Go Back   IH8MUD.com > General Tech Forums > HardCore Corner
LinkBack (175) Thread Tools Display Modes
Old 09-25-07, 12:28 PM   #181 (permalink)
boots4's Avatar
TLCA# 19547
Originally Posted by CRZA1 View Post
Your exhaust is nearly identical to what I have done. Still looking for more 3" mandrel bent tube (havent really looked that hard). I'm interested in where you frame side mounts end up vertically on the frame rails. Mine are a few inches below the rails, but I have the vertical fluid filles type. I am going to work on it this eve so I'll try to start a thread so you can see my project. You have quickly caught up to me and I am a solid year deep.
I should have more accurate pics of where the motor sits in relation to the frame this weekend when I work on the frame side mounts. I'm in it 5 months so far. Lets see your build!!
build-up: Family Haulin' FJ60
boots4 is offline   Reply With Quote
Old 09-25-07, 12:30 PM   #182 (permalink)
KOOL AAROW
kling-on's Avatar
TLCA# 15374
all I can say is WOW
82 FJ60 5.3, 4l60E, OME Heavy, 33 KM2's 410's, ARB bull & side bars ...SOA in the works
85 FJ60 Trail beater SM 420 crawler box lockers 456, 4D's bobed & choped with a Metal Tech cage
GIT-R-DONE!!!!
TLCA #15374
low riders want SWITCHES... 4 wheelers want SHIFTERS
www.jkcustoms.com
kling-on is offline   Reply With Quote
Old 09-25-07, 12:58 PM   #183 (permalink)
boots4's Avatar
TLCA# 19547
Originally Posted by gifu View Post
Looks like this will be a real nice truck. I noticed that when you put the torque-converter on, you said, "
Slid right on but I don't think I got it lined up quite right because it sticks out too far to mount on the flexplate." This has me a little worried; when you install a torque-converter, you are supposed to slids it on, then rotate it while pushing... there should be two more "steps" as things line up and the torque converter slides all the way on. You'll know it's on all the way, if... once the motor is mounted to the tranny... you find that the converter must be slid forward 1/2" or so. If it was already touching the flexplate... you didn't do it right. And I understand this could potentially damage the converter. I'm not expert... this is just what transmission guys have told me.
otherwise... looks real nice.
Yeah it's not on all the way but I didn't force anything and it's not hooked up to the flywheel. The tolerances on my instruction sheet were tighter than 1/2" and it talked about shimming if it had to be pulled to the flywheel too far. It didn't talk about the rotate and push technique. I don't plan on running it as is and will separate the tranny/engine to put it in correctly. I'll have to try that technique.
Old 09-25-07, 04:17 PM   #184 (permalink)
Turbo Diesel Lover
Tapage's Avatar
Originally Posted by boots4 View Post
I never had a problem with it in front of the 2F. I've been reading about relays and how to wire up the fan so that when I get to that point I'll have a plan. I was planning on buying a wiring kit (and maybe I still will) but with enough knowledge it doesn't look too hard to get it right.
Actually not .. you place a electro termo switch that activate the fans at desired temp .. quite easy. My question about cooling come from the Intercooler idea .. that it's one more " thing " in the air way to the factory rad ..
I can't figure how much cooling need a 4BT but since it's a turbo diesel could be more cooling requirements ..
HJ-60 2H-T Intercooled Tencha
Old 09-25-07, 05:09 PM   #185 (permalink)
boots4's Avatar
TLCA# 19547
Now I follow you. The other local 4bt FJ60 hasn't had any issues with cooling using his factory radiator, granted he isn't running an intercooler. From everything I've read about other 4bt swaps I feel comfortable using the factory radiator. I do have a mechanical water temp gauge I'll use along with the dash gauge but will probably have to wait until next summer to really test it since it's already cooling down up here.
Old 09-26-07, 03:44 PM   #186 (permalink)
Turbo Diesel Lover
Tapage's Avatar
Good point .. I'm always thinking all have the same temp issues as we have down here in Panamá
Old 09-30-07, 03:38 AM   #187 (permalink)
GreasedPiggy's Avatar
Man, I miss a few days on your build and look how much stuff happens!!!
Really appreciate the exhaust routing photos, since my former motor is an I6 too, I am considering what you did. I was thinking of using some of that exhaust wrap stuff, since my idea of metal heat shielding would not lower the total under-hood temps. The wrap lowers pipe temps and diverts the heat downstream.
Those mounts are real artwork! Gusseting looks really good. It may be the angle of the photo but there is a potential stress riser at the aft edge of the notch for the turbo lube return... ...probably nothing, just my eyes.
Your build is really looking great, I'm learning a lot about what to expect. Now considering a different tranny...
1975 FJ 55, Cummins 4BT, 4L80E, NP208, SOA, 14 bolt rear, Dana 60 front, ARB Lockers, Scout II PS, Discs, Cross-over, TSL Q78-16
1995 T-100, 4" susp lift, 33 Goodyear MT/R, bought it new, my DD
1961 ford Falcon, 5.0L EFI, T-5, 9-inch
GreasedPiggy is offline   Reply With Quote
Old 10-01-07, 01:36 PM   #188 (permalink)
boots4's Avatar
TLCA# 19547
Wow, no pics on this page yet, I can fix that!
I had a great friday and then a slow saturday so i guess it evened out. I kept passing by the old pair of mounts that I cut off the frame and started to wonder how those would work out. The angle was wrong but that was easily fixed with some measurements and a cut-off wheel. With the engine in the bay where I wanted I figured out the position of the mounts. I pulled the engine and tacked them on.
