Go Back   IH8MUD.com > General Tech Forums > HardCore Corner
LinkBack (175) Thread Tools Display Modes
Old 09-17-09, 12:33 PM   #1111 (permalink)
Cruiserdrew's Avatar
TLCA# 11734
Originally Posted by boots4 View Post
I haven't even run a CB yet. The HAM will have to come later. I've seen radio selectors so I may be able to add that into the system to select between the CB and the HAM in the future. The K40 antenna I bought says it will work with both.
Careful with this thought as there are some unexpected legal complications.
Bottom line: You need a separate antenna.
Anyway, this is a great build up, and I'm enjoying the updates.
Andrew
Old 09-17-09, 12:37 PM   #1112 (permalink)
OHV Trail Patrol
CreeperSleeper's Avatar
TLCA# 15577
x2 Besides, seperate antennas work better.
Chad - Cascade Cruisers
KE7VSA - MetalTech
FZJ80 - 37's, lifted, locked, geared, cut and dented.
Originally Posted by bugsnbikes View Post
Dewd- You would bend those spindles if I tucked them into the passenger seat You are a candidate for a bobbed 80----not a high clearance bumper.
CreeperSleeper is offline   Reply With Quote
Old 09-17-09, 01:05 PM   #1113 (permalink)
boots4's Avatar
TLCA# 19547
Yup, I know nothing about HAM so looks like I'll stick to CB for now.
build-up: Family Haulin' FJ60
boots4 is offline   Reply With Quote
Old 09-18-09, 05:16 AM   #1114 (permalink)
KOOL AAROW
kling-on's Avatar
TLCA# 15374
new wheels and tiresd look great and those G/Y's will last for ever on a " light" FJ60 I had guy runnem on F350 towing all the time get 50-60k miles outa them
82 FJ60 5.3, 4l60E, OME Heavy, 33 KM2's 410's, ARB bull & side bars ...SOA in the works
85 FJ60 Trail beater SM 420 crawler box lockers 456, 4D's bobed & choped with a Metal Tech cage
GIT-R-DONE!!!!
TLCA #15374
low riders want SWITCHES... 4 wheelers want SHIFTERS
www.jkcustoms.com
kling-on is offline   Reply With Quote
Old 09-18-09, 08:48 AM   #1115 (permalink)
boots4's Avatar
TLCA# 19547
Originally Posted by kling-on View Post
...on F350 towing all the time get 50-60k miles outa them
holy moly! Not used to tires lasting that long anymore. I do get them to chirp going around the corner when I shift into 2nd and the aussie locks up.
I'm going to wheel them next weekend at the Cruise the Woods event next week. I'll be a tailgunner for the friday toyota only run so I hope to see how they do offroad. I think I might sipe the small center blocks and leave the bigger ones for grooving. I plan on leaving the outer lugs alone to reduce the chances of chunking but I want to see how they pack up to see if I get any ideas on grooving.
Old 09-18-09, 10:36 AM   #1116 (permalink)
OHV Trail Patrol
TLCA# 15577
I'm excited to see how well they work... I wish I could run with you Friday. Guess you will just have to come along on the Friday night run!
KE7VSA - MetalTech
Old 09-18-09, 11:58 AM   #1117 (permalink)
boots4's Avatar
TLCA# 19547
I'm in!
Old 09-20-09, 10:52 AM   #1118 (permalink)
Dirtgypsy's Avatar
TLCA# 17541
Antenna mount looks great. How long is the antenna you bought?
Clint
It's a Jeep thing I didn't understand. So I bought an FJ60 and now I get it.
Just bump it.
SOA in progress!
ROTW: http://forum.ih8mud.com/60-series-wa...lver-60-a.html
Dirtgypsy is offline   Reply With Quote
Old 09-20-09, 01:48 PM   #1119 (permalink)
KOOL AAROW
kling-on's Avatar
TLCA# 15374
just sip the centers and run-em and post pics
GIT-R-DONE!!!!
TLCA #15374
www.jkcustoms.com
Old 09-20-09, 08:42 PM   #1120 (permalink)
boots4's Avatar
TLCA# 19547
The antenna is only 3" but I'm hoping with it on the fender it will be high enough (it's top loaded) to get decent performance. I thought the 4" would just look too tall on the fender.
Old 09-23-09, 09:03 AM   #1121 (permalink)
boots4's Avatar
TLCA# 19547
weekly update
I went to the store to find new gasket material for the antenna base because the one I made was just too thick. I found a tire repair kit with a circular patch that looked promising and then found an outside wall outlet cover with a gasket and opted for that (it was cheaper). Turns out the gasket has stamped precuts that you remove to get which hole size you need so I wasn't able to use this as it interfered with cutting a circle out of it. Back to the drawing board. As I was telling the that my rubber gasket for the antenna base was too thick she went downstairs and pulled out some "fun foam" she got from somewhere. It was just what I was looking for so I traced it and cut out a new gasket piece.
As I was doing that UPS showed up and delivered my antenna and coax cable. I got a top-loaded 3" K40 SuperFlex in white with the tunable tip and a 9" coax with one end a P259 connector and the other end spades. I found them for a good price off of amazon.com.
