LinkBack (4) Thread Tools Display Modes
Old 08-03-07, 07:37 AM   #91
wngrog's Avatar
TLCA# 8121
Originally Posted by independent4x View Post
so Larry, the more i look at that body mount design.......you are basically hard mounting the body to the frame
typical mounts are cushioning the body to the frame on a horizontal plane by having an isolator (rubber or ply) sandwiched beween the 2 metal surfaces....looks to me like the body will basically be riding on the 2 horizontal bolts....ie metal to metal.
can you explain that idea a little more in detail?
The red things are bushings.
Wow. Wow. Wow.
That build table is impressive!
The only way to get one of those tubs square is to build a new frame. When Todd Yonkman did his, he had so many shims in his onld frame mounts getting it close to level.
I cannot wait to see this thing in the end....Great Work!
Rock Midget Motorsports
www.rockmidget.com
2009 Calendars at www.rockmidget.com
wngrog is offline   Reply With Quote
Old 08-03-07, 07:45 AM   #92
Originally Posted by woody View Post
my assumption was the red in the images are spring-eye type poly bushings....
yeah, that's pretty much what i was guessing...............just when i glanced at the rendering for some reason i didn't get that.
'71 FJ40 - project
'74 FJ40 - parts
'93 Trooper RS 2 door
'97 7.3L powerstroke - hauler
independent4x is offline   Reply With Quote
Old 08-03-07, 08:16 AM   #93
Mad4wd's Avatar
Guys
They are poly bushings, correct. We machined alluminum sleeves which will be inserted into the 2x2 and 2x3 that they give you for mounts. The sleeves will then be TIG'd to the box mounts on the cab.
This should be alot stronger than a simple single shear mount PLUS it leaves my floor clean for cage. I will have some pics up today as they are bent up and ready to go.
I am working on the connection of the front cowl to tub. Aqualu bolts it together with 4 bolts in the floor...which i want something stronger so I am drilling, countersinking, bucking and microshaving aircraft rivets at the overlap in a nice pattern....I have an AP w/Avionics and I have a sheetmetal fetish so...it has to be sick. I will be posting pics soon...should have mounts done today hopefully.
Thanks for the props also
Larry
TLCA #17281
FJ45 SWB Project, Aqualu, 6.0 L HO, Fab9's, In Progress
66 FJ40 Project/Parts ?
84 4-Runner, Bone Stock Texas Truck
87 4-Runner, 22RET, SAS, Etc.
05 Ram CTD, BD, ATS Trans
"I could have been a chimney sweep....does anyone know where I put that matchbook cover?"
Mad4wd is offline   Reply With Quote
Old 08-03-07, 10:07 AM   #94
FLYINGLOW's Avatar
TLCA# 9203
I have nothing to say that hasn't been said already. Its great to see the Canadian content too! NWF and Aquilu do very nice work. Check out Todd's truck at the Aquilu web site too. It was just featured in 4WD magazine.
77 FJ40 TBI 2F, ARB rear, rear 45 springs, 36" TSLs, Warn 8274......
Made in Japan, Built in Canada
97 4 Runner Ltd
FLYINGLOW is offline   Reply With Quote
Old 08-03-07, 10:58 AM   #95
In the garage
John Smith's Avatar
TLCA# 9074
Thank You for taking the time to do this thread! It is great.
79 FJ40 & 78 FJ55
http://users.starpower.net/johnsmith <- Detailed ToyBox install instructions
Please help save the Upper Tellico OHV area, Donate to the Rescue Tellico Fund http://www.sfwda.org/trails/tellico/donate.html
John Smith is online now   Reply With Quote
Old 08-03-07, 12:22 PM   #96
Medusa's Avatar
Can you share the durometer on the poly bushings?
Got Rice?
Medusa is offline   Reply With Quote
Old 08-03-07, 03:27 PM   #97
Tigerstripe40's Avatar
Wow, this build is awesome.
James Henry
Wasatch Cruisers
TLCA 11233
76 FJ40 'SeldomSeen'
91 VZN130 'CanOWorms'
Tigerstripe40 is offline   Reply With Quote
Old 08-03-07, 05:49 PM   #98
Mad4wd's Avatar
Medusa,
Honestly I don't know. They are spring eye bushings that were the right dimensions to fit into the existing box tube welded to the tub.
Larry
TLCA #17281
Old 08-04-07, 11:05 AM   #99
Is that fire wall standard for Aqualu?
Originally Posted by Mad4wd View Post
Marking for 'imaginary' firewall line...
Check out our new location in Duncan, BC
www.raddcruisers.ca
--> 60 Series Cable Lockers available - 4.11s or 3.70s - all hardware included
Limited Quantities - Deposit or Full Payment Required to hold your order while they ship
Radd Cruisers is online now   Reply With Quote
Old 08-05-07, 09:35 AM   #100
Mad4wd's Avatar
Yes, that is their OEM firewall, which I will be changing in places to suit our build.
Larry
TLCA #17281
Old 08-07-07, 01:15 PM   #101
IH8MUD Tour Guide
concretejungle's Avatar
TLCA# 14646
very very very very very very very very very very very nice.
I thought Gary's (wagoneer) build was awesome, this is going to get even better!
