Go Back   IH8MUD Forums > Toyota Tech Forums > HardCore Corner
Old 01-31-08, 10:53 PM   #1
80s muncher
2badfjs's Avatar
modded fliped rear 60 springs, front and rear
i've been in a long process of this mod on my 69/40
the plan has been to use the to 2 military wrap springs off two sets of rear 60 springs and mod them with some lifted 40 springs.
throw some 60 axles under the 40,and add disc brakes to the rear axle.
scout power steering is in the plan also.
i'll try to keep the thread posted as i get opportunities to work on it.
hoping to have it all done by april (a deadline to get the 40 out of the garage, for reasons i won't disclose right now)
i have the rear springs in and the rear axle in. i have changed the shackle angle from the first time i mounted them. i'm happy with the second mounting and the shackle angle. (hope i can get it out of the garage)
as for the front.
i have all the stock hangers removed as of tonight.
the front axle has been together for some time now. it's just been waiting for its new home
next will be outboarding the new Ruffstuff hangers.
just a few pics
SOLID ROCK OFF-ROAD
http://www.solidrockoff-road.com/
1991-92 80 series sliders available, WITH CAT PROTECTION!
It's how YOU want it, i'm just here to build it for you.
SLIDERS FOR 40s' 60s' and 80s' plus a little bit more
2badfjs is offline   Reply With Quote
Old 01-31-08, 10:54 PM   #2
80s muncher
2badfjs's Avatar
just a few more of the front end
SOLID ROCK OFF-ROAD
Old 02-01-08, 04:27 PM   #3
projektdotnet's Avatar
Finally getting around to using those skycrappers eh?
"Those who would give up essential liberty to purchase a little temporary safety, deserve neither liberty nor safety." -Benjamin Franklin
projektdotnet is offline   Reply With Quote
Old 02-01-08, 05:51 PM   #4
Tapage's Avatar
It looks that you are in the top of the height line for your garage
HJ-60 2H-T Intercooler Tencha
Originally Posted by pygpen
Old 02-05-08, 05:21 PM   #5
80s muncher
2badfjs's Avatar
a little midnight madness
so in the middle of the night i get to work on the 40.
welded the hangers to plates the other day.
tried to set up the right side as best i could.
measured to 60 axle to get "center" 29.5" pin 2 pin.
so this is the spec i'm working off of as far as centering the hangers.
as far as the rear pivot hanger, it is about as close to the stock location as possable.
the front mount is moved forward to the front edge of the bumper.
i will only tack these up to see how everything sits once the axle is in and the weight of the 40 rests on the springs. (ride heigth and shackle angle)
only then will i finish welding everything up.
i'm hoping the front will be just a tad higher than the rear. this is why i used a 4" pack in the front and a 2.5" pack in the rear.
i also started removing the steering box before i start on the drivers side.
one step closer i guess
SOLID ROCK OFF-ROAD
Old 02-05-08, 05:23 PM   #6
80s muncher
2badfjs's Avatar
more
SOLID ROCK OFF-ROAD
Old 02-05-08, 09:09 PM   #7
Isotel's Avatar
TLCA# 16898
Lookin Good Bud!
1976 FJ40 TBI350 700R4 D300 SOA Locked 37" PBR's Protected by REDLINE
Colorado Land Cruisers - Club
Redline Land Cruisers - PM me for info on our products or to order!
CrAwLoRadO.com
Old 02-05-08, 09:18 PM   #8
Cruiserdrew's Avatar
TLCA# 11734
Looks very good. Wise choice to keep the shackles up front. I wish I had done that. Nice welds too.
Those rear tires went waaay back. That rig should be great in the rocks.
?Ruff Stuff bits??
Just personal opinion, but after a year of use, beefed up 60 series springs are the way to go for FJ40 suspension. You will also enjoy the wider track with the FJ60 axles.
What are you doing for high steer?
Nice build. Looking forward to the outcome.
Andrew
1984 FJ-60 H55f, 4.11, Now SOA!
1997 FZJ-80 Driveway queen
Old 02-05-08, 09:22 PM   #9
Dog is my co-pilot.
Josie'sLandCruiser's Avatar
TLCA# 6446
Hi All:
Looking good! Your project is great!
I just did a 60 Series rear spring swap on my FJ40 (SUA, using OMEs.) Currently getting the rear drive shaft lengthened, and awaiting some longer shackle side plates from Marlin Crawler (the shackles I used were not long enough.)
How do you plan to mount the shocks in the rear?
Regards,
Alan
www.seattlecruiserheads.com
Josie'sLandCruiser is offline   Reply With Quote
Old 02-06-08, 09:21 AM   #10
80s muncher
2badfjs's Avatar
Q:Lookin Good Bud!
thanks trevor
Q: Drew, Looks very good. Wise choice to keep the shackles up front. I wish I had done that. Nice welds too.
and if my fronts had been flipped i'd have the same outcome.
?Ruff Stuff bits??
yes sir!
no hi-steer. keeping it SUA
me2.
Q: jose, How do you plan to mount the shocks in the rear?
don't know yet but i'm sure i can make something work
i'll probably make a new x-member for sure. i'm gonna need it anyway to attach a limit strap for the axle.
SOLID ROCK OFF-ROAD
Old 02-08-08, 09:53 AM   #11
BELMONT148's Avatar
TLCA# 16668
Looks good. Those Ruff Stuff brackets look nice. That is the next progression of my front end. I hate the SR on mine, and I am going to redo it just like yours. May or may not go with the 60 axles and springs. Depends on if I can get a donation of those bits in the next year. The outboarding doesn't look as hard as I thought.
