06-12-07, 07:55 PM
| | Site Addict
| Family haulin' FJ60 ************************************************** ************************************************** ******
Here is a Table of Contents to help find things. These are the main points of each page. Just find your topic and click on the page number in the navigation bar. - page 1... FJ60 tear down and 2F engine pull, cut up stepvan and cummins 4bta engine pull
page 2... rear frame channel removal and boxing, hydroboost adapting, rear disc idea, 203 tcase disassembly, leaf spring painting and mock-up page 3... Transgo 4L80E-3 manual shift kit install, rear spring hanger welded, 203 GRB to 4L80e adapted page 4... Jerry Nichols No. for 203 doubler to splitcase adapter and assembly, front spring placement, tcase rebuild, drivetrain mock-up (4l80e to 203 to splitcase) page 5... front and rear springs mounted, fix 4BT killer dowel pin (KDP), 4BT cleaning and painting, turbo repair and pyro probe placement, LED dash lights, 4L80e to 203 mated, spectrum coating page 6... rear axle mock up, 203 drilled/tapped, 4BT and 4L80 connected, 4BT placement, clearance and engine side mounts, downpipe start page 7... frame side engine mounts, tranny crossmember and mounts, Art Carr shifter mount, intercooler mock-up page 8... Tranny cable connected, intercooler to radiator mounts, doubler/tcase operation and install, rear axle perch welded, front/rear ubolt plates, front axle mock-up page 9... front axle mounted, dual battery mock-up and trays, bum turbo, mech water temp gauge placement, dual fuel filters, rear disc brake install, AC compressor placement idea, fixed and improved turbo with link, throttle cable hook-up, front axle caster adjustment, front diff guard and axle truss, hydroboost and brake MC install, power steering box tap for ram assist page 10... Wheel spacers, front axle shims installed, Aussie locker in front 3rd, completed downpipe, front axle assembly and longfield super 30 set installed, Marlin High Steer, hydroboost and power steering hoses converted to AN, overflow and PS fluid reservoir mount, brake lines, heater hose routing, lower radiator hose, alignment, intercooler routing page 11… rear weather strip lip fixed, 4l80 rebuild page 12… rear shackles lengthened, doubler/tcase shifters, rear shocks, front shocks and hoops page 13… fender skirts, electric vacuum pump and regulator for tranny modulator, sound deadening engine bay. page 14… doubler/tcase shifter linkage, vacuum regulator install, LED dash lights glowing page 15… 38's mounted, rear quarters trimmed, reconfigured front packs, minor flex page 16… fuel pump and cut-off solenoid, wired up t.converter lock-up, spiral baffle in downpipe, reworked lower radiator hose adapter, tranny cooler installed page 17… first major trip report, contour fan installed using spal controller, baffle removed from downpipe and downpipe heat wrapped, exhaust routed out back, 366 (3200rpm) govenor spring installed, intercooler pulled and cleaned, rig ramped for flex, front drive shaft started page 18… rig gets named, front long spline driveshaft finished, new water temp sender, rear body mount cut for clearance, rear bump stops, first wheeling pics @ TSF, new amsoil air filter with 4" intake. page 19… Modify Hydroboost for 1 1/4" master cylinder, bench bleed MC, heat shield for air filter, 8 groove pully alignment on CS-144alternator install, high mount rear speakers, hydroboost with 1 1/8" MC install from chevy astrovan, front fender trim page 20… lower body line textured and painted, gutter reseal and paint, boost gauge signal line moved, battery straps, hydroassist ram install page 21… wastegate signal line capped, beach wheeling pics and vid, mountain wheeling pics and vids, broke front driveshaft, page 22… removeable rear mud flaps, rebuilt front driveshaft with stronger slip-spline, Hilift demount plate for breaking tire bead from rim, tried out BB for internal tire balance, Coretrax tie down strips from rear cargo area, TSF Cruise the Woods pics, page 23… rear seat back painted, went back to 44mm inducer on my turbo, wastegate tied shut, made 3" intake for turbo mod, extended front/rear bump stops page 24… intercooler and tubing pressure test for leaks, replace passenger side motor mount, made new tcase shifters and extended the levers, console 10" sub box, heater core replacement and duct cleaning, interior firewall insulation, page 25… boost leak troubleshooting (gaskets and o-rings), tire grooving, fabbed steering stops, custom intake horn, snow wheeling pics, front shock repositioning, page 26… 42's (yeah right!), rear shock repositioning, reworked hydro assist mount and clamp, reseal hydrobooster, initial rocker cut and slider mock up page 27… tube bending for sliders, pics of inside of rockers, page 28… sliders mounted on the frame, car crushing pics and vid, smaller lower steering joint for shock clearance, rear bumper 1/4 sliders, page 29… rear bumper mounted, mudflaps fix and remounted, radio flyer welding cart, bilstein 5150s leaking seal, page 30… skid plate frame brackets, CB radio info, TSF wheeling testing out Dirtgypsy's SOA, bending tube for front bumper, page 31… front drive shaft lengthened/retubed, johnny joint and antiwrap bar links, antiwrap bar axle brackets, Poly performance rear axles installed, aussie locker installed in rear, new front axle shock mounts, page 32… Bilstein 7100s mounted, Brokenparts front bumper mounted, rear 1/4 protection bent and mocked, line lock swagelok ball valve and brake line routing, skid plate slapped together, page 33… Rubicon 2009 trip report, Antiwrap bar, page 34… Front bumper phase 1, massive tire failure, page 35… TinyTach install, better boost line fitting, HE351 Holset VGT turbo cleaning, H1 double beadlock rims with pressed centers and rock rings, Cobra 18 WX ST II CB install in dash, page 36… H1 rims mounted, page 37… Junction block for power, pic of Dora in 4WD Toyota Owners Mag, page 38… CB antenna mounted on front fender, skidplate mods, CTW'09 pics and video, Rubicon Part 1 video, sloppy windshield wipers fix, resealed heater core, aluminum rear interior 1/4 panel, page 39… Rubicon Part 2, Rubicon Part 3, lower coolant intake port moded, Rubicon Part 4, Rubicon Part 5, page 40… Rubicon Part 6, Rubicon Part 7, Rubicon Part 8, Rubicon Part 9, page 41… Reworked T.converter, fatigued crossmember, revised crossmember and mounts, revised shifter linkage, tranny failure and replacement, Rubicon Part 10, page 42… Electronic tranny control box and circuit board, line-lock leak fix, new belt tensioner, page 43… ************************************************** ************************************************** ******
Alright fellow forumonians, I've got a project underway and it's time to start sharing. I've lurked here for a while and have absorbed much knowledge, so now it's time for me to show what I've done with that collective knowledge and put it to good use.
