1FZ-FE mated to H42/H55F tranny?
I know the 1FZ-FE was not originally mated to a H42/H55F tranny but rather an A442 (I think) auto tranny.
My quesiton is, other than the work requried to do it, how hard would it be to make a bell housing to mount a H series tranny to the 1FZ-FE? I suppose the choice is make a "plate" with a change in bolt pattern or make a whole new weld together bellhousing. Any other issues why the engine wouldn't fit in a 60? Height, width, etc.? I am not worried about the electronics, etc, just getting it clear the firewall and hood. __________________ 83 FJ60, major project in progress Check out status of the build: http://forum.ih8mud.com/60-series-wagons/128847-83-fj60-build-up-thread.html |
Dog is my co-pilot.
Hi All:
The 1FZ-E was offered with a five speed transmission in some markets, such as Venezuela. Not sure whether it was the H55F or one of the variations of the 151 Series transmissions. Have you checked with Spector Off-Road? They seem to have everything and anything (at a price, of course!) Good luck! Alan |
Yeah, upon further reading it is a different non-us transmission.
I am going to dump the idea for now. Thanks! __________________ 83 FJ60, major project in progress Check out status of the build: http://forum.ih8mud.com/showthread.php?t=128847 |
Wiring must be a headache also...
But it would be the perfect petrol engine for the 60! __________________ Looking for an FJ55. |
Hi some help ..
The H151 come factory in the 1FZ-FE and in the 1HD-T engines .. late 7* series with the 1HZ also come with the R151 .. The 1HZ ( that share the same bolt pathern that the 1HD-T and 1FZ-FE ) come with H55F tranny and the HF1A t-case on the 70 cruisers pre 90 .. It means if that you found the Bellhousing ( never search in my EPC ) you can bolt an H151 with a 2H engine .. The issue it's the 2H use a 275mm clutch and the 1FZ-FE and 1HD-T 300mm clutch .. The Other issue are the tranny input shafts that in the 1HZ are 21 fine splines and in the 1HD-T are 14 IIRC .. |
#6 | |
Diesel for blood
I think the H150 has no electrics and the H151 does,the "1" denoting the dfference. __________________ HZJ75 cab chassis 95 model ,stocker FJ73+1HZ Diesel NEW GEARBOX 1HZ =same power as 3F with 30% better fuel economy 2in Dobinsons lift.Powerdown adj shocks 33 in BFG A/T HJ61 with slidin windas regrettfully SOLD:(Volvo 740 GL |
Other than the electronics, is there any problem just throwing the entire FJZ80 driveline in? Engine, Auto, transfer case?
Only problem I see is the full time AWD? Wiring isn't too big a concern, it is the other stuff... EDIT: Looks like you can get a part time 4WD/2WD kit at Slee: Slee - Drivetrain - Drive Shafts __________________ 83 FJ60, major project in progress Check out status of the build: http://forum.ih8mud.com/showthread.php?t=128847 Last edited by Project60; 03-01-08 at 10:57 AM. |
I will go with part time all the way or at least remove the rear of the HF2AV .. the VC .. and run with the CDL activated .. quite easy.
It sounds like it is a fairly easy swap
?Transfer case drops on the passenger side, new motor mounts, new t-case mount, drive shaft mods, wiring... Am I missing anything stupid obvious like I need to do an SOA to clear the engine, t-case drops are wrong,etc?? Why has no one else went this route?? __________________ 83 FJ60, major project in progress Check out status of the build: http://forum.ih8mud.com/showthread.php?t=128847 |
Credit Card | Property for sale in Spain | Adverse Credit Remortgage | Credit Cards | Electrical Shops |
