07-18-07, 09:52 AM
#91 (permalink)
Mace you're a good sport.
I've been trying to get a hold of Mudraks for the past three weeks with no success  so I decided to call Jerry Nichols with colorado offroad express and he picked up the phone on the second ring. After 5 minutes of business and 20 minutes of chatting I got his info to pay for the 203 to splitcase doubler using paypal. I got my confirmation email saying the adapter was in stock and that he was just waiting for the tracking number. I'm happy I found his number on this board and if anyone needs it again here it is:
Jerry Nichols 719-576-0616 for the 203 to splitcase adapter
I was happy with the service. He also told me to watch out for the splitcase rebuild kits (since I asked) that replace the intermediate shaft. There have been kits with soft shafts. He said to test it with a file on the corner, it should dance on the metal. If it bites/files into it the shaft is not hardened enough and to send it back. He said these soft shafts are wearing groves in them in 1500 miles. So I thought I'd pass on the warning.
build-up: Family Haulin' FJ60
07-19-07, 04:51 PM
#92 (permalink)
Supporting Vendor
Originally Posted by boots4
so I decided to call Jerry Nichols [/SIZE]
Jerry is da Man! glad he could help you out!
07-20-07, 12:52 PM
#93 (permalink)
Guys, I ordered my 203 adapter just 3 days ago and it showed up this morning!  Great service. Don't hesitate to give Jerry a call if you are going to pick up this adapter. I still have to order a splitcase rebuild kit so I will get as much together this weekend as I can and will get pics of the parts.
07-20-07, 02:10 PM
#94 (permalink)
OHV Trail Patrol
Sweet deal. BTW- good seeing you last night and congrats again on the beautiful baby... Now get wrenchin'!
Chad - Cascade Cruisers
KE7VSA - MetalTech
FZJ80 - 37's, lifted, locked, geared, cut and dented.
Originally Posted by bugsnbikes
Dewd- You would bend those spindles if I tucked them into the passenger seat  You are a candidate for a bobbed 80----not a high clearance bumper.
07-21-07, 11:41 PM
#96 (permalink)
Originally Posted by Hank
Thanks Hank, the new boy is great. Now I'm even more glad to have a big butt '60.
Thanks for the ideas on the tranny cooler. I'll be using the FJ60's radiator that doesn't have an integrated tranny cooler. Since the diesel tends to run cool I just bought a 3rd gen (dodge cummins) tranny cooler that uses coolant. The idea is that the tranny will help warm up the engine. I'll definitely be running a temp gauge on the tranny and if it's running warmer than I'd like I will probably pick up one of those inline coolers like you suggested.
I'm planning to run the contour dual fans. I asked the 4bt guys about needing air flow through the intercooler (having one of the fans running all the time) but they said at idle rpms I'm not making any boost so cooling off the intercooler really doesn't do anything. I'm thinking of wiring them for on/off operation with one thermostatically controlled and the other for additional cooling (maybe for the a/c). That way i could turn them off at a stream crossing or deep mud hole. Plus since I'll have more shifters due to the doubler, I can get more switches to make the dash look important.
07-22-07, 12:09 AM
#97 (permalink)
Mudrak has been in Europe since Rubithon.
John on the hawgs
07-22-07, 06:20 AM
#98 (permalink)
Diesel's generate more heat than gas motors. More BTU's in the fuel.
Unless you're just talking low-speed light throttle stuff..
Personally, I'd follow the KISS principle.. wire them both together on a thermostat, with a manual override on a switch that's also tied into the A/C switch.
On mine, my toggle is on-off-on - the top position is thermo controlled.. middle is stream crossing, and bottom is manual on. Be sure to put a light on the dash that goes on when you shut the fans off.  (Terminal 87a is good for that)
07-23-07, 08:29 AM
#99 (permalink)
I like that idea. What kind of controller do you use for the thermo (like a dcc controller)?
It's funny that on our older rigs that didn't come with idiot lights we end up finding a way to put some on.
07-23-07, 09:36 AM
#100 (permalink)
I was previously using the old $16 adjustable controller from the parts store (The one with the probe)..
Now, I have a wire off the PCM that goes to ground at 200°
07-23-07, 10:44 AM
#101 (permalink)
weekly update
Yet another weekend of random small projects all contributing to the bigger picture.
I got two packages last week.
This is the insulation stuff I am going to try that I got from http://www.secondskinaudio.com. The top bottle is the called spectrum firewall (heat insulation) and the tub is spectrum spray which is the sound insulation. I also grabbed a spray gun to put it on. The initial plan is to coat the firewall and underside of the tranny tunnel with the firewall product and coat the inside of the cruiser with the spray product. Both have rust inhibiting properties.