Jeremy
Project Evelyn
71' FJ40 W/ 78 2F, 4 speed Tranny & Transfer
SOA, 38" TSL's, 4W discs
"When you rob Peter to pay Paul, you will get the vote of Paul. If there are more Pauls than Peters, you win the election."
BELMONT148 is online now   Reply With Quote
Old 02-08-08, 09:58 AM   #12
BELMONT148's Avatar
TLCA# 16668
PS- I would check your shackle angle with the weight on the springs before you burn those brackets in. May need to move forward or backward a little to get good ride and flex.
Jeremy
Project Evelyn
Old 02-08-08, 10:04 AM   #13
80s muncher
2badfjs's Avatar
Jeremy
thanks, i've done that.
i used a floor jack to compress the spring untill the 40 came off the jack-stand.
it looks just about right, i'll shoot a pic this weekend.
hoping to get the axle under it tomorrow or tonight
SOLID ROCK OFF-ROAD
Old 02-08-08, 10:02 PM   #14
80s muncher
2badfjs's Avatar
full weight of the 40 is now on all fours
i have 103" wheel-base and some pretty good shackle angles.
thanks to 84cruiser for helping me move the axle under the front
i could actually stand on the front bumper and bounce the snot out of the front end (without shocks)
the shackles never let the springs lock forward.
SOLID ROCK OFF-ROAD
Old 02-09-08, 09:37 PM   #15
Dog is my co-pilot.
TLCA# 6446
Hi All:
"2badfjs," you say your rig now has a 103 inch wheelbase. Can you explain how you gained that extra 13 inches?
With the 60 Series rear springs, I can see you gaining four inches in the rear, but nine inches in front?
No disrespect intended - just very interested in the build you have done on your rig!
Thanks!
Alan
[quote=2badfjs;3022310]
<snip>
Old 02-09-08, 10:51 PM   #16
80s muncher
2badfjs's Avatar
[quote=Josie'sLandCruiser;3024358]Hi All:
Thanks!
Alan
Originally Posted by 2badfjs View Post
<snip>
103" is right!
i'll measure the distance from the bumpstops to the axles to get the difference.
using rear 60 springs at both ends might have something to do with it.
both front and rear shackle hangers are at the very ends of the frame.
still trying to get the manual steering box out. what a pain, i'll borrow a steering wheel puller on monday.
left front fender is off for the scout p/s set up
getting close!!
SOLID ROCK OFF-ROAD
Old 02-09-08, 11:50 PM   #17
wesintl's Avatar
TLCA# 4180
I thought this was just an ornament to mock up for parts. You intend to drive this beast one day
Lookin good jim Time for a
1964 FJ40 | 1966 M416 | 1976 FJ40 | 1985 BJ70 Volvo Power| 1997 FZJ80 | TDI commuter car
Rising Sun
; Former CLCC
You should be able to delete your own thread. Communists abound
Real Change is here --> Cato Institute
wesintl is offline   Reply With Quote
Old 02-10-08, 12:00 AM   #18
80s muncher
2badfjs's Avatar
i'm hoping sooner than later.
its' only been about 1.5 years since it went under the knife.
or
SOLID ROCK OFF-ROAD
Old 02-10-08, 12:44 AM   #19
Beagles Rule!
D'Animal's Avatar
TLCA# 17104
Based on the second picture in Post #1, you need a taller garage or you are not going to get it out of there.
FJ40.5 Build - http://forum.ih8mud.com/hardcore-cor...ly-begins.html
http://www.fcfabrication.com/
D'Animal is online now   Reply With Quote
Old 02-10-08, 09:15 AM   #20
80s muncher
2badfjs's Avatar
nope, we measured.
with the soft top down and the garage door pushed up, it will just clear the roll bar by .000000001111 mm
SOLID ROCK OFF-ROAD
Old 02-10-08, 06:45 PM   #21
71-CRUISER's Avatar
TLCA# 14378
I am using fliped FJ60 rears w/ the 2nd and 5th leaves removed. Hangers are all in stock locations and my shackles are about 7" pin to pin.
My wheel base is right at 100" w/ a ft shackle reversal and stock FJ40 ft springs.
Michael Harness
co-owner
www.AtlantaCustomCreations.com
TLCA #14378
03 Tundra 4x4
71 FJ-40 EFI 5.0, NP435, SOA, 38.5s SXs, Disked/Longed/Aussie/4X4 Labs front, welded rear, MetalTech, Saginaw etc.....
71-CRUISER is offline   Reply With Quote
Old 02-11-08, 10:49 AM   #22
BELMONT148's Avatar
TLCA# 16668
Looks good, nice shackle angle. Should be nice and flexy. I see some fender trimming in your future, or either some nice, "homebrew", raised tube fenders.
Jeremy
Project Evelyn
Old 02-11-08, 06:25 PM   #23
80s muncher
2badfjs's Avatar
Jeremy
tube fenders for sure
i'll have a pair of nice 40 for sale soon
SOLID ROCK OFF-ROAD
Old 02-14-08, 10:39 PM   #24
Beagles Rule!
D'Animal's Avatar
TLCA# 17104
Were those FJ62 springs to start with? With two leafs removed you still have a lot of leafs in thier.
Old 02-16-08, 10:02 PM   #25
CaliCruiser's Avatar
TLCA# 15987
Ya that is what I was thinking too, 60's have 5 to begin with.
Dylan
'85 FJ60 | SOA | ARB | M8274-50 | Sliders | Aussie'd | H55F | 4.7 Toybox | 4.88s | Custom Crap
CaliCruiser is offline   Reply With Quote