So here's the plan, and like all good plans the important part will be adapting to what comes my way.
Cummins 4bta (intercooled)
manual 4L80e
203 to splitcase doubler
SOA
38s
hydroboost
hydroassist
larger fuel tank ***decided to run the cruiser tank instead 10/07***
and some other stuff like:
some kind of insulation/liner for interior floor/firewall
custom bumpers
fender trimming
marlin hysteer
arp knuckle studs
Intended use is a capable all-rounder for trips, DD activities, some towing, and a whole lot of wheelin! It's been almost a year since I sold my last truck/wheeler and the offroad videos on youtube just aren't satisfying my need for the great outdoors, so I'm pushing forward on this project. I've got another kid coming soon so having more room to haul the family became a necessity since my wheelin' "photographer" pulls double duty as a mom.
So lets get some pics in here since all of us seemed to be into the picture books as kids rather than the story books. I'll have a bunch of pics to start with until I get caught up to where I'm at.
That's what I started with.
rear axle out
grill and headlight out
Front axle out
Yup, my seals were shot, bearing grease should be thicker than that. It's being rebuilt anyways.
the brakes still worked fine with that line smashed (wasn't me)
looks good inside
it's floating now
prepped for cut n' turn
this is where I'm at with the front axle so far
goodbye bumper brackets and spring hangers
starting to collect some s****
next I started working on the springs I'm planning on using. The rears will be the chevy 63 inchers and the fronts will be a hybrid pack using a ford ranger rear main leaf. I used a 3 leaf plus overload on a ford ranger I built up and I was happy with the results so I'm going to do it with the cruiser since it's got such a big butt (plenty of room to mount). I have a 4 leaf pack that I'll thinking I'll add one more leaf to start out with and tune from there. The ranger main leaf is 58 inches long so I have a little work to get them under the front, but those flexed pretty well too. I'll just have to build up the pack since the 4bta is heavy in the mid section. I wire brushed and painted each leaf. The chevys are in the front and the ranger main leafs are the furthest away.
front spring mock up. The plum is the original center and since the holes are offset on the ranger springs I figure the axle will move forward 1-3 inches. I wanted to move the axle forward so this is good.
I'm doing a shackle reversal so I don't snag a shackle when approaching obstacles and the long springs will push the mounting point out to the very front.
the rear mount will be tricky since I plan on going through the frame to keep the SO low and that point of the frame just starts to curve out. The crossmember will be removed and relocated.
burned in a front channel and mocked up the spring hangers. So I bought a stepvan for the 4bta and have found that the frame has a lot of steel I can use for fabbing parts. Those hangers were made from that frame. Not bad for living in the recycling age.
you can see the plate I put in there to distribute the weight to both crossmembers on the front of the cruiser. Probably over kill but diesels do produce some good torque.
decided to commit and burn the hangers in. I'm using flux core since I'm doing this outside and am newer to welding than some of you so I usually end up touch-up grinding/flapper wheeling my welds since they aren't the nicest to look at. Paint usually improves the appearace some, or hides it in my case. I'm using a Ready welder II and really like it. Great for portability since I built a little cart to haul my batteries around with. Future plans include dual batteries in the cruiser and a connector wired in for my welder for trail repairs.
I'm out of time so I'll get more pics up tomorrow. Once I'm caught up, pics will probably come more on a weekly basis. I usually get 2 solid days to work on the cruiser on the weekend and after that I upload the pics.
Glad to finally join the ranks and build something I hope to be proud of.
__________________ 85 FJ60, tweaking, Cummins 4BTA, 4L80 manual shift, 203/splitcase doubler, SOA, 37s on H1s, other stuff.
build-up: Family Haulin' FJ60
06-12-07, 08:30 PM
| | 250+ Club
| wow i hope your one of those guys that hasta sell his rig as soon as he finishes it so he can start a new one case if yah did that i would by it.
but really it looks like you thought it out and are making good progress.
keep us posted
__________________ 03 Taco 33s some tube an a Winch SOLD Alice
87 Sami 35s toys 6.5:1 SOLD Matilda
84 FJ60 Lifted 33s pizza cutters 5SPD. Rooth "The Mud Butt Wagon"
"Landcruiser cause everything else sucks" Mudrak |
06-12-07, 08:36 PM
| | 250+ Club
| Alright! Good to see another 4bt cummins in a cruiser. keep it up
__________________ Martin Hovis 1974 FJ40, Freeborn Red, 4BT, NV4500, Dana300, SOA, 35s, Locked...In Progress 1977 FJ40, Smurf Blue, 2.5 lift, 33s.