In the other box was my 203 to splitcase adapter. It comes nicely packaged.
Splitcase side of adapter
203 side of the adapter
New output (203)/input (splitcase) shaft on the left, old shaft on the right, and the bearing retainer and gear reused from the 203 case.
The 203 bearing retainer fits into the this spot. It was a little too tight so i ended up lightly sanding the bearing retainer housing until it fit into the adapter snuggly. The minimal instructions also said to remove that tab on the bearing retainer but there was a cutout for it in the adapters so I left it.
Now it fits
The shaft is installed and I ended up replacing that bearing. Napa wanted $59 for it but I found a bearing house and they had one for $29 so I went with the bearing house.
The doubler is assembled. You can see the access plate that I made. I just need to tap the hole for a fill plug and paint it.
Shifter side, the adapter comes with a hole and fitting for a breather
The kit comes with a sealed bearing to separate the two cases. There are two bearings in a row, one on the adapter and one on the bearing retainer of the 203.
Tranny side with the shaft retainer bolted on. Those allen head screws are too tall and are bottoming on the 4L80e 4x4 adapter so I'll have to look for something slimmer to replace those screws.
07-23-07, 11:09 AM
#102 (permalink)
Replaced the front spring hangers I made with new ones. I spaced them out to account for the width between the shackles on the rear of the spring. I also scooted them forward just a tad since I didn't get them as far forward as I would have liked the first time. I just tacked them on this time and will weld them on later.
Before
After
I'll put some gussets on them for additional support.
After I kept thinking about it I decided to just rebuild the turbo now while the engine is on the stand. I ended up taking off the starter, exhaust manifold and turbo. It will make it easier to clean up the block so I can paint it.
Painted and baked my exhaust manifold. I thought the paint was silver and not wanna-be chrome, but since I started it I guess I'll just use it. It's 1200 degree stuff so it might last for a couple of months.
Painted the wastegate accuator while I was at it.
Wire brushed the block heater.
Trying to get the turbine housing off the turbo. I'll soak it this week with some PB blaster while I'm at work and hopefully it will come apart this weekend.
Wife's been great letting me work on my stuff outside while she watches the kids and makes sure I eat something during the day. She'll be happy to have another car once this is back on the road.
07-23-07, 12:17 PM
#103 (permalink)
Hell yes! Great pics and info.
85' FJ60 - 2F, desmog, 4-spd, 4.88's, Aussie rear, SOA, 37's on 2" bs ***FOR SALE***
95' FZJ80 - new to me, some mods, details to come...
Copper State Cruisers #71
KavikOffRoad.com
60 Series porn
07-23-07, 01:07 PM
#104 (permalink)
Thanks. Once I get to drilling the 203 for the 4x4 adapter, hopefully I'll be able to completely answer your question 1 or 2 pages back about hooking up the 203 to the tranny. I read on your thread you have all your parts together for your repower plan. When are you planning on putting all that in?
07-23-07, 01:40 PM
#105 (permalink)
Turbo Diesel Lover
Your wife really loves you ..
HJ-60 2H-T Intercooled Tencha
Originally Posted by crushers
07-23-07, 01:41 PM
#106 (permalink)
I'm ironing out my spring over right now. I really want to get some wheeling in before I start pulling it apart again. I'm also trying to find an extra split case so I can build the new set up in the garage before the teardown.
Keep up the good work!
KavikOffRoad.com
60 Series porn
07-23-07, 09:34 PM
#107 (permalink)
"Trying to get the turbine housing off the turbo. I'll soak it this week with some PB blaster while I'm at work and hopefully it will come apart this weekend. "
I just got my Turb housing separated from the Bearing housing. Mine was WELDED (it seemed like it). I used PB Blaster both outside and IN. Twice a day, everyday. On the Sixth week (no joke) it came apart fairly easily...
...I quietly celebrated in my workshop
Great build! keep it up!
Best Regards,
George
1975 FJ 55, Cummins 4BT, 4L80E, NP208, SOA, 14 bolt rear, Dana 60 front, ARB Lockers, Scout II PS, Discs, Cross-over, TSL Q78-16
1995 T-100, 4" susp lift, 33 Goodyear MT/R, bought it new, my DD
1961 ford Falcon, 5.0L EFI, T-5, 9-inch
07-24-07, 08:01 AM
#108 (permalink)
Originally Posted by GreasedPiggy
I just got my Turbo housing separated from the Bearing housing. Mine was WELDED (it seemed like it). I used PB Blaster both outside and IN. Twice a day, everyday. On the Sixth week (no joke) it came apart fairly easily...
