Go Back   IH8MUD Forums > Toyota Tech Forums > HardCore Corner
LinkBack (22) Thread Tools Display Modes
Old 03-26-08, 02:03 PM   #151
what he said
Mace's Avatar
how much lift are you expecting to need???
I am kinda gay.......
My Myspace
Old 03-27-08, 12:01 AM   #152
I am going to cut all I can to limit myself to 4" of lift. I have 4" j rear springs and 4" slee fronts now and plan on running them. I want to avoid going higher.
my front is 3 link and will do more work than the rear with this radius set up. which is opposite of the factory suspension which is stiff as hell in front and cush in rear
I should be out building but the fab shop hasn't finished my front axle..promised me by saturday....Even if they were done I dont know how I am going to move these heavy axles around for the build as I have only 1 local friend who knows anything of wrenches and is willing to get dirty (thanks dan). I baught a protools hd bender and notcher last week that is free to use if somone wants to help me....
97lx450
4" slee/j's, sliders, bumpers, 3" exhaust, custom turbo, HG pm/Valve job/seals, sweet custom skid plate, Sleeoffroad parts, Buys oe parts from Cruiser Dan
used to have 37" swampers..
1 tons and 42's pending.....
Budget Blown
my build http://forum.ih8mud.com/hardcore-cor...j80-build.html
98 100 series. rear locker.
2008 6.7L dodge 2500 quad cab
Dusty is online now   Reply With Quote
Old 03-27-08, 02:20 AM   #153
what he said
Mace's Avatar
so where is local?
My Myspace
Old 03-27-08, 10:20 AM   #154
lemoore ca 93245
A short 8 hour drive from Las vegas...longer in your wheeling rig. come help for a weekend and ill buy your gas to and from (sub compacts only)
97lx450
Budget Blown
Old 03-27-08, 10:49 AM   #155
bustanutley's Avatar
Mr. Rice came up with a very nice simple solution for moving axles around
FJ-40 on FO-DEEs
just a lil guy
HOMEGROWN
bustanutley is online now   Reply With Quote
Old 03-27-08, 11:09 AM   #156
brokenparts's Avatar
TLCA# 16127
ingenious...I have a new project this weekend.
brokenparts is online now   Reply With Quote
Old 03-27-08, 11:52 AM   #157
nice and easy. i will makey
Mace you still havn't answered the question
97lx450
Budget Blown
Old 03-27-08, 04:06 PM   #158
what he said
Mace's Avatar
Personaly, I would make the links as long as humanly possible. You can get decent articulation out of an 80 series with 4" of lift tho.. It would be a compromise..
I would love to come up and help ya, but I have enough troubles getting bob, my 40 and a 63 ragtop bug on the road lol
My Myspace
Old 04-02-08, 12:52 AM   #159
the trail gear reservoir is practically bolt on-just bend the tab a bit and it bolts right to the factory spot but in a more convenient position. I got their kit for 220 bones. There seems like a lot of slop in the brackets they supplied but the heim is tight. I am not impressed
97lx450
Budget Blown
Old 04-02-08, 12:57 AM   #160
the lines fit nice. like they were made for the ram
got the rear arbed d70 back from gear dude. new 3/4 ton brakes on ruffstuff brackets. does it look right?
notice the pinion flange that tom woods made me. It allows me to use an 80 series rear shaft
97lx450
Budget Blown
Old 04-02-08, 01:01 AM   #161
I wish I had more time. we have a 2 week old addition to family. (benjamin) And with work and kids I piece together an hour here and minute there. but getting closer....
97lx450
Budget Blown
Old 04-02-08, 05:46 AM   #162
Z()LTAN's Avatar
atleast your moving
Lock, Stomp and Steer, No Fear
Z()LTAN is offline   Reply With Quote
Old 04-02-08, 10:46 PM   #163
looks sweet
mrqtipp is offline   Reply With Quote
Old 04-04-08, 09:54 AM   #164
concretejungle's Avatar
TLCA# 14646
i bet the wife isn't happy when you have a two week old trying to sleep and you are out banging, welding, grinding....and if working on your cruiser is anything like mine, CUSSING like a sailor!
95' FZJ80 OME med./J lift, ARB rack, ARB Bull Bar w/tmax 12,500, 35" truxus, Aussie locker-rear, Center Diff Lock, Sliders, IPOR Skid, IPOR rear bumper, upgraded slee sticker, custom dents, more to come. . .
concretejungle is offline   Reply With Quote
Old 04-05-08, 12:57 AM   #165
correct. thats why I am farming out as much work as possible right now and buying as much preassembled stuff as possible. If the local shop was faster I would have them finish it for me but I still don't even have my front axle back.....
97lx450
Budget Blown
Old 04-06-08, 10:05 PM   #166
cleaned the shop and started mock up. most all the brackets are prefabed stuff from ruff stuff and balistic.
the pics in the mock up are actually with a couple inches compression. so there should be about 6-7" between the top of the radius arms bracket and the bottom of the frame rail. so I will be limited to about 5" uptravel weather I like it or not. I may need to buy a couple of 6" springs from Slee.
note this is an 80 series rear shaft that is a direct bolt up to the pinion flange tom woods made me. look at the pics. do I need a spacer on the tcase becaus shaft is overextended or is it ok-Mr slee could you comment? I could move the rear axle forward a bit but then I will need to trim some metal off the body just behind the rear door. I dont want the rear axle comming forward much. I can have a longer shaft made but would like to avoid that.
