Go Back   IH8MUD Forums > Toyota Tech Forums > HardCore Corner
LinkBack (22) Thread Tools Display Modes
Old 12-17-07, 12:48 AM   #91
available in a hospital bone yard near you...
here is what they look like after you cut the excess off
97lx450
4" slee/j's, sliders, bumpers, 3" exhaust, custom turbo, HG pm/Valve job/seals, sweet custom skid plate, Sleeoffroad parts, Buys oe parts from Cruiser Dan
used to have 37" swampers..
1 tons and 42's pending.....
Budget Blown
my build http://forum.ih8mud.com/hardcore-cor...j80-build.html
98 100 series. rear locker.
2008 6.7L dodge 2500 quad cab
Dusty is online now   Reply With Quote
Old 12-17-07, 12:57 AM   #92
GreasedPiggy's Avatar
nice, and the 'patient' is a Dana 60 I assume?
very resourceful, what does one cost apprx from a liquidator???
1975 FJ 55, Cummins 4BT, 4L80E, NP208, SOA, 14 bolt rear, Dana 60 front, ARB Lockers, Scout II PS, Discs, Cross-over, TSL Q78-16
1995 T-100, 4" susp lift, 33 Goodyear MT/R, bought it new, my DD
1961 ford Falcon, 5.0L EFI, T-5, 9-inch
GreasedPiggy is offline   Reply With Quote
Old 12-17-07, 09:51 AM   #93
ringpinion.biz's Avatar
install kit
Actually there are 3 different bearing kits. D70 d70HD d70u.
What is it out of? What is the BOM number? This starts with a 6 and is on a metal tag, or stamped into the axle tube. If you cant find this, than inner pinion brg number and carrier brg number will tell for sure. As far as the rear shafts, the stock 35sp is pretty strong, but we do offer some upgraded ones that are fairly inexpensive too.
Originally Posted by Dusty View Post
here are the axles. I will just order bothe install kits for the d70 tomorow if nobody knows how to tell what d70 this is.
JTS Diff Parts & Accessories
ih8mud sponsor
866-349-6801
info@justdifferentials.com
www.justdifferentials.com
99 uzj100 35's, uniball a-arms, fox shocks, 4.88, lockers, bullbar, drawers & more.
ringpinion.biz is offline   Reply With Quote
Old 12-17-07, 09:31 PM   #94
As was said above BOM is the best way.But bearing nubbers can get you what you need and tell you what pinion offset you have.
Stock 1.5" 35 spline axles take alot of abuse,but I have since upgraded to a set of Mosers
Just a little more Chevy than most Cruisers
The Woohoodilly-69 FJ55,350/465/203/205,Dana 60 w/ARB,Dana70 w/Detroit,5.86s,on 42" IROKs
The Chacha-08 FJ Cruiser,Sandstorm,all stock for now
FRIZZLEFRY is offline   Reply With Quote
Old 12-17-07, 11:43 PM   #95
I don't know. But they are free if the hospital has left them outside and you drive by in pickup seriously these things get tossed all the time by hospitals but most haul them away because they have no discrete place to store junk. My hospital has a jusk pile. Anyone need a xray machine? there is one sitting in back of the hospital right now. it probably throws out enough radiation to cook your pizza. Im waiting for them to upgrade the MRI so I can have the 3000lb magnets in the old one.....
only thing i can see stamped is on the webbing of the housing c34835
ouch. and if you have the 55 iron pig then the 80 series must be the iron hefer
97lx450
Budget Blown
Old 12-18-07, 09:47 PM   #96
Should be a BOM stamped into one of the axle tubes.Should be a 6XXXXX-X type of number.Could be hidden under some paint,goop, or rust maybe?
Here is my post form Pirate when I couldnt find the BOM on my 70
Dana 70 BOM help - Pirate4x4.Com Bulletin Board
Old 12-30-07, 12:54 AM   #97
parts are comming in:
ruffstuff brackets
d70 disk brake conversions
chromolies
35 spline dodge drive flanges (hubless)
42" iroks
summit 1 1/4" threaded machine joints
2" x 1/4" dom
install kits for gears Are still pending. I wish I hadn't ordered these from 4wheelparts.
I am still stumped on finding a pinion flange for the dana 60 and 70 that will allow me to use my toyota driveshafts. I believe I have searched well but cant find em. Anyone know where to get these? otherwise I will need to use one of those conversion ujoints and I don't want to do that iff poss
97lx450
Budget Blown
Old 12-31-07, 12:06 PM   #98
CreeperSleeper's Avatar
TLCA# 15577
Sounds like a killer build! Keep us posted. If this seems to work out well for you, I may scrap my buggy plans for a few more years and follow in your footsteps!
Chad
Cascade Cruisers- President
KE7VSA
Views from the Creeper
MetalTech
Originally Posted by DanKunz View Post
You stacked rocks to climb your porch......HA!!!
CreeperSleeper is offline   Reply With Quote
Old 12-31-07, 03:13 PM   #99
freds40's Avatar
Check Highangledriveline. Jess has them for mini truck.
freds40 is offline   Reply With Quote
Old 12-31-07, 10:58 PM   #100
thanks so much. I will be giving them a call tues (darned holliday)
Got some more done last night. tore down the d60 and press washed it today. perhaps i can clean it up with wire and sand tomorow. I have never tore into one before-beefy.
My little bro is down for the holliday and cleaned all the old brackets off the frame-he does great work. I wish he could just live at my house for a few weeks and finish the build for me.
