09-09-07, 08:50 PM
#121 (permalink)
Beagles Rule!
Originally Posted by orangefj45
lookin good dan! wanna run a 3FE in it???
I would love too!
I'm just too stupid to figure out the wiring.
09-09-07, 08:55 PM
#122 (permalink)
Beagles Rule!
Todays progress
My goal today was to get the radiator installed.
What a pain that was. Nothing bolted in.
The Top Pic is the FJ 40 Radiator.
The Bottom Pic is the FJ 60 Radiator
The Middle Pic is the Radiator I used. You do not want to know what it's from.
09-09-07, 09:13 PM
#123 (permalink)
Beagles Rule!
Originally Posted by splitshot
Hey orange, give him a steel trash can to replace the one his wife burned up
Wife picked up one when I was at the 45 Run.
09-09-07, 09:40 PM
#124 (permalink)
Beagles Rule!
The donor vehicle came apart but it was a fruitless venture.
The radiator out of a 40 will not work unless you fab up a new radiator support or cut the frame supports.
09-09-07, 09:43 PM
#125 (permalink)
Beagles Rule!
Is this Stock for a 1974 F motor in an FJ40?
09-09-07, 10:11 PM
#126 (permalink)
no the alt is out to far.
73 FJ40 Green - Original
74 FJ40 Red - (BMFCAGE) SOA 36X17IROKS weldedrear ARBfront and what ever els you can think of
97 FZJ80 Green (the wife's) - locked
67 fj45lwb in the works
09-09-07, 10:11 PM
#127 (permalink)
Beagles Rule!
Here is the final product.
09-09-07, 10:12 PM
#128 (permalink)
Beagles Rule!
The radiator is not just off set but it is square with the fan. My 40's and my 60's are the same way.
09-09-07, 10:22 PM
#129 (permalink)
Will you have room for the head light on the drivers side?
09-10-07, 07:39 AM
#130 (permalink)
Beagles Rule!
I should have enough room for it. I took the measurements from my 40 and they are the same.
Here is the gap between the radiator and the front bib. It is the same as a 40.
09-10-07, 08:13 AM
#131 (permalink)
What's next?
I might have missed it but, have you figured out how to fab the rear glass opening?
You picked the right man to do your cage, impressive work.
'69 fj40
CSC#103
A dry heat still cooks a turkey
09-10-07, 08:20 AM
#132 (permalink)
Happy Owner
and here is a shot of D checking it for fit, looks good brother and i have your springs
09-10-07, 08:26 AM
#133 (permalink)
Beagles Rule!
It will have the hatchback that the 74's came with for now.
09-10-07, 08:27 AM
#134 (permalink)
Beagles Rule!
My plan is to build the entire rig and drive it to Surf and Truf 2007 for the shake down test.
I will then take it all apart and it will get paint and weatherstripping, etc.
09-10-07, 08:30 AM
#135 (permalink)
Former Lifer
how in the world did you wife melt a 55 gallon drum?
Limit all US politicians to two terms; One in office, One in prison
09-10-07, 08:32 AM
#136 (permalink)
What's next?
Hmmmm, I wonder if the top half of ambulance swing doors would work also.
'69 fj40
CSC#103
09-10-07, 08:37 AM
#137 (permalink)
Beagles Rule!
During my FJ40 Rear bumper Build, I was welding and an ember caught a rag on fire about 10 feet away. I did not notice since I still had the helmet down. She picked up the rag and threw it in the trash can.
A few minutes later the trash can went up in flames.
09-10-07, 11:16 AM
#138 (permalink)
Beagles Rule!
Here is the 3" gap between the fan and the radiator.
This is the same measurement I took from my FJ 40 and my FJ 60.
09-10-07, 11:18 AM
#139 (permalink)
Beagles Rule!
I will be installing a flat bed with a roof rack. Similar to Mudracks rig but on an economy level.
09-10-07, 12:58 PM
#140 (permalink)
Metal Tech
Ah yes, the highly technical way of figuring out the height of a seat or whatever. Start stacking whatever chunks of wood/metal till best fit
Propane Powered 2f.