I know it's HUGE motor, but it sure would be cool to see a duramax/allison combo in a cruiser.
95' FZJ80 OME med./J lift, ARB rack, ARB Bull Bar w/tmax 12,500, 315 Nitto, stainless brake lines, Center Diff Lock, Sliders, IPOR Skid, IPOR rear bumper, upgraded slee sticker, custom dents, more to come. . .
concretejungle is online now   Reply With Quote
Old 08-07-07, 02:10 PM   #102
Mad4wd's Avatar
Ive actually thought about that...I am waiting for Grogan to commision me to build it for him.... We dont do alot of builds normally for two reasons. One, I am out of space (waiting on a 4K addition) and Second I am way critical and slow on how I work...so its diffulcult to find people willing to pay for that level of 4wd work...but they will pay for street rod /streetcar work.
Larry
TLCA #17281
Old 08-07-07, 08:33 PM   #103
Mad4wd's Avatar
Ok, here are a few more pics as we start mounting the body mounts.
We Dykem's blued the centerline and clamped up the mount to help find hole centers.
TLCA #17281
Old 08-07-07, 08:34 PM   #104
Mad4wd's Avatar
We are using a center punch w/ a V-block to mark center. The V-block keeps the punch perpindicular to the work face ensuring a 'true' center.
TLCA #17281
Old 08-07-07, 08:36 PM   #105
Mad4wd's Avatar
This is a cutter made by 'Uni-bit' that bores super accurate holes. It beats the heck out of using a hole saw which skips all over the place. They are available in quite a few sizes.
TLCA #17281
Old 08-07-07, 08:38 PM   #106
Mad4wd's Avatar
.250" Wall tubes inserted into cab with bushings in place.
TLCA #17281
Old 08-07-07, 08:39 PM   #107
Mad4wd's Avatar
Outside view of what is taking place in the mounts on the cab.
TLCA #17281
Old 08-07-07, 08:41 PM   #108
Mad4wd's Avatar
Getting ready to tack the sides to the frame. Then we can remove the body and TIG the sleeves to the cab. We then will begin the process of skinning the mounts and TIG'ing the outside of the mounts to the rails.
TLCA #17281
Old 08-07-07, 09:23 PM   #109
wngrog's Avatar
TLCA# 8121
Larry
Funny.....
Did you see how BIG that Suburban Gorilla had to be on Extreme 4x4 to fit the Duramax in it?
No thanks, I will take this anyday.
Is this your personal rig? Damn, you are getting to spend some awesome time on it.
I am very impressed with the attention to detail.
What about getting some of the pictures of your model in this thread
www.rockmidget.com
Old 08-07-07, 09:54 PM   #110
what he said
Mace's Avatar
Gotta ask.. Why 2 bushings??
I am kinda gay.......
My Myspace
Mace is online now   Reply With Quote
Old 08-07-07, 09:54 PM   #111
GreasedPiggy's Avatar
I don't think I can keep watching this thread because I'll start crying!!!
This is a seriously cool build. Awesome approach.
1975 FJ 55, Cummins 4BT, 4L80E, NP208, SOA, 14 bolt rear, Dana 60 front, ARB Lockers, Scout II PS, Discs, Cross-over, TSL Q78-16
1995 T-100, 4" susp lift, 33 Goodyear MT/R, bought it new, my DD
1961 ford Falcon, 5.0L EFI, T-5, 9-inch
GreasedPiggy is offline   Reply With Quote
Old 08-07-07, 10:10 PM   #112
LT
Metal Tech
LT's Avatar
TLCA# 12989
Where do you get these little gems? I hate making holes with the hole saw.
Propane Powered 2f.
LT is online now   Reply With Quote
Old 08-07-07, 11:15 PM   #113
Mad4wd's Avatar
I buy them mailorder...they work great...not super cheap, but they last ok with a slow spped drill press or air drill.
Specs:
Carbide Hole Cutters
135 degree split point ensures a true start and eliminates bit walking. No center-punching is required, and the 3/16" pilot drill is double-ended for long life
Three-flatted shank provides a more secure chuck hold, reduces slippage
Hardened carbon steel body is turned from solid steel, not welded, for long life and durability
Designed to make holes in material less than 1/8" thick (up to 10 gauge)
Ideal for use with stainless steel, mild steel, copper, brass, aluminum, plexiglass, fiberglass, and laminates
Carbide cutting edge cuts cleanly without hogging, chattering, or vibration for true, round holes
TLCA #17281
Old 08-07-07, 11:21 PM   #114
Mad4wd's Avatar
Originally Posted by wngrog View Post
Funny.....
G,
I know how big that thing was, we built the axles for that mega beast...that project got waaayyy out of control. The engine is not that big if you take the dual turbo crap off of it. Yep, this one is mine and i try to put an hour or two everyday on it. I was waiting for someone to say something about the Mrs's...let me see what I can do for you...thanks for the good words.
Larry
TLCA #17281
Old 08-08-07, 09:12 AM   #115
Mad4wd's Avatar
Grogan,
You asked for them....heres a couple...
TLCA #17281
Old 08-08-07, 09:13 AM   #116
Mad4wd's Avatar
again...hehehehehe