I pulled the coax through the passenger side wiring gasket.
I decided to tag off of my radio to get the constant 12v and the switched 12v and then grounded the CB to a dash brace.
I put the antenna together and wired it up. Using a SWR meter from a friend I started out with 2.8 - 1 which is close to 3 -1 meaning don't operate your radio because it can ruin it. Using the tunable tip I got channel 1 and 40 down to 1.5 - 1. I originally had the coax cable grounded to a bolt holding the ball mount to the fender but that wasn't good enough so I ended up grounding to the battery and performanced improved. I found a channel with clear activity and got a location from a local truckstop that is 9 miles away from my house. Pretty good considering I live in a city with hills and buildings and I was able to reach that far. I'll have to see what it does on the open road.
I did some reshaping of the skid plate and cleared a rub point. Unfortunately I missed two more and will need to pull it off and clearance those parts before the event this weekend.
I got the front tires siped hitting the alternating small blocks of the center lugs. That leaves the larger lugs for now in case I want to groove them; if not I'll just sipe those too. Not sure I'll get the rears done before the event but I'll get them soon.
I also replaced all my heater hose with gates green stripe. I found another one leaking so I just got 10' of hose and hit them all.
Old 09-23-09, 05:26 PM   #1122 (permalink)
Dirtgypsy's Avatar
TLCA# 17541
9 miles? man that is awesome. I am lucky to get mine to do 1/4 or line of sight. The skid looks really good as well.
Have fun and be safe this weekend! And of course (not that I have to ask) but pics are always welcome.
Clint
Just bump it.
SOA in progress!
Old 09-23-09, 08:24 PM   #1123 (permalink)
mrqtipp's Avatar
looks good
keep the good work up
mrqtipp is offline   Reply With Quote
Old 09-24-09, 08:32 AM   #1124 (permalink)
boots4's Avatar
TLCA# 19547
Thanks.
I pulled off the skid last night after work and will nibble on it in a couple places for clearance and slap it back on before I leave for the event on friday. I also cleaned up and patched the cut-out in the hood mat I had from the previous intake and made a battery quick-connect for my power inverter so I can blow up my matress for camping. I found little metal spring clamps for $.50 that worked out great. Eventually I'll run some wire inside the cab so I can hook up the inverter there. I think I'll trickle the batteries tonight to top them off. Since the family is staying home I'm just going to sleep inside Dora.
Old 09-29-09, 08:51 AM   #1125 (permalink)
brokenparts's Avatar
TLCA# 16127
quick one for you Mike... Did you simply swap the mounting plates between the Hydroboost setup and the toyota stuff or was it more involved? I looked on page 9 and that's what it looks like? Hope Cruisin the Woods was fun!!!! Let's see some pics!
ROTW: http://forum.ih8mud.com/60-series-wagons/198064-rotw-brokenparts-fj-60-a.html
Old 09-29-09, 10:03 AM   #1126 (permalink)
boots4's Avatar
TLCA# 19547
Zach,
Check out page 2 of my thread. I made a plate and inserted the hole piece from the stepvan plate into this one. I actually like the way 1974FJ40 did it and it can been seen on page 5 of his thread.
Got some pics and vids from CTW. I'm still working on that Linux box and still haven't gotten Kdenlive to render in h.264 format (the format I'd prefer). I did try out rendering in mpeg4 and it worked so I might just output them to that so I can a least get the Rubicon vids up. The CTW vids I can put together on my Mac machine.
Old 09-29-09, 10:26 AM   #1127 (permalink)
TLCA# 16127
thanks dude!!!! We'll have to get together soon and finish up that bumper.
Old 10-01-09, 11:33 AM   #1128 (permalink)
boots4's Avatar
TLCA# 19547
Cruise the woods '09
I was a tail gunner for the Friday toyota run for the semi-hard group. We had 7 rigs total and no one had any real problems. This was my first wheeling on the new tires/rim combo so when I hit camp and got settled I dropped the pressure down to 9psi. At this pressure the tires bulged and I could always let out more if needed.
This is at the Rockpile after the others had gone through.
I just spun in this spot since I wasn't getting any sidewall traction from my passenger side.
I backed up a little to repostion.
Then I just crawled up.
We hit another trail called Waterfall and when this was wet and I had no rear locker I was denied this line. I wanted to make it up this time and really had no trouble this time.
I think this is my full extension on the front driver side. If you look close you can see how much my main leaf is separated from the rest of the pack.
The next day I helped direct traffic at a checkpoint at a trail called Can Opener. The lower filter and top obstacle are new and the lower filter was where I was at. It proved challenging for most rigs and there was one rock in particular that was diff hanger. That rock must have lost a 1/2" of material that day with all the diffs that drug on it and the sound was equvilent of somebody dragging fingernails on a chalkboard. My hair stands up just remembering it.
Esh was on top for winch duty but before he headed up I got to check out all the electronic goodies he has. It was some really neat expedition stuff. He did a toyota diesel conversion on his and that thing is way quiet! If it wasn't for the signature injection pump ticking at idle it'd be hard to tell it was a diesel. We joked though because he can hear all the other sounds his truck makes while I don't hear mine cause my diesel is louder.