Just curious, did you just spray liberally inside? Or did you take off one of the wheels so you could see inside to spray? Thanks, I'll be prepared to do something else since it sounds like one week won't be enough time for soaking.
07-24-07, 11:08 AM
#109 (permalink)
Lubrication Engineers (LE) makes a penetrating oil that spanks the shit out of PB blaster, and I was a PB fan prior to using this.
07-24-07, 11:22 AM
#110 (permalink)
Lubrication Engineers (LE) makes a penetrating oil that spanks the **** out of PB blaster, and I was a PB fan prior to using this.
That's funny, I just quoted you on another thread. Any more info on that magical stuff?
07-24-07, 08:59 PM
#112 (permalink)
Yeah, I heard of Kroil and LE and would much rather use that stuff but the PB Blaster was what they had on the shelves at the moment. I've heard of guys separating the housing in just a couple of days. I think mine was the worst case, the PB stuff did work though.
Also, I bought a gallon of kerosene at the hardware store to break up the carbon on the inside of the housing . I soaked the whole unit in a bucket. 2 weeks of that and it was still WELDED. A bunch of carbon chunks came out though, so I knew I could spray PB on the inside joint.
I shot the PB into the housing using the red sprayer straw. And just tilted it around then put it back into my huge vise and would go to work. Then later, I'd shoot it again, and also give it a few test wacks. Hammer didn't work. My deadblow hammer did nothing. I used my mini-sledge (bigger BFH) and hit it all around. DON'T crack the cast housing!
Tip: you also have the Holset so be sure to leave the retainers bolted in place but a little loose. This will keep the Turb hsg from flying off and bending your turbo shaft. That thing is DELICATE! Do not bend.
So about 6 weeks later, I routinely wacked the housing and all of a sudden, I could see a micro-budge. Flipped it and hit the other side.
Then, it just slipped off. Super happy but kinda disappointed...
I almost could not believe I WON!  I was soo pissed before.
(I'm in my happy place now).
Now I can rebuild and plan to rotate to align with my custom manifold
Good Luck. Yours may come off right away...
07-25-07, 08:36 AM
#113 (permalink)
Thanks for the info Greasedpiggy, I'll put the retaining bolts back in and get some kerosene. Are you documenting this anywhere? On 4btswaps maybe?
07-25-07, 09:27 AM
#114 (permalink)
I have just about acquired every major part. I am just starting to clean up each and yes, I'm taking photos.
I plan to show the build here once it gets more serious...
...until then I enjoy watching and learning from other members.
07-26-07, 01:51 PM
#115 (permalink)
did you test fit trans to engine ? th400 you pulled is a BOP pattern which is wierd thought all were chevy pattern.
suppose you could have a dual drilled adapter.
a518 to 203, or 47rh to 203 are easy bolt ins no electronics, rh lockup converter with three wires, dodge bell adapter only item needed, takes same
doubler adapter. 203 from 727 which is everywhere. all swapable. built to handle anything you want the through at at it, billet parts in the rh is puller and drag diesels use ( same 727 stuff ). havent done it myself but options.
did you reclock the 203 ? trans and 4bt is degree mounted, punching your own holes in the 203 allow you to run sqaured up, or clock up flat
EMAIL ME
click on my name, Send email to HI^C
TONS FOR SALE <<<CLICK ME
"everyone has different experiences and different opinions"
My posts "greatly based on my observations and opinions" and "TO EACH HIS OWN"
Sig edited to help futher eliminate those who have or get twisted panities.
07-26-07, 02:29 PM
#116 (permalink)
I thought about the dodge trannys but decided on the 4L80e since my 4bt came with the chevy adapter, which does have two patterns. I've eliminated the electronics from the 4L80e so it too needs no computer, just my arm for shifting manually. I am going to wire my lock-up to a button (location undecided) and idiot light to give me efficiency and provide me with downhill braking in any gear. I've got the tech manual for the 4L80e to help me. The output on the 4L80e is 32 spline and the internals are compared to the turbo 400 so it should be pretty strong. I think more of these tranny's will be used in future projects who want a strong overdrive. If the computer control units decrease in price (like other technologies) that will make these pretty attractive.