"Correct me if I'm wrong Sandy, but if I kill all the golfers, they're gonna lock me up and throw away the key" |
06-13-07, 08:01 AM
| | Forum Lifer
| Very cool build, love seeing 60s built. |
06-13-07, 08:59 AM
| | procrastinating
| Lookin good.... chalk another SOA 60 in P-town area! Hope to see ya out on the trails when its done! |
06-13-07, 09:26 AM
| | Site Addict
| Thanks for the comments already. It's funny how having someone watching what you are doing can be motivating. In fact last night I did some more grinding. I work 12 hour days so I usually am not motivated to do much when I get home from work. So if I do get motivated I usually choose something easy like grinding or pounding. Here are some more pics to get caught up.
Pulled the hood, support, radiator, and disconnected all the little stuff that would keep the engine in
starting to lift
and it's out!
sure is a long engine
there really is alot of room in an FJ60 engine bay
here it sits until now awaiting sale
removed the brake master and booster plus the clutch master since I'm planning on running an auto. I ran a manual in my last truck and would rather wimp out with just two pedals instead of three. Plus I'm looking for it to cushion the drivetrain a little. However, the auto won't be a true auto, more on that later.
started taking off lines I won't need
more to come soon, time to do some work, the funding kind.
build-up: Family Haulin' FJ60 |
06-13-07, 09:34 AM
| | Site Addict
| Brokenparts thanks, I have been watching your stuff too since you are so close. It'd be great to see your rig up close to see how tall it really is. Is it close to being done from your last build-up? We'll definitely hook up an do a run sometime. I recognize some of your wheelin' pics from brown's camp. There sure are some decent trails out there, although it's been a while since I've been out there.
If Florida were closer lowtiderider, your many projects would be fun to see in person. How are you liking the open air feeling of your choptop? I don't think it'd be viable here in portland where we see colder rain, but I bet you dry off quicker after surfing.
06-13-07, 10:30 AM
| | procrastinating
| Quote:
Originally Posted by boots4 Brokenparts thanks, I have been watching your stuff too since you are so close. It'd be great to see your rig up close to see how tall it really is. Is it close to being done from your last build-up? We'll definitely hook up an do a run sometime. I recognize some of your wheelin' pics from brown's camp. There sure are some decent trails out there, although it's been a while since I've been out there.
If Florida were closer lowtiderider, your many projects would be fun to see in person. How are you liking the open air feeling of your choptop? I don't think it'd be viable here in portland where we see colder rain, but I be you dry off quicker after surfing. | Cool, I look foward to seeing yours all finished up and on the trails. I agree about chopping the top. If the weather/climate was different here or if I could store it indoors, I would have already chopped it. Until one of those changes... I've gotta keep the top and the big butt. Got another week or two until Big Blue is all buttoned up.
You should try to make it to the next Cascade Cruisers meeting next thursday at Buster's BBQ. |
06-13-07, 10:37 AM
| | what he said
| Looks good!
Family haulers are fun
__________________ I am kinda gay.......
I've set the bar, don't trip over it....
"Mary Poppins: In every job that must be done, there is an element of fun. You find the fun and - SNAP - the job's a game." |
06-13-07, 10:44 AM
#10 (permalink)
| | Forum Lifer
| Nice build thread! |
06-13-07, 11:01 AM
#11 (permalink)
| | Site Addict
| Brokenparts, is that cascadecruiser meeting thursday 6/21? What time does the meeting start and how long do they usually last (I've got a little daughter who goes to bed by 8:30 or she gets grumpy)? I thought about hooking up with you guys but figured I needed my crap back on the road. PM me any details I'd need if you cannot share them here, thanks.
06-13-07, 11:16 AM
#12 (permalink)
| | procrastinating
| no secrets on the meetings... 7:00 every third thursday (yes to 6/21 queston  ) of the month at Buster's BBQ in tigard just off 99 near the Baxters. Meetings are family friendly and usually dont much longer than 45mins to an hour. Alot of people hang out after and BS for awhile but getting home by that time shouldnt be a problem. The link to the local TLC "cascadecruisers" in down in my sig. Click on it and introduce yourself to the cruiserheads over there. Lots of good people from our club cruise this site too. |
06-13-07, 11:21 AM
#13 (permalink)
| | procrastinating
| there's also a guy from the club that just finished his 4bt swap that might prove to helpful to you during your buld too.
Hi jack over... |
06-13-07, 11:45 AM
#14 (permalink)
| | Site Addict
| Thanks for the info, now I'm just waiting for approval to post over on the cascade forum. I'll probably link it here since I plan on keeping this my main thread. I'll plan on showing up at the meeting and shaking a few hands. And I definitely want to meet the other 4bt swapper. I've got ideas for the motor mounts and AC unit for the 4bt but it'd sure be nice to see one set up already. I also keep my eyes glued on the 4btswaps forum. Good info on this engine over there and that's where I've been getting my engine specific ideas.
06-13-07, 11:55 AM
#15 (permalink)
| | procrastinating
| Cool... we'll see ya then! |
06-13-07, 12:48 PM
#16 (permalink)
| | Site Addict
| OK so I've got a little more time to post pics. Lets get to some engine fun.
Here's what I brought home just two months ago. It started right up and was very close to my place. I had bid on a few on dovebid.com but did not have any luck and the prices seemed to be inflated at the time because now the vans in the NorthWest are going for much cheaper. If it's less than $3000 grand in the Northwest I think it is a good deal, at least from what I've seen for the last 8 months.