Aside from the dusty gravel roads the event was great and we had a great turn out. The military GYs did great so it looks like I'll just stick to siping for now.
I put together a vid from the footage.
YouTube - Cruise the Woods 9-09
Old 10-01-09, 11:51 AM   #1129 (permalink)
boots4's Avatar
TLCA# 19547
weekly update
I spent a solid day on the Rubicon videos and got the cutting and editing finished. Just want to add some music and try out some compression settings. Here's the first trial with footage from our still camera before we fired up the camcorder (better quality).
YouTube - Rubicon 06-09 Part 1
We are getting rain again and I wanted to do something about my floppy windshield wipers. I pulled the motor and studied the connection some more. I tried out clipping it which didn't work and then just used some wire to secure the plastic piece to the wiper arm. I put in some relief cuts where the wire wraps around the inside of the plastic piece so the bushing on the wiper motor would still snap in.
The bushing snapped in and I tried out the wipers and they are solid again. We'll see if this holds up and if it doesn't it's back to the drawing board.
I washed and cleaned Dora after the trip and pulled the air cleaner to tap out the dust. I found some breaks in the element so I sealed them up with some clear cement after I cleaned it up.
I pulled the skidplate and will modify a new rubbing spot. I really tucked it tight so now I'm relieving all the spots that show up. Once I fix one the next one shows up because the drivetrain can wiggle a little more and touch where it didn't touch before.
Last edited by boots4; 10-20-09 at 04:53 PM. Reason: Reloaded video for better quality
Old 10-01-09, 04:04 PM   #1130 (permalink)
Turbo Diesel Lover
Tapage's Avatar
few sections looks like a dry Tellico ..
HJ-60 2H-T Intercooled Tencha
Old 10-02-09, 09:54 PM   #1131 (permalink)
TLCA# 16127
Wish I could have made CTW... looks like it was dry for once!
Old 10-03-09, 10:09 AM   #1132 (permalink)
boots4's Avatar
TLCA# 19547
Funny, I was wishing it was a little more wet. I PM'd you about a date for tube action.
Old 10-03-09, 07:59 PM   #1133 (permalink)
TLCA# 16127
PM'd ya back... sounds like a plan.
Old 10-04-09, 05:33 PM   #1134 (permalink)
Dirtgypsy's Avatar
TLCA# 17541
Cool pics! That is some serious drop! Sorry I couldn't make it CTW as well. I am stoked to see those vids from Rubithon.
Hey pm me as well on the work days. I don't think the funds are in place to finish my bumper but I can come and help!!
Clint
Just bump it.
SOA in progress!
Old 10-08-09, 06:30 PM   #1135 (permalink)
esh
esh's Avatar
TLCA# 4408
I found a dual battery setup I like. Writeup on Rising Sun- Dual Battery Install W/ Voltage Sensing Relay - Rising Sun Member Forums
Found a source for the VSR on ebay (BEP Marine #722). 300Amp Voltage Sensitive Relay (VSR) - Voltage Sensitive Relays - BEP Marine The VSR is pretty high amp and has a switch to combine batteries if needed.
Instead of the Luna dual battery display, I am going to get this aussie round dual display for digits. RGB Electronics (Australia) >> LCD volt meter >> Model No : PMV+V also found on ebay.
Ken, Cascade Cruisers
'64 FJ40, '66 FJ45, '79 FJ40, '81 BJ42, '82 BJ42, '85 xcab, '89 HZJ62
esh is offline   Reply With Quote
Old 10-08-09, 06:50 PM   #1136 (permalink)
boots4's Avatar
TLCA# 19547
Funny, I was reading that same article today and liked his set up. I also like the simple volt meters too, thanks for adding.
Old 10-09-09, 02:10 PM   #1137 (permalink)
National Luna
Try this one....It's the most common we use in South Africa and it's robust like the Cruiser it's mounted in
HJ60 2H Diesel Donkey
Pretoria, South Africa
BosBok is offline   Reply With Quote
Old 10-09-09, 04:34 PM   #1138 (permalink)
boots4's Avatar
TLCA# 19547
Originally Posted by BosBok View Post
National Luna
I actually already have one of these, I just haven't hooked it up. Well, I did have it hooked up but wired incorrectly however I've got that figured out now, just have to see if I popped the inner fuse or not. It's got a great track record and that's why I choose it. I wanted something that could stand up to the extra vibs I get from my diesel and these have proven to be tough.
Old 10-15-09, 09:38 AM   #1139 (permalink)
boots4's Avatar
TLCA# 19547
biweekly update
I have been doing random stuff on Dora and preparing the house/yard for winter. Also been preparing for our third to arrive in 2 1/2 more weeks!
For Dora stuff I dove into the dash again to fix the leaking heater core connection. I've been putting this off because I haven't needed my heater until lately so this leak was isolated by having the temp selector set on cold. This still isn't a fun job the second time around.
