Old 03-31-08, 10:19 PM   #1
slickrock's Avatar
TLCA# 18284
hydro assist 1.5X8X.75 DA HYD CYL goo size for FJ40
1.5X8X.75 DA HYD CYL.
I plan on Hydro assist for my fj40 , will be mounting one end of the ram to my diff and the other to the my Tie rod. I have 60 seris steering so cannot mount one end to my frame. I was thinking about a cyl. the size above. Would this be large enough to cycle my steering from stop to stop?
Or would a 1.5X6X.75 DA HYD CYL be better?
8/73 FJ40, 4" tweaked front flipped extended wheel base SUA, rear SOA, 35 Cooper STT Discoverers, fully locked, 1.5" Marlin wheel spacers, 60 series power steering, just under 100" wheel base, full cage, 60 series ignition, roof rack and custome awning, Syrius sat. radio, and a whole bunch of electrionic toys to get GPS directions and keep me in touch with other rigs in case something like the movie "Red Dawn" happens.
www.centralvalleycrawlers.org
slickrock is offline   Reply With Quote
Old 03-31-08, 10:31 PM   #2
psc told me yota axles need a 6" ram and dana's need a 8" ram. get on it
97lx450
4" slee/j's, sliders, bumpers, 3" exhaust, custom turbo, HG pm/Valve job/seals, sweet custom skid plate, Sleeoffroad parts, Buys oe parts from Cruiser Dan
used to have 37" swampers..
1 tons and 42's pending.....
Budget Blown
98 100 series. rear locker.
2008 6.7L dodge 2500 quad cab
Dusty is offline   Reply With Quote
Old 03-31-08, 11:01 PM   #3
what he said
Mace's Avatar
1.5 x 6 is the way to go.
I am kinda gay.......
My Myspace
Old 03-31-08, 11:19 PM   #4
bustanutley's Avatar
my 1.75 ram provides quite a bit more power without slowing steering down too much.
FJ-40 on FO-DEEs
just a lil guy
HOMEGROWN
bustanutley is offline   Reply With Quote
Old 04-01-08, 02:37 AM   #5
I installed the 2"X6" throw ram assist on my 85 mini truck axles and it works great
87 Samurai,Toy axles 529's Detroit f spool r,2 1/2 lifted 4404's,custom shackle reverse & duel shacked in rear,36 Swamper SX's, 8000 lb. winch, Toy FJ60 p/s, Hydro assist, 4x4 labs high steer, roll cage, Trail Tough 6.5.1 t-case gears,Toy high angle drive lines
jwade is offline   Reply With Quote
Old 04-01-08, 08:17 AM   #6
Have a Coke and a smile:D
bigndn's Avatar
TLCA# 18682
I have 4X4 labs Hysteer steering arms on mine and the 6" ram limits my turning radius terribly. My TR moves 7.75". I now have my grubby little paws on an 8" that will be installed this weekend!
MEASURE HOW MUCH YOUR TIE ROD MOVES TO BE SURE.
Chad
1976 FJ40: TBI350/SM465/SOA/SR/37's/ARBs/30-Longs/Metal Tech/SROR/Oeyes
1984 FJ60: TBI350/NV4500/ARBs/OME lift/Oeyes
1985 Toy Hilux: 6" lift/4.3L/R150F/Marlin's DUC/ARBs/30-Longs/5.29s/37's/Oeyes
2005 Dodge Ram 2500 CTD bullydogged, airlift
There's plenty of room for all of God's creatures, right next to my mashed potatoes!
Originally Posted by Mrs bigndn View Post
If it's got knockers or lockers, he'll be checking it out."
bigndn is offline   Reply With Quote
Old 04-01-08, 09:15 AM   #7
what he said
Mace's Avatar
4x4 labs arms are considerably longer than a stock FJ60 steering is. But you are right, the best option is to measure the total throw necessary just to make sure..
My Myspace
Old 04-01-08, 03:30 PM   #8
ok i am hijacking you dan
question: I know if you run the ram paralel to the tierod and the pitman is pushing less than paralell (say at 20' when the drivers side front is drooped and pass front is stuffed) there will be disproportionate arc between the pitman and the ram. thus some tendancy to oppose one onother if there is a ram on the tierod of a crossover setup.
keeping this in mind is it ok to mount the assiting ram on the tierod as opposed to the link going from my pass side highsteer arm to the pitman?
I will be running a crossover steering. I could easily run a highsteer but my tires are big and my truck is heavy and I would like to protect my knuckles and this is why I am running a crossover.
Mace?
97lx450
Budget Blown
Old 04-01-08, 03:47 PM   #9
With hydro assist, the ram only moves on its own when the box is “maxed out”, there is no definite link between the two systems. The easiest way to understand this is to hook the system up and leave the ram disconnected from its tierod mount. When steering without much resistance the ram won’t move, but when you bottom the box out in one direction of the other (turned full lock) the ram will move.