97lx450
Budget Blown
Old 12-31-07, 11:10 PM   #101
Here is another spot i am thinking of: I am thinking of doing a 3 link with trackbar in rear (just like front). the rear liks will be about 4 1/4 feet with the joints. I am planning on placing the frame side 3rd link (which will go to a tower just pass side lateral to the diff housing) on the pass side inner framrail just above the frame link mount which takes its link to the axle tube. (see pic)
My concern is that the oe trackbar mount (which I would like to keep) orriginates on the pass side frame and takes its link to the drivers side axle housing. any potential for bind like this? note that the rear driveshaft will be orriginating and running parelel to the 3rd link.
should I abandon the 3 link and go with a pair of rear radiur arms?
it is impossible to take a 3rd link from the drivers side as the gas tank is in the way. If it wasn't for the gas tank I would do a 4 link.
and yea my exhaust has got to be moved. I am going to keep my glasspack on the outside of the frame and have it exit in front of the rear wheel or under the truck
also: are these any good? saw them recently Dana 60 Outer Axle Seal [D60-OuterSeal] - $55.00 : Mad 4 Wheel Drive, Bulletproof Offroad Parts & Custom Axle Assemblies
97lx450
Budget Blown
Old 01-05-08, 06:34 PM   #102
what the hell happened?
ats4x4dotcom's Avatar
If it were me, a rear centre with "knock on" cv rings, for over 38's, and a rear housing with d60 cv's mounted on it for bigger.
More psi steering pump pressure, and hydro assist for bigger than 38's toome thinks.
[planning these type of mods on an 80 at the moment, already have the 39.5 x 16.5/17 rockers, looking for a truck]
We have been modding the front diffs, and rears, and out of over 350+ of which were broken before they came to us, havent had a broken one back as yet, though 35's are the biggest, one on 37's we really see on an 80 here.
Darren McRae 95 80 series 1FZ-FE with bits to come
http://forum.ih8mud.com/80-series-tech/207630-project-rooby-80-all-rounder-build.html
ats4x4dotcom is offline   Reply With Quote
Old 01-10-08, 01:00 AM   #103
42" iroks
97lx450
Budget Blown
Old 01-10-08, 01:08 AM   #104
fitment issues
97lx450
Budget Blown
Old 01-10-08, 01:09 AM   #105
more
97lx450
Budget Blown
Old 01-10-08, 01:11 AM   #106
even more
97lx450
Budget Blown
Old 01-10-08, 01:26 AM   #107
So the rear axle will move back a few inches as shown and I am considering moving the front axle rearward also a couple inches which will be easy to do as shown. It looks to be much easier to move the front axle rearward than to cut into my bumper and radiator support.
Another thing im looking at is the front axle lower links. as shown in the axle pick I only have about 2.5" of exposed axle shaft on the pass side of this dodge dana 60. as my incoming summit joints are already wider than that I will need to now fab my own bracket instead of buying one for this side
This axle is a dodge SRW dana 60. I like it as it has the extra beefy inner c's and I like the external hub design as I can use the bolt on external 35sp flanges which I like. (as apposed to inner drive flanges which are also cool). that 2.5" of pass side axletube lines up directly under the front upper coil catch which is convenient. I do worry that if my lower link on the pass side goes to this location My wheels may hit the link when turning. I may need to use a DRW cheby dana 60 up front.
The front is about at projected ride height while I would like the rear several inches lower than in pics
97lx450
Budget Blown
Old 01-10-08, 05:21 PM   #108
TLCA# 15577
Sweet...
Chad
KE7VSA
MetalTech
Old 01-18-08, 12:40 AM   #109
mocking it up
At stuff, sitting on the bump stop she should look like this in the front:
97lx450
Budget Blown
Old 01-18-08, 12:43 AM   #110
At ride heigth with 26" at the frame she would lookj like this:
97lx450
Budget Blown
Old 01-18-08, 12:46 AM   #111
This scenerio would give 5" of uptravel
97lx450
Budget Blown
Old 01-18-08, 12:51 AM   #112
Running a 70" wms with my wheels would look likje this and require a 1.5" spacer each side.
To kjeep it this low will require some cutting.
Question: my mock up above shows 16" of spring from upper to lower perch at neutral height. Does anyone know if that corilates with the slee 4" or 6" springs? I have the 4" now but made a pair of 2" spacers
97lx450
Budget Blown
Old 01-18-08, 09:00 AM   #113
You'll probably still have to drop your bump stops more if that's you full compression. You'll be fine until you get the wheels turned and then you'll really be into the fenders.
I run 3" of up travel at the bump stops on my comanndo with 1 tons. I have plenty of room to go more, but not if the wheels are turned.
After you get you alxe beack together...mount up the wheel and turn it so you can check. You'll want to do that anyway to make sure you keep your tires outs of your links (ask me how I know )
adamsclarke is offline   Reply With Quote
Old 01-18-08, 01:55 PM   #114
clownmidget's Avatar
dusty, what is the spread between your lower links mount and upper link? are you getting 10" or less? looks like less than that to me.
why aren't you going to triangulate 4-link the rear and loose the rear panhard? you probably already said but i'm too lazy to read 4 pages...
those 42's are dopey big, you gonna hurt yourself. you keeping the whole body of this truck or is it a soon to be convertible, chopped rear w/tube doors?
i think if you cut the front fender wells out to just in front of the leading edge of the front doors you will have good space for moving the front axle back a bit but i think those 42's under full lock are going to be tough to keep off the frame or your links. might end up affecting your turning radius.
i like it man
Mike R.
hmmm....nuthin'
Answer a fool according to his own folly.
clownmidget is offline   Reply With Quote
Old 01-18-08, 10:50 PM   #115
oops
97lx450
Budget Blown
Old 01-18-08, 10:53 PM   #116