Driver
Passenger
Put the engine back in to see where the studs would hit and marked them on the mounts so that the engine can slide down.
Driver
Passenger
Pulled the engine back out and cut out the slots. I also cut out some gussets and welded it all together. I put the gussets downward so water wouldn't have a place to sit and rust.
Driver
Passenger, the motor mounts stud's are offset so that's why this side's slot is in a different spot than the other side. Both frame mounts are at the same spot on their side of the frame.
Finished, I'll paint them before I put the engine in for good.
Wheeled the engine back into the bay and fit it on the mounts. Weight of the engine is on the mounts with the tranny supported by a rachet strap underneath it wrapped around the frame (mock tranny mount). Slid in good and I have clearance on the firewall to the downpipe off of the turbo.
Driver
Passenger, I'll either cut off the bottom of the frame mount or wrap it under the frame with some more gussets.
Height of the 4bt in the bay. That's the hood line and I might rub on the liner in which case I can just trim some out.
I picked up these 4L80e 4x4 tranny mounts and that ended friday. On saturday I dove into the tranny crossmember. These mounts looked like they's absorb vibration well... but ended up being too deep to fit inbetween the tranny and doubler. I found this out after fabbing up my crossmember. I'm going to need something with less beer gut so I took these back to napa and searched through their picture book. I found some I thought might work but none had diamensions and they didn't have them in stock. I'm going to check with the tranny shop that I bought my shift kit from and see what they have before calling the manufacture of the mounts I was looking at to get the diamensions.
Once I figured out those mounts weren't going to work I also realized that I didn't think about clearing the front driveshaft. I didn't finish the crossmember so I'll get that incorporated too. Just some more cutting and welding.
This is the my Art Carr shifter. Since I was going to be shifting this like a stick I wanted something that could stand up to that on a daily basis. This has nice big numbers that will be easy to see to know what gear I'm in while driving. 4th will be my overdrive. For now I will leave the gates and see how I like it instead of cutting them out for the 1st to Rev. throw.
It came with the mounting console that I wasn't planning on so that was a nice suprise. There is a nice little shelf below 1st that I think I'll mount my switch for my lock-up on the torque converter.
Being stuck without tranny mounts I moved on and started putting the second coating of spectrum inside. I also did some test fitting of the stepvan gas tank. Once I got to looking at it I needed to know how many gallons it was to see if it really was going to be worth the time to mount it. I had never filled the old cruiser tank more that 17 gallons but research says it is a 23 gallon tank (I guess E didn't really mean empty on the gauge) and the stepvan's tank is only 30 gallons. If I were to drive conservative and got 25MPG I'd gain 170ish mile range with the 30 gal tank. With the cruiser tank I'll still get close to 600 miles so I decided the time wasn't worth mounting the stepvan tank. Maybe I'll come back to it later but for now I'll just put the old tank back in and deal with a 500 mile range.
Old 10-01-07, 02:00 PM   #189 (permalink)
brokenparts's Avatar
TLCA# 16127
nice.... I really wish I would have held out for an art carr shifter and not gone with the rat-sh*t shifter.
ROTW: http://forum.ih8mud.com/60-series-wagons/198064-rotw-brokenparts-fj-60-a.html
Old 10-01-07, 03:49 PM   #190 (permalink)
Boots, would you grab a measurment from the bottom frame rail to the lowest point of the oil pan? Wanna see where mine is in comparison. Thanks
CRZA1 is offline   Reply With Quote
Old 10-01-07, 05:30 PM   #191 (permalink)
boots4's Avatar
TLCA# 19547
Sure can, I'll get it after work.
Old 10-02-07, 08:12 AM   #192 (permalink)
boots4's Avatar
TLCA# 19547
I measured last night and got 8 3/8" Let me tell you how I measured because that part of the frame slopes downward.
I hung the tape measure from the hole circled in the pic, got a big level and held it up to the bottom of the pan keeping it level so that one side of the level crosses by the hanging tape measure and took a reading. This way I got the lowest point on the bottom of the pan and using that hole you should be able to replicate it exactly.
Old 10-02-07, 08:38 AM   #193 (permalink)
Sweet. I'll check tonight. Wanna see if I'm too low or if my mounts are gonna work. I must say, your mounts look awesome.
Old 10-02-07, 09:02 AM   #194 (permalink)
boots4's Avatar
TLCA# 19547
Thanks again CRZ1. I never got a good measurement on the bulge in the hood so there may be even more room there then I realize.
Old 10-02-07, 09:52 AM   #195 (permalink)
redcorn's Avatar
It's getting cold and wet.....
Any approximate completion date?
Looking great nonetheless!!!!!!
john
No cruisers left behind, they all deserve a good home
BIG WAGONS RULE
http://forum.ih8mud.com/60-series-wa...orns-turd.html
redcorn is offline   Reply With Quote
Old 10-02-07, 10:32 AM   #196 (permalink)
boots4's Avatar
TLCA# 19547
john
Yeah that cold and wet stuff has me a little worried since I'm doing this outside. I am under cover but still outside. Fall sure has stepped in within the last two weeks. I'd like to have it on the ground in a month and drivable in two. Some things I'm trying not to worry about until later i.e. new rear panels, sliders, finishing the rear bumper, AC functional.
Once I get that crossmember done I can get angles for the differentials and get the axles set up including the cut 'n turn. I need to pull the engine one more time for mounts/frame painting and to correctly install the torque converter and then I should be able to put it in and leave it. Wiring to get it running should be simple. We are planning on driving it to Calif. for christmas so most everything will need to be working by then and I'd sure hope I can get some testing in it before then! Plus all this great rain is making great mud and I sure miss wheeling.