Not wanting to do this again I wanted to make it a permanent fix. The first core lasted 20+ years so that was a bet I was willing to make. Why I didn't just sweat the joint with solder, I don't know but I used JBWeld and it doesn't leak so same bird killed with a stick instead of a stone. I was generous and put on two layers.
While the JBWeld was curing I inspected the flaps because the controls on the dash weren't very smooth. The weather stripping I used wasn't faring too well.
So I pulled the box apart, yanked all that stuff off and used that "fun foam" that I used on the CB mount to line the flaps. All the levers/flaps were hooked up right but there were clearance issues with the previous foam that was causing restrictions. Once I fix those spots the flaps opened and closed without much force on the dash controls. You can see the fun foam on the flaps and the heater core reinstalled in this pic.
I've had two pieces of aluminum roughly cut out for the interior rear quarters. The aluminum is from two sections I saved from the stepvan chop. I shaped the passenger side and put it on. I'm not sure if I'll polish it, brush finish it, or paint it. I really don't store anything in this side since it's the fuel side and I've never really sealed up the filler neck hole in the bottom of the quarter panel. For the driver side I'll cut in an access panel in so I can continue to store stuff on that side.
I had the front tires balanced. I didn't do the rears because I wasn't sure if the o-rings were leaking (I was losing pressure somewhere) in which case I'd have to separate the H1 rims to replace them. The leak ended up being the valve core not tight enough and that probably happened with the air down tool that removes the core for faster air down. I must not have tightened them enough after reinserting. Anyways the rears can be balanced now but at the time I only got the fronts done. I was suprised to see the difference in weight it took!
Here's what it took on the driver side.
And this is all it took on the passenger side!
Results on the hwy are night and day. It's been a long time since Dora has been this smooth and that's with only two tires balanced. It has also reduced most of the minor DW I have.
I've never been completely satisfied with the steering. It just seems too loose and recently felt worse. Last week I was slowing (using brakes) to turn onto another street and the wheel went heavy, meaning loss of assist. It hasn't done that before and hasn't done that since but that obviously drew my attention to the whole system.
The setup goes: steering pump to hydroboost to steering box which feeds the ram and then low pressure back to the steering pump. After thinking about it I've isolated it to the steering gear box. The brakes didn't lose assist, just the steering so I may have a seal inside leaking pressure. I'm sure it's the original box and it has over 230K on it. So the plan is to reseal the gear box. As good measure I'll be resealing the steering pump (saginaw) too at which time I'll mod the valve for a little more pressure and flow.
Dora's been wandering a bit more lately so I continued my attention to the system and checked out the linkage. I've got two TRE's that have play; the driver side Tie Rod which I recently replaced and the drag link passenger. Since I've recently replaced the driver side Tie Rod and this TRE is going out I believe I've found the weaklink in my linkage. I believe the order from weakest to strongest is in this order: driver Tie Rod TRE, passenger drag link TRE, passenger Tie Rod TRE, pitman arm drag link TRE. I don't want to replace the FJ80 joint with another one, I want to get something stronger. There is plenty of clearance on the driver steering arm for a bigger joint whether a bigger TRE or possibly a stout Heim joint. The passenger side arm is pretty tight on clearance so to take the easy route I think I'm going to try out fixing the driver side first and replacing the passenger drag link TRE with the one I pulled from the passenger tie rod that is still nice and tight (I replaced it when I replaced the driver side recently).
To finish up my random projects I completed the clearancing of the skidplate and will check it this week to see if I have any other rubbing spots. Don't really care for how it turned out but this is more a function over form thing.
Old 10-19-09, 09:46 AM   #1140 (permalink)
Dirtgypsy's Avatar
TLCA# 17541
Dude, I don't know how you do it. I ask for one day or even part of one day on the cruiser and I get the stink eye. You need to tell us all your secrets!
The cruiser is looking great! I need to get a copy of your side panel. I don't know if you managed to pick up the steering box seal kit but I ordered mine from "Jon V" PM me if you want his e-mail. It was $58 shipped for just the seals. I got his info from Mace here on the board.
Clint
Just bump it.
SOA in progress!
