Go Back   IH8MUD Forums > Toyota Tech Forums > HardCore Corner
Old 01-11-08, 10:20 AM   #1
88chevota's Avatar
Converting AC to on board air
Ok guys, I really want to convert my ac compressor to onboard air, but the only thing I have seen so far is with using a york. Does anyone know if I can use my stock chevy compressor? it is from a 1990 TBI 350.
1988 FJ62 - Chevy 350 TBI, SM465 tranny, NP205 t-case, cruiser/minitruck hybrid rear axle, SOA, shackle reversal, 35" Maxxis Bighorns, 14" travel shocks all around. check out the build. All done!!! http://forum.ih8mud.com/60-series-wagons/164109-chevota-gets-makeover.html
1997 FZJ80 - Collector's Edition (wife's)
88chevota is offline   Reply With Quote
Old 01-11-08, 11:08 AM   #2
Medusa's Avatar
You can use it and it will produce lots of air. The real question is how long it will last. Unlike a York, the vane-type of compressor you have relies on lubricant contained within the refrigerant. You will need to add an inline oiler on the input side and a coalescing filter to remove the oil on the output side. Even with these measures I have never been able to get more than two years of service out of these units before they burn up. If you have a number of compressors or can get them cheap, that is an option -- use 'em and lose 'em.
Got Rice?
Medusa is offline   Reply With Quote
Old 01-11-08, 09:31 PM   #3
88chevota's Avatar
can I use a york with a serpentine belt? From what I know my compressor ain't cheap. I could sell it and almost pay for all the parts at a junkyard.
1988 FJ62 - Chevy 350 TBI, SM465 tranny, NP205 t-case, cruiser/minitruck hybrid rear axle, SOA, shackle reversal, 35" Maxxis Bighorns, 14" travel shocks all around. check out the build. All done!!! http://forum.ih8mud.com/showthread.php?t=164109
Old 01-12-08, 10:11 AM   #4
Medusa's Avatar
Sure, you just need to install a serpentine pulley/clutch assembly on the York.
Got Rice?
Old 01-12-08, 10:50 AM   #5
GreatBasinCustomHomes.com
haystax's Avatar
TLCA# 14279
Try these guys - ::Kilby Enterprises::
'76 FJ40 - 2F,SO,SR,RDB,PS,4.88,Q78TSL,earlydizzy,mod'd carb,Aussie'd front,weld'd rear,MetalTech'd...still too fast in 4LO
Great Basin Custom Homes
haystax is offline   Reply With Quote
Old 01-20-08, 07:28 PM   #6
why do we need to take the oil out of the air helps the air tools and really is it bad for the tires. plus if it isnt really used that often how much would it hurt to add a drop of oil to the intake of the compressor when and if you use it.
blackandbluefj is offline   Reply With Quote
Old 01-20-08, 07:55 PM   #7
Ramblin Wreck
CruisinGA's Avatar
I don't filter the air from my York...
You can perform a mod to York's that significantly reduces the amount of oil they pass into the air. OilFix
It doesn't hurt anything, just gets messy. And filters are cheap. You can also set it up so that the filter drains into the oiler.
Even if I had an engine with an A/C compressor I would figure out a way to mount a york. Anything else is a short term solution and could fail on the trail. I depend on the York to operate my ARB, and it would often be dangerous if I could not air up after some remote trails before hitting the road again.
Bailey Quintrell
'74 FJ40--37 Irocks-32 Bolt 'Locks-SM420-ARB-XD9000i-FJ60 PS-MetalTech Cage
'93 FZJ80-DD-Part Time 4wd-locked-5" lifted-snorkel-bullbar-315 AT's
'97 FZJ80
'98 UZJ100-OEM RR locker
ΣΧ
CruisinGA is offline   Reply With Quote
Mortgages | Debt Consolidation | Credit Card Consolidation | Mortgages | Ringtones
