Go Back   IH8MUD Forums > Toyota Tech Forums > HardCore Corner
Old 01-15-08, 08:47 PM   #1
1974FJ's Avatar
80 axle with centered t-case output?
I know that the 80 series axle doesn't have a completely centered 3rd. But in a fj40, how wrong would it be to run a 80 series rear axle with a centered t-case output? Just trying to weigh some options.
Hovis
1974 FJ40, Freeborn Red, 4BT, NV4500, Dana300, SOA, 35s, Lo
cked
1977 FJ40, Smurf Blue, 2.5 lift, 33s.
"Correct me if I'm wrong Sandy, but if I kill all the golfers, they're gonna lock me up and throw away the key"
1974FJ is offline   Reply With Quote
Old 01-15-08, 09:08 PM   #2
theyis's Avatar
Hmmm...
Do you have some other t-case in there with a centered out and are wondering if you can run the 80 rear? IIRC the 80 rear is 5 inches off center. I've been told that it would be okay from Jeremiah at Proffitt's but a driveline guy told me don't do it. I know that isn't any help but that is as far as I got on the same question. If you were going to stretch the wheelbase a bit I would think it would be okay.
Kyon
97 FZJ-80 40th (With me in Germany...)
78 FJ-40 (Gone to Canada...)
00 H1 (Gone to Germany of all places...)
theyis is offline   Reply With Quote
Old 01-15-08, 09:17 PM   #3
1974FJ's Avatar
Plan is to run a NP205(centered output) and was wondering if a 80s rear would be ok. It is stretched a tad, but with a nv4500, its more like stock drive shaft length for a 40 series.
Hovis
cked
Old 01-16-08, 10:39 AM   #4
......what?
alkaline747trio's Avatar
Trail or DD? DD, might not work so well....trail, should be fine strength wise.
'92 - 3FE POWER'D!
-- Slee 6"/OME 863J, Pro-Comp 14" ES3000/N74L, Gen. 2 Slee Front Control Arms, T-G Sliders, Ext. Diff. Breathers, DBA Gold S/D Rotors, Slee SS Brake Lines, 5.29s, Aussie Locker'd rear, 37x14 IROK Bias/38.5x11 Boggers, some black bed-liner on the outside, some orange inside, 180k.
'85 Honda Accord - 55MPG!!!
-- No air filter, Custom Burple (blue and purple) Paint.
Upstate Cruisers
alkaline747trio is offline   Reply With Quote
Old 01-16-08, 12:59 PM   #5
In the garage
John Smith's Avatar
TLCA# 9074
My friend runs a 80 series rear axle on his 4Runner buggy with a centered transfer case with zero driveline issues and the small offset.
79 FJ40 & 78 FJ55
John Smith is offline   Reply With Quote
Old 01-16-08, 01:05 PM   #6
theyis's Avatar
Sounds very similar to what I was originally planning for my 40 until I got the 80. I was going to run an NV4500 with a Klune to a split t-case with 80 axles front and rear. Anyways, the thing I don't quite know/understand is what the compound angles would do to the drive shaft. Seems to me that it would be okay. The drive shaft is designed to flex in any direction... I have been trying to picture the movement in my mind's eye and I think I can see it. Imagine one end of the shaft stationary the other end of the shaft is rigged to make a 3' circle around the stationary end. Now spin the shaft and put the circle end in motion. I think it would do it no problem. Not sure if that is a good example but I have to "see" things to understand them.
Alk, not sure I get the logic. Seems to me that on the road you would be facing a much more static environment. i.e. the compound angles would be much less in play, albeit at a much faster driveshaft rotation. On the trail, you would see the angles changing all over the place. Slower rotation speed, yes, but angles would be changing quick.
I still think the drive shaft would be okay...
Old 01-16-08, 01:55 PM   #7
1974FJ's Avatar
Mostly a DD.
Difference here is the length in drive shafts. His 4runner, i would imagine, would have a longer rear drive shaft to decrease the offset over a given amount of space. And i guess not knowing what the length will be from my t-case output flange to the rear axle flange makes this a dumb question. Just looking for ideas so i can start getting parts together.
Hovis
cked
Old 01-16-08, 02:07 PM   #8
theyis's Avatar
I would plan or running a double cardon shaft. Stretching to 110" will help too. Gives a great departure angle .
Old 01-16-08, 04:03 PM   #9
Isotel's Avatar
TLCA# 16898
there is always the Hybrid Centered Cruiser Diff Option.. if you use Tacoma Shafts your Width would be about 60"..
My Driveshaft is 24" long in my cruiser, and the t-case is offset by about 2.5" from the Diff FLange, i have no driveline vibrations with a Toy CV Shaft from an IFS Minitruck
1976 FJ40 TBI350 700R4 D300 SOA Locked 37" PBR's Protected by REDLINE
Colorado Land Cruisers - Club
Redline Land Cruisers - PM me for info on our products or to order!
CrAwLoRadO.com
Old 01-17-08, 01:18 PM   #10
bustanutley's Avatar
you will need to run u-joints on both end of the shaft and you will not be able to rotate your pinion up. U-joint angles on either end of the shaft need to be = within 2-3 deg to not get vibs. As long as the flanges are in parallel plains and you don't exceed the u-joints operation angle you'll be okay.