The chevy adapter on the back of the 4bt along with the motor mounts give it the tilt, the tranny stays level. The main reason I will clock my case is to get the front drive shaft to clear the tranny if needed but I'll need to get that in the chassis before I commit to drilling new holes in the 203. The allen head bolts on the bearing retainer on the front of the 203 case are a little too tall for the 4x4 adapter that came with my tranny so I will need to find shorter ones to get the adapter mounting surfaces flush.
07-30-07, 09:22 AM
#117 (permalink)
weekly update
Family help is all gone and we have the house back to ourselves. We were greatful for the help but it's nice to get back to our routine. We've had visitors for the last 5 weeks.
I got out the turbo and swung the hammer at it a couple of times but no luck so far. Fortunately the UPS guy knocked on the door this weekend and dropped off this:
A rebuild kit for my splitcase plus some other stuff I picked up from Kurt from cruiseroutfitters. Good guy and fast delivery. So with the turbo soaking I got started on the TC rebuild and getting it attached to my 203 doubler. I started with the front half and after getting the front output taken care of (seals, bearings) I attached to the adapter.
Here's the adapter sandwiched.
Replaced all bearings and put the gears on. Getting the bearings off the output shaft wasn't easy but getting it all back together wasn't hard.
I found some plugs at a local hardware store and the plug was just big enough. I filled the hole with the RTV silicone I've been using and tapped it in.
You can see the bigger picture of the hole I plugged. It's right underneath where the input and intermediate gears meet.
Test fit the back cover to get things lined up. Had to figure out how to line up the 2 to 4wd shifter shaft on the shifting fork. I got it cleared and then it slipped into spot.
Tested all shifters, rotated parts, and then torqued it all together. I thought I'd test fit the combo. Findings: Looks like the front drive shaft will clear the tranny pan (plus it will be angled down whereas it's level in the pic) with the 203 pretty much straight up and down (no clocking), the output shaft on the tranny is bottoming in the input of the 203 before the 4x4 adapter it flush so I'll need to trim that.
My splitcase was pretty dirty. I pressure washed it but 22 years of grime didn't come off. I tried a wire brush wheel and while that worked it couldn't get into everything so I ended up using some degreaser and a green scott pad and it cleaned up pretty quick.
07-30-07, 09:55 AM
#118 (permalink)
You totally eliminated the computer control from a 4L80E? There are more than a few people who would be VERY interested in that...
07-30-07, 10:00 AM
#119 (permalink)
You are unravelling so many of issues and mysteries for me on this build!
Thanks.
Your front driveshaft may have to be flipped end for end to eliminate the factory crossmember..
Great work and documentation!
john
07-30-07, 11:17 AM
#120 (permalink)
Turbo Diesel Lover
You can make a new custom cross member ..
LinkBack to this Thread: http://forum.ih8mud.com/hardcore-corner/160807-family-haulin.html
| Posted By |
For |
Type |
Date |
| Here's the Descrambler - Page 8 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
11-01-09 03:53 PM |
| Untitled document |
This thread |
Refback |
10-25-09 05:08 PM |
| cool thread on using a VNT,VVT or whatever turbo - Page 8 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
10-18-09 09:39 AM |
| Untitled document |
This thread |
Refback |
10-16-09 09:10 AM |
| 74 Fj40 - Page 3 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
10-10-09 11:22 PM |
| Has anyone actually used a 4L80E??? - Page 3 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
10-09-09 06:56 PM |
| ARAMP1's Ultimate TowRig Buld Thread - Page 2 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
10-06-09 02:19 PM |
| Has anyone actually used a 4L80E??? - Page 2 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