Old 10-08-07, 11:08 AM   #197 (permalink)
boots4's Avatar
TLCA# 19547
weekly update
I went out hunting again for tranny mounts but this time I didn't come home empty-handed. I eventually ended up a baxter auto parts and after explaining what I was doing he told me I could look at his inventory for myself. Perfect! That's what I wanted to do but didn't know I could ask. So I hung out in the back opening boxes to check the size ( I brought my adapter with me so I'd know) There were a couple of choices but ultimately choose a pair of motor mounts. Since the tranny is heavier and I added another 80 pounds on with the doubler I think these will work out nicely. Plus they are similar in design to my motor mounts and it should better absorb vibration from the engine (that's what I'm thinking at least). When adapting parts together that weren't ment for each other KISS is a good principle to follow. After I found the mounts the parts guy thought it looked like a chrysler application but couldn't find the number in his book, so I included the number for anyone thinking about doing the same/similar thing.
The offset worked out to my advantage. I couldn't have the mount stick out to far passed the adapter because it would run into the front driveshaft (actually the crossmemeber would in order to accomodate the mount).
The studs were bigger so I needed to drill and tap to have the mounts screw in. I was thinking of bolting on a flat piece so that I could use a center mount but that would have made getting to the bolt holes on the adapter difficult under the rig. As it is right now I'll need to mount the adapter on the tranny first and then the doubler to it.
Mounts are on
The mounts also needed to be no deeper than the adpater to fit inbetween the tranny and the doubler. These work.
It took me all weekend but I finished the transmission crossmember. It was originally designed for the other mounts I had but those didn't work so I had to modify the crossmember in a couple of places. I probably just should have started over but I didn't want to waste the metal. I'll get better pics once I take it all out for painting
Passeger side. Big notch for the driveshaft. I also had to notch the top to clear the rear heater lines.
Driver side. This part of the frame is angled so the frame side mounts made up the difference.
Tranny mounts
The weight of the engine/tranny is on the mounts, the strap is not holding any weight I just tighten it back up. The engine mounts distorted a little bit so I might shim under the tranny mounts to level it some more.
Now I can pull it all back out and paint it. I will also gusset those frame-side mounts once everything is out of the way. I took some time building another work table for outside (got tired of working off of saw horses) and I had to chop some wood so the family could stay warm this week. I also finished my last bit of lining on the interior so now I can put the seats back in and work on placement for the shifter.
Old 10-08-07, 02:18 PM   #198 (permalink)
Turbo Diesel Lover
Tapage's Avatar
It looking incredible dude .. thanks for posting and keeping us up to date ..
Old 10-08-07, 02:39 PM   #199 (permalink)
cali-cruiser's Avatar
What turbo housing are you going to be running? It would probably be a good idea from what is probablt a 15 or 17cm housing to either a 12 or a 9 cm housing. This was the best thing I did to my 4bt. the 12 on my cut the turbo lag to near nothing. As for radiators I'm running my stock 40 rad with a Volvo 760 intercooler in front of that. The only time I've ever had a problem was running for 3-4 hours in 85 deg. heat on a trail andI forgot to turn on my fan, started smelling antifreeze saw some drips, so I flicked on the fan and it was cool in a matter of minutes.
Any more questions holla. Nice looking work.
Josh
PS get ready to replace motor mounts often, I went through 3 pairs of the ones like you have before I went to a new design with 2" poly bushings.
'75 fj40 with 94' Cummins 4BT-3GSK 12cm turbo housing-
willwood front disc, Scout Power steering, SOA front, three link w/ air shocks rear.
cali-cruiser is offline   Reply With Quote
Old 10-08-07, 04:28 PM   #200 (permalink)
boots4's Avatar
TLCA# 19547
Josh
Glad to hear you liked the 12cm housing because that's what I got too. Mine is wastegated and I've thought about fixing it shut to get more boost but I think I will run it first to get a baseline before playing with it.
Well, now you need to share what you did for your new design on your motor mounts. Did you use poly on your motor mount or your transmission mounts, or both? How did the old ones fail (wear out, rip)? It would seem like polys would transmit more vibes to the frame.
Old 10-09-07, 05:46 PM   #201 (permalink)
my current set up is, two polys up front on the motor, with a large rubber mount on the back of the t-case. The rubber motor mounts I was getting would either smash flat on the passenger side or tare apart on the drivers (the bottom end of the 4BT is amazing). The polys don't seem to transfer to bad of vibration but it definitely is is not like running in a Cadillac. The bushings are these :
http://www.polyperformance.com/shop/...&cat=28&page=1
The other engine mod I did that made a big difference was the 3GSK. now it pulls all the way through the gear not just the first bit.
Josh
Old 10-09-07, 06:06 PM   #202 (permalink)
boots4's Avatar
TLCA# 19547
Thanks for the info. The guys on the 4btswaps site that have used these mounts haven't reported any problems so I'll keep an eye on those once it's on the road.
I'm assuming you did the govenor spring in your injection pump, did you get your 366 spring from pier's diesel or somewhere local? Did you need to bleed the injection pump after you opened it up to replace the spring?
