Go Back   IH8MUD.com > General Tech Forums > HardCore Corner
LinkBack (175) Thread Tools Display Modes
Old 08-27-09, 07:46 PM   #1081 (permalink)
Dirtgypsy's Avatar
TLCA# 17541
so true so true.
Clint
It's a Jeep thing I didn't understand. So I bought an FJ60 and now I get it.
Just bump it.
SOA in progress!
ROTW: http://forum.ih8mud.com/60-series-wa...lver-60-a.html
Dirtgypsy is offline   Reply With Quote
Old 09-04-09, 09:53 AM   #1082 (permalink)
boots4's Avatar
TLCA# 19547
weekly update
Just worked on little things.
I finally got my power junction block bolted in. I cut a piece of aluminum as a mounting base. I wanted to clear the accessary wiring off the battery and was planning to add more so this will keep that more orgainized. I picked this up a while ago.
I ditched the zip ties and finally mounted my vacuum regulator for the tranny with a bolt. It's more secure now. I also re-tuned the injection pump. I maxed out the AFC wheel to it's deepest setting (controls fueling when boosting), turned back the smoke screw (adjusts the fuel it sees before boost), bumped the timing (running 15 degrees now), and put a 1/4 turn up on the power screw. It runs a little smoother, boosts more aggressive/stronger, smokes less, and dropped ETGs 50-75F degrees. I'm not into belching black smoke at an intersection even though it'd be nice to smoke screen some of the retards on the road. My wife even said it seemed quieter last night because she didn't hear me until I hit the driveway instead of from around the corner (she must have been distracted).
After removing the air filter shroud I reset my vacuum gauge on the intake tube and have not seen it register so my previous shrouding was too restrictive. I still want to put in a heat barrier between the filter and the turbo but I'll leave this one open on the sides. Since I removed the shroud I wanted to close in the hole I made from shock placement and I made a rubber boot from the left over cuttings from the mud flaps.
It goes here. I still need to secure it but obviously I'll want it removeable so I can get to the shock bolt.
That should keep the water from splashing onto the air filter.
I stared at the exhaust path underneath for ideas about heat shielding. I also remembered that I still have exhaust wrap so I removed the down pipe and put another layer on it to see how it does, so now my down pipe is double wrapped.
Other stuff:
I picked up some 1/8" plate for the front bumper. We also made it to the beach with the family and got my sister to take her rig out on the sand. Dora's new shoes obviously don't float as well as the PJs but then again I didn't air down either. Now Dora's got sand in all her cracks.
I did front brakes and flushed the brake fluid on the other car. I also redesigned a stronger mount for my trailer jack and welded that on running out of wire just as I finished. On top of that I'm playing with a Linux OS on a spare computer I have around and am hoping to get that worked out so I can use that to edit my videos. It was a busy couple of days.
build-up: Family Haulin' FJ60
boots4 is offline   Reply With Quote
Old 09-04-09, 10:10 AM   #1083 (permalink)
Dirtgypsy's Avatar
TLCA# 17541
Definately a busy couple of days for you! I really like the junction box. I am pretty sure I will be knee deep in a de-smog here this month and like the cleaner looks of that electrical set up. Maybe the smog stuff will get replaced with that!
Also congrats on the pic of you and Dora on Cadillac Hill in the 4WD Toyota Owners Mag!
Clint
Just bump it.
SOA in progress!
Old 09-04-09, 10:31 AM   #1084 (permalink)
boots4's Avatar
TLCA# 19547
Clint
Can you scan it and put it on, I haven't seen it!
Old 09-04-09, 11:12 AM   #1085 (permalink)
Dirtgypsy's Avatar
TLCA# 17541
I don't have a scanner sorry! Maybe someone else will read this and post up!
Clint
Just bump it.
SOA in progress!
Old 09-04-09, 11:34 AM   #1086 (permalink)
boots4's Avatar
TLCA# 19547
I have a scanner so bring the magazine when you come over in a week and I'll scan it.
Old 09-04-09, 10:31 PM   #1087 (permalink)
Dirtgypsy's Avatar
TLCA# 17541
will do amigo.
clint
Just bump it.
SOA in progress!
Old 09-05-09, 10:15 AM   #1088 (permalink)
brokenparts's Avatar
TLCA# 16127
Nice bumper...
