-08-08, 09:10 AM   #4
negative castor you mean........top to the rear , bottom to the front. i do 4 degrees on mine.
attatoy is offline   Reply With Quote
Old 04-08-08, 09:35 AM   #5
Z()LTAN's Avatar
hmmm yeah top back, some people/pictures say positive some say negatave is top back....
Old 04-08-08, 11:53 AM   #6
......what?
alkaline747trio's Avatar
4-6 should be good. It's preference though, some people like more some people like less. Factory is 4 though.
'92 - 3FE POWER'D!
-- Slee 6"/OME 863J, Pro-Comp 14" ES3000/N74L, Gen. 2 Slee Front Control Arms, T-G Sliders, Ext. Diff. Breathers, DBA Gold S/D Rotors, Slee SS Brake Lines, 5.29s, Aussie Locker'd rear, 37x14 IROK Bias/38.5x11 Boggers, some black bed-liner on the outside, some orange inside, 180k.
'85 Honda Accord - 55MPG!!!
-- No air filter, Custom Burple (blue and purple) Paint.
Upstate Cruisers
alkaline747trio is offline   Reply With Quote
Old 04-08-08, 12:50 PM   #7
what he said
Mace's Avatar
They are wrong
Postive Caster is always towards the rear of the truck.
5* is a good number.
I am kinda gay.......
My Myspace
Old 04-08-08, 04:48 PM   #8
Tapage's Avatar
Originally Posted by Mace View Post
They are wrong
X2 But I thought it should be your trail rig only .. did you plan run it faster .? if not 4* should be nice ..
I thought ( based on my personal apreciations ) that more caster, more strees in your steering pump / box under turns ..
HJ-60 2H-T Intercooler Tencha
Originally Posted by pygpen
Old 04-08-08, 05:15 PM   #9
what he said
Mace's Avatar
There are diminishing returns on the actual caster #.
5 is a good median. I pretty much guarantee that you won't know the difference between 4 and 5*
And yes, it is harder on your PS system, but hell, wheeling is hard on it too
My Myspace
Old 04-09-08, 05:29 AM   #10
Z()LTAN's Avatar
so thats 5* from zero? in the up back direction?
Old 04-09-08, 09:21 AM   #11
what he said
Mace's Avatar
0* means the kingpins are directly above each other.
5* means the top KP is moved to the back of the truck. Picture the limbo
My Myspace
Old 04-09-08, 09:45 AM   #12
Medusa's Avatar
Or picture this.....
Got Rice?
Medusa is offline   Reply With Quote
Old 04-10-08, 05:35 AM   #13
Z()LTAN's Avatar
cheers med
cheers guys
Old 04-11-08, 06:36 AM   #14
Would that mean that on a trail rig 0* would be beneficial?
Less stress on steering box, and no undesirable wheel straightening up
Thanks friend but I'm not calculating anything. Im just going on the "if I can get it to fit" calculator
You don't need adaptor plates. That's what gaffer tape was invented for.
OpTimuS is offline   Reply With Quote
Old 04-11-08, 08:47 AM   #15
neg. 5 is really good number but on rocks and not daily driver more would give the steering of a grader which helps to pull around objects!
I did it again !
RidderFab is offline   Reply With Quote
Old 04-11-08, 10:09 AM   #16
what he said
Mace's Avatar
I ran my 40 for a while like that
It sucked on and off road..
The stresses on the axle from proper caster nothing compared to wheeling the rig..
My Myspace
Old 04-11-08, 10:14 AM   #17
Z()LTAN's Avatar
what about if i do some onroad kms?
Old 04-11-08, 10:22 AM   #18
On our race truck ( pics in Woodys photo page ) we run 13 neg. camber now that is very xtreme but works scary well! But if I was to do a trail rig use with moderate road travel I would with out a doubt run 7 neg. and if I do remember right Woodys when we did it is 6-7 neg.
I did it again !
Old 04-11-08, 10:40 AM   #19
Z()LTAN's Avatar
so by negative you meen positive? lol
Old 04-11-08, 11:15 AM   #20
When I say neg. the front axle -top ball joint goes the back of the truck !
I did it again !
Old 04-11-08, 11:16 AM   #21
I guess from Woodys drawing that it would mean pos.
I did it again !
Old 04-11-08, 11:26 AM   #22
......what?
Calling it camber and saying it's negative, unless you ARE talking about camber...makes me wonder....
'92 - 3FE POWER'D!
Upstate Cruisers
Old 04-11-08, 07:05 PM   #23
what he said
Mace's Avatar
He knows more than it sounds
My Myspace
Old 04-11-08, 11:18 PM   #24
......what?
I'll take your word for it
'92 - 3FE POWER'D!
Upstate Cruisers
Old 04-12-08, 02:38 AM   #25
so would this beneficial??
Old 04-12-08, 11:34 AM   #26
what he said
Mace's Avatar
Only if you think poor handling is beneficial..
My Myspace
Old 04-12-08, 06:02 PM   #27
so it would achieve nothing..........
ok cheers.
Old 04-13-08, 01:09 AM   #28
TLCA# 15288
Setting caster to zero will make it a scary ride. It wont want to go straight to save its life... You will have to HOLD THE WHEEL and pay attention because it will dart from left to right like its on crack. Very bad mojo...
Positive caster is just as the picture states. IF you insist on calling it negative even though the upper kingpin is tilted to the rear of the truck all your doing is making yourself to sound like a fool. (no offense)
Negative caster makes it easier to turn the wheel. Positive makes it track better. Both pos. and neg. caster will make the wheel return to center. Pos. just makes it go straight better but with some added resistance.
Ive seen some Mercedes spec'ed at almost 20 deg pos. caster.
Suspension version 2 for our Camaro will be in the neighborhood of 7-8 deg. pos.
My FJ40 will be around 8-10 deg. pos. Better for higher speeds and I want it to go straight when on the road without having to pay ALOT of attention to it.
If you have any type of power steering system I see no reason to set caster to a neg. number.
This is my opinion and may or may not reflect the veiws of those who may or may not give a crap...
Chris
DHONDAGOD is offline   Reply With Quote
Old 04-13-08, 01:15 AM   #29
I do give a **** and your comments are well worthwhile.
And by having such a big positive castor in your L/C how does it affect how heavy the steering is?
If I plan on running Hydro-assist will it make any difference?