Old 10-09-07, 10:12 PM   #203 (permalink)
Yeah the governor spring I did, I got it from PDR. It ended up being a two month ordeal to get it back running again. I ended up bending the fuel shot off lever inside the pump so that it would not ride on the full fuel screw and thus would not let any fuel to the injectors. I was going to school and had no time to work on it then, but after a new fuel filter and a new lift pump, I finally realized the problem and ended up welding the crack on the arm inside of the pump. Its been running ever since. As for bleeding, just crack the injectors and crank it, this will work out any air that is still in the pump either that or run your electric pump for a bit with the key on and it should run fuel through the pump and out the return line.
I'm running my exhaust the same way and find it is the best way I have found. I just added a single chamber flowmaster and found that it knocked down the noise quite a bit, now all I hear is the sweet song of the turbo. the egts were a bit high before intercooler, but with it is a dream.
Josh
Old 10-10-07, 04:39 PM   #204 (permalink)
boots4's Avatar
TLCA# 19547
I got outside the last two nights and have been putting the interior back together. I needed to get the driver's seat in so I could see about positioning the shifter. It looks like I'll want to build a little plateform to bring it up to a more comfortable position. Since I'll need to shift this like a stick I want it to be comfortable to reach.
Another package showed up today with 4 relays. The plan is to wire the headlights with relays (one for low, one for high) to get some more voltage to them (will make them brighter). Another relay will go with my spal fan controller (suppost to be here tomorrow) to run the contour fans for cooling. And the last relay will be a spare until I get the little compressor wired up for on-board air.
Old 10-11-07, 05:23 AM   #205 (permalink)
redcorn's Avatar
Adding the 7" Roundeyes headlamps was one of the best mods I made for travelling in my rig.
Stock lamps blow
BIG WAGONS RULE
Old 10-13-07, 09:00 AM   #206 (permalink)
boots4's Avatar
TLCA# 19547
Stock lamps blow
I definitely agree with that! I'm wiring in the relays to get ready for adding more powerful headlights in the future. Still need shocks and drivelines so those take $$ priority. But there's always christmas right around the corner.
Old 10-15-07, 11:31 AM   #207 (permalink)
boots4's Avatar
TLCA# 19547
weekly update
We had some dry weather this last weekend so I got some painting done. Before I painted I added gussets to the front spring hangers and tranny mounts. I also painted the motor mounts (motor side), tranny crossmember, and my 203 access cover.
I only painted the inside frame to the middle. I can finish up the rest with the drivetrain mounted. I have some acid etching around where the battery was. I want to clean that up a little more before I paint it too.
Gussets on the front hanger. I was going to do something fancy with the gussets but decided to just get on with it and spend time on more important stuff.
Tranny mounts finshed up
While the paint was drying I worked on getting the shifter mounted. After trying a couple of positions I decided it needed to come up to be more comfortable so I fabbed up a base. I also trimmed the plastic base to make it shorter. I haven't coated the tranny access cover because I'm not sure were the TC shifters are going to come through.
The base will fasten to the floor with the bolts I tacked on inside.
Holes
The base
Painted the base and put the shifter in to see how it looked. I have about 1 inch of room off the dash when the shifter is in Park.
While the engine was out I separated the tranny to install the torque converter correctly. I did the push and turn trick a couple of times and felt it go in deeper. Then I put the tranny back on to line up the torque converter. The instructions that came with it said that a gap of 1/16" - 1/8" was fine but that anything bigger needed to have washers/spacers put inbetween the TC and flex-ring to get it to that spacing. Mine was more like 3/16" strong so I got some grade 8 washers (those seemed to be the most consistent in thickness) and put those in. That brought me within the range on the instructions. Now getting them in there was tricky and took me some time, but with enough patience I finally got them all in and started to tighten the bolts. I brought in the TC a little at a time and moved to the next bolt trying to be as even as possible. It suggested that the TC could produce unwanted vibration if it were misaligned by tightening one bolt down all the way and then moving on to the next. I turned the engine with a rachet to turn the flywheel while tightening the bolts. Here's a pic of the spacing. All mounting surfaces were sanded before putting this together.
Old 10-15-07, 11:34 AM   #208 (permalink)
boots4's Avatar
TLCA# 19547
With the engine back in the bay after the paint dried and hopefully for the last time, I started positioning the intercooler/radiator. I came up with a mounting strip to joint the two together. Again I used pieces off the stepvan frame.
It's hard to see but it's the piece with the bolts on it and it goes inbetween the radiator and intercooler. All holes were pre-existing so I just tacked bolts on this piece that lined up with the holes.
I clearanced the flanges on the radiator so I could get the intercooler down.
This is where I mounted it to the radiator.
It's just placed in there right now and will need mounts to the frame or the radiator support. I was concerned that I'd have hood clearance problems but from what I can tell it looks like I'll be fine. I won't really know until I get the engine hoist out of there (no reason for it to be there now) and test fit the hood.
I tested my mech. water temp gauge to make sure it works before I put in the time fitting it in the dash. I ordered a pair of Marlin's new front axle seals and those showed up; I bought my rebuild kit before those came out so I'll use the ones in that kit as spares. I also got my Spal fan controller. It's smaller than I imagined and looks pretty nice.
Old 10-15-07, 11:47 AM   #209 (permalink)
OHV Trail Patrol
CreeperSleeper's Avatar
TLCA# 15577
Wow, the amount of work that you get done in a weekend amazes me... I need to come over and watch you so I learn how to do that!
Everything is looking great, as usual...
Chad - Cascade Cruisers
KE7VSA - MetalTech
FZJ80 - 37's, lifted, locked, geared, cut and dented.
Originally Posted by bugsnbikes View Post
Dewd- You would bend those spindles if I tucked them into the passenger seat You are a candidate for a bobbed 80----not a high clearance bumper.
