Go Back   IH8MUD Forums > Toyota Tech Forums > HardCore Corner
Old 01-31-08, 08:38 PM   #1
cruzerman350's Avatar
usings leafs as links?
i am planning on doing a 3 link on the rear of my cruiser and im playing with a bunch of different ideas. first off can i use the leaf springs as the lower links if i cut them right after the axle? also with the top link can i run a triangle link? like one that goes from each side fo teh frame to the center of the axle? i would usea johnny joint on the axle for the link and jsut bushings where it attaches to the frame. i made the link in red and the leafs in blue. 569hw7.jpg][/url]
if that wont work does anyone have any better cheap ideas? i was thinking two link with a panhard bar but i cant afford that many johnny joints. stupid low paying job.
thanks
-miles
"cruzerman that thing looks like it takes no prisoners...straight up black, the grim reaper of Toyotas"
-CruisinMT
72 FJ-40 with a 350 and fj60 trans and t-case. custom cage, belly pan, bilstien 7100s, and some badass paint
cruzerman350 is offline   Reply With Quote
Old 01-31-08, 08:50 PM   #2
BiffS's Avatar
leafs are simply not a good idea for that application. The lower links need to be rigid and are used to help locate the axle. if you were to apply torque to the axle through drive line forces, the leafs would bend and allow the axle to wrap: the whole reason for getting rid of leafs in the first place. the rear end would also have wicked death wobble under acceleration, likely leading to a crash or worse.
If you're low budget, best to stick with the leaf set up. a linked setup aint cheap to do properly. good quality steel for lower links will be thick (.385 or larger ideally). I paid $35 /ft for my .385 - 4130 cromo.
the triangulated link is not a good plan either, it will bind.
Sans Leaves. . . Link it don't leaf it!
Project ToyAudi: Daily driver duty for a while:Audi 2.8 in a FJ 40.
DD for the Mrs.: PZJ77V RHD for hauling cargo.
BiffS is offline   Reply With Quote
Old 01-31-08, 09:15 PM   #3
Pacer's Avatar
thank you for taking the time
Pacer
1972 r75/5
1974 r90/6
1989 fj62
2002 325xit
Pacer is offline   Reply With Quote
Old 01-31-08, 09:23 PM   #4
what he said
Mace's Avatar
Leaves are bad but the triangle upper link is just fine...
the wall thickness of the tube also really depends on the OD of the tube...
A larger OD is harder to bend than a smaller OD..
I am kinda gay.......
My Myspace
Old 01-31-08, 09:27 PM   #5
so if i run a 2" 3/8 wall tubing for lower links and for the triangular upper link all will work out? can i weld the lower links solid to the axle housing and do the same with the uper so the whole assembly just pivots?
-CruisinMT
Old 01-31-08, 09:36 PM   #6
what he said
Mace's Avatar
Use some sort of joints at the axle end please..
My Myspace
Old 01-31-08, 09:45 PM   #7
bustanutley's Avatar
first post very bad idea,
second post worse idea, won't even work, at all, the axle would only be able to move straight up and straight down down. You would end up tearing metal(scary)
you need to do some research,
linked suspension and cheep are not two phrases that go together, if you can't afford proper parts stick with leaf springs, they will work better(and safer) than some hacked together scary suspension.
FJ-40 on FO-DEEs
just a lil guy
HOMEGROWN
bustanutley is offline   Reply With Quote
Old 01-31-08, 11:22 PM   #8
The Anti-Leafer
LC_Hamma's Avatar
TLCA# 3343
Don't experience with new dude Whats wrong w/ a typical tried & true 4 link? Stay away from the panhard in the rear where you want max travel & you don't want one side kicking out due to the panhard swing. Run your J Joints at the frame & heims at the axle. I assume you're doin low co$t coil springs?
'72 FJ55 http://forum.ih8mud.com/fj55-iron-pig-preservation-society/76835-pig-chebby-avalanche-trim-%3D.html
'73 FJ40 http://s132.photobucket.com/albums/q...&addtype=local
'78 FJ40 - future crawler in pieces
'93 Ram W350 5 spd. SRW CTD
'99 Ram 3500 4X4 5 spd. DRW CTD
'74 BMW 3.0CS future project
LC_Hamma is offline   Reply With Quote
Old 01-31-08, 11:34 PM   #9
what he said
Mace's Avatar
bushings on the axle end lowers are cheap and easy..
Then you can do bushings on the frame end of the wishbone (triangle)
You would only need 3 joints then..
My Myspace
Old 02-01-08, 01:48 AM   #10
alright i was just thinking of ways i could do it easily. i have a set of coil springs and thats what sparked this whole thought process. most of the geometry i knew wouldn't work but i figured someone on here would know best and thats why i asked. all i want is more flex in the rear and right now it looks like im gonna have to just put my stock springs back on cause the springs that came on it are stiff as shit. im thinking leaf springs with a trac bar is my best option at his point. is 30% of flex out of a johnny joint enough to use on a trac bar or do i have to run a hiem joint?
thnaks for the input.
-miles
-CruisinMT
Old 02-01-08, 09:24 AM   #11
I use an RE joint on my wrap bar. It is basically the same thing as a johny joint, works fine. I think max it out but I do not need any more flex.
