to make your own steering arms
using the stock length, lateral angle, and bolt pattern, couldn't one design their own high steer arms out of say.... 1/2" plate?
has anyone? short of killing yourself on untested homemade attempts, what could it hurt? __________________ www.rusmannx.com 72 fj40: F-3speed, DUI, 2bbl rochester, 4 inch skyjacker, 33x10.5 tsl radials, saginaw, 8274. |
I seriously doubt that 1/2 in. plate would be strong enough.
__________________ Any brag I make comes with 4 kids in back, and one of them likely will be sleeping ![]() '78FJ40:33s,SBC,PS,SR,Rrflip,4"lift,Warn,Lockrite, Rockbox, Topless. Parts in, waiting for shoptime: 4.10fine-spline R&P F&Rr, ARB front, York, dual batteries under Rr floor. |
Admin
try 1"....
now find a press to bend them to the height needed....and get them both the same. now accurately drill the 4 holes required AND find the correct taper for the cones... happy hunting
__________________ Brian 'woody' Swearingen 1974 FJ40 'The Raisin' - Pitbull Rockers, 30-spline Longfields, SOA - 1/4 ellip 1996 FZJ80 'Gretchen' - MetalTech, ARB, OME, IPOR, 4x4Labs 2003 2500HD Duramax - Edge/Juice/Attitude, 285 Nitto Terra Grapplers, 4" exhaust Forum Questions? Click Here! 'America will never be destroyed from the outside. If we falter and lose our freedoms, it will be because we destroyed ourselves.' Abraham Lincoln |
..and add trunnion pin with exacting tolerances... keeping in mind that sloppy fit equals broken down on trail with torn up knuckle and steering... and be sure your insurance premiums are up to date...
__________________ utah4x4club.com U4WDA |
And after you get al of the machining and bending accomplished, find a way to heat treat the arms so they have sufficient strength.
__________________ Got Rice? |
what axle?
__________________ EMAIL ME click on my name, Send email to HI^C TONS FOR SALE <<<CLICK ME "everyone has different experiences and different opinions" My posts "greatly based on my observations and opinions" and "TO EACH HIS OWN" Sig edited to help futher eliminate those who have or get twisted panities. |
#7 | |
Oh...Durka Durka Durka.
Luke Porters arms are not heat treated... http://4x4labs.com/products/steeringarms.html Good luck! -Steve |
I'm sure you can come up with some arms that will work/bolt on. Now take the money you saved and invest in a good full cage and 5 point belts. You are playing with your life by trying to cut the wrong corners. Spend the money and be safe.
Phil |
ok, 1" then.
my buddies dad has a machine shop that can manipulate 1" steel with ease... that isn't the problem. (he can do 16' of 1" plate at a time, and punch 1" diameter holes in 1" steel) it's the design that concerns me. __________________ www.rusmannx.com 72 fj40: F-3speed, DUI, 2bbl rochester, 4 inch skyjacker, 33x10.5 tsl radials, saginaw, 8274. |
#10 |
http://www.compgoparts.com/Informati.../Ackermann.swf
here is a nice animation on the ackermann principle you are all dying to know about __________________ www.rusmannx.com 72 fj40: F-3speed, DUI, 2bbl rochester, 4 inch skyjacker, 33x10.5 tsl radials, saginaw, 8274. |
#11 |
Admin
DAMN....that is a nice animation...thanks for the link!!
Do you get Toyota Trails? GREAT writeup on Luke's 4x4 Labs arms and the work he does to ensure correct Ackerman. __________________ Brian 'woody' Swearingen 1974 FJ40 'The Raisin' - Pitbull Rockers, 30-spline Longfields, SOA - 1/4 ellip 1996 FZJ80 'Gretchen' - MetalTech, ARB, OME, IPOR, 4x4Labs 2003 2500HD Duramax - Edge/Juice/Attitude, 285 Nitto Terra Grapplers, 4" exhaust Forum Questions? Click Here! 'America will never be destroyed from the outside. If we falter and lose our freedoms, it will be because we destroyed ourselves.' Abraham Lincoln |
#12 |
and here is another super visual of how to get your own ackerman angle.
http://www.nationaltbucketalliance.c...n/Ackerman.asp __________________ www.rusmannx.com 72 fj40: F-3speed, DUI, 2bbl rochester, 4 inch skyjacker, 33x10.5 tsl radials, saginaw, 8274. |
#13 |
WHAT AXLE?
#14 |
oh sorry, stock 40 axle.
#15 |
Steve, Aren't Lukes arms machined out of billet stock, hence not bent? Heat treating would only be necessary if the stock was heated and bent.
#16 |
Admin
Lukes are bent....
#17 |
Not aware that they are *billet*...
The strait set, and bent set that I have at my shop, look like *normal* steel. When I talked to Luke about the material and some other issues/questions, I was told that 1" cold rolled steel would be fine if I had to replicate an arm/arms... Good luck! -Steve |
#18 |
#19 |
After talking with Luke about some fittment/clearence issues, I went ahead and made my own set of arms out of cold rolled steel, 1" thick. Here are some pics of the finished install...
http://www.mindcrater.com/Galleries-...s/RamRod-5.htm Good luck! -Steve Luke Porter is a great guy. He makes some very high-quality, top-notch products. I hope to do more business with him in the near future. |
#20 |
poser, what did you shape yours with?
those are some pretty clean lines. __________________ www.rusmannx.com 72 fj40: F-3speed, DUI, 2bbl rochester, 4 inch skyjacker, 33x10.5 tsl radials, saginaw, 8274. |
#21 |
Shame on you Poser...
that is way to clean... you're supposed to go wheelin' once in a while with that thing... what do you think it is?... an 80 or something?
#22 |
Thanks, I stand corrected. The double arms I made for my D60 axles are flat and made of T100 steel. I would hate to have to even try to bend that stuff.
#23 |
Wise One
Unless you are doing something, not available, why bother? Every time I look, the price is down on them, I have less than $250 in my Hi Steer, all new 1 ton GM ends and used components everwhere else.
Found a guy going to Dana 60 up front and loaded up Butch |
#24 |
Former Wheeler
Where's the good price on 40 steering arms with a GM taper, Butch? I'm ditchin' my heims.
__________________ War Pig and the nameless 45lv "Don't you know, Stan, it's always between a Giant Douche and a Turd Sandwich." |
#25 | |
Wise One
Butch |
#26 | |
By hand, with a vertical DoAll, and a belt sander... |
#27 | |
That is a customers truck that has 765 miles on it since 2000..... He hopes to put a few hundred more on while we are in the Black Hills in a week... Good luck! -Steve |
