Old 10-09-07, 07:14 PM   #1
crusier72's Avatar
strongest crusier axle
I'm looking to increase the strength of my rear cruiser axle. I run an 2F sm420 with a stock cruiser case for now but might go up to a dana 20 or 300.
I broke my rear diff that had a set of 4:11 fine splines and a lockright in it. The center pin exploded when I smoked the 37" IROK's and grabbed 2nd the gears survived.
I'm looking to replace the diff with something that can take my heavy foot and allow me to drive home. This is driven on the street so I'm shying away from a welded rear. The detroit sounds like a good upgrade but it's only a 3Pinion because of the C-clips and I'm worried it will self destruct if I brake an axle. Is the ARB the strongest choice in a rear cruiser axle.
crusier72 is offline   Reply With Quote
Old 10-09-07, 08:27 PM   #2
wngrog's Avatar
TLCA# 8121
If you stick with a Cruiser case and a Cruiser rear axle, then a 4.11 fine spline 3rd with an ARB is a good choice. If you are just running around on the street though, leave it open and there is a lot less stress back there when you do clutch dumps.
The probelm is, there is really nothing south of the SM420 that will stand up to roasting 37s (which I find very hard to believe with a 2F and SM420 having owned and run said combo many times)
OK, if you are going to change the Tcase, the D300 is an upgrade, the D20 is not much of one.
If you go with either case, then a 9" axle will be a better choice than a Cruiser axle seeing that the output will then be centered. Above that, even a 31 spline 9" is stronger than a stock Crusier axle.
Rock Midget Motorsports
www.rockmidget.com
2009 Calendars at www.rockmidget.com
wngrog is offline   Reply With Quote
Old 10-09-07, 08:41 PM   #3
crusier72's Avatar
This isn't where I broke but same day it gets wheeled and I like to hammer on it. So you think that an arb would be my best bet for a cruiser axle. Thanks
Old 10-09-07, 08:51 PM   #4
what he said
Mace's Avatar
ARB..
But honestly, I suspect that improper setup killed the center pin..
I am kinda gay.......
My Myspace
Old 10-09-07, 08:52 PM   #5
I've been running detroits in the back of two of my rigs for years , Broken axles and driven out with the remaining one (other side held on by the rdb bracket) no issues ever with either of them . I beat on my junk pretty hard some days.
1977 fj40
1985 bj60
1978 fj40
1976 fj45 in pieces
1974 fj40
Too many if you ask my wife , Never enough for me !
too tall is offline   Reply With Quote
Old 10-10-07, 11:31 AM   #6
Tapage's Avatar
I thought a ARB it's definately and upgrade .. but I believe you first gonna broka an axle ( Poly performance in this case ) before a cross pin ..
HJ-60 2H-T Intercooler Tencha
Originally Posted by pygpen
Old 10-10-07, 12:16 PM   #7
Isotel's Avatar
TLCA# 16898
Sounds like the center pin was worn (Common Issue with Lunchbox lockers)
I Love my D300, and i have a Centered Cruiser/Mini HyBrid rear Axle that is holding up good with my Fine Spline 4:11's and a Wrap Bar..
but a 9" will survive longer, especialy if you up size tires or go to a healthy V8
1976 FJ40 TBI350 700R4 D300 SOA Locked 37" PBR's Protected by REDLINE
Colorado Land Cruisers - Club
Redline Land Cruisers - Safety First
CrAwLoRadO.com - Just Check it out
Old 10-10-07, 01:35 PM   #8
crusier72's Avatar
What locker are you running Isotel?
My problem with lunchbox lockers in a cruiser case is that all the torque goes through a single pin even in double sheer I'd like to see more material to take the load when it's locked.
Old 10-10-07, 02:14 PM   #9
Isotel's Avatar
TLCA# 16898
I run an Aussie in the rear, and a Lockright in front, Id love to upgrade to an ARB, but its working fine so far.. Ive run it for about a year.
Old 10-10-07, 05:25 PM   #10
Mbrantley's Avatar
Mark was trying to get up on a ledge when he had all four tires smoking with that stupid tractor motor when he grabbed second the rear just kinda clunked and then stopped turning, very unimpressive. When we pulled it apart it seemed that the center pin had sheared taking out the carrier. Would it have really mattered if the side gears & Drivers were or weren't shimmed properly? I never liked the idea of mixing a lock wrong with a single center pin and 37s.
Don't waist any time, effort, money on the offset rear when you still have a turd cruiser transfer case and you know you want to do front burns.