I found this one on portland's craigslist and was only the second one I'd seen since I'd been searching. Poor guy, he bought it to do a swap, found the jeep he wanted to put it in, went on vacation, came back and the jeep was stolen! So that pushed him far enough to decide to move to arizona where it didn't rain as much. So lucky for me he was selling all his stuff and that's how I picked up this one. The other lucky thing is that he neglected to state that this was the intercooled version! More power, better EGTs! Although I beleive in stock form it will easily pull my cruiser around and I don't plan on turning up the fuel screw for more power right out of the gate. I'm sure I won't be able to resist tinkering later though.
It had some shelves and stuff in it that I had to take out before I could start cutting away.
then I started going to town
more cutting
looks like the dude got stuck in the mud a couple of times. underneath was covered with caked-on mud.
that's how much I've cut off up to now. it was fun driving around the yard like this.
yanked the seat so moving it around became a balancing act pushing on the gas and brake and cranking on that steering wheel. This one did not have power steering but was easier once a lot of the body was gone.
then I drove it up to the concrete under it's own power for the last time to pull the engine.
the hoist just reached far enough to hook up. I ended up cutting that crossbrace by the tranny to make it easier since the intake elbow was hitting the top of the cowl. Many have pulled this out of an uncut van but I'm borrowing that hoist so I ended up cutting stuff first before I could get it to my place. It sure is nice when you've got some decent equipement for the job.
that's me getting some arm action on (pumping the hoist). That's why I'm called boots because I wear those things wrenching and wheeling. I'll have to get new ones soon since they are almost warn through the rubber.
Once it was up high enough it twisted inline with the hoist.
I pulled it around the front and in the shade. It's barely touching the tranny pan but nothing else. If for some reason it decided to fall I didn't want it to fall very far. I didn't have any problems but didn't mind being cautions with the heart of my engine transplant.
still have parts in there I'm going to use
I separated the tranny from the engine on the ground and then hung the engine on a stand and taped up all the openings. It was greasy so I soaked it with engine cleaner and rinsed it with my pressure washer. I sure enjoy having that pressure washer.
other side.
here's a quick shot of it a little cleaner
the idea for a larger gas tank starts here. This is the stepvan's tank. I think it's 30 plus gallons but don't know the exact amount yet, maybe someone seeing this does.
and use these crossmembers to mount it to the cruiser. I've seen tanks mounted to the body and to the frame. The cruiser is originally mounted to the body so I don't think it will be a problem to attach it to the frame. The crossmembers are shorter so I will have to lengthen them but that shouldn't be a problem. That is a 14 bolt and I was considering using it and was torn on that for a while, but I decided to run the cruiser axle instead. Running the 14 bolt I would have to run a centered Tcase, deal with the lug pattern, the width difference (I'm sticking with my FJ60 front), all of which can be solved but time and money play a part. If I snap a shaft I can always upgrade. Plus I like the offcentered diffs. If you have to plow with the front a path is already made for the rear.
driveshaft and exhaust from the stepvan
OK, I'm taking a break for now and returning to "work."
06-13-07, 12:59 PM
#17 (permalink)
| | procrastinating
| sweet! |
06-13-07, 02:59 PM
#18 (permalink)
| | 250+ Club
Join Date: Feb 2004 Location: ravenna Mi sittin 10 deep.
| way good thread, keep it coming.
__________________ Drafting the big bricks with my little brick
78'&80'fj40'&a83'fj60
Great Lakes Land Cruisers |
06-13-07, 06:59 PM
#19 (permalink)
| | 250+ Club
| COOL!!!! I'm looking for a 4bt van for mine. Go over to http://4btswaps.com/forum/index.php There are some cruiserheads over there. Keep the write and pics coming...
Jeff Blumenthal
TLCA# 9883
KE5RST
Austin, Tx
1/71 FJ40 Dulcinea 350/700R4/NP203/TLC3SP/SO/FSR/RSR/RSHR
95 FZJ80 DeFlared, DeRunning Boarded, 33s, more to come www.lslc.org/austin |
06-13-07, 07:48 PM
#20 (permalink)
| | Site Addict
| Yeah, 4btswaps is a great place. Once I got the diesel bug I read just about every thread on that site! Great stuff over there. This is definitely the place for cruisers though, can't beat MUD!
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | |
