Old 03-30-08, 11:52 AM   #1
quick question on sbc timing
ok just did a 350 swap into fj60 and engine builder stuck on a set of 305 heads and a torquer cam and i cant remember from who but being sunday and i cant get hold of him till tomorrow i was wondering where to set ignition timing. on a 88 350 tbi have it set to 0 but heard anywhere from 2 to 10 btdc. does this make any sense
thanks all
Bryon
blackandbluefj is offline   Reply With Quote
Old 03-30-08, 08:17 PM   #2
hammerhead's Avatar
I run 7° on my old carbed motor with HEI...
utah4x4club.com
U4WDA
hammerhead is offline   Reply With Quote
Old 03-31-08, 08:00 PM   #3
Former Wheeler
Gumby's Avatar
TLCA# 5658
8ish would be a good place to start. If it starts to ping at all with the higher compression heads, turn it back.
If you want to run premium you can go a little more, if you run regular and/or live where it gets good and warm, you need to run less.
War Pig and Cerdito
"Don't you know, Stan, it's always between a Giant Douche and a Turd Sandwich."
Gumby is offline   Reply With Quote
Old 04-01-08, 10:30 AM   #4
camcruiser13's Avatar
i think it like on e degre for every thousand feet above sea level? does this sound right
cc
76' fj40
camcrusier13 build threads the following are links, just click, go on try it
Traction Bar
Sliders
Ram Assist
Bumper Poison Spider Style
Shackle Reversal
Half Doors
if your doing it im sure ive done it, need help just ask.......
camcruiser13 is online now   Reply With Quote
Old 04-01-08, 07:02 PM   #5
kc_chevota's Avatar
TLCA# 13454
0 deg if you have a stock chip, i run mine at 5 with a aftermarket chip and have the knock sensor hooked up. don't forget to open the timing jumper when seting.
Rob
Rob R.
1979 VJ40
1984 FJ60
Coming soon 09 Get Flat Nasty With TAC
Tornado Alley Cruisers vice pres
I know the voices aren't real, but they do have some good ideas.
kc_chevota is online now   Reply With Quote
Old 04-05-08, 09:05 PM   #6
Eskimo's Avatar
Man, 305 heads never flowed very well, not sure why he'd do that...
Rich in NC
FJ - '73 FJ-40 Cruggy - LSx/4-wheel steer Rockwells/4-link/coilovers/42's
Build thread --> http://forum.ih8mud.com/hardcore-corner/124040-keeping-low-rockwells-k-under-knife-again.html
'01 Chevy 2500HD 8.1 Allison Lux-o-tow
Eskimo is offline   Reply With Quote
Old 04-05-08, 10:10 PM   #7
hei ............. 8 degrees and addjust higher slowley till pinging then retard 2 degrees, TBI ........well why would you waste your time?
attatoy is offline   Reply With Quote
Old 04-08-08, 06:21 PM   #8
well he has done many boat motors like this and says it brings thee torque range down to idle and quite frankly it seems like its true. I didnt need or want a racecar, already did that and got the tickets. and i have already snapped a rubber motor mount so i seems pretty peppy but i've yet to get offroad
thanks
Bryon
Old 04-09-08, 06:31 AM   #9
Former Wheeler
Gumby's Avatar
TLCA# 5658
That's exactly why it's done. Better low end and higher compression. TBI works great for crawling. I'd take it over TPI any day.
War Pig and Cerdito
Old 04-09-08, 04:33 PM   #10
Alz Toy's Avatar
TLCA# 16471
601's, and 416's are supposed to be decent heads, came on the HO motors. Smaller ports and valves mean higher velocity up to a point ( lowwer rpm's ), which means more torque and throttle response. The 601's are supposed to be the best of the lot. Good chamber design, allows running a LITTLE higher comp ratio without problems. Lots of Guys doin this on the Chevelle Tech forum, on there street cars. Just passing some info on. Al
'77 FJ40, 350/ SM 420 / 3spd t/case, TPI Smoky Mtn lift, 35's , Scout p/s, Tornado Alley Cruisers member
Alz Toy is offline   Reply With Quote
Old 04-10-08, 06:57 AM   #11
Roll Tide!
'74 UA FJ's Avatar
305 heads are the cheap way to bump up compression on a 350. Another (better) way is to buy 350 vortec heads.
1974 FJ40 FI vortec 350, H42/Orion 4:1, 4" lift, 35x15.50 SXs on MRW beadlocks, lock-rited f/r, Saginaw ps, etc, etc.
1994 FZJ80 with lockers and 285 revos.
'74 UA FJ is online now   Reply With Quote
Old 04-10-08, 07:47 AM   #12
Former Wheeler
Gumby's Avatar
TLCA# 5658
votec heads are a minimum $100 + another $100 to find out they are cracked at the center coolant holes.
305 heads should be damn near free.
I had 305 heads on my T100 350, but recently put that block under vortec heads and intake in a Suburban.
War Pig and Cerdito
Finance | Mobile Phones | Mobile Phones | Loans | Online Advertising