09-10-07, 01:12 PM
#141 (permalink)
it still looks like the front axle should be moved forward more .just a thought
keep up the great work
Jake S.
FJ40,350 small block ,sm465 ,spring over ,cut-N-turn,saginaw,shackle reversal, 38.5 superswampers, 4 wheel disc brakes, OBA=CO2 ,
Warn 8274 ,4x4 labs high steer,Marlin chromo birfs ,lunchbox lockers(front+rear) ,Metaltech Jackson cage
 ... ROTW:PBGBOTTLE
....  ... Cardomain Pics
09-10-07, 02:04 PM
#142 (permalink)
Former Lifer
gotcha.. I misread that as she melted a steel 55 gallon drum.
09-10-07, 02:19 PM
#143 (permalink)
Beagles Rule!
I don't disagree. This is as far forward as it goes before you have to move the steering box and have custom arms made as well as utilize a rear steer set up.
I'm going to run it for now. When the 35" are on there I will see how bad it rubs and handles. After SnT it may get moved more.
09-12-07, 12:25 PM
#144 (permalink)
Beagles Rule!
LOL!
I'm sure Summit Racing has a seat locator for sale but this is how it's done in the real world.
09-12-07, 02:43 PM
#145 (permalink)
Metal Tech
I do the same thing. I will grab anything that I can stack till it looks good to me and start welding.
Propane Powered 2f.
09-12-07, 10:28 PM
#146 (permalink)
Rookie
4 door
Very respectable work sir.
Thought I would show a pic of my HJ45. This and a handful of others were custom built for mining and utility companies. RHD
09-13-07, 05:36 AM
#147 (permalink)
did you just buy that one? i know michael in floorida had one for sale on ebay recently.
where are you located?
PS: welcome to mud!!!
09-14-07, 08:01 AM
#148 (permalink)
elder statesman
Dan, it's been a while since I checked in on your build........any you ARE moving right along! A couple of thoughts.
1. I have a good fiberglass cap that has a rotten rain gutter; you are welcome to it. Just have to give me a heads up to get it from my backyard to the shop.
2. I agree with pgbottle about moving the axle. If your only issue with moving it forward is the short pitman arm of the FJ60 steering box..........make it longer! I don't think you should plan on moving the axle again later. Just get it over with now.
In fact, I might consider moving the steering box itself a little further forward. It might help that left front shock that is currently aligned with the steering box.
3. If you're going with a custom fuel tank, why settle for 20 gallons?
That rig could be totally expedition worthy, and a 20 gallon tank would be a handicap.
A carbureted man in a fuel injected world.
65SWB45, 64LWB45, 68FJ40,72V840, 76HJ45[gone],84FJ60[gone], 76K5, 73Sub454, 97Sub5.7, 2002 Trailblazer
TLCA delegate, Trail Crew-LAC TLCA, The White Trash of the Elwood Chapter
my website:
http://www.marksoffroad.net
IT'S FASTER if you CALL ME!
09-14-07, 08:46 AM
#149 (permalink)
Beagles Rule!
That would be great.
[quote=65swb45;2540717]
[quote]
Right now it is moved 3" foward. It is going to get a Mudrack SOA kit. The front perchs on his kit are adjustable so I can get another 1.5" or so out of it. I did not ahve the kit last weekend when time allowed. (Piss Poor Planning on my Part.)
My original intention was to use the stock FJ60 tank. Moving the crossmember back where it should be and it currently is foiled this plan. I could still mount it but I would have to remove it to get the shocks off.
The one pictured is a fuel tank that I had laying around. I have two of them so if I can figure out how to mount both of them I will be at 40gal.
Thanks for the input. I do appreciate it. This is the first vehicle I have built in this fashon.
09-14-07, 11:03 AM
#150 (permalink)
Great build. I am in the process of doing the same with a BJ60 frame and BJ40. Can you get me a shot of your rear body mounts? I am struggling a bit with what to do back there.
Thanks.
Brad T
88 HJ61 " Marmaduke " 12H-T, A440, extreme valve body, PI, cable lockers, PTO winch, SOA, 2" body lift, FF, ARP studs, Longfields, 5.29s, 38x14.5R16 Toyo MTs...
78 BJ 40/42/60