ROTW: http://forum.ih8mud.com/60-series-wagons/198064-rotw-brokenparts-fj-60-a.html
Old 09-05-09, 11:07 AM   #1089 (permalink)
boots4's Avatar
TLCA# 19547
Thanks Zack! That turned out pretty good. I saw that photographer following me so I wondered what they'd use. Looks like Cruiserdrew made it in too, that's his green 40.
Old 09-05-09, 06:13 PM   #1090 (permalink)
Dirtgypsy's Avatar
TLCA# 17541
It's usually that other guy's white 62 that makes it into al the photo shoots. Jeeze you put a big block in a truck and all of a sudden you are a celebrity or something
btw that is not Drew's 40. It is really nice but not his.
Clint
Just bump it.
SOA in progress!
Old 09-05-09, 07:55 PM   #1091 (permalink)
boots4's Avatar
TLCA# 19547
Clint
I thought that was his hat, but I didn't remember him having that rack on there so I guess it's not him.
Old 09-06-09, 06:25 PM   #1092 (permalink)
Cruiserdrew's Avatar
TLCA# 11734
My hat's a lot bigger and 40's a lot uglier.
Now back to the most excellent build thread......
BTW...With CaliCruiser's help on Friday, I got the H41/toybox/split case mounted up and bolted in. Waiting for driveshafts and it's mobile.!
Andrew
Cruiserdrew is online now   Reply With Quote
Old 09-06-09, 07:16 PM   #1093 (permalink)
Dirtgypsy's Avatar
TLCA# 17541
can you take some pics and post up how the install goes? very anxiously wanting more info on these installs.
Clint
Just bump it.
SOA in progress!
Old 09-06-09, 10:36 PM   #1094 (permalink)
boots4's Avatar
TLCA# 19547
That's in the 60? What is the 203 GRB going in?
Old 09-09-09, 10:04 AM   #1095 (permalink)
boots4's Avatar
TLCA# 19547
weekly update
No mods this week just useage.
Here are some pics from last week's beach outting.
The other purpose for some tube work is to have a place to hang stuff.
This week we got a load of wood and pretty much maxed out my trailer capcity beyond tire limits. Had to be 4-5000lbs and then a couple hundred more in the back of the rig. I was worried about the trailer tires (leafs still had a little more left) so I kept my max at 50mph even though Dora was willing to pull it faster. I could tell I had a good load behind but the brakes had plenty of power.
Side note:
I've been troubleshooting a video editor (Kdenlive) on my Linux machine I've been trying out. I like the software but am having rendering issues to sort out or I'd have Part 1 of the Rubicon to share. Linux is new to me so I'm going through a learning curve. Soon I hope.
Old 09-09-09, 10:23 AM   #1096 (permalink)
TLCA# 16127
Love the new look of the wheels and tires. What beach were you at?
Old 09-09-09, 10:46 AM   #1097 (permalink)
boots4's Avatar
TLCA# 19547
The absolutely most northern beach possible in Oregon. It's just north of Fort Stevens and is right where the Columbia river meets the Pacific ocean. Great for kids and nice to drive out on so you don't have to make 20 trips with all the stuff a family ends up bringing. Shipwreak beach is just down (10 mins) the road and has the remains of a beached ship to play around.
Old 09-09-09, 11:27 AM   #1098 (permalink)
TLCA# 16127
coolio... we'll have to check that area out sometime.
Old 09-09-09, 04:38 PM   #1099 (permalink)
Turbo Diesel Lover
Tapage's Avatar
which flavor of Linux are u using . ?
I love the SuSe performance and support ( web support off course ) been throught Fedora, RedHat, Mandrake ( howdy old ) Debian etc ..
HJ-60 2H-T Intercooled Tencha
Old 09-09-09, 05:19 PM   #1100 (permalink)
boots4's Avatar
TLCA# 19547
Trying out openSUSE 11.1 and am pretty impressed with it even though it's had a few issues to work out. Same with the Kdenlive video editor. I'm having problems with the mlt package and ffmpeg stuff.
Old 09-09-09, 05:43 PM   #1101 (permalink)
Turbo Diesel Lover
Tapage's Avatar
which version are u using and are you getting an error with those packs .. if you already take an apget and update paca after yoru instalation would be interesting see which packs you update ..
SuSe and all linux flavors need to do a lot of work on packs compatibilies .. but since all are made by diferent foolks looks a little complicated ..
