bad ass winch
Hey guys,anyone built or no of any extreme pto winch setups??
im thinkin of runnin vf2 style left hand output transfer case to either the back of a h42 & split case or in between like marlins toybox,then run a drive shaft forward to a minitruk ifs diff with a drum on one end? still with me? any ideas?cheers __________________ HDJ81 Daily driver 78 FJ55R-KC under construction 84 FJ40 NASTY RUSTY BUSH TRUK |
Not .. I'm loose at minutruck ifs diff !
#3 | |
Oh...Durka Durka Durka.
Are you going to offer this as a bolt-on kit? |
maybe?
if i can get some input!! lookin on toyotas parts EPC it shows a rear power takeoff? anyone ever come across one of these??check this link to my local forum http://www.offroadexpress.co.nz/modu...ewtopic&t=6192 theres a coupla youtube vid links there basically i want to connect a second transfer( behind my cruiser box) and run a drive shaft forward to a locked front diff with a drum on one end with the cable on it?? think like the pto style they used to have but on a lot larger/faster/powerful scale??
what the hell happened?
malaysian guys were running this set up at this years outback challenge, using datsun 120 y diff, as they are cheap.
PTO shaft to pinion flange, welded diff, winch drum hooked to axle on one side, so a 3.__ to 1 step up in the PTO drive. Some talk of them measured at 25kph on the winch cable, winching. __________________ Darren McRae 95 80 series 1FZ-FE with bits to come http://forum.ih8mud.com/80-series-tech/207630-project-rooby-80-all-rounder-build.html |
Holy FAWK!! that zuk winched over fast as hell! I've never seen that before.
__________________ 95' FZJ80 OME med./J lift, ARB rack, ARB Bull Bar w/tmax 12,500, 35" truxus, Aussie locker-rear, Center Diff Lock, Sliders, IPOR Skid, IPOR rear bumper, upgraded slee sticker, custom dents, more to come. . . Remember it's a gateway drug, so it will actually lead to "crystal meh". |
retired maths geek huh
what kind of cable/ rope do they use ?
__________________ '71MS75 threw a rod '74MS75 seized engine '75BJ40 farm tractor type R '79FJ55 rostig schwein '80BJ40 never ending resto '88LN65 frame-off '90HDJ80 the bear '92LN85 turbo ute |
now you see what i mean
![]() would toyota`s standard pto takeoff be able to handle that sort of abuse?
that sounds reeeeeeealy scarry. 25kph line speed?! don't get in the way of that fawker or you're toast.
i'd still run an electric winch myself....... __________________ TLCA and PMC member ![]() looking for Advance Adapters parts? send me a pm!
#10 |
a pierce 12500lb electric winch is pretty much hard core enough for me...slow and steady wins the race
__________________ 1974 FJ40 OEM Soft Top (1) Child boy version (1) Child girl version (1) New boy Child, done as of 11/6/08 ![]() 197 Wife TLC FST Canvas & Maint: http://forum.ih8mud.com/40-55-series...soft-tops.html |
#11 |
It really depends on the race. Some challenge events are pretty much a winch race nowadays !
#12 | |
NO fun ! |
#13 |
down here we call them "winch challenges" and they are either some big mud holes or steep inclines,people use mainly hydraulic & PTO but i wanna build something that really cranks
#14 |
what rig would this go in ?
I had a brain fart while thinking about this thread the other day, I think it might be a brilliant idea but I probably won't have the time to build it before long
#15 | |
X2 2MK, NO one has to this day created a CONTINUISE DUTY rated ELECTRIC winch...
#16 |
now were thinkin!! denis has finally clicked to what im on about
![]() ![]() so do you think its possible to put a transfer box in between the original vehicles gearbox & transfer case? like marlins toybox deal?
#17 |
I think the dual case idea is the best option, as if you ran it straight off the PTO i could see that making for some really hairy extractions if you were ever in a tippy or technical spot.
__________________ 1988 FJ 62- SUA, 1" body, 34" trxus mudders, 2.5" exhaust, 27spl Longs/Pig Inners, 4.88s, torsen LSD/lockright, 4runner brakes, other random stuff... 1986 pickup- 2wd, 22r, 4 speed, DD 1985 F-150- mpi 302, future tow rig |
#18 |
So I think I have a way to clutch it. Use an open diff and put a disk brake from something small on the non spool side. Then you engage the winch and all the power would run through the disc brake side and not pull any on the line. The power you send to the winch would be directly related to how much braking you do. Seems like a good way to control it and could be done on a low budget. Something like an e-brake with the cable run to a lever would work. I'm thinking this is only a comp type thing.
__________________ jetboy, 75-40 |
#19 |
Yeah, you let off the lever and bad things happen.Maybe a ratchet type style hookup for it.
__________________ Drafting the big bricks with my little brick ![]() ![]() 78'&80'fj40'&a83'fj60 Great Lakes Land Cruisers |
#20 |
Location: I live in Oslo.. the biggest village in Norway
lots of old cruisers have a mechanical winch connected to the engine... maybe you could use one of those
Many 40'2 and 60's have that .... it will lift you car straight off the ground .. or break the safety-pin __________________ HJ60..OSLO
#21 |
with a 33:1 (-ish) ratio in the worm gear drive the line speed will be somewhat limited for comps.
#22 |
A 4:1 winch is the easy part. The hard part is the PTO. There's no way they'd be using any factory gear with anything as heavy as a Land Cruiser.
I'm running a huge hydraulic pump off my PTO and that runs my 8000 lb Superwinch. Its about 2/3 as fast as an 8274 unloaded and about 10 times as fast at full load. __________________ Rocky Mountain Land Cruiser Association TLCA # 5513 '87BJ74, '86BJ70, '78FJ45, '53M100, '90M101cdn I support our Troopies |
#23 |
what about mounting it on the front axle for a comp only vehicle. This way you could just put a chain drive off the front flange to the flange on the winch for power and use a clutch to engage the winch. I don't like the idea of a winch on the axle, but you would have full driveline power right there.
#24 | ||
my thoughts exactly,i was thinkin of using a ifs minitruck front diff!!Quote:
![]() im in the process of collecting bits for this,when i get everythin together i`ll post some pics,might have to extend my 40`s wheelbase to fit it under there ![]()
#25 | |
you've probably seen this but I thought the link might fit this thread well anyway ![]() http://www.offroadexpress.co.nz/modu...&p=81341#81341 Please do post some updates by all means ! I'm currently thinking azbout something along these lines too