FJ-40 on FO-DEEs
just a lil guy
HOMEGROWN
Old 02-01-08, 01:29 PM   #12
BiffS's Avatar
-miles
If you're thinking "track bar" which is also known as a "panhard bar" it's parallel with the axle (goes from side to side) and isn't needed in most leaf set ups. It will limit articulation severely and tug the axle to once side on the extremes of the stroke.
a "wrap bar" or "traction bar" set up runs parallel with the drive shaft; from the front to the rear of the truck and is a good idea with leaf set ups, especially if you're sprung over. This helps prevent axle wrap which can break pinions and u joints.
the 30 deg. travel of JJs and RE ends is considerable when you factor in that 30 degrees of axle articulation in each direction is virtually the equivalent of almost 35" of tire travel from stuff to droop.
Old 02-01-08, 02:42 PM   #13
thank you for the info. i am going to make a traction bar with a johnny joint. is there any specific length i should make the shackle? ive seen pictures or traction bars with a shackle and im wondering if longer or shorter would be better. also does the form bracket have to be in any specific spot?
thanks
-miles
-CruisinMT
Old 02-01-08, 04:10 PM   #14
BiffS's Avatar
that's one place that you can save money and use a heim joint at the transfercase side and rubber bushings at the axle side.
length should be as long as possible, and you can use a standard shackle (5-6") at the transfer case side.
Old 02-01-08, 04:17 PM   #15
what he said
Mace's Avatar
longer and flatter is better,
Shorter, with a serious upward angle will control axle wrap but will create wheel hop..
My Myspace
Old 02-02-08, 01:57 PM   #16
The only reason I know of to incorporate i leaf into a linked rear is to use it in place of a coil . It which case you need to run a shackle on each end of the leaf. This allows the axle to swing freely front to back with the arc of suspension travel that will be determined by your links. In a space limitted situation
where a tall coil just won't fit, or you just can't afford one, this works well. I set up a FJ40 rear using a reworked (leaves removed) chevy 52" leaf pack and got just under 16" of linear travel which is about 24" of articulation.
You will need to tub the rear for this
lcwizard is offline   Reply With Quote
Old 02-03-08, 07:08 PM   #17
thanks
-miles
this is the swing arm i am using on my fj55
redline fj55 is offline   Reply With Quote
Old 02-04-08, 12:57 AM   #18
does anyone have a CAD drawing for a traction bar bracket? i have access to a plasma table but i don't have the CAD program on this computer.
a bracket like this one
also if anyone needs some of those brackets i can make a few.
thanks
-miles
-CruisinMT
Old 02-04-08, 01:01 AM   #19
I don't have a drawing of it but I could make one real quick for you if you like, what is the diameter of cruiser axle tubes? 3.5" I think?
edit:
If I threw a few bucks at you would you make me a pair as well?
FJ-40 on FO-DEEs
just a lil guy
HOMEGROWN
Old 02-04-08, 01:29 AM   #20
fj40forlife's Avatar
TLCA# 5624562435
C.A.D= cardbored and ducktape =]
I think have some drawen out. have to check
Eric
What is rock crawling?
My build http://www.pirate4x4.com/forum/showthread.php?t=637144
fj40forlife is offline   Reply With Quote
Old 02-04-08, 05:25 PM   #21
edit:
yeah thanks that would be awesome. i can make a few pairs. when you make the drawing could you send me the original so i can put it in the computer that controls the plasma cam? for the plasma i need the file in DXF. thanks. my email is jeffspicolli350@yahoo.com. im making it out of 3/8 plate. they have to have a 9/16" hole for the bolts. i don't know what you think they are worth so just make me an offer.
thanks
-miles
-CruisinMT
Old 02-05-08, 02:07 AM   #22
I don't mean to jump in uninvited but depending on price I will take a set.....if possible.
ToyLet503 is offline   Reply With Quote
Old 02-05-08, 03:24 PM   #23
well i think i have enough plate to make another set but im not positive. if i have enough ill make you a set for lets say $40 plus shipping? if that too much let me know.
thanks
-miles
-CruisinMT
Old 02-05-08, 05:20 PM   #24
projektdotnet's Avatar
That looks like something from ruffstuff, sorry no cad for ya
"Those who would give up essential liberty to purchase a little temporary safety, deserve neither liberty nor safety." -Benjamin Franklin
projektdotnet is offline   Reply With Quote
Old 02-10-08, 07:18 PM   #25
If your thinking about a low budget link set up have you thought about a one link. You only need on heim at the frame and then two for a panhard. It looks like they work pretty well and I can't think of a cheaper or simpler way to link the rear.
Not that I have done it.
crujones is offline   Reply With Quote
Old 02-11-08, 11:03 AM   #26
BELMONT148's Avatar
TLCA# 16668
Yes, I think $40 is a little too much. Check the link out.
Antiwrap/Traction Bar Plates (Laid Back) [0690116] - $27.00
Jeremy
Project Evelyn
71' FJ40 W/ 78 2F, 4 speed Tranny & Transfer
SOA, 38" TSL's, 4W discs
"When you rob Peter to pay Paul, you will get the vote of Paul. If there are more Pauls than Peters, you win the election."
BELMONT148 is offline   Reply With Quote
Old 02-11-08, 04:38 PM   #27
oh ok i had no idea what they were worth. well ill jst build a set for myself then.
-CruisinMT
Old 02-12-08, 01:52 PM   #28
YODA 88 62's Avatar
Cheap one link?
1988 FJ 62- SOA, Aussies front and rear, 30-spline Longs, 4.88s, 36x13.5 Iroks, Marlin hysteer
YODA 88 62 is offline   Reply With Quote
Old 02-12-08, 02:36 PM   #29
what he said
Mace's Avatar
Originally Posted by YODA 88 62 View Post
Cheap one link?
There are so many suspension designs out there that are better than a one link..
My Myspace
Old 02-12-08, 11:32 PM   #