CreeperSleeper is offline   Reply With Quote
Old 10-15-07, 12:05 PM   #210 (permalink)
concretejungle's Avatar
TLCA# 14646
this is really an amazing build. Your attention to detail is awesome, right down to the LED lights!!
Could you post a link of this 4bt conversion forum you speak of occasionally? I would like to educate myself a bit.
Thanks and keep diggin'
95' FZJ80 OME med./J lift, ARB rack, ARB Bull Bar w/tmax 12,500, 35" truxus, Aussie locker-rear, Center Diff Lock, Sliders, IPOR Skid, IPOR rear bumper, upgraded slee sticker, custom dents, more to come. . .
Go 80, or go unsatisfied
concretejungle is offline   Reply With Quote
LinkBack to this Thread: http://forum.ih8mud.com/hardcore-corner/160807-family-haulin.html
Posted By For Type Date
Here's the Descrambler - Page 8 - Cummins 4BT & Diesel Conversions Forums This thread Refback 11-01-09 03:53 PM
Untitled document This thread Refback 10-25-09 05:08 PM
cool thread on using a VNT,VVT or whatever turbo - Page 8 - Cummins 4BT & Diesel Conversions Forums This thread Refback 10-18-09 09:39 AM
Untitled document This thread Refback 10-16-09 09:10 AM
74 Fj40 - Page 3 - Cummins 4BT & Diesel Conversions Forums This thread Refback 10-10-09 11:22 PM
Has anyone actually used a 4L80E??? - Page 3 - Cummins 4BT & Diesel Conversions Forums This thread Refback 10-09-09 06:56 PM
ARAMP1's Ultimate TowRig Buld Thread - Page 2 - Cummins 4BT & Diesel Conversions Forums This thread Refback 10-06-09 02:19 PM
Has anyone actually used a 4L80E??? - Page 2 - Cummins 4BT & Diesel Conversions Forums This thread Refback 10-03-09 10:05 AM
FJ60 drivetrain swap questions - Page 3 - Expedition Portal Forum This thread Refback 09-19-09 04:03 PM
6bt in 87 V3500....progress thread - Page 2 - Cummins 4BT & Diesel Conversions Forums This thread Refback 08-15-09 04:29 AM
The new and improved Tiny-Tach - Cummins 4BT & Diesel Conversions Forums This thread Refback 08-12-09 06:45 PM
anyone actually using a 4l80? - Cummins 4BT & Diesel Conversions Forums This thread Refback 08-09-09 04:26 PM
THE 4L80/85E information thread - Cummins 4BT & Diesel Conversions Forums This thread Refback 08-09-09 09:24 AM
Lift pump pre filter - Cummins 4BT & Diesel Conversions Forums This thread Refback 08-07-09 05:04 PM
Mini Mercedes, Mod Haulin Mercedes, Mercedes Service Atlanta - Felprocatalogw This thread Refback 07-09-09 11:19 AM
Completed '74 Plymouth Satellite 4bt swap - Cummins 4BT & Diesel Conversions Forums This thread Refback 07-01-09 09:19 PM
New to Diesel Swap Questions - Plumbing Electrical Etc - Cummins 4BT & Diesel Conversions Forums This thread Refback 06-06-09 11:23 AM
Electric Vacuum Pumps - Cummins 4BT & Diesel Conversions Forums This thread Refback 05-27-09 11:00 AM
Show off ur motor mounts. - Page 6 - Cummins 4BT & Diesel Conversions Forums This thread Refback 05-20-09 07:40 PM
Official Cummins 4BT video thread! - Page 3 - Cummins 4BT & Diesel Conversions Forums This thread Refback 05-20-09 03:25 AM
'85 FJ60 Landcruiser 4BT/4L480e SOA - Cummins 4BT & Diesel Conversions Forums This thread Refback 05-17-09 01:41 AM
Here's the Descrambler - Page 4 - Cummins 4BT & Diesel Conversions Forums This thread Refback 05-16-09 10:44 AM
Here's the Descrambler - Page 6 - Cummins 4BT & Diesel Conversions Forums This thread Refback 04-23-09 12:49 PM
April 18 - SOLV @ Tillamook State Forest This thread Refback 04-18-09 09:41 PM
Family Trucksters? - Colorado4x4.org Forums This thread Refback 04-14-09 07:50 AM
700r4 feasibility study - Page 6 - Cummins 4BT & Diesel Conversions Forums This thread Refback 03-25-09 09:15 PM
Jeep Cj2A Bikini Top, Jeep Cj Exhaust Manifold Gasket Replacement, Jeep Cj5 Exhaust Flange - Polarisdiesel This thread Refback 03-08-09 11:24 AM
Gm Card Points For Chevy Malibu, Gm Automotive Warranty Audit, Gm Cars With 200 Plus Amp Alternators - Shadowdemon This thread Refback 03-08-09 09:51 AM
Scout Engine Conversion Headers, Scottie Kit Car Parts, Scranton Area Rental Cars - Marshlandboar This thread Refback 03-08-09 08:44 AM
1992 80 Series - Cummins 4BT & Diesel Conversions Forums This thread Refback 03-07-09 11:34 AM
Buy Ford Bronco 4X4 Lifted, Buy Electric Cars, Buy Geo Metro - Yvonneridley This thread Refback 03-07-09 03:24 AM
Toyota Collapsed Top Radiator Hose, Toyota Cold Fusion France, Toyota Concept Cars - Newavengers This thread Refback 03-07-09 01:43 AM