FJ-40 on FO-DEEs
just a lil guy
HOMEGROWN
bustanutley is online now   Reply With Quote
Old 01-17-08, 05:11 PM   #11
......what?
It would be structurally sound, as in it's not going to grenade from being spun, but it could probably cause terrible vibrations that could cause things to come loose.
'92 - 3FE POWER'D!
Upstate Cruisers
Old 01-17-08, 08:12 PM   #12
scouthead's Avatar
This is how I've always understood things:
(u-joints on both ends of the shaft mean no C.V.s, just a plain old U-joint)
My Scout came factory equipped with Dana 18(offset transfer like a cruiser), and centered rear diff(Dana 27-yikes!). Granted the driveshaft was quite a bit longer than a cruiser's, but it worked just fine.
Never really looked right though!
I've chosen to ignore the pile of receipts...but I know it's growing...
scouthead is offline   Reply With Quote
Old 01-17-08, 08:35 PM   #13
Eskimo's Avatar
My rear diff is offset and it drives fine on the street, up to about 55 is the highest I've had it, but with my gearing, that's about 75 in a rig with 4.11's and a 35" tire.
Rich in NC
FJ - '73 FJ-40 Cruggy - LSx/4-wheel steer Rockwells/4-link/coilovers/42's
Build thread --> http://forum.ih8mud.com/hardcore-corner/124040-keeping-low-rockwells-k-under-knife-again.html
'01 Chevy 2500HD 8.1 Allison Lux-o-tow
Eskimo is offline   Reply With Quote
Old 01-18-08, 08:55 PM   #14
crusier72's Avatar
Hijack
I'm going to put a d300 in my cruiser and will be running the stock rear end for a while has anyone run 3sp joints at 20 degrees. I'm probably just going to try it and deal with some vibes. Mine is only a weekend warrior.
crusier72 is offline   Reply With Quote
Old 01-27-08, 04:21 PM   #15
FJ55 Junkie
TLCA# 3757
Ditto. You won't be able to run a double cardan joint, or rotate the pinion, but provided you stay within the operating range of the u-joint it doesn't care whether you're down... or out!
Lance
Iron Pig Off Road : Toyota 4WD experts
Last edited by IPOR; 01-27-08 at 04:22 PM. Reason: to fix sketchy spelling errors...
IPOR is offline   Reply With Quote
Old 01-28-08, 12:01 PM   #16
jcj_78FJ40's Avatar
Wouldn't the gas tank on an 80 series interfere with a centered output?
78 fj40, 4" lift, Scout PS, Aussie in the rear, ARB in the front. SM465/3spd TC in the works.
91 FJ80-stock for now-future expedition truck
jcj_78FJ40 is offline   Reply With Quote
Old 01-28-08, 12:47 PM   #17
1974FJ's Avatar
Its not going on a 80, Its going under my 74 fj40.
Whats the width of a toyota mini rear axle(V6)?
And whats the width of a fj40 rear axle? and the width of a fj80 rear axle?
Hovis
cked
Old 01-28-08, 06:16 PM   #18
Sputnik40's Avatar
TLCA# 6187
Any more info on this? Are you running one, have you seen one, build threads?
"The devil made me do it the first time. The second time I done it on my own."
Sputnik40 is offline   Reply With Quote
Old 01-28-08, 10:15 PM   #19
fj40 = 55"wms
ifs rear ~ 58"
taco rear = 60"
fj80 = 62"?
FJ-40 on FO-DEEs
just a lil guy
HOMEGROWN
Old 01-28-08, 10:19 PM   #20
It is detailed well in dhondagod's thread
Dhondagods Fj40 Build - Pirate4x4.Com Bulletin Board
FJ-40 on FO-DEEs
just a lil guy
HOMEGROWN
Old 01-29-08, 09:02 AM   #21
1974FJ's Avatar
Thanks, is this IFS mini rear as strong as the taco rear? and whats the difference?
Hovis
cked
Old 01-29-08, 09:24 AM   #22
No, well, the shafts are stronger stock. But the ring and pinion setup is not as strong. The taco third is much stronger. It has bracing that keeps the ring gear from defecting. With cromo shafts the taco rear makes for a very stout axle.
FJ-40 on FO-DEEs
just a lil guy
HOMEGROWN
Old 02-02-08, 06:13 PM   #23
88chevota's Avatar
I did this similar hybrid build. I think I detailed it pretty well. I went with 58" wide, because that is the stock width of 60 series. I used axle shafts from a 90's 4runner and my LC third There is a link to the build in my signature. The minitruck ring and pinion is only an 8". The Landcruiser is like a 9.5" from what I've read.
1988 FJ62 - Chevy 350 TBI, SM465 tranny, NP205 t-case, cruiser/minitruck hybrid rear axle, SOA, shackle reversal, 35" Maxxis Bighorns, 14" travel shocks all around. check out the build. All done!!! http://forum.ih8mud.com/60-series-wagons/164109-chevota-gets-makeover.html
1997 FZJ80 - Collector's Edition (wife's)
88chevota is offline   Reply With Quote