10-03-09 10:05 AM |
| FJ60 drivetrain swap questions - Page 3 - Expedition Portal Forum |
This thread |
Refback |
09-19-09 04:03 PM |
| 6bt in 87 V3500....progress thread - Page 2 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
08-15-09 04:29 AM |
| The new and improved Tiny-Tach - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
08-12-09 06:45 PM |
| anyone actually using a 4l80? - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
08-09-09 04:26 PM |
| THE 4L80/85E information thread - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
08-09-09 09:24 AM |
| Lift pump pre filter - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
08-07-09 05:04 PM |
| Mini Mercedes, Mod Haulin Mercedes, Mercedes Service Atlanta - Felprocatalogw |
This thread |
Refback |
07-09-09 11:19 AM |
| Completed '74 Plymouth Satellite 4bt swap - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
07-01-09 09:19 PM |
| New to Diesel Swap Questions - Plumbing Electrical Etc - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
06-06-09 11:23 AM |
| Electric Vacuum Pumps - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
05-27-09 11:00 AM |
| Show off ur motor mounts. - Page 6 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
05-20-09 07:40 PM |
| Official Cummins 4BT video thread! - Page 3 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
05-20-09 03:25 AM |
| '85 FJ60 Landcruiser 4BT/4L480e SOA - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
05-17-09 01:41 AM |
| Here's the Descrambler - Page 4 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
05-16-09 10:44 AM |
| Here's the Descrambler - Page 6 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
04-23-09 12:49 PM |
| April 18 - SOLV @ Tillamook State Forest |
This thread |
Refback |
04-18-09 09:41 PM |
| Family Trucksters? - Colorado4x4.org Forums |
This thread |
Refback |
04-14-09 07:50 AM |
| 700r4 feasibility study - Page 6 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
03-25-09 09:15 PM |
| Jeep Cj2A Bikini Top, Jeep Cj Exhaust Manifold Gasket Replacement, Jeep Cj5 Exhaust Flange - Polarisdiesel |
This thread |
Refback |
03-08-09 11:24 AM |
| Gm Card Points For Chevy Malibu, Gm Automotive Warranty Audit, Gm Cars With 200 Plus Amp Alternators - Shadowdemon |
This thread |
Refback |
03-08-09 09:51 AM |
| Scout Engine Conversion Headers, Scottie Kit Car Parts, Scranton Area Rental Cars - Marshlandboar |
This thread |
Refback |
03-08-09 08:44 AM |
| 1992 80 Series - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
03-07-09 11:34 AM |
| Buy Ford Bronco 4X4 Lifted, Buy Electric Cars, Buy Geo Metro - Yvonneridley |
This thread |
Refback |
03-07-09 03:24 AM |
| Toyota Collapsed Top Radiator Hose, Toyota Cold Fusion France, Toyota Concept Cars - Newavengers |
This thread |
Refback |
03-07-09 01:43 AM |
| Official Cummins 4BT video thread! - Page 5 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
03-06-09 03:21 PM |
| Dually Fenders For Van, Dual Sport Motorcycle Tires, Dubai Car Rentals - Tiresbicycle |
This thread |
Refback |
03-06-09 02:04 AM |
| Ford Truck Exhaust Manifold Leak, Ford Truck Clutch Kits, Ford Truck Front Fenders My My Messages - Polarisclothing |
This thread |
Refback |
03-06-09 02:04 AM |
| Gmc Truck Plastic Bed Liners Plainfield Illinois, Gmc Truck Mud Flaps, Gmc Truck Tune Up - Balljoint |
This thread |
Refback |
03-06-09 01:40 AM |
| JacobPadilla's Bookmarks on Delicious |
This thread |
Refback |
02-20-09 07:21 PM |
| Mufflers - Cummins 4BT & Diesel Conversions Forums |
Post #0 |
Refback |
02-16-09 07:58 PM |
| Here's the Descrambler - Page 5 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
02-13-09 12:48 PM |
| FJ60 Build - Page 6 - Pirate4x4.Com Bulletin Board |
This thread |
Refback |
02-12-09 08:54 AM |
| 74 Fj40 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
02-02-09 06:13 PM |
| PNWJeep.com • View topic - My Build... |
This thread |
Refback |
01-31-09 10:16 PM |