Official Cummins 4BT video thread! - Page 5 - Cummins 4BT & Diesel Conversions Forums This thread Refback 03-06-09 03:21 PM
Dually Fenders For Van, Dual Sport Motorcycle Tires, Dubai Car Rentals - Tiresbicycle This thread Refback 03-06-09 02:04 AM
Ford Truck Exhaust Manifold Leak, Ford Truck Clutch Kits, Ford Truck Front Fenders My My Messages - Polarisclothing This thread Refback 03-06-09 02:04 AM
Gmc Truck Plastic Bed Liners Plainfield Illinois, Gmc Truck Mud Flaps, Gmc Truck Tune Up - Balljoint This thread Refback 03-06-09 01:40 AM
JacobPadilla's Bookmarks on Delicious This thread Refback 02-20-09 07:21 PM
Mufflers - Cummins 4BT & Diesel Conversions Forums Post #0 Refback 02-16-09 07:58 PM
Here's the Descrambler - Page 5 - Cummins 4BT & Diesel Conversions Forums This thread Refback 02-13-09 12:48 PM
FJ60 Build - Page 6 - Pirate4x4.Com Bulletin Board This thread Refback 02-12-09 08:54 AM
74 Fj40 - Cummins 4BT & Diesel Conversions Forums This thread Refback 02-02-09 06:13 PM
PNWJeep.com • View topic - My Build... This thread Refback 01-31-09 10:16 PM
Do I really need two 12-volt batteries? - Cummins 4BT & Diesel Conversions Forums This thread Refback 01-25-09 11:58 AM
Dodge intake horns - Cummins 4BT & Diesel Conversions Forums This thread Refback 01-20-09 07:22 PM
Here's the Descrambler - Page 3 - Cummins 4BT & Diesel Conversions Forums This thread Refback 01-11-09 01:57 PM
Snow wheeling TSF Browns camp this weekend Jan 3 or 4 2009? This thread Refback 01-02-09 12:38 PM
how come my trans shifts? - Page 2 - Cummins 4BT & Diesel Conversions Forums This thread Refback 01-02-09 02:49 AM
Name that thing-a-ma-jig - Cummins 4BT & Diesel Conversions Forums This thread Refback 12-19-08 03:10 PM
Fuel Log - Cummins 4BT & Diesel Conversions Forums This thread Refback 12-07-08 01:06 PM
toyota fj62 swap - Cummins 4BT & Diesel Conversions Forums This thread Refback 12-04-08 09:27 AM
CAC Intake Manifold Part Numbers-ATTN: boots4 - Cummins 4BT & Diesel Conversions Forums This thread Refback 11-28-08 08:09 PM
Sound proofing on sump - Page 2 - Cummins 4BT & Diesel Conversions Forums This thread Refback 11-11-08 10:05 PM
video request plz - Cummins 4BT & Diesel Conversions Forums This thread Refback 11-06-08 09:23 AM
Bosch VE timing question - Cummins 4BT & Diesel Conversions Forums This thread Refback 11-02-08 09:29 PM
Using 2-stroke oil - Cummins 4BT & Diesel Conversions Forums This thread Refback 10-30-08 07:03 PM
4runnerclub.org :: Zobrazit téma - oprava šedesátky This thread Refback 10-26-08 12:05 PM
Need serious help with egt's - Page 2 - Cummins 4BT & Diesel Conversions Forums This thread Refback 10-22-08 01:26 PM
Hydroboost setup question - Cummins 4BT & Diesel Conversions Forums This thread Refback 10-22-08 12:35 PM
Power and economy and reliability where is the happy medium - Page 4 - Cummins 4BT & Diesel Conversions Forums This thread Refback 10-21-08 04:53 PM
Opinions please - Cummins 4BT & Diesel Conversions Forums This thread Refback 10-21-08 02:41 PM
Diesel questions This thread Refback 10-19-08 11:45 AM
Turbo Info, HY35s, Photos/info... Etc - Page 12 - Cummins 4BT & Diesel Conversions Forums This thread Refback 10-18-08 11:42 AM
Boost gauge location? - Cummins 4BT & Diesel Conversions Forums This thread Refback 10-16-08 11:59 AM
Isuzu Commercial Diesel - Pirate4x4.Com Bulletin Board This thread Refback 10-14-08 11:14 PM
Use orginal gas tank question - Cummins 4BT & Diesel Conversions Forums This thread Refback 10-05-08 08:59 AM
View the profile of boots4 This thread Refback 10-04-08 09:05 PM
tuning for an HX35 - Cummins 4BT & Diesel Conversions Forums This thread Refback 09-28-08 07:09 AM
Full Power Screw.... - Cummins 4BT & Diesel Conversions Forums This thread Refback 09-27-08 11:46 PM
4x4.ee :: Vaata teemat - Tõsine HJ-60 project This thread Refback 09-15-08 02:15 PM
Weldernator - Cummins 4BT Forums This thread Refback 09-05-08 04:56 AM
Engine Choices --3.3l vs. 3.9l - Cummins 4BT Forums This thread Refback 08-16-08 04:45 PM
Noob EGT question. - Cummins 4BT Forums This thread Refback 08-13-08 06:15 PM
New Guy - Cummins 4BT Forums This thread Refback 08-01-08 05:56 AM
Which Dodge automatic to use in FJ80? - Cummins 4BT Forums This thread Refback 07-28-08 08:25 AM