LinkBack to this Thread: http://forum.ih8mud.com/hardcore-corner/160807-family-haulin.html | | Posted By | For | Type | Date | | another electric vacuum pump question - Cummins 4BT & Diesel Conversions Forums | This thread | Refback | 02-06-10 12:02 AM | | Best Sounding Pipe Muffer Combo - Cummins 4BT & Diesel Conversions Forums | This thread | Refback | 02-04-10 01:46 PM | | 4.10's and 35's? - Cummins 4BT & Diesel Conversions Forums | This thread | Refback | 02-01-10 03:41 AM | | Cruise Moab 2010 | This thread | Refback | 01-25-10 04:16 PM | | How much oil does your engine use? - Cummins 4BT & Diesel Conversions Forums | This thread | Refback | 01-02-10 01:00 PM | | 1988 S-10 4x4 4BT Swap - Page 5 - Cummins 4BT & Diesel Conversions Forums | This thread | Refback | 12-31-09 04:36 PM | | 4BT in Trailblazer? - Cummins 4BT & Diesel Conversions Forums | This thread | Refback | 12-23-09 06:25 PM | | Supercharger install! We dont need no stinkin turbos. - Page 2 - Cummins 4BT & Diesel Conversions Forums | This thread | Refback | 11-29-09 09:58 AM | | Weight - Cummins 4BT & Diesel Conversions Forums | This thread | Refback | 11-26-09 07:08 AM | | Here's the Descrambler - Page 8 - Cummins 4BT & Diesel Conversions Forums | This thread | Refback | 11-01-09 03:53 PM | | Untitled document | This thread | Refback | 10-25-09 05:08 PM | | cool thread on using a VNT,VVT or whatever turbo - Page 8 - Cummins 4BT & Diesel Conversions Forums | This thread | Refback | 10-18-09 09:39 AM | | Untitled document | This thread | Refback | 10-16-09 09:10 AM | | 74 Fj40 - Page 3 - Cummins 4BT & Diesel Conversions Forums | This thread | Refback | 10-10-09 11:22 PM | | Has anyone actually used a 4L80E??? - Page 3 - Cummins 4BT & Diesel Conversions Forums | This thread | Refback | 10-09-09 06:56 PM | | ARAMP1's Ultimate TowRig Buld Thread - Page 2 - Cummins 4BT & Diesel Conversions Forums | This thread | Refback | 10-06-09 02:19 PM | | Has anyone actually used a 4L80E??? - Page 2 - Cummins 4BT & Diesel Conversions Forums | This thread | Refback | 10-03-09 10:05 AM | | FJ60 drivetrain swap questions - Page 3 - Expedition Portal Forum | This thread | Refback | 09-19-09 04:03 PM | | 6bt in 87 V3500....progress thread - Page 2 - Cummins 4BT & Diesel Conversions Forums | This thread | Refback | 08-15-09 04:29 AM | | The new and improved Tiny-Tach - Cummins 4BT & Diesel Conversions Forums | This thread | Refback | 08-12-09 06:45 PM | | anyone actually using a 4l80? - Cummins 4BT & Diesel Conversions Forums | This thread | Refback | 08-09-09 04:26 PM | | THE 4L80/85E information thread - Cummins 4BT & Diesel Conversions Forums | This thread | Refback | 08-09-09 09:24 AM | | Lift pump pre filter - Cummins 4BT & Diesel Conversions Forums | This thread | Refback | 08-07-09 05:04 PM | | Mini Mercedes, Mod Haulin Mercedes, Mercedes Service Atlanta - Felprocatalogw | This thread | Refback | 07-09-09 11:19 AM | | Completed '74 Plymouth Satellite 4bt swap - Cummins 4BT & Diesel Conversions Forums | This thread | Refback | 07-01-09 09:19 PM | | New to Diesel Swap Questions - Plumbing Electrical Etc - Cummins 4BT & Diesel Conversions Forums | This thread | Refback | 06-06-09 11:23 AM | | Electric Vacuum Pumps - Cummins 4BT & Diesel Conversions Forums | This thread | Refback | 05-27-09 11:00 AM | | Show off ur motor mounts. - Page 6 - Cummins 4BT & Diesel Conversions Forums | This thread | Refback | 05-20-09 07:40 PM | | Official Cummins 4BT video thread! - Page 3 - Cummins 4BT & Diesel Conversions Forums | This thread | Refback | 05-20-09 03:25 AM | | '85 FJ60 Landcruiser 4BT/4L480e SOA - Cummins 4BT & Diesel Conversions Forums | This thread | Refback | 05-17-09 01:41 AM | | Here's the Descrambler - Page 4 - Cummins 4BT & Diesel Conversions Forums | This thread | Refback | 05-16-09 10:44 AM | | Here's the Descrambler - Page 6 - Cummins 4BT & Diesel Conversions Forums | This thread | Refback | 04-23-09 12:49 PM | | April 18 - SOLV @ Tillamook State Forest | This thread | Refback | 04-18-09 09:41 PM | | Family Trucksters? - Colorado4x4.org Forums | This thread | Refback | 04-14-09 07:50 AM | | 700r4 feasibility study - Page 6 - Cummins 4BT & Diesel Conversions Forums | This thread | Refback | 03-25-09 09:15 PM | | Jeep Cj2A Bikini Top, Jeep Cj Exhaust Manifold Gasket Replacement, Jeep Cj5 Exhaust Flange - Polarisdiesel | This thread | Refback | 03-08-09 11:24 AM | | Gm Card Points For Chevy Malibu, Gm Automotive Warranty Audit, Gm Cars With 200 Plus Amp Alternators - Shadowdemon | This thread | Refback | 03-08-09 09:51 AM | | Scout Engine Conversion Headers, Scottie Kit Car Parts, Scranton Area Rental Cars - Marshlandboar | This thread | Refback | 03-08-09 08:44 AM | | 1992 80 Series - Cummins 4BT & Diesel Conversions Forums | This thread | Refback | 03-07-09 11:34 AM | | Buy Ford Bronco 4X4 Lifted, Buy Electric Cars, Buy Geo Metro - Yvonneridley | This thread | Refback | 03-07-09 03:24 