Samurai on Toyota axle build
This is what I bought in Sacramento. I'm gona keep this one away from the dang trees!!
My new steering: Toyota P/S box KRC high pressure P/S pump Trail Gear 2" ram hydro assyst large alluminum resevor Jan. 14, 2008 Its on like a chicken bone, and the build begins. In my shop at 11:00 pm Jan. 15, 08 No more running gear. 3:00 AM Got the 1.3 out and started replacing some of the not so straight body parts. Built my front cross member Made my spring hangers for the rear and ready to bolt them on Got most of the body work done. 16V installed front hanger welded on Rear axle going in Suspension done Out w/the old dented and cracked winder frame and in w/the new I taped my FJ60 box for Hydro Assist FJ60 P/S box is mounted Hydro assist is installed __________________ 87 Samurai,Toy axles 529's Detroit f spool r,2 1/2 lifted 4404's,custom shackle reverse & duel shacked in rear,36 Swamper SX's, 8000 lb. winch, Toy FJ60 p/s, Hydro assist, 4x4 labs high steer, roll cage, Trail Tough 6.5.1 t-case gears,Toy high angle drive lines |
Front and rear 85 Toyota CV D-lines built and installed
Spent Sunday sanding all day Primered and welded on beed locks Tuesday Smokey Got it up on rollers. I gave it a paint job. It is my 1st and up close it looks like a seagle took a **** on it. One day when I have more time and money I'll get a good paint job. I got these corner covers from Trail Tough to cover that nasty dent there on the corner Out on to the trailor to the car wash and clean the under carrage so I can paint it. Prerdy much trail ready.:driving: I'm still in a bit of a delima about weather I want to have fender flares or not. What do you think? Beed locks done and it looks like a beast! KRC pump installed Trail Gear X-large p/s fluid resevor I finished up w/the P/S hyro assist and WOW! No steering probs at all. Installed the CD player Installed the rock lights I put my Trail Tough bad boy rock sliders on and a piece of dimond plate on the rocker panel. I did not like the chrome dimond plate look so I painted all of the black and it looks alot better.m2c Installed my KC lights Installed the Trail Tough off set radio antina 2 months worth of work on this beast almost ready __________________ 87 Samurai,Toy axles 529's Detroit f spool r,2 1/2 lifted 4404's,custom shackle reverse & duel shacked in rear,36 Swamper SX's, 8000 lb. winch, Toy FJ60 p/s, Hydro assist, 4x4 labs high steer, roll cage, Trail Tough 6.5.1 t-case gears,Toy high angle drive lines |
wow . looooong front shackles..
__________________ EBI bitch 81 minitruck , frame shortened 12.5 inches, wheel base at 101 inches, s10's , dual t-cases, e-z locker front, welded rear, and 36" michelin xl's all cut up
I don't know what your talking about. Those are nomal 2" lifted shackles from 4-wheel parts
that thing is awsome mate!
what the DC drive shafts set you back? __________________ Lock, Stomp and Steer, No Fear
#6 | |
Either way, excellent work!!! Two months and an awesome, capable trail rig, I am jealous, and looking forward to seeing some action shots.
__________________ Pacer 1972 r75/5 1974 r90/6 1989 fj62 2002 325xit |
I've never seen a fj60 box tapped that way... does it work pretty well?
__________________ "Just bump it" I am offended by reality all the time. http://www.cascadecruisers.com/ http://www.myspace.com/zachsu ROTW: http://forum.ih8mud.com/60-series-wagons/198064-rotw-brokenparts-fj-60-a.html |
Sweet, A Sami Build on Mud! Nice!
on Hydro Assist, as long as you tap into the proper Pressure cavity's it should not matter where you do it.. Lookin good.. __________________ 1976 FJ40 TBI350 700R4 D300 SOA Locked 37" PBR's Protected by REDLINEColorado Land Cruisers - Club Redline Land Cruisers - Safety First CrAwLoRadO.com - Just Check it out
my suspension sits at a similar angle and it seems to work ok.. mine is not quite as high though __________________ 1976 FJ40 TBI350 700R4 D300 SOA Locked 37" PBR's Protected by REDLINEColorado Land Cruisers - Club Redline Land Cruisers - Safety First CrAwLoRadO.com - Just Check it out
#10 | |
my brother wants to do the same thing to his sami. just have to find him some axles __________________ cc------------- 76' fj40 camcrusier13 build threads the following are links, just click, go on try it Traction Bar Sliders Ram Assist Bumper Poison Spider Style Shackle Reversal Half Doors if your doing it im sure ive done it, need help just ask....... |
#11 |
pretty fast build ..
Did you tapped your Sbox as is .. asembled . ? |
#12 |
This is my 3rd suspension like this and have had no issues w/the steering. I'm also running 4x4 Labs steering arms that put the tie rod behind the axle.
The D-lines set me back $300.00 I tap the box into the main vain at the top and took the box apart to do the housing and it works great. __________________ 87 Samurai,Toy axles 529's Detroit f spool r,2 1/2 lifted 4404's,custom shackle reverse & duel shacked in rear,36 Swamper SX's, 8000 lb. winch, Toy FJ60 p/s, Hydro assist, 4x4 labs high steer, roll cage, Trail Tough 6.5.1 t-case gears,Toy high angle drive lines |
#13 |
Test run to Praire City in Sac. Had a really good day. The onlt thing that broke was a hub sheerd off all the studs but those can be replaced. Need to do a little more trimming on the rear.
#14 |
that is some great flex,
di you reinforce the frame where you streched it out front, the reason i ask is we just didi this to my brothers and i think we should add some fish plates etc.. __________________ cc------------- 76' fj40 camcrusier13 build threads the following are links, just click, go on try it Traction Bar Sliders Ram Assist Bumper Poison Spider Style Shackle Reversal Half Doors if your doing it im sure ive done it, need help just ask....... |
#15 |
I plated the frame top and bottom where I lengthend it
#16 |
wrong, looks like its gunna kill the pinion angle. but if it work good for him then great. wicked sami btw
#17 |
Pinion angle sits good. You can't realy tell in the pic but it is pointed upward
#18 |
did some clearance on the rear fenders and its perfect now. all I have left to do is my roll cage
#19 |
NCZ ROCK4XFABRICATION CAGE
Lay out Working on the back Front hoop fits really good and tight __________________ 87 Samurai,Toy axles 529's Detroit f spool r,2 1/2 lifted 4404's,custom shackle reverse & duel shacked in rear,36 Swamper SX's, 8000 lb. winch, Toy FJ60 p/s, Hydro assist, 4x4 labs high steer, roll cage, Trail Tough 6.5.1 t-case gears,Toy high angle drive lines |
#20 |
nice cage.
those prefab cages are not bad aye __________________ Lock, Stomp and Steer, No Fear
#21 |
very nice
#22 |
got the cage all put together and it is very nice.
#23 |
Nice build. As far as pre-fab tubing work goes, that is a very nice cage.
#24 |
Thanx
#25 |
Went up to Cow Mountain for the day. Here are some pics. I'll get some video soon.