Let's See Your Trucks! - Page 8 - Cummins 4BT Forums This thread Refback 07-24-08 09:37 PM
74 Fj40 - Page 4 - Cummins 4BT Forums This thread Refback 07-21-08 10:13 AM
IDEAS? EGT's Hot at stock and pump turned up any ideas? - Page 2 - Cummins 4BT Forums This thread Refback 07-12-08 01:40 PM
Build-up: Jeep YJ w/ Isuzu diesel - Page 11 - Pirate4x4.Com Bulletin Board This thread Refback 07-10-08 10:32 AM
Arrrgg....it always works this way - Cummins 4BT Forums This thread Refback 06-28-08 05:56 PM
Can You Still Hear After running you're 4BT? - Page 3 - Cummins 4BT Forums This thread Refback 06-27-08 06:10 AM
What gears for 37 This thread Refback 06-25-08 12:58 PM
What gears for 37 This thread Refback 06-23-08 08:33 AM
Exhaust Routing - Cummins 4BT Forums This thread Refback 06-21-08 11:29 PM
74 Fj40 - Page 2 - Cummins 4BT Forums This thread Refback 06-13-08 05:28 PM
Kdp ? - Cummins 4BT Forums This thread Refback 06-13-08 06:24 AM
IDEAS? EGT's Hot at stock and pump turned up any ideas? - Cummins 4BT Forums This thread Refback 06-10-08 10:47 AM
vacuum booster for brakes? - Cummins 4BT Forums This thread Refback 06-08-08 04:39 PM
Timbercrawler -- View topic - Who owns... This thread Refback 06-06-08 11:05 AM
Hot rod gets a 4BT - Cummins 4BT Forums This thread Refback 06-05-08 07:32 PM
Timbercrawler -- View topic - Who owns... This thread Refback 06-04-08 10:01 PM
Timbercrawler -- View topic - Who owns... This thread Refback 06-04-08 09:46 PM
VE Pump Question - Cummins 4BT Forums This thread Refback 06-04-08 07:51 PM
Your max GCVW with a 4BT? - Cummins 4BT Forums This thread Refback 06-04-08 02:57 PM
2nd maiden voyage - Cummins 4BT Forums This thread Refback 05-30-08 12:06 PM
Sound proofing on sump - Page 2 - Cummins 4BT Forums This thread Refback 05-18-08 09:21 PM
Pullys - Cummins 4BT Forums This thread Refback 05-17-08 08:28 AM
Muffler or no muffler? Exhaust diameter? - Page 3 - Cummins 4BT Forums This thread Refback 05-13-08 07:25 PM
Mongos 4BT Firewood Monster Truck - Page 4 - Cummins 4BT Forums This thread Refback 05-12-08 12:05 PM
Muffler or no muffler? Exhaust diameter? - Page 2 - Cummins 4BT Forums This thread Refback 05-11-08 04:20 PM
Rebuild H1 turbo - Cummins 4BT Forums This thread Refback 05-10-08 04:16 PM
4bt radiator - Cummins 4BT Forums This thread Refback 05-08-08 05:14 PM
Radiator hose adapters - Cummins 4BT Forums This thread Refback 05-03-08 09:09 PM
Vibration Issues Affecting Me?? - Cummins 4BT Forums This thread Refback 05-01-08 05:42 AM
H1C rebuild kits on EBAY - Cummins 4BT Forums This thread Refback 04-21-08 08:59 PM
Vote: 4bt or 6bt in Jeep J20 - Cummins 4BT Forums This thread Refback 04-16-08 09:18 PM
Hydroboost or Vacuum pump - Cummins 4BT Forums This thread Refback 04-16-08 02:32 PM
$3k step van or $2k used motor - Cummins 4BT Forums This thread Refback 04-08-08 05:49 PM
$3k step van or $2k used motor - Cummins 4BT Forums This thread Refback 04-08-08 03:12 PM
4bt swap - Cummins 4BT Forums This thread Refback 04-06-08 02:42 PM
trailer mod haulin This thread Refback 04-06-08 11:50 AM
Here is the truck for those who care - Cummins 4BT Forums This thread Refback 04-03-08 05:26 PM
insurance - Cummins 4BT Forums This thread Refback 04-01-08 12:12 PM
my bronco build - Page 2 - Cummins 4BT Forums This thread Refback 03-31-08 07:02 PM
Engine/Transmission Adapter P/N - Cummins 4BT Forums This thread Refback 03-26-08 09:36 PM
Hi Case mount AC - Cummins 4BT Forums This thread Refback 03-26-08 06:38 PM
Hi Case mount AC - Cummins 4BT Forums This thread Refback 03-26-08 06:21 PM
My '68 Kaiser M715 - Cummins 4BT Forums This thread Refback 03-26-08 02:51 PM
Please Help! Need inout on Trans - Cummins 4BT Forums This thread Refback 03-26-08 12:51 PM
My '68 Kaiser M715 - Cummins 4BT Forums This thread Refback 03-25-08 08:55 PM
FZJ80 w/ 4BT, couple questions - Cummins 4BT Forums This thread Refback 03-25-08 05:06 PM
mod za haulin This thread Refback 03-25-08 08:13 AM
Bought a 4BT with turbo missing....which one to buy? - Cummins 4BT Forums This thread Refback 03-18-08 08:17 PM
Questions before the swap starts - Cummins 4BT Forums This thread Refback 03-18-08 06:37 AM
Step Van????s - Page 2 - Cummins 4BT Forums This thread Refback 03-07-08 08:01 PM
tater chip tuck??? - Cummins 4BT Forums This thread Refback 03-07-08 05:48 AM