LinkBack to this Thread: http://forum.ih8mud.com/hardcore-corner/160807-family-haulin.html
Posted By For Type Date
Here's the Descrambler - Page 8 - Cummins 4BT & Diesel Conversions Forums This thread Refback 11-01-09 03:53 PM
Untitled document This thread Refback 10-25-09 05:08 PM
cool thread on using a VNT,VVT or whatever turbo - Page 8 - Cummins 4BT & Diesel Conversions Forums This thread Refback 10-18-09 09:39 AM
Untitled document This thread Refback 10-16-09 09:10 AM
74 Fj40 - Page 3 - Cummins 4BT & Diesel Conversions Forums This thread Refback 10-10-09 11:22 PM
Has anyone actually used a 4L80E??? - Page 3 - Cummins 4BT & Diesel Conversions Forums This thread Refback 10-09-09 06:56 PM
ARAMP1's Ultimate TowRig Buld Thread - Page 2 - Cummins 4BT & Diesel Conversions Forums This thread Refback 10-06-09 02:19 PM
Has anyone actually used a 4L80E??? - Page 2 - Cummins 4BT & Diesel Conversions Forums This thread Refback 10-03-09 10:05 AM
FJ60 drivetrain swap questions - Page 3 - Expedition Portal Forum This thread Refback 09-19-09 04:03 PM
6bt in 87 V3500....progress thread - Page 2 - Cummins 4BT & Diesel Conversions Forums This thread Refback 08-15-09 04:29 AM
The new and improved Tiny-Tach - Cummins 4BT & Diesel Conversions Forums This thread Refback 08-12-09 06:45 PM
anyone actually using a 4l80? - Cummins 4BT & Diesel Conversions Forums This thread Refback 08-09-09 04:26 PM
THE 4L80/85E information thread - Cummins 4BT & Diesel Conversions Forums This thread Refback 08-09-09 09:24 AM
Lift pump pre filter - Cummins 4BT & Diesel Conversions Forums This thread Refback 08-07-09 05:04 PM
Mini Mercedes, Mod Haulin Mercedes, Mercedes Service Atlanta - Felprocatalogw This thread Refback 07-09-09 11:19 AM
Completed '74 Plymouth Satellite 4bt swap - Cummins 4BT & Diesel Conversions Forums This thread Refback 07-01-09 09:19 PM
New to Diesel Swap Questions - Plumbing Electrical Etc - Cummins 4BT & Diesel Conversions Forums This thread Refback 06-06-09 11:23 AM
Electric Vacuum Pumps - Cummins 4BT & Diesel Conversions Forums This thread Refback 05-27-09 11:00 AM
Show off ur motor mounts. - Page 6 - Cummins 4BT & Diesel Conversions Forums This thread Refback 05-20-09 07:40 PM
Official Cummins 4BT video thread! - Page 3 - Cummins 4BT & Diesel Conversions Forums This thread Refback 05-20-09 03:25 AM
'85 FJ60 Landcruiser 4BT/4L480e SOA - Cummins 4BT & Diesel Conversions Forums This thread Refback 05-17-09 01:41 AM
Here's the Descrambler - Page 4 - Cummins 4BT & Diesel Conversions Forums This thread Refback 05-16-09 10:44 AM
Here's the Descrambler - Page 6 - Cummins 4BT & Diesel Conversions Forums This thread Refback 04-23-09 12:49 PM
April 18 - SOLV @ Tillamook State Forest This thread Refback 04-18-09 09:41 PM
Family Trucksters? - Colorado4x4.org Forums This thread Refback 04-14-09 07:50 AM
700r4 feasibility study - Page 6 - Cummins 4BT & Diesel Conversions Forums This thread Refback 03-25-09 09:15 PM
Jeep Cj2A Bikini Top, Jeep Cj Exhaust Manifold Gasket Replacement, Jeep Cj5 Exhaust Flange - Polarisdiesel This thread Refback 03-08-09 11:24 AM
Gm Card Points For Chevy Malibu, Gm Automotive Warranty Audit, Gm Cars With 200 Plus Amp Alternators - Shadowdemon This thread Refback 03-08-09 09:51 AM
Scout Engine Conversion Headers, Scottie Kit Car Parts, Scranton Area Rental Cars - Marshlandboar This thread Refback 03-08-09 08:44 AM
1992 80 Series - Cummins 4BT & Diesel Conversions Forums This thread Refback 03-07-09 11:34 AM
Buy Ford Bronco 4X4 Lifted, Buy Electric Cars, Buy Geo Metro - Yvonneridley This thread Refback 03-07-09 03:24 AM
Toyota Collapsed Top Radiator Hose, Toyota Cold Fusion France, Toyota Concept Cars - Newavengers This thread Refback 03-07-09 01:43 AM
Official Cummins 4BT video thread! - Page 5 - Cummins 4BT & Diesel Conversions Forums This thread Refback 03-06-09 03:21 PM
Dually Fenders For Van, Dual Sport Motorcycle Tires, Dubai Car Rentals - Tiresbicycle This thread Refback 03-06-09 02:04 AM
Ford Truck Exhaust Manifold Leak, Ford Truck Clutch Kits, Ford Truck Front Fenders My My Messages - Polarisclothing This thread Refback 03-06-09 02:04 AM