I will use the oe track bar bushing at the frame side of track bar but will use a 7/8 shank heim at the axle side which I have. note that the trackbar will be extended 5" and is almost paralell-the extended trackbar is not represented in pic. May need a slight bend in the bar which will be 1 3/4 x 1/4 wall to clear the huge diff cover. these offset trackbar mounts from roughstuff are trick. all of their brackets are so overkill. note the offset axle coil bracket
Note the driveshaft that now must angle to the middle due to the centered dana 70. (the 80 series rear is slightly offset to pass side) should I keep the pinion level or angle to the output of the tcase? Should I just buy a slee cv shaft? Cristo comment please.
I will need to make the brackets that connect the upper rear radius arm to the lower arm. getting a plasma cutter from the local weld shop tomorow
This is the final mock up. any comments greatly appreciated
97lx450
Budget Blown
Old 04-06-08, 10:07 PM   #167
picss
97lx450
Budget Blown
Old 04-06-08, 10:09 PM   #168
picssss
97lx450
Budget Blown
Old 04-06-08, 10:12 PM   #169
so close
97lx450
Budget Blown
Old 04-06-08, 10:15 PM   #170
subliminal message: dont vote democrat
97lx450
Budget Blown
Old 04-06-08, 10:22 PM   #171
another big question on my mind is whether the 9/16" summit joints are beef enough for the frame side of the radius arms. I want a pair of evo joints right now but i hear they can take a while to get here from canada. does anyone have a new pair (or 3) of the same 1 1/4 shank (left or right just make them all the same) that they can sell right now? I will pay extra
97lx450
Budget Blown
Old 04-06-08, 10:24 PM   #172
last pic.
would you rather have poly rear shafts? would be a whole lot easier than this
To recap my questions:
1. is the driveshaft overextended?
2. point the pinion at the tcase or leave it flat? (the driveshaft now is now angled to the side due to using a non offset rear axle)
3. Use evo joints at the frame?
97lx450
Budget Blown
Old 04-06-08, 10:55 PM   #173
slickrock's Avatar
TLCA# 18284
we need to see how high from the bottom of the spring retainer stop to the top of the axle spring perch is with a 4 inch lift spring. Once that is figured out, the ride height can dictate where we weld everything.
See if we can get a whole day Sunday and have the wives and kids do something for a good 6 hours. Everything can atleast be tacked into place.
Ill pick up that scheduled 40 Thursday.
8/73 FJ40, 4" tweaked front flipped extended wheel base SUA, rear SOA, 35 Cooper STT Discoverers, fully locked, 1.5" Marlin wheel spacers, 60 series power steering, just under 100" wheel base, full cage, 60 series ignition, roof rack and custome awning, Syrius sat. radio, and GPS
www.centralvalleycrawlers.org
forum.ih8mud.com/ca-central-valley-crawlers
slickrock is online now   Reply With Quote
Old 04-06-08, 11:13 PM   #174
Use an angle finder, find the vertical angle at the t-case. Make this the same angle at the axle, this is at ride height. A CV complicates problems with an offset, although that shaft is long enough you may be able to get away with it.
Shaft length is borderline too short, but it does look like it has a lot of slip
FJ-40 on FO-DEEs
just a lil guy
HOMEGROWN
Old 04-06-08, 11:19 PM   #175
good point. does someone have the measurement of the compressed length of a rear j spring as it sits under the truck? what about the compressed length of a slee 6" spring?
I wish I had a pic of an oe shaft as it sits on an 80 series so I could compare and see how much mine is extended
97lx450
Budget Blown
Old 04-08-08, 12:03 AM   #176
Arya Ebrahimi's Avatar
Dusty, you want the axis of the pinion and the axis of the transfer case output to be parrallel. This will keep the u-joints happy. With your offset pinion you do not want a CV shaft as the u-joint at the pinion will be very unhappy. If you need more input on this, let me know and I'll try to explain better.
For the DS, I think you should finish setting up the suspension and cycle it w/o the springs and see how the DS is behaving. I'd imagine it's not going to slip all that much. Whatever the case, figure out what the max extension is and then how much spline engagement that correlates to. With that info we can better judge your situation. If you do need to lengthen the shaft, I'd suggest having it retubed longer with thicker tubing than making a spacer. I just retubed my rear shaft on my trail rig this past weekend and it took me all of 2-3 hours with some 2.5" Schedule 40 pipe(nice and beefy).
As for the rear joints, I don't know. I know that I used 9/16" bolts(Rubicon Express joints) for the two attachment points of the front radius arm suspension on my old Jeep Cherokee, but that rig weighs a full ton less than an 80.
Looking good so far!!! Keep up the good work, and congrats on the new addition!!!
Ary
HOKIES UNITED
Arya Ebrahimi
'94 FZJ80 215k miles, locked, 4.88s, 285 Revo's, ARB Bullbar, Hella 4000's, homemade drawers
'86 Toyota Pickup SAS'ed, welded, 4.88s, 38 TSLs, and lots o' tube
Arya Ebrahimi is offline   Reply With Quote
Old 04-08-08, 06:21 PM   #177
I purchased 3 evolution 1 1/4" joints today. will see when they get here
97lx450
4" slee
