Have a Coke and a smile:D
Sealing Bead Locks........
I searched and read most of the info available. I'm looking for additional pointers on how to get the bead locks to seal.
I have 15X8 steelies with Ruff Stuff's kit welded in. I mounted 37X12.5 MT/Rs on them. Two hold air to 25 lbs, two were totally flat this morning. It's not a leak from welding the ring in. What else can I do? I have a big run this weekend, so I'm looking for quick tips right now, but I'll tear them completely apart after the run if need be. I have OBA, so at least I can air them up during the run if they're flat.
__________________ Chad 1976 FJ40: TBI350/SM465/SOA/SR/37's/ARBs/30-Longs/Metal Tech/SROR/Oeyes 1985 Toy Hilux: 6" lift/4.3L/R150F/Marlin's DUC/ARBs/30-Longs/5.29s/37's/Oeyes 2005 Dodge Ram 2500 CTD bullydogged, airlift There's plenty of room for all of God's creatures, right next to my mashed potatoes! |
Dog is my co-pilot.
Hi All:
The tire shops (sure as Les Schwab) use a sealant on the bead area of the wheel when mounting tube-less tires. IIRC I saw this stuff listed in a Grainger catalog in the tire equipment section. Good luck! Let us know how it goes. Alan |
I put a realllllllllly small layer of slime green on the bead of the tire befor i mounted them and i havent had them leak. but then agian. i havent had time to wheel with the new slime green stuff. before that i never use anything
__________________ What is rock crawling? My build http://www.pirate4x4.com/forum/showthread.php?t=637144 |
what he said
a light coat of silicone will help (install the rims then wait for 24 hrs before you inflate them.
But honestly, I bet your welds are leaking __________________ I am kinda gay....... My Myspace http://profile.myspace.com/index.cfm...endid=75712409 "Mary Poppins: In every job that must be done, there is an element of fun. You find the fun and - SNAP - the job's a game." |
X2 on the welds.....pin holes are very common in DIY beadlocks that I have seen.
The ultimate solution..................................STAUNS baby
__________________ Got Rice? |
i smeared black sillycone around the weld on mine (unbolted the beadlock ring and smear it all over).. then air it up, wait a few minutes, then let the air out.
Worked like a champ for me.. I think airing up pushed the silicone into the pinholes, then it dried.. Try some soapy water and you can pinpoint the leak easier.. __________________ Rich in NC FJ - '73 FJ-40 Cruggy - LSx/4-wheel steer Rockwells/4-link/coilovers/42's Build thread --> http://forum.ih8mud.com/hardcore-corner/124040-keeping-low-rockwells-k-under-knife-again.html '01 Chevy 2500HD 8.1 Allison Lux-o-tow |
#7 | |
Thanks for the input, everyone. I'll try the silicon route after this weekend! I'll probably try the green slime until then. I'll let you know how it works out!
Take a flapper wheel and grind the welds down smooth. If there are any low spots weld more and flapper it again until they are flat and smooth. THen take the outer ring and bevel the outside edge of the ring on the inside lip so that it doesn't cut into your tire when it's folded over . We have done multiple sets of weld ons and had no leakers with this technique . If you have to use silicone then you have done something wrong.
__________________ 1977 fj40 1985 bj60 1978 fj40 1976 fj45 in pieces 1974 fj40 Too many if you ask my wife , Never enough for me ! |
#9 | |
![]() Just kidding. That's basically what I did.
#10 |
NOOB question alert
Are the inner and outer beadlock rings supposed to be touching or not? I didn't think they were supposed to be smashed together, but I've seen 3 or 4 sets now that are touching, so I don't know.
#11 |
what he said
weld on's are not supposed to touch..
You would have to pinch the living crap out of the bead for them to touch. Also, torque is only like 25 ft lbs.. __________________ I am kinda gay....... My Myspace http://profile.myspace.com/index.cfm...endid=75712409 "Mary Poppins: In every job that must be done, there is an element of fun. You find the fun and - SNAP - the job's a game." |
#12 |
That's what I figured. So am I correct in assuming that some 'factory bead locks' will touch?
#13 |
what he said
Some do, some don't. A lot of it depends on how thick the tires bead is..
#14 |
We had the same problem with the ones we built for my 40. Two held two leaked. We took them apart this weekend and there were small hairline cracks in the weld, I assume this was from grinding the welds down a little to far. Jason cleaned them up and then added another weld all the way around, using a flapper disk, he smoothed out the new weld instead of grinding it down. We torqued all the bolts to 15 lbs., aired it up to about 20lbs, then retorqued to 20lbs. As of this morning everything is holding great!
__________________ 6/72 fj40 tlca#10212 Oh my god it's a monster!!! No,... it's just my Frank. http://www.flickr.com/photos/9460528@N02/ |
Credit Card Debt | Personal Injury Lawyer Los Angeles | Mortgage Calculator | Mobile Phones | Mortgage Calculator |