AM | | Toyota Collapsed Top Radiator Hose, Toyota Cold Fusion France, Toyota Concept Cars - Newavengers | This thread | Refback | 03-07-09 01:43 AM | | Official Cummins 4BT video thread! - Page 5 - Cummins 4BT & Diesel Conversions Forums | This thread | Refback | 03-06-09 03:21 PM | | Dually Fenders For Van, Dual Sport Motorcycle Tires, Dubai Car Rentals - Tiresbicycle | This thread | Refback | 03-06-09 02:04 AM | | Ford Truck Exhaust Manifold Leak, Ford Truck Clutch Kits, Ford Truck Front Fenders My My Messages - Polarisclothing | This thread | Refback | 03-06-09 02:04 AM | | Gmc Truck Plastic Bed Liners Plainfield Illinois, Gmc Truck Mud Flaps, Gmc Truck Tune Up - Balljoint | This thread | Refback | 03-06-09 01:40 AM | | JacobPadilla's Bookmarks on Delicious | This thread | Refback | 02-20-09 07:21 PM | | Mufflers - Cummins 4BT & Diesel Conversions Forums | Post #0 | Refback | 02-16-09 07:58 PM | | Here's the Descrambler - Page 5 - Cummins 4BT & Diesel Conversions Forums | This thread | Refback | 02-13-09 12:48 PM | | FJ60 Build - Page 6 - Pirate4x4.Com Bulletin Board | This thread | Refback | 02-12-09 08:54 AM | | 74 Fj40 - Cummins 4BT & Diesel Conversions Forums | This thread | Refback | 02-02-09 06:13 PM | | PNWJeep.com • View topic - My Build... | This thread | Refback | 01-31-09 10:16 PM | | Do I really need two 12-volt batteries? - Cummins 4BT & Diesel Conversions Forums | This thread | Refback | 01-25-09 11:58 AM | | Dodge intake horns - Cummins 4BT & Diesel Conversions Forums | This thread | Refback | 01-20-09 07:22 PM | | Here's the Descrambler - Page 3 - Cummins 4BT & Diesel Conversions Forums | This thread | Refback | 01-11-09 01:57 PM | | Snow wheeling TSF Browns camp this weekend Jan 3 or 4 2009? | This thread | Refback | 01-02-09 12:38 PM | | how come my trans shifts? - Page 2 - Cummins 4BT & Diesel Conversions Forums | This thread | Refback | 01-02-09 02:49 AM | | Name that thing-a-ma-jig - Cummins 4BT & Diesel Conversions Forums | This thread | Refback | 12-19-08 03:10 PM | | Fuel Log - Cummins 4BT & Diesel Conversions Forums | This thread | Refback | 12-07-08 01:06 PM | | toyota fj62 swap - Cummins 4BT & Diesel Conversions Forums | This thread | Refback | 12-04-08 09:27 AM | | CAC Intake Manifold Part Numbers-ATTN: boots4 - Cummins 4BT & Diesel Conversions Forums | This thread | Refback | 11-28-08 08:09 PM | | Sound proofing on sump - Page 2 - Cummins 4BT & Diesel Conversions Forums | This thread | Refback | 11-11-08 10:05 PM | | video request plz - Cummins 4BT & Diesel Conversions Forums | This thread | Refback | 11-06-08 09:23 AM | | Bosch VE timing question - Cummins 4BT & Diesel Conversions Forums | This thread | Refback | 11-02-08 09:29 PM | | Using 2-stroke oil - Cummins 4BT & Diesel Conversions Forums | This thread | Refback | 10-30-08 07:03 PM | | 4runnerclub.org :: Zobrazit téma - oprava šedesátky | This thread | Refback | 10-26-08 12:05 PM | | Need serious help with egt's - Page 2 - Cummins 4BT & Diesel Conversions Forums | This thread | Refback | 10-22-08 01:26 PM | | Hydroboost setup question - Cummins 4BT & Diesel Conversions Forums | This thread | Refback | 10-22-08 12:35 PM | | Power and economy and reliability where is the happy medium - Page 4 - Cummins 4BT & Diesel Conversions Forums | This thread | Refback | 10-21-08 04:53 PM | | Opinions please - Cummins 4BT & Diesel Conversions Forums | This thread | Refback | 10-21-08 02:41 PM | | Diesel questions | This thread | Refback | 10-19-08 11:45 AM | | Turbo Info, HY35s, Photos/info... Etc - Page 12 - Cummins 4BT & Diesel Conversions Forums | This thread | Refback | 10-18-08 11:42 AM | | Boost gauge location? - Cummins 4BT & Diesel Conversions Forums | This thread | Refback | 10-16-08 11:59 AM | | Isuzu Commercial Diesel - Pirate4x4.Com Bulletin Board | This thread | Refback | 10-14-08 11:14 PM | | Use orginal gas tank question - Cummins 4BT & Diesel Conversions Forums | This thread | Refback | 10-05-08 08:59 AM | | View the profile of boots4 | This thread | Refback | 10-04-08 09:05 PM | | tuning for an HX35 - Cummins 4BT & Diesel Conversions Forums | This thread | Refback | 09-28-08 07:09 AM | | Full Power Screw.... - Cummins 4BT & Diesel Conversions Forums | This thread | Refback | 09-27-08 11:46 PM | | 4x4.ee :: Vaata teemat - Tõsine HJ-60 project | This thread | Refback | 09-15-08 02:15 PM | | Weldernator - Cummins 4BT Forums | This thread | Refback | 09-05-08 04:56 AM | | Engine Choices --3.3l vs. 3.9l - Cummins 4BT Forums | This thread | Refback | 08-16-08 04:45 PM | | Noob EGT question. - Cummins 4BT Forums | This thread | Refback | 08-13-08 06:15 PM | | New Guy - Cummins 4BT Forums | This thread | Refback | 08-01-08 05:56 AM | | Which Dodge automatic to use in FJ80? - Cummins 4BT Forums | This thread | Refback | 07-28-08 08:25 AM | | Let's