h1 back spacing
I found a deal on some recentered h1 rims. They have been back spaced by copperhead fab 3.75. I'm planning on running my d60 and 14 bolt at full width. Good idea or ?
The Anti-Leafer
Since you're runnin 16.5's, caliper clearance won't be a problem, even w/ disk on the rear.... Run IT
__________________ '72 FJ55 http://forum.ih8mud.com/fj55-iron-pig-preservation-society/76835-pig-chebby-avalanche-trim-%3D.html '73 FJ40 http://s132.photobucket.com/albums/q...&addtype=local '78 FJ40 - future crawler in pieces '93 Ram W350 5 spd. SRW CTD '99 Ram 3500 4X4 5 spd. DRW CTD '74 BMW 3.0CS future project
that's the info i was looking for... Thanks. Any idea of what approx width I'd be at running 14" wide tires ( iroks).
what he said
~ 86" wide...
Or so.. Make the trailer fenders drive over ![]() My H1 rims are about 5.5" BS... __________________ I am kinda gay....... My Myspace http://profile.myspace.com/index.cfm...endid=75712409 "Mary Poppins: In every job that must be done, there is an element of fun. You find the fun and - SNAP - the job's a game." |
damn that's wide
what he said
my 40 is 82"
I really like the width.. __________________ I am kinda gay....... My Myspace http://profile.myspace.com/index.cfm...endid=75712409 "Mary Poppins: In every job that must be done, there is an element of fun. You find the fun and - SNAP - the job's a game." |
should be liveable... I suppose if its too wide I could do some narrowing.
picking these up...
__________________ "Just bump it" I am offended by reality all the time. http://www.cascadecruisers.com/ http://www.myspace.com/zachsu ROTW: http://forum.ih8mud.com/60-series-wagons/198064-rotw-brokenparts-fj-60-a.html |
The Anti-Leafer
You know that sh!ts heavy right? 3/8" plate centers + 1/4" plate rock ring? I bet your at 60 lbs. a wheel right now. You gonna add a chamfer to those lug holes ain't ya?
__________________ '72 FJ55 http://forum.ih8mud.com/showthread.php?t=76835 '73 FJ40 http://s132.photobucket.com/albums/q...&addtype=local '78 FJ40 - future crawler in pieces '93 Ram W350 5 spd. SRW CTD '99 Ram 3500 4X4 5 spd. DRW CTD '74 BMW 3.0CS future project
#10 |
what he said
they are HEAVY..
15" steel rims with 39.5" Iroks = 80 ish lbs each Recentered hummer rims with 39.5" Iroks = 135 lbs each... Then fill the fronts with water... 330 lbs each
#11 |
well, I'm gettin a good deal on them and I'm trying my best to collect buggy parts on a budget so I'm less likely to say screw it and start cutting on the 60... at least the weight will be on the bottom side right?
42s are the plan.
#12 |
not to hi-jack my own thread but speaking of water in the tires....
Do you think there is any advantage of putting water in my front tires at Moab... I bought one of those snazzy water fill tire thing-a-bobs but have been reluctant to fill them for the trails around here but since I'm trailering my 60 to Moab I thought it might be worth it? Or am I asking too much of my 30 splines with 39.5s? __________________ "Just bump it" I am offended by reality all the time. http://www.cascadecruisers.com/ http://www.myspace.com/zachsu ROTW: http://forum.ih8mud.com/60-series-wagons/198064-rotw-brokenparts-fj-60-a.html |
#13 |
what he said
no reason with stock cruiser knuckles...
Moab has excellent traction anyway.. __________________ I am kinda gay....... My Myspace http://profile.myspace.com/index.cfm...endid=75712409 "Mary Poppins: In every job that must be done, there is an element of fun. You find the fun and - SNAP - the job's a game." |
#14 | |
#15 |
Ride On...
So is the one ton stuff going under your 60 or is this stuff for the buggy. Either way its cool
#16 |
The Anti-Leafer
![]() Dam, I wouldn't try that unless equipped w/ Bobby's 60 birfs & treated R & P. Carrier side gears would be next to :nuke: Broken - you runnin stock Spicer 30 spline outers or cromo stuff? __________________ '72 FJ55 http://forum.ih8mud.com/showthread.php?t=76835 '73 FJ40 http://s132.photobucket.com/albums/q...&addtype=local '78 FJ40 - future crawler in pieces '93 Ram W350 5 spd. SRW CTD '99 Ram 3500 4X4 5 spd. DRW CTD '74 BMW 3.0CS future project
#17 | |
I'm really really really tryin to keepin my 60 as it sits now and just collecting buggy parts over the next year for a true hardcore wheeler. I'm soooo tempted to just throw the 1ton stuff under there, sell the old stuff(axles, toybox, etc) and order up an atlas, and get to cuttin but I'd really hate to do that to her right now.... __________________ "Just bump it" I am offended by reality all the time. http://www.cascadecruisers.com/ http://www.myspace.com/zachsu ROTW: http://forum.ih8mud.com/60-series-wagons/198064-rotw-brokenparts-fj-60-a.html Last edited by brokenparts; 02-01-08 at 01:43 PM. |
#18 | |
I really really think I am pushing my luck running a tbi 350, th350, 4 to 1 toybox to split case, and 39.5s with a mild to heavy foot (not to mention my 60 weighs 5400lbs.) but so far I've had good luck. ![]()
#19 |
Go 1ton stuff under your 60 series ..
#20 |
what he said
Buggy...
Buggy all the way.. __________________ I am kinda gay....... My Myspace http://profile.myspace.com/index.cfm...endid=75712409 "Mary Poppins: In every job that must be done, there is an element of fun. You find the fun and - SNAP - the job's a game." |
#21 |
geez, you guys are a lot of help.
#22 |
Build a buggy and keep your 60 for wet days and snow runs. Then you can tow your buggy with your 60 and be set for either environment.
__________________ 85 FJ60, testing, Cummins 4BTA, manual 4L80E, 203 to splitcase doubler, SOA, 38s, some other stuff. build-up: Family Haulin' FJ60 |