swapping a 4bt into a 1988 28 ft pace arrow MH - Cummins 4BT Forums This thread Refback 03-06-08 05:04 PM
Hydroboost, Steering, A/C and gearing questions questions - Cummins 4BT Forums This thread Refback 03-06-08 01:36 PM
74 Fj40 - Cummins 4BT Forums This thread Refback 03-05-08 01:45 PM
74 Fj40 - Cummins 4BT Forums This thread Refback 03-05-08 12:11 PM
my Yj is complete pics inside!!!!!! - Cummins 4BT Forums This thread Refback 03-04-08 07:56 PM
intercooler cooling - Cummins 4BT Forums This thread Refback 03-02-08 07:49 PM
repower with a 4l80? - Page 3 - Cummins 4BT Forums This thread Refback 03-01-08 06:37 AM
RPM's with gears and tires - Cummins 4BT Forums This thread Refback 02-28-08 08:33 PM
What is need to 4l80e? - Cummins 4BT Forums This thread Refback 02-27-08 08:37 PM
Tranny explosions, parts all over! - Cummins 4BT Forums This thread Refback 02-27-08 07:13 PM
4l80e converter - Cummins 4BT Forums This thread Refback 02-26-08 06:55 PM
4bt radiator - Cummins 4BT Forums This thread Refback 02-25-08 05:58 PM
4bt swap into a TJ - Cummins 4BT Forums This thread Refback 02-22-08 11:48 AM
6bt in 87 V3500....progress thread - Page 3 - Cummins 4BT Forums This thread Refback 02-21-08 11:38 PM
Feb Dovebid vans - Cummins 4BT Forums This thread Refback 02-21-08 08:51 PM
Mpg<auto<man - Page 2 - Cummins 4BT Forums This thread Refback 02-19-08 01:56 PM
6bt in 87 V3500....progress thread - Page 4 - Cummins 4BT Forums This thread Refback 02-18-08 09:13 PM
Big Line Kit???? - Cummins 4BT Forums This thread Refback 02-10-08 09:04 PM
better auto transmission for 4bt - Cummins 4BT Forums This thread Refback 02-07-08 03:49 PM
My new Shop Class - Cummins 4BT Forums This thread Refback 02-07-08 01:23 PM
3/4 ton Suburban, Expedition/Overlander RV 4bt or 6bt - Cummins 4BT Forums This thread Refback 02-07-08 11:04 AM
better auto transmission for 4bt - Cummins 4BT Forums This thread Refback 02-06-08 04:03 PM
Turbo Upgrade...remove exh. manifold or not - Cummins 4BT Forums This thread Refback 02-04-08 05:29 PM
Turbo Compressor Housings - Cummins 4BT Forums This thread Refback 01-28-08 05:46 PM
Identify this engine - Cummins 4BT Forums This thread Refback 01-25-08 07:53 PM
6bt in 87 V3500....progress thread - Page 4 - Cummins 4BT Forums This thread Refback 01-24-08 08:38 PM
Turbo Compressor Housings - Cummins 4BT Forums This thread Refback 01-22-08 07:54 PM
Battery specs??? - Cummins 4BT Forums This thread Refback 01-21-08 09:35 PM
Turbo Compressor Housings - Cummins 4BT Forums This thread Refback 01-20-08 05:29 PM
Where to buy tan Cummins engine paint? - Cummins 4BT Forums This thread Refback 01-19-08 09:23 PM
Turning Up The Pump - a pictoral 'how to' - Cummins 4BT Forums This thread Refback 01-18-08 12:08 PM
Sound proofing on sump - Page 2 - Cummins 4BT Forums This thread Refback 01-18-08 10:30 AM
repower with a 4l80? - Page 2 - Cummins 4BT Forums This thread Refback 01-17-08 10:08 AM
Got a 4b, now what truck?? - Cummins 4BT Forums This thread Refback 01-16-08 04:28 PM
Anyone tried this in a 90's GMC Vandura? - Cummins 4BT Forums This thread Refback 01-16-08 03:36 PM
Anyone tried this in a 90's GMC Vandura? - Cummins 4BT Forums This thread Refback 01-16-08 12:52 PM
Who is in the PNW? - Cummins 4BT Forums This thread Refback 01-12-08 03:19 PM
Newbie needin help. Calling NOVA Guys - Cummins 4BT Forums This thread Refback 01-11-08 12:18 PM
H1C rebuild kits on EBAY - Cummins 4BT Forums This thread Refback 01-10-08 11:30 AM
H1C rebuild kits on EBAY - Cummins 4BT Forums This thread Refback 01-10-08 10:21 AM
95yj - Cummins 4BT Forums This thread Refback 01-08-08 04:07 PM
air filter flow rates - Cummins 4BT Forums This thread Refback 01-07-08 06:28 PM
Show off ur motor mounts. - Page 10 - Cummins 4BT Forums This thread Refback 01-07-08 05:38 PM
Exhaust Done (New video) - Cummins 4BT Forums This thread Refback 01-06-08 10:19 PM
Cummins 4BT Forums - View Profile: boots4 This thread Refback 12-29-07 07:31 PM
fuel line - Page 2 - Cummins 4BT Forums This thread Refback 12-28-07 04:59 AM
intercooler cooling - Cummins 4BT Forums This thread Refback 12-24-07 06:56 PM
Bypass filter setups - Cummins 4BT Forums This thread Refback 12-23-07 08:18 PM
Shaker - Cummins 4BT Forums This thread Refback 12-18-07 08:19 PM
hydroboost fitting sizes - Cummins 4BT Forums This thread Refback 12-18-07 02:44 PM