Would a trussed mini rear with a v6 carrier hold up? (Keep in mind that Mark's cruiser is not obese like many are)
Matt
Tube buggy on 42s
- For Sale - 85' runner on 35s http://forum.ih8mud.com/vehicles-tra...5-4runner.html
Mbrantley is offline   Reply With Quote
Old 10-10-07, 11:53 PM   #11
bustanutley's Avatar
My buddy runs a custom rear axle that uses 35spline 6on5.5 shafts (stock convertion part from superior?) with a rear fj80 cruiser third and dana 60 side gears all in a diamond housing. So far it has been holding up very well to a lexus v8 and 44s the only are of concern is where the side gears are welded to the carrier.
PS I really dig your low ass cruiser that is cool!
FJ-40 on FO-DEEs
just a lil guy
HOMEGROWN
bustanutley is offline   Reply With Quote
Old 10-11-07, 08:27 AM   #12
crusier72's Avatar
If I understand you correctly the dana60 side gears fit into the 80carrier and he welded them to the case to make it a welded rear end. That is a neat idea. Is the axle centered?
Mbrantly do you have any dana60 side gears or did you recycle them.
Thanks for the compliment the low cruiser is fun and stable.
Mark
Old 10-11-07, 08:41 AM   #13
what he said
Mace's Avatar
Matt
If it added extra stress because the center pin had to move further to actually engage the locker then yes..
V6 carrier nost likely will be no stronger.
If you weld to a cast ceter section IMHO you are creating as many problems as you are solving. Weld the cruiser axle solid (teeth to teeth only) and wheel the piss out of it.
If you are getting a new tcase that allows front dig. Then you will need entirely new axles anyway.. weld up a $50 third and go wheel..
My Myspace
Old 10-11-07, 09:00 AM   #14
Ride On...
lowtideride's Avatar
TLCA# 14891
So.. Welded Spider gears produce less stress than a lunch box locker ???(i.e. Aussie, Lock R)
Is that what you are saying?
www.NFCruiserheads.org 1983 SR5 Hilux...
has had no peers for 50 years...
lowtideride is offline   Reply With Quote
Old 10-11-07, 09:09 AM   #15
what he said
Mace's Avatar
yep. At least stress on the center pin..
The center pin is captured and immobile with a welded rear. with an aussie, it has to move a bit to "engage" the locker. That is why the center pin opening is clam shaped in a lunchbox locker.
that being said, I would not worry about it if set up correctly with a good center pin...
My Myspace
Old 10-11-07, 09:49 AM   #16
Mark
Yeah that is what he did, but the side gears don’t just fit into the carrier he had to have it hogged out. He is trying to figure out a better way of having the gears connected to the carrier. If you want to see pictures there will be an article about his rear end in crawl sometime. The axle is centered
But if you aren’t breaking shafts I 100% agree with mace, welded-up spiders is a stronger setup. Lunchbox lockers rely on the strength of the carrier which sometimes has a lot to be desired. I have bent/deformed a carrier to the point where one side would no longer engage.
FJ-40 on FO-DEEs
just a lil guy
HOMEGROWN
Old 10-11-07, 09:56 AM   #17
what he said
Mace's Avatar
you bent a cruiser carrier?
My Myspace
Old 10-11-07, 10:24 AM   #18
yeah, when it went together everything was in spec, few years later, one day the locker stopped working, took it apart to find one side of the bastard was 8 thousandths difference side to side and things were not parallel. Put same locker into and new third and everything is good now
FJ-40 on FO-DEEs
just a lil guy
HOMEGROWN
Old 10-11-07, 10:26 AM   #19
what he said
Mace's Avatar
You are the first person I have ever heard of doing that without something catastrophic happening to cause it...
My Myspace
Old 10-11-07, 10:33 AM   #20
Former Wheeler
Gumby's Avatar
TLCA# 5658
Something to be said for he's the first person to NOTICE it before something catastrophic happened.
War Pig and Cerdito
"Don't you know, Stan, it's always between a Giant Douche and a Turd Sandwich."
Gumby is offline   Reply With Quote
Old 10-11-07, 10:46 AM   #21
what he said
Mace's Avatar
Donno, it is still pretty rare..
Even with people not noticing things, how often do cruisers carriers fail?
rarely..
My Myspace
Old 10-11-07, 11:13 AM   #22
megolfer's Avatar
why not a custom axle with a spidtrex axle housing. This would give you a 9" center section with 1 ton full float kit.
www.tlca.org
President-Central Valley Crawlers
www.centralvalleycrawlers.org
www.marlincrawler.com
megolfer is offline   Reply With Quote
vBulletin® v3.7.3 ©2000 - 2008, Jelsoft Enter