Gmc Truck Plastic Bed Liners Plainfield Illinois, Gmc Truck Mud Flaps, Gmc Truck Tune Up - Balljoint This thread Refback 03-06-09 01:40 AM
JacobPadilla's Bookmarks on Delicious This thread Refback 02-20-09 07:21 PM
Mufflers - Cummins 4BT & Diesel Conversions Forums Post #0 Refback 02-16-09 07:58 PM
Here's the Descrambler - Page 5 - Cummins 4BT & Diesel Conversions Forums This thread Refback 02-13-09 12:48 PM
FJ60 Build - Page 6 - Pirate4x4.Com Bulletin Board This thread Refback 02-12-09 08:54 AM
74 Fj40 - Cummins 4BT & Diesel Conversions Forums This thread Refback 02-02-09 06:13 PM
PNWJeep.com • View topic - My Build... This thread Refback 01-31-09 10:16 PM
Do I really need two 12-volt batteries? - Cummins 4BT & Diesel Conversions Forums This thread Refback 01-25-09 11:58 AM
Dodge intake horns - Cummins 4BT & Diesel Conversions Forums This thread Refback 01-20-09 07:22 PM
Here's the Descrambler - Page 3 - Cummins 4BT & Diesel Conversions Forums This thread Refback 01-11-09 01:57 PM
Snow wheeling TSF Browns camp this weekend Jan 3 or 4 2009? This thread Refback 01-02-09 12:38 PM
how come my trans shifts? - Page 2 - Cummins 4BT & Diesel Conversions Forums This thread Refback 01-02-09 02:49 AM
Name that thing-a-ma-jig - Cummins 4BT & Diesel Conversions Forums This thread Refback 12-19-08 03:10 PM
Fuel Log - Cummins 4BT & Diesel Conversions Forums This thread Refback 12-07-08 01:06 PM
toyota fj62 swap - Cummins 4BT & Diesel Conversions Forums This thread Refback 12-04-08 09:27 AM
CAC Intake Manifold Part Numbers-ATTN: boots4 - Cummins 4BT & Diesel Conversions Forums This thread Refback 11-28-08 08:09 PM
Sound proofing on sump - Page 2 - Cummins 4BT & Diesel Conversions Forums This thread Refback 11-11-08 10:05 PM
video request plz - Cummins 4BT & Diesel Conversions Forums This thread Refback 11-06-08 09:23 AM
Bosch VE timing question - Cummins 4BT & Diesel Conversions Forums This thread Refback 11-02-08 09:29 PM
Using 2-stroke oil - Cummins 4BT & Diesel Conversions Forums This thread Refback 10-30-08 07:03 PM
4runnerclub.org :: Zobrazit téma - oprava šedesátky This thread Refback 10-26-08 12:05 PM
Need serious help with egt's - Page 2 - Cummins 4BT & Diesel Conversions Forums This thread Refback 10-22-08 01:26 PM
Hydroboost setup question - Cummins 4BT & Diesel Conversions Forums This thread Refback 10-22-08 12:35 PM
Power and economy and reliability where is the happy medium - Page 4 - Cummins 4BT & Diesel Conversions Forums This thread Refback 10-21-08 04:53 PM
Opinions please - Cummins 4BT & Diesel Conversions Forums This thread Refback 10-21-08 02:41 PM
Diesel questions This thread Refback 10-19-08 11:45 AM
Turbo Info, HY35s, Photos/info... Etc - Page 12 - Cummins 4BT & Diesel Conversions Forums This thread Refback 10-18-08 11:42 AM
Boost gauge location? - Cummins 4BT & Diesel Conversions Forums This thread Refback 10-16-08 11:59 AM
Isuzu Commercial Diesel - Pirate4x4.Com Bulletin Board This thread Refback 10-14-08 11:14 PM
Use orginal gas tank question - Cummins 4BT & Diesel Conversions Forums This thread Refback 10-05-08 08:59 AM
View the profile of boots4 This thread Refback 10-04-08 09:05 PM
tuning for an HX35 - Cummins 4BT & Diesel Conversions Forums This thread Refback 09-28-08 07:09 AM
Full Power Screw.... - Cummins 4BT & Diesel Conversions Forums This thread Refback 09-27-08 11:46 PM
4x4.ee :: Vaata teemat - Tõsine HJ-60 project This thread Refback 09-15-08 02:15 PM
Weldernator - Cummins 4BT Forums This thread Refback 09-05-08 04:56 AM
Engine Choices --3.3l vs. 3.9l - Cummins 4BT Forums This thread Refback 08-16-08 04:45 PM
Noob EGT question. - Cummins 4BT Forums This thread Refback 08-13-08 06:15 PM
New Guy - Cummins 4BT Forums This thread Refback 08-01-08 05:56 AM
Which Dodge automatic to use in FJ80? - Cummins 4BT Forums This thread Refback 07-28-08 08:25 AM
Let's See Your Trucks! - Page 8 - Cummins 4BT Forums This thread Refback 07-24-08 09:37 PM
74 Fj40 - Page 4 - Cummins 4BT Forums This thread Refback 07-21-08 10:13 AM
IDEAS? EGT's Hot at stock and pump turned up any ideas? - Page 2 - Cummins 4BT Forums This thread Refback 07-12-08 01:40 PM