FJ-40 on FO-DEEs
just a lil guy
HOMEGROWN
Old 04-01-08, 04:11 PM   #10
slickrock's Avatar
TLCA# 18284
Mace?
did you sleeve the tierod so yours doesn't bend for the ram mount?
Old 04-01-08, 06:36 PM   #11
Nice explaination. I will ram the tierod
I have some 1.5" x 1/8 dom and some 1 3/4" x 1/4 dom and can use either for the tierod. I was planning on using the 1.5 alone. I only have tube adapters for the 1.5". but i do have some 2" x 1/4" dom I caould use to sleeve the 1.5 but this sounds like a bit overkill
97lx450
Budget Blown
Old 04-01-08, 06:53 PM   #12
what he said
Mace's Avatar
No, the ram will have to extend ( or compress) fully before the steering box will be able to function if you disconnect it. This is why larger rams feel "slow" at a stoplight. The fluid will bypass the stock box till it has a restriction, then it will let the box move. That is also the reason putting the ram on the TR is no big deal at all..
My Myspace
Old 04-01-08, 08:40 PM   #13
You are right Mace, I should have said no resistance, I have done it with the tires off the ground and the ram does not move until on the stops. With any resistance the ram will have to fully extend. Either way, not mechanically linked
FJ-40 on FO-DEEs
just a lil guy
HOMEGROWN
Old 04-01-08, 09:17 PM   #14
PKP80's Avatar
TLCA# 14900
D, I am using 1.25"x.25 DOM for the tierod and draglink all w/ heim ends. 1.5 is too thick and will seemingly cause clearance issues.
As far as the Hydro assist, I'm doing an 1.5 w/ 8" stroke (as per Slee) running off of stock 80 steering box and pump with and added oversized cooling res.
Sam Shaya
96' FZJ80 convertable
4x4 Labs Rear end/Custom shock mounts KING shocks/
other goodies, but you get the idea.
Call Sign KI6KNB
"Team Pull-OUT"
Phi Kappa Psi
PKP80 is offline   Reply With Quote
Old 04-01-08, 11:45 PM   #15
Im using 1 ton tre's except at the pitman where I am using an 80 series tre from marlin
I like the thick look
97lx450
Budget Blown
Old 04-01-08, 11:47 PM   #16
I like the thick look and with crossover there shouldn't be a clearance issue
97lx450
Budget Blown
Old 04-02-08, 11:08 AM   #17
Me and my Big Wheel
camcruiser13's Avatar
you will love the ram, and wish you would have done it sooner,
cc
76' fj40
camcrusier13 build threads the following are links, just click, go on try it
Traction Bar
Sliders
Ram Assist
Bumper Poison Spider Style
Shackle Reversal
Half Doors
if your doing it im sure ive done it, need help just ask.......
camcruiser13 is offline   Reply With Quote
Old 04-02-08, 02:34 PM   #18
what he said
Mace's Avatar
1.5 x .120 dom is gonna bend if you hit a rock..
I prefer .250 1.5 or thicker.
My Myspace
Old 04-02-08, 07:24 PM   #19
thats why i love this place. 1 3/4 x 1/4" dom is now on its way to my house. the local steel yard promised to have it and 100 feet of 1 3/4 x .120 dom at my house by friday. new bender should be here any day....
97lx450
Budget Blown
Old 04-02-08, 09:00 PM   #20
what he said
Mace's Avatar
I did mean thicker material, not diameter
But that will be stupid strong steering.
My Myspace
Old 04-02-08, 10:38 PM   #21
slickrock's Avatar
TLCA# 18284
I'm going to hijack my thread back, anyone know a good place tofind a 1.5X6X.75" ram for under 60 bucks?
Need to track down on so Dusty can port my box next weekend
Old 04-02-08, 11:31 PM   #22
I need to keep the inside diameter the same cause I already have tube adapters. I worry that if my tierod is too strong the knuckle may become the weak link. But weakness is poorly tolerated on this build-no weakness permitted
Dan you need to get your own thread. have you checked the local morgan and slates? ill port your box and you can figure out how to mount the bender to my driveway. I was thinking about welding a mount to the fire hydrant
97lx450
Budget Blown
Old 04-03-08, 09:14 AM   #23
slickrock's Avatar
TLCA# 18284
Good idea. Maybe you can simply say it is for emergency "doctor" stuff that other lower people wouldn't understand.
It is called a hammer drill and readhead bolts. Dawn will love it. My deal on a ram no longer sell that item so I need to track down something. THey do have it at Morgan Slates, but don't know what size they have or how much.
Old 04-03-08, 09:24 AM   #24
bigndn's Avatar
TLCA# 18682
Mine from West Texas Offroad ran $160. Not saying it can't be found for $60, but good luck!
Chad
Old 04-03-08, 11:00 AM   #25
what he said
Mace's Avatar
Call Baileynet.com and see what they have available.
My Myspace
Old 04-03-08, 11:39 AM   #26