| Do I really need two 12-volt batteries? - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
01-25-09 11:58 AM |
| Dodge intake horns - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
01-20-09 07:22 PM |
| Here's the Descrambler - Page 3 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
01-11-09 01:57 PM |
| Snow wheeling TSF Browns camp this weekend Jan 3 or 4 2009? |
This thread |
Refback |
01-02-09 12:38 PM |
| how come my trans shifts? - Page 2 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
01-02-09 02:49 AM |
| Name that thing-a-ma-jig - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
12-19-08 03:10 PM |
| Fuel Log - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
12-07-08 01:06 PM |
| toyota fj62 swap - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
12-04-08 09:27 AM |
| CAC Intake Manifold Part Numbers-ATTN: boots4 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
11-28-08 08:09 PM |
| Sound proofing on sump - Page 2 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
11-11-08 10:05 PM |
| video request plz - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
11-06-08 09:23 AM |
| Bosch VE timing question - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
11-02-08 09:29 PM |
| Using 2-stroke oil - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
10-30-08 07:03 PM |
| 4runnerclub.org :: Zobrazit téma - oprava šedesátky |
This thread |
Refback |
10-26-08 12:05 PM |
| Need serious help with egt's - Page 2 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
10-22-08 01:26 PM |
| Hydroboost setup question - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
10-22-08 12:35 PM |
| Power and economy and reliability where is the happy medium - Page 4 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
10-21-08 04:53 PM |
| Opinions please - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
10-21-08 02:41 PM |
| Diesel questions |
This thread |
Refback |
10-19-08 11:45 AM |
| Turbo Info, HY35s, Photos/info... Etc - Page 12 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
10-18-08 11:42 AM |
| Boost gauge location? - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
10-16-08 11:59 AM |
| Isuzu Commercial Diesel - Pirate4x4.Com Bulletin Board |
This thread |
Refback |
10-14-08 11:14 PM |
| Use orginal gas tank question - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
10-05-08 08:59 AM |
| View the profile of boots4 |
This thread |
Refback |
10-04-08 09:05 PM |
| tuning for an HX35 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
09-28-08 07:09 AM |
| Full Power Screw.... - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
09-27-08 11:46 PM |
| 4x4.ee :: Vaata teemat - Tõsine HJ-60 project |
This thread |
Refback |
09-15-08 02:15 PM |
| Weldernator - Cummins 4BT Forums |
This thread |
Refback |
09-05-08 04:56 AM |
| Engine Choices --3.3l vs. 3.9l - Cummins 4BT Forums |
This thread |
Refback |
08-16-08 04:45 PM |
| Noob EGT question. - Cummins 4BT Forums |
This thread |
Refback |
08-13-08 06:15 PM |
| New Guy - Cummins 4BT Forums |
This thread |
Refback |
08-01-08 05:56 AM |
| Which Dodge automatic to use in FJ80? - Cummins 4BT Forums |
This thread |
Refback |
07-28-08 08:25 AM |
| Let's See Your Trucks! - Page 8 - Cummins 4BT Forums |
This thread |
Refback |
07-24-08 09:37 PM |
| 74 Fj40 - Page 4 - Cummins 4BT Forums |
This thread |
Refback |
07-21-08 10:13 AM |
| IDEAS? EGT's Hot at stock and pump turned up any ideas? - Page 2 - Cummins 4BT Forums |
This thread |
Refback |
07-12-08 01:40 PM |
| Build-up: Jeep YJ w/ Isuzu diesel - Page 11 - Pirate4x4.Com Bulletin Board |
This thread |
Refback |
07-10-08 10:32 AM |
| Arrrgg....it always works this way - Cummins 4BT Forums |
This thread |
Refback |
06-28-08 05:56 PM |
| Can You Still Hear After running you're 4BT? - Page 3 - Cummins 4BT Forums |
This thread |
Refback |
06-27-08 06:10 AM |
| What gears for 37 |
This thread |
Refback |
06-25-08 12:58 PM |
| What gears for 37 |
This thread |
Refback |
06-23-08 08:33 AM |
| Exhaust Routing - Cummins 4BT Forums |