Build-up: Jeep YJ w/ Isuzu diesel - Page 11 - Pirate4x4.Com Bulletin Board This thread Refback 07-10-08 10:32 AM
Arrrgg....it always works this way - Cummins 4BT Forums This thread Refback 06-28-08 05:56 PM
Can You Still Hear After running you're 4BT? - Page 3 - Cummins 4BT Forums This thread Refback 06-27-08 06:10 AM
What gears for 37 This thread Refback 06-25-08 12:58 PM
What gears for 37 This thread Refback 06-23-08 08:33 AM
Exhaust Routing - Cummins 4BT Forums This thread Refback 06-21-08 11:29 PM
74 Fj40 - Page 2 - Cummins 4BT Forums This thread Refback 06-13-08 05:28 PM
Kdp ? - Cummins 4BT Forums This thread Refback 06-13-08 06:24 AM
IDEAS? EGT's Hot at stock and pump turned up any ideas? - Cummins 4BT Forums This thread Refback 06-10-08 10:47 AM
vacuum booster for brakes? - Cummins 4BT Forums This thread Refback 06-08-08 04:39 PM
Timbercrawler -- View topic - Who owns... This thread Refback 06-06-08 11:05 AM
Hot rod gets a 4BT - Cummins 4BT Forums This thread Refback 06-05-08 07:32 PM
Timbercrawler -- View topic - Who owns... This thread Refback 06-04-08 10:01 PM
Timbercrawler -- View topic - Who owns... This thread Refback 06-04-08 09:46 PM
VE Pump Question - Cummins 4BT Forums This thread Refback 06-04-08 07:51 PM
Your max GCVW with a 4BT? - Cummins 4BT Forums This thread Refback 06-04-08 02:57 PM
2nd maiden voyage - Cummins 4BT Forums This thread Refback 05-30-08 12:06 PM
Sound proofing on sump - Page 2 - Cummins 4BT Forums This thread Refback 05-18-08 09:21 PM
Pullys - Cummins 4BT Forums This thread Refback 05-17-08 08:28 AM
Muffler or no muffler? Exhaust diameter? - Page 3 - Cummins 4BT Forums This thread Refback 05-13-08 07:25 PM
Mongos 4BT Firewood Monster Truck - Page 4 - Cummins 4BT Forums This thread Refback 05-12-08 12:05 PM
Muffler or no muffler? Exhaust diameter? - Page 2 - Cummins 4BT Forums This thread Refback 05-11-08 04:20 PM
Rebuild H1 turbo - Cummins 4BT Forums This thread Refback 05-10-08 04:16 PM
4bt radiator - Cummins 4BT Forums This thread Refback 05-08-08 05:14 PM
Radiator hose adapters - Cummins 4BT Forums This thread Refback 05-03-08 09:09 PM
Vibration Issues Affecting Me?? - Cummins 4BT Forums This thread Refback 05-01-08 05:42 AM
H1C rebuild kits on EBAY - Cummins 4BT Forums This thread Refback 04-21-08 08:59 PM
Vote: 4bt or 6bt in Jeep J20 - Cummins 4BT Forums This thread Refback 04-16-08 09:18 PM
Hydroboost or Vacuum pump - Cummins 4BT Forums This thread Refback 04-16-08 02:32 PM
$3k step van or $2k used motor - Cummins 4BT Forums This thread Refback 04-08-08 05:49 PM
$3k step van or $2k used motor - Cummins 4BT Forums This thread Refback 04-08-08 03:12 PM
4bt swap - Cummins 4BT Forums This thread Refback 04-06-08 02:42 PM
trailer mod haulin This thread Refback 04-06-08 11:50 AM
Here is the truck for those who care - Cummins 4BT Forums This thread Refback 04-03-08 05:26 PM
insurance - Cummins 4BT Forums This thread Refback 04-01-08 12:12 PM
my bronco build - Page 2 - Cummins 4BT Forums This thread Refback 03-31-08 07:02 PM
Engine/Transmission Adapter P/N - Cummins 4BT Forums This thread Refback 03-26-08 09:36 PM
Hi Case mount AC - Cummins 4BT Forums This thread Refback 03-26-08 06:38 PM
Hi Case mount AC - Cummins 4BT Forums This thread Refback 03-26-08 06:21 PM
My '68 Kaiser M715 - Cummins 4BT Forums This thread Refback 03-26-08 02:51 PM
Please Help! Need inout on Trans - Cummins 4BT Forums This thread Refback 03-26-08 12:51 PM
My '68 Kaiser M715 - Cummins 4BT Forums This thread Refback 03-25-08 08:55 PM
FZJ80 w/ 4BT, couple questions - Cummins 4BT Forums This thread Refback 03-25-08 05:06 PM
mod za haulin This thread Refback 03-25-08 08:13 AM
Bought a 4BT with turbo missing....which one to buy? - Cummins 4BT Forums This thread Refback 03-18-08 08:17 PM
Questions before the swap starts - Cummins 4BT Forums This thread Refback 03-18-08 06:37 AM
Step Van????s - Page 2 - Cummins 4BT Forums This thread Refback 03-07-08 08:01 PM
tater chip tuck??? - Cummins 4BT Forums This thread Refback 03-07-08 05:48 AM
swapping a 4bt into a 1988 28 ft pace arrow MH - Cummins 4BT Forums This thread Refback 03-06-08 05:04 PM
Hydroboost, Steering, A/C and gearing questions questions - Cummins 4BT Forums This thread Refback 03-06-08 01:36 PM