See Your Trucks! - Page 8 - Cummins 4BT Forums | This thread | Refback | 07-24-08 09:37 PM | | 74 Fj40 - Page 4 - Cummins 4BT Forums | This thread | Refback | 07-21-08 10:13 AM | | IDEAS? EGT's Hot at stock and pump turned up any ideas? - Page 2 - Cummins 4BT Forums | This thread | Refback | 07-12-08 01:40 PM | | Build-up: Jeep YJ w/ Isuzu diesel - Page 11 - Pirate4x4.Com Bulletin Board | This thread | Refback | 07-10-08 10:32 AM | | Arrrgg....it always works this way - Cummins 4BT Forums | This thread | Refback | 06-28-08 05:56 PM | | Can You Still Hear After running you're 4BT? - Page 3 - Cummins 4BT Forums | This thread | Refback | 06-27-08 06:10 AM | | What gears for 37 | This thread | Refback | 06-25-08 12:58 PM | | What gears for 37 | This thread | Refback | 06-23-08 08:33 AM | | Exhaust Routing - Cummins 4BT Forums | This thread | Refback | 06-21-08 11:29 PM | | 74 Fj40 - Page 2 - Cummins 4BT Forums | This thread | Refback | 06-13-08 05:28 PM | | Kdp ? - Cummins 4BT Forums | This thread | Refback | 06-13-08 06:24 AM | | IDEAS? EGT's Hot at stock and pump turned up any ideas? - Cummins 4BT Forums | This thread | Refback | 06-10-08 10:47 AM | | vacuum booster for brakes? - Cummins 4BT Forums | This thread | Refback | 06-08-08 04:39 PM | | Timbercrawler -- View topic - Who owns... | This thread | Refback | 06-06-08 11:05 AM | | Hot rod gets a 4BT - Cummins 4BT Forums | This thread | Refback | 06-05-08 07:32 PM | | Timbercrawler -- View topic - Who owns... | This thread | Refback | 06-04-08 10:01 PM | | Timbercrawler -- View topic - Who owns... | This thread | Refback | 06-04-08 09:46 PM | | VE Pump Question - Cummins 4BT Forums | This thread | Refback | 06-04-08 07:51 PM | | Your max GCVW with a 4BT? - Cummins 4BT Forums | This thread | Refback | 06-04-08 02:57 PM | | 2nd maiden voyage - Cummins 4BT Forums | This thread | Refback | 05-30-08 12:06 PM | | Sound proofing on sump - Page 2 - Cummins 4BT Forums | This thread | Refback | 05-18-08 09:21 PM | | Pullys - Cummins 4BT Forums | This thread | Refback | 05-17-08 08:28 AM | | Muffler or no muffler? Exhaust diameter? - Page 3 - Cummins 4BT Forums | This thread | Refback | 05-13-08 07:25 PM | | Mongos 4BT Firewood Monster Truck - Page 4 - Cummins 4BT Forums | This thread | Refback | 05-12-08 12:05 PM | | Muffler or no muffler? Exhaust diameter? - Page 2 - Cummins 4BT Forums | This thread | Refback | 05-11-08 04:20 PM | | Rebuild H1 turbo - Cummins 4BT Forums | This thread | Refback | 05-10-08 04:16 PM | | 4bt radiator - Cummins 4BT Forums | This thread | Refback | 05-08-08 05:14 PM | | Radiator hose adapters - Cummins 4BT Forums | This thread | Refback | 05-03-08 09:09 PM | | Vibration Issues Affecting Me?? - Cummins 4BT Forums | This thread | Refback | 05-01-08 05:42 AM | | H1C rebuild kits on EBAY - Cummins 4BT Forums | This thread | Refback | 04-21-08 08:59 PM | | Vote: 4bt or 6bt in Jeep J20 - Cummins 4BT Forums | This thread | Refback | 04-16-08 09:18 PM | | Hydroboost or Vacuum pump - Cummins 4BT Forums | This thread | Refback | 04-16-08 02:32 PM | | $3k step van or $2k used motor - Cummins 4BT Forums | This thread | Refback | 04-08-08 05:49 PM | | $3k step van or $2k used motor - Cummins 4BT Forums | This thread | Refback | 04-08-08 03:12 PM | | 4bt swap - Cummins 4BT Forums | This thread | Refback | 04-06-08 02:42 PM | | trailer mod haulin | This thread | Refback | 04-06-08 11:50 AM | | Here is the truck for those who care - Cummins 4BT Forums | This thread | Refback | 04-03-08 05:26 PM | | insurance - Cummins 4BT Forums | This thread | Refback | 04-01-08 12:12 PM | | my bronco build - Page 2 - Cummins 4BT Forums | This thread | Refback | 03-31-08 07:02 PM | | Engine/Transmission Adapter P/N - Cummins 4BT Forums | This thread | Refback | 03-26-08 09:36 PM | | Hi Case mount AC - Cummins 4BT Forums | This thread | Refback | 03-26-08 06:38 PM | | Hi Case mount AC - Cummins 4BT Forums | This thread | Refback | 03-26-08 06:21 PM | | My '68 Kaiser M715 - Cummins 4BT Forums | This thread | Refback | 03-26-08 02:51 PM | | Please Help! Need inout on Trans - Cummins 4BT Forums | This thread | Refback | 03-26-08 12:51 PM | | My '68 Kaiser M715 - Cummins 4BT Forums | This thread | Refback | 03-25-08 08:55 PM | | FZJ80 w/ 4BT, couple questions - Cummins 4BT Forums | This thread | Refback | 03-25-08 05:06 PM | | mod za haulin | This thread | Refback | 03-25-08 08:13 AM | | Bought a 4BT with turbo missing....which one to buy? - Cummins 4BT Forums | This thread | Refback | 03-18-08 08:17 PM | | Questions before the swap starts - Cummins 4BT Forums | This thread | Refback | 03-18-08 06:37 AM | | Step Van????s - Page 2 - Cummins 4BT Forums | This thread | Refback | 03-07-08 08:01 PM | | tater chip tuck??? - Cummins 4BT Forums | This thread | Refback | 03-07-08 05:48 AM | | swapping a 4bt into