This thread |
Refback |
06-21-08 11:29 PM |
| 74 Fj40 - Page 2 - Cummins 4BT Forums |
This thread |
Refback |
06-13-08 05:28 PM |
| Kdp ? - Cummins 4BT Forums |
This thread |
Refback |
06-13-08 06:24 AM |
| IDEAS? EGT's Hot at stock and pump turned up any ideas? - Cummins 4BT Forums |
This thread |
Refback |
06-10-08 10:47 AM |
| vacuum booster for brakes? - Cummins 4BT Forums |
This thread |
Refback |
06-08-08 04:39 PM |
| Timbercrawler -- View topic - Who owns... |
This thread |
Refback |
06-06-08 11:05 AM |
| Hot rod gets a 4BT - Cummins 4BT Forums |
This thread |
Refback |
06-05-08 07:32 PM |
This thread |
Refback |
06-04-08 10:01 PM |
This thread |
Refback |
06-04-08 09:46 PM |
| VE Pump Question - Cummins 4BT Forums |
This thread |
Refback |
06-04-08 07:51 PM |
| Your max GCVW with a 4BT? - Cummins 4BT Forums |
This thread |
Refback |
06-04-08 02:57 PM |
| 2nd maiden voyage - Cummins 4BT Forums |
This thread |
Refback |
05-30-08 12:06 PM |
| Sound proofing on sump - Page 2 - Cummins 4BT Forums |
This thread |
Refback |
05-18-08 09:21 PM |
| Pullys - Cummins 4BT Forums |
This thread |
Refback |
05-17-08 08:28 AM |
| Muffler or no muffler? Exhaust diameter? - Page 3 - Cummins 4BT Forums |
This thread |
Refback |
05-13-08 07:25 PM |
| Mongos 4BT Firewood Monster Truck - Page 4 - Cummins 4BT Forums |
This thread |
Refback |
05-12-08 12:05 PM |
| Muffler or no muffler? Exhaust diameter? - Page 2 - Cummins 4BT Forums |
This thread |
Refback |
05-11-08 04:20 PM |
| Rebuild H1 turbo - Cummins 4BT Forums |
This thread |
Refback |
05-10-08 04:16 PM |
| 4bt radiator - Cummins 4BT Forums |
This thread |
Refback |
05-08-08 05:14 PM |
| Radiator hose adapters - Cummins 4BT Forums |
This thread |
Refback |
05-03-08 09:09 PM |
| Vibration Issues Affecting Me?? - Cummins 4BT Forums |
This thread |
Refback |
05-01-08 05:42 AM |
| H1C rebuild kits on EBAY - Cummins 4BT Forums |
This thread |
Refback |
04-21-08 08:59 PM |
| Vote: 4bt or 6bt in Jeep J20 - Cummins 4BT Forums |
This thread |
Refback |
04-16-08 09:18 PM |
| Hydroboost or Vacuum pump - Cummins 4BT Forums |
This thread |
Refback |
04-16-08 02:32 PM |
| $3k step van or $2k used motor - Cummins 4BT Forums |
This thread |
Refback |
04-08-08 05:49 PM |
This thread |
Refback |
04-08-08 03:12 PM |
| 4bt swap - Cummins 4BT Forums |
This thread |
Refback |
04-06-08 02:42 PM |
| trailer mod haulin |
This thread |
Refback |
04-06-08 11:50 AM |
| Here is the truck for those who care - Cummins 4BT Forums |
This thread |
Refback |
04-03-08 05:26 PM |
| insurance - Cummins 4BT Forums |
This thread |
Refback |
04-01-08 12:12 PM |
| my bronco build - Page 2 - Cummins 4BT Forums |
This thread |
Refback |
03-31-08 07:02 PM |
| Engine/Transmission Adapter P/N - Cummins 4BT Forums |
This thread |
Refback |
03-26-08 09:36 PM |
| Hi Case mount AC - Cummins 4BT Forums |
This thread |
Refback |
03-26-08 06:38 PM |
This thread |
Refback |
03-26-08 06:21 PM |
| My '68 Kaiser M715 - Cummins 4BT Forums |
This thread |
Refback |
03-26-08 02:51 PM |
| Please Help! Need inout on Trans - Cummins 4BT Forums |
This thread |
Refback |
03-26-08 12:51 PM |
This thread |
Refback |
03-25-08 08:55 PM |
| FZJ80 w/ 4BT, couple questions - Cummins 4BT Forums |
This thread |
Refback |
03-25-08 05:06 PM |
| mod za haulin |
This thread |
Refback |
03-25-08 08:13 AM |
| Bought a 4BT with turbo missing....which one to buy? - Cummins 4BT Forums |
This thread |
Refback |
03-18-08 08:17 PM |
| Questions before the swap starts - Cummins 4BT Forums |
This thread |
Refback |
03-18-08 06:37 AM |
| Step Van????s - Page 2 - Cummins 4BT Forums |
This thread |
Refback |
03-07-08 08:01 PM |
| tater chip tuck??? - Cummins 4BT Forums |
This thread |
Refback |
03-07-08 05:48 AM |
| swapping a 4bt into a 1988 28 ft pace arrow MH - Cummins 4BT Forums |
This thread |
Refback |
03-06-08 05:04 PM |
| Hydroboost, Steering, A/C and gearing questions questions - Cummins 4BT Forums |
This thread |
Refback |
03-06-08 01:36 PM |
| 74 Fj40 - Cummins 4BT Forums |
