Go Back   IH8MUD Forums > Toyota Tech Forums > HardCore Corner
Old 02-02-08, 12:07 AM   #1
40 build
I would like to get some feed back on my build. I have a 40, and I have a rolled 97 ZJ grand Cherokee. The 40 has zero powertrain. Pretty much a rolling frame and body. My point is, I wanna put the EFI 4.0 Auto trans and t-case, in the 40. I also wanted to swap the Dana 30 and 35 4 link set ups off of it to the 40.
Any of you think it would be worth the time? Doing the work is not a prob for me. Just would like some input.
Thx,
Allen
Keep the rubber side down..
AllenAllen is offline   Reply With Quote
Old 02-02-08, 12:19 AM   #2
brokenparts's Avatar
TLCA# 16127
I'd search for at least some LC drivetrain... the dana 30 and 35 are a downgrade from the LC junk.... especially if you can find some 60 series stuff.
brokenparts is online now   Reply With Quote
Old 02-02-08, 12:30 AM   #3
the only draw backis if I have LC axles I cant use my jeep eng, trans and T-case. Pumpkins r on diff sides
Old 02-02-08, 12:36 AM   #4
fj40forlife's Avatar
TLCA# 5624562435
Get a t case. thats pass side drop and a center rear end from a pick up. But i would never evne put does jeep axles under a fj40
What is rock crawling?
My build http://www.pirate4x4.com/forum/showthread.php?t=637144
fj40forlife is offline   Reply With Quote
Old 02-02-08, 12:38 AM   #5
Hottrod81's Avatar
TLCA# 18127
I think you would be highly disappointed.
www.centralvalleycrawlers.org
My 4Runner Build
Originally Posted by Toyrunner87 View Post
I treated that hood like Ike treated Tina and it still won't budge.
Hottrod81 is offline   Reply With Quote
Old 02-02-08, 10:26 AM   #6
Hudson's Dad
LCOwner's Avatar
The 4.0 is not such a bad engine once they put the EFI on. And the auto is as good as any other. If you dead set on doing this I'd look for a Dana 300 and put that in rather than the 241 (or what ever it is). Keep the LC axles if you can they're way better and can be upgraded to beyond what that 4.0 can put out.
America now has BO. Can you smell it?
LCOwner is offline   Reply With Quote
Old 02-07-08, 02:08 PM   #7
Tapage's Avatar
Same idea .. I would choose the engine and tranny, adapter to a junkyard split case and run the toy axles .. maybe your fab skills are good enought to run coils from the ZJ onto the 40 .. ( I thought should be more less the same weight )
Believe the t-case on the ZJ it's a 231 . ?
HJ-60 2H-T Intercooler Tencha
Originally Posted by pygpen
Old 02-07-08, 03:25 PM   #8
Isotel's Avatar
TLCA# 16898
i think your better off selling the jeep whole, and building it with that money..
Although it would be nice to Piss off the Purists with an all jeep FJ40, LOL..
The issue with the jeep suspension is its all week, Brackets are week, Links are week, Steering is Junk, Axles are week, all that stuff will start breaking if you wheel it decently hard on 33's
You could adapt the 4.0 and auto to a Dana 300 and use FJ60 Toyota Axles, or go up to one tons. then just build your suspension to suit.. Leaf springs in the front Sprung over, and some sort of linked rear setup!
1976 FJ40 TBI350 700R4 D300 SOA Locked 37" PBR's Protected by REDLINE
Colorado Land Cruisers - Club
Redline Land Cruisers - PM me for info on our products or to order!
CrAwLoRadO.com
Old 02-09-08, 12:12 AM   #9
The Anti-Leafer
LC_Hamma's Avatar
TLCA# 3343
So very true speaking from someone who's analyzed all the stock brackets closely. I adapted a coil suspension, similar to a TJ, & had the same frame of mind that I could save a bunch of time just swapping out most of the link/ coil brackets onto my 40 axles. After buying all the used brackets all I eventually used was the lower front coil buckets & rear top & bottom coil buckets. Everything else was, as mentioned above, too light of a guage of metal for real world wheelin. Don't even think the short, thin walled, too small dia. link mat'l. & bushings used are adequate either. Happy buildin dude!
'72 FJ55 http://forum.ih8mud.com/fj55-iron-pig-preservation-society/76835-pig-chebby-avalanche-trim-%3D.html
'73 FJ40 http://s132.photobucket.com/albums/q...&addtype=local
'78 FJ40 - future crawler in pieces
'93 Ram W350 5 spd. SRW CTD
'99 Ram 3500 4X4 5 spd. DRW CTD
'74 BMW 3.0CS future project
LC_Hamma is offline   Reply With Quote
Advertising | Loans | Credit Cards | Personal Loans | Loans