a 1988 28 ft pace arrow MH - Cummins 4BT Forums | This thread | Refback | 03-06-08 05:04 PM | | Hydroboost, Steering, A/C and gearing questions questions - Cummins 4BT Forums | This thread | Refback | 03-06-08 01:36 PM | | 74 Fj40 - Cummins 4BT Forums | This thread | Refback | 03-05-08 01:45 PM | | 74 Fj40 - Cummins 4BT Forums | This thread | Refback | 03-05-08 12:11 PM | | my Yj is complete pics inside!!!!!! - Cummins 4BT Forums | This thread | Refback | 03-04-08 07:56 PM | | intercooler cooling - Cummins 4BT Forums | This thread | Refback | 03-02-08 07:49 PM | | repower with a 4l80? - Page 3 - Cummins 4BT Forums | This thread | Refback | 03-01-08 06:37 AM | | RPM's with gears and tires - Cummins 4BT Forums | This thread | Refback | 02-28-08 08:33 PM | | What is need to 4l80e? - Cummins 4BT Forums | This thread | Refback | 02-27-08 08:37 PM | | Tranny explosions, parts all over! - Cummins 4BT Forums | This thread | Refback | 02-27-08 07:13 PM | | 4l80e converter - Cummins 4BT Forums | This thread | Refback | 02-26-08 06:55 PM | | 4bt radiator - Cummins 4BT Forums | This thread | Refback | 02-25-08 05:58 PM | | 4bt swap into a TJ - Cummins 4BT Forums | This thread | Refback | 02-22-08 11:48 AM | | 6bt in 87 V3500....progress thread - Page 3 - Cummins 4BT Forums | This thread | Refback | 02-21-08 11:38 PM | | Feb Dovebid vans - Cummins 4BT Forums | This thread | Refback | 02-21-08 08:51 PM | | Mpg<auto<man - Page 2 - Cummins 4BT Forums | This thread | Refback | 02-19-08 01:56 PM | | 6bt in 87 V3500....progress thread - Page 4 - Cummins 4BT Forums | This thread | Refback | 02-18-08 09:13 PM | | Big Line Kit???? - Cummins 4BT Forums | This thread | Refback | 02-10-08 09:04 PM | | better auto transmission for 4bt - Cummins 4BT Forums | This thread | Refback | 02-07-08 03:49 PM | | My new Shop Class - Cummins 4BT Forums | This thread | Refback | 02-07-08 01:23 PM | | 3/4 ton Suburban, Expedition/Overlander RV 4bt or 6bt - Cummins 4BT Forums | This thread | Refback | 02-07-08 11:04 AM | | better auto transmission for 4bt - Cummins 4BT Forums | This thread | Refback | 02-06-08 04:03 PM | | Turbo Upgrade...remove exh. manifold or not - Cummins 4BT Forums | This thread | Refback | 02-04-08 05:29 PM | | Turbo Compressor Housings - Cummins 4BT Forums | This thread | Refback | 01-28-08 05:46 PM | | Identify this engine - Cummins 4BT Forums | This thread | Refback | 01-25-08 07:53 PM | | 6bt in 87 V3500....progress thread - Page 4 - Cummins 4BT Forums | This thread | Refback | 01-24-08 08:38 PM | | Turbo Compressor Housings - Cummins 4BT Forums | This thread | Refback | 01-22-08 07:54 PM | | Battery specs??? - Cummins 4BT Forums | This thread | Refback | 01-21-08 09:35 PM | | Turbo Compressor Housings - Cummins 4BT Forums | This thread | Refback | 01-20-08 05:29 PM | | Where to buy tan Cummins engine paint? - Cummins 4BT Forums | This thread | Refback | 01-19-08 09:23 PM | | Turning Up The Pump - a pictoral 'how to' - Cummins 4BT Forums | This thread | Refback | 01-18-08 12:08 PM | | Sound proofing on sump - Page 2 - Cummins 4BT Forums | This thread | Refback | 01-18-08 10:30 AM | | repower with a 4l80? - Page 2 - Cummins 4BT Forums | This thread | Refback | 01-17-08 10:08 AM | | Got a 4b, now what truck?? - Cummins 4BT Forums | This thread | Refback | 01-16-08 04:28 PM | | Anyone tried this in a 90's GMC Vandura? - Cummins 4BT Forums | This thread | Refback | 01-16-08 03:36 PM | | Anyone tried this in a 90's GMC Vandura? - Cummins 4BT Forums | This thread | Refback | 01-16-08 12:52 PM | | Who is in the PNW? - Cummins 4BT Forums | This thread | Refback | 01-12-08 03:19 PM | | Newbie needin help. Calling NOVA Guys - Cummins 4BT Forums | This thread | Refback | 01-11-08 12:18 PM | | H1C rebuild kits on EBAY - Cummins 4BT Forums | This thread | Refback | 01-10-08 11:30 AM | | H1C rebuild kits on EBAY - Cummins 4BT Forums | This thread | Refback | 01-10-08 10:21 AM | | 95yj - Cummins 4BT Forums | This thread | Refback | 01-08-08 04:07 PM | | air filter flow rates - Cummins 4BT Forums | This thread | Refback | 01-07-08 06:28 PM | | Show off ur motor mounts. - Page 10 - Cummins 4BT Forums | This thread | Refback | 01-07-08 05:38 PM | | Exhaust Done (New video) - Cummins 4BT Forums | This thread | Refback | 01-06-08 10:19 PM | | Cummins 4BT Forums - View Profile: boots4 | This thread | Refback | 12-29-07 07:31 PM | | fuel line - Page 2 - Cummins 4BT Forums | This thread | Refback | 12-28-07 04:59 AM | | intercooler cooling - Cummins 4BT Forums | This thread | Refback | 12-24-07 06:56 PM | | Bypass filter setups - Cummins 4BT Forums | This thread | Refback | 12-23-07 08:18 PM | | Shaker - Cummins 4BT Forums | This thread | Refback | 12-18-07 08:19 PM | | hydroboost fitting sizes - Cummins 4BT Forums | This thread | Refback | 12-18-07 02:44 PM | | | |