74 Fj40 - Cummins 4BT Forums This thread Refback 03-05-08 01:45 PM
74 Fj40 - Cummins 4BT Forums This thread Refback 03-05-08 12:11 PM
my Yj is complete pics inside!!!!!! - Cummins 4BT Forums This thread Refback 03-04-08 07:56 PM
intercooler cooling - Cummins 4BT Forums This thread Refback 03-02-08 07:49 PM
repower with a 4l80? - Page 3 - Cummins 4BT Forums This thread Refback 03-01-08 06:37 AM
RPM's with gears and tires - Cummins 4BT Forums This thread Refback 02-28-08 08:33 PM
What is need to 4l80e? - Cummins 4BT Forums This thread Refback 02-27-08 08:37 PM
Tranny explosions, parts all over! - Cummins 4BT Forums This thread Refback 02-27-08 07:13 PM
4l80e converter - Cummins 4BT Forums This thread Refback 02-26-08 06:55 PM
4bt radiator - Cummins 4BT Forums This thread Refback 02-25-08 05:58 PM
4bt swap into a TJ - Cummins 4BT Forums This thread Refback 02-22-08 11:48 AM
6bt in 87 V3500....progress thread - Page 3 - Cummins 4BT Forums This thread Refback 02-21-08 11:38 PM
Feb Dovebid vans - Cummins 4BT Forums This thread Refback 02-21-08 08:51 PM
Mpg<auto<man - Page 2 - Cummins 4BT Forums This thread Refback 02-19-08 01:56 PM
6bt in 87 V3500....progress thread - Page 4 - Cummins 4BT Forums This thread Refback 02-18-08 09:13 PM
Big Line Kit???? - Cummins 4BT Forums This thread Refback 02-10-08 09:04 PM
better auto transmission for 4bt - Cummins 4BT Forums This thread Refback 02-07-08 03:49 PM
My new Shop Class - Cummins 4BT Forums This thread Refback 02-07-08 01:23 PM
3/4 ton Suburban, Expedition/Overlander RV 4bt or 6bt - Cummins 4BT Forums This thread Refback 02-07-08 11:04 AM
better auto transmission for 4bt - Cummins 4BT Forums This thread Refback 02-06-08 04:03 PM
Turbo Upgrade...remove exh. manifold or not - Cummins 4BT Forums This thread Refback 02-04-08 05:29 PM
Turbo Compressor Housings - Cummins 4BT Forums This thread Refback 01-28-08 05:46 PM
Identify this engine - Cummins 4BT Forums This thread Refback 01-25-08 07:53 PM
6bt in 87 V3500....progress thread - Page 4 - Cummins 4BT Forums This thread Refback 01-24-08 08:38 PM
Turbo Compressor Housings - Cummins 4BT Forums This thread Refback 01-22-08 07:54 PM
Battery specs??? - Cummins 4BT Forums This thread Refback 01-21-08 09:35 PM
Turbo Compressor Housings - Cummins 4BT Forums This thread Refback 01-20-08 05:29 PM
Where to buy tan Cummins engine paint? - Cummins 4BT Forums This thread Refback 01-19-08 09:23 PM
Turning Up The Pump - a pictoral 'how to' - Cummins 4BT Forums This thread Refback 01-18-08 12:08 PM
Sound proofing on sump - Page 2 - Cummins 4BT Forums This thread Refback 01-18-08 10:30 AM
repower with a 4l80? - Page 2 - Cummins 4BT Forums This thread Refback 01-17-08 10:08 AM
Got a 4b, now what truck?? - Cummins 4BT Forums This thread Refback 01-16-08 04:28 PM
Anyone tried this in a 90's GMC Vandura? - Cummins 4BT Forums This thread Refback 01-16-08 03:36 PM
Anyone tried this in a 90's GMC Vandura? - Cummins 4BT Forums This thread Refback 01-16-08 12:52 PM
Who is in the PNW? - Cummins 4BT Forums This thread Refback 01-12-08 03:19 PM
Newbie needin help. Calling NOVA Guys - Cummins 4BT Forums This thread Refback 01-11-08 12:18 PM
H1C rebuild kits on EBAY - Cummins 4BT Forums This thread Refback 01-10-08 11:30 AM
H1C rebuild kits on EBAY - Cummins 4BT Forums This thread Refback 01-10-08 10:21 AM
95yj - Cummins 4BT Forums This thread Refback 01-08-08 04:07 PM
air filter flow rates - Cummins 4BT Forums This thread Refback 01-07-08 06:28 PM
Show off ur motor mounts. - Page 10 - Cummins 4BT Forums This thread Refback 01-07-08 05:38 PM
Exhaust Done (New video) - Cummins 4BT Forums This thread Refback 01-06-08 10:19 PM
Cummins 4BT Forums - View Profile: boots4 This thread Refback 12-29-07 07:31 PM
fuel line - Page 2 - Cummins 4BT Forums This thread Refback 12-28-07 04:59 AM
intercooler cooling - Cummins 4BT Forums This thread Refback 12-24-07 06:56 PM
Bypass filter setups - Cummins 4BT Forums This thread Refback 12-23-07 08:18 PM
Shaker - Cummins 4BT Forums This thread Refback 12-18-07 08:19 PM
hydroboost fitting sizes - Cummins 4BT Forums This thread Refback 12-18-07 02:44 PM