This thread |
Refback |
03-05-08 01:45 PM |
This thread |
Refback |
03-05-08 12:11 PM |
| my Yj is complete pics inside!!!!!! - Cummins 4BT Forums |
This thread |
Refback |
03-04-08 07:56 PM |
| intercooler cooling - Cummins 4BT Forums |
This thread |
Refback |
03-02-08 07:49 PM |
| repower with a 4l80? - Page 3 - Cummins 4BT Forums |
This thread |
Refback |
03-01-08 06:37 AM |
| RPM's with gears and tires - Cummins 4BT Forums |
This thread |
Refback |
02-28-08 08:33 PM |
| What is need to 4l80e? - Cummins 4BT Forums |
This thread |
Refback |
02-27-08 08:37 PM |
| Tranny explosions, parts all over! - Cummins 4BT Forums |
This thread |
Refback |
02-27-08 07:13 PM |
| 4l80e converter - Cummins 4BT Forums |
This thread |
Refback |
02-26-08 06:55 PM |
This thread |
Refback |
02-25-08 05:58 PM |
| 4bt swap into a TJ - Cummins 4BT Forums |
This thread |
Refback |
02-22-08 11:48 AM |
| 6bt in 87 V3500....progress thread - Page 3 - Cummins 4BT Forums |
This thread |
Refback |
02-21-08 11:38 PM |
| Feb Dovebid vans - Cummins 4BT Forums |
This thread |
Refback |
02-21-08 08:51 PM |
| Mpg<auto<man - Page 2 - Cummins 4BT Forums |
This thread |
Refback |
02-19-08 01:56 PM |
| 6bt in 87 V3500....progress thread - Page 4 - Cummins 4BT Forums |
This thread |
Refback |
02-18-08 09:13 PM |
| Big Line Kit???? - Cummins 4BT Forums |
This thread |
Refback |
02-10-08 09:04 PM |
| better auto transmission for 4bt - Cummins 4BT Forums |
This thread |
Refback |
02-07-08 03:49 PM |
| My new Shop Class - Cummins 4BT Forums |
This thread |
Refback |
02-07-08 01:23 PM |
| 3/4 ton Suburban, Expedition/Overlander RV 4bt or 6bt - Cummins 4BT Forums |
This thread |
Refback |
02-07-08 11:04 AM |
This thread |
Refback |
02-06-08 04:03 PM |
| Turbo Upgrade...remove exh. manifold or not - Cummins 4BT Forums |
This thread |
Refback |
02-04-08 05:29 PM |
| Turbo Compressor Housings - Cummins 4BT Forums |
This thread |
Refback |
01-28-08 05:46 PM |
| Identify this engine - Cummins 4BT Forums |
This thread |
Refback |
01-25-08 07:53 PM |
This thread |
Refback |
01-24-08 08:38 PM |
This thread |
Refback |
01-22-08 07:54 PM |
| Battery specs??? - Cummins 4BT Forums |
This thread |
Refback |
01-21-08 09:35 PM |
This thread |
Refback |
01-20-08 05:29 PM |
| Where to buy tan Cummins engine paint? - Cummins 4BT Forums |
This thread |
Refback |
01-19-08 09:23 PM |
| Turning Up The Pump - a pictoral 'how to' - Cummins 4BT Forums |
This thread |
Refback |
01-18-08 12:08 PM |
This thread |
Refback |
01-18-08 10:30 AM |
| repower with a 4l80? - Page 2 - Cummins 4BT Forums |
This thread |
Refback |
01-17-08 10:08 AM |
| Got a 4b, now what truck?? - Cummins 4BT Forums |
This thread |
Refback |
01-16-08 04:28 PM |
| Anyone tried this in a 90's GMC Vandura? - Cummins 4BT Forums |
This thread |
Refback |
01-16-08 03:36 PM |
This thread |
Refback |
01-16-08 12:52 PM |
| Who is in the PNW? - Cummins 4BT Forums |
This thread |
Refback |
01-12-08 03:19 PM |
| Newbie needin help. Calling NOVA Guys - Cummins 4BT Forums |
This thread |
Refback |
01-11-08 12:18 PM |
This thread |
Refback |
01-10-08 11:30 AM |
This thread |
Refback |
01-10-08 10:21 AM |
| 95yj - Cummins 4BT Forums |
This thread |
Refback |
01-08-08 04:07 PM |
| air filter flow rates - Cummins 4BT Forums |
This thread |
Refback |
01-07-08 06:28 PM |
| Show off ur motor mounts. - Page 10 - Cummins 4BT Forums |
This thread |
Refback |
01-07-08 05:38 PM |
| Exhaust Done (New video) - Cummins 4BT Forums |
This thread |
Refback |
01-06-08 10:19 PM |
| Cummins 4BT Forums - View Profile: boots4 |
This thread |
Refback |
12-29-07 07:31 PM |
| fuel line - Page 2 - Cummins 4BT Forums |
This thread |
Refback |
12-28-07 04:59 AM |
This thread |
Refback |
12-24-07 06:56 PM |
| Bypass filter setups - Cummins 4BT Forums |
This thread |
Refback |
12-23-07 08:18 PM |
| Shaker - Cummins 4BT Forums |
This thread |
Refback |
12-18-07 08:19 PM |
| hydroboost fitting sizes - Cummins 4BT Forums |
This thread |
Refback |
12-18-07 02:44 PM |
