fj60 or fj62 front axle?
I am going to "build" a front "60 series" axle. New gears/locker/longs. Is there any reason to use the 62 series since I'm replacing everything, or is the only difference the gusset on the housing? I'd rather not have the gusset, my 80 rear gussets hang up on everything!
__________________ zcruz |
people typically shoot for the 62s for the 4.11s and there might be just a little more trussing on them too if I recall correctly. I know lowtiderider likes using them over the 60 axles.
__________________ "Just bump it" I am offended by reality all the time. http://www.cascadecruisers.com/ http://www.myspace.com/zachsu ROTW: http://forum.ih8mud.com/60-series-wagons/198064-rotw-brokenparts-fj-60-a.html |
Exactly right. The 60 axles have 3.70 gears and 62 axles have 4.10s and an extra gussit on the botom of the housing. Everything else is identical (brakes etc.)
__________________ Michael Harness co-owner www.AtlantaCustomCreations.com TLCA #14378 03 Tundra 4x4 71 FJ-40 EFI 5.0, NP435, SOA, 38.5s SXs, Disked/Longed/Aussie/4X4 Labs front, welded rear, MetalTech, Saginaw etc..... |
I have a set of 60 axels that are 411gearing,and full floater for the rear. I was going to put under my trail rig but now am thinking maybe not. Let me know if you might be interested.
if you're putting 4.88s or whatever in the axle, then the factory truss is the only difference...
__________________ jonathan malphrus -- 72fj40 the only pinstriping i'll ever have on my cruiser will be after i hit a ny yankee 'these are my awards, mother, from army. the seal is for marksmanship and the gorilla is for sand racing.' ...build-up here (stalled)... |
Right on. I'm definately going with the 60 instead of the 62. I dont need the 4.11s since I'm regearing and prefer not to have the gusset "anchor" on the bottom. I could cut it off, but why work harder? Thanks guys.
Pinion angle is also different but if you plan to do a cut-n-turn that won't matter either.
__________________ utah4x4club.com U4WDA |
Credit Card | Refinance | Personal Loans | Electricity Suppliers | Go ACC |