Old 09-09-09, 06:02 PM   #1102 (permalink)
boots4's Avatar
TLCA# 19547
PM'd for SUSE tech.
Old 09-09-09, 06:23 PM   #1103 (permalink)
Dirtgypsy's Avatar
TLCA# 17541
cool pics. will be nice when you / we finish the front bumper. I know you like bigger tires but I am really liking the 37's! They look great and the offset is perfect.
Clint
Just bump it.
SOA in progress!
Old 09-11-09, 02:37 PM   #1104 (permalink)
Rum Runnin'
GLTHFJ60's Avatar
TLCA# 17825
Garage
Bump for pics of the old rims, if you're still willing to sell.
Johnny C
Waiting to be installed:
Previous Rig:
1987 FJ60 - Big Red
ΦΚΤ - Fall 06
GLTHFJ60 is offline   Reply With Quote
Old 09-11-09, 03:43 PM   #1105 (permalink)
boots4's Avatar
TLCA# 19547
Still working on that.
Old 09-15-09, 10:06 PM   #1106 (permalink)
boots4's Avatar
TLCA# 19547
PM'd finally.
Old 09-17-09, 09:45 AM   #1107 (permalink)
boots4's Avatar
TLCA# 19547
weekly update
Dirtgypsy came over on Monday and we worked on his rear upper shock mounts and slider mounts. We'll be stuffing 12" shocks in the rear (still need to change the lower mount). I keep telling him to cut off the rockers so we can tuck up those sliders but he's a full body guy.
Anyways, I got a little time on Dora the next day. First I cut out some 1/8" plate for the lower part of the front bumper. The corners I put together in two pieces due to a bend that was needed.
I tacked in the pieces to see what it looks like and if I want to change anything. I'll cut the tacks when we do the dimple dies and weld it up afterwards.
I had a plan to make a mount and then Wagongear came out with a nice simple mount. It reuses parts from the old antenna and since I couldn't find mine I went with something else. With the mounting surface sloping in two directions my custom mount was going to take more work than it's worth so I just decided to go with a ball mount so I could adjust the antenna to stick straight up. I "adjusted" the original antenna hole on the passenger side so that the ball mount would be centered and cover up the old hole. Then I drilled the three mounting holes for the ball mount.
Dirtgypsy had an extra ball mount laying around so he gave it to me. I cleaned it up and set it in to see if I got the holes lined up.
I cut out a rubber pad and shaped it to act as a gasket for the mount out of an old spring pad but it turned out too thick so I'll use something else, maybe a bike inner tube.
My splitter to use my CB antenna for my CB and radio showed up. This is the Firestick AR-1A. In the 70-80s they made splitters to use an am/fm antenna for CB use and that turned out bad because the am/fm antenna isn't ment to transmit, only receive. A CB antenna can do both and I only wanted 1 antenna so we see how this does. Antenna and cable should be in any day now.
I had just a little more energy left so I started modding the skid plate so it wouldn't rub on the tcase. It started raining so stopped but I'll finish that part up next week.
Old 09-17-09, 10:25 AM   #1108 (permalink)
TLCA# 11734
Where is the HAM radio mount?
Andrew
Old 09-17-09, 11:12 AM   #1109 (permalink)
boots4's Avatar
TLCA# 19547
I haven't even run a CB yet. The HAM will have to come later. I've seen radio selectors so I may be able to add that into the system to select between the CB and the HAM in the future. The K40 antenna I bought says it will work with both.
Old 09-17-09, 11:55 AM   #1110 (permalink)
The Anti-Leafer
LC_Hamma's Avatar
TLCA# 3343
Liking all the mods I've done a few in my time.... You really need a winch for that truck if you plan on wheelin any. Oh, & the beadlock rings need to be black & all the tubing should be dark gray. Good to see someone driving a *finished project truck w/a build thread on it. Who knows when mine'll be on the trail
LC_Hamma is offline   Reply With Quote
LinkBack to this Thread: http://forum.ih8mud.com/hardcore-corner/160807-family-haulin.html
Posted By For Type Date
Here's the Descrambler - Page 8 - Cummins 4BT & Diesel Conversions Forums This thread Refback 11-01-09 03:53 PM
Untitled document This thread Refback 10-25-09 05:08 PM
cool thread on using a VNT,VVT or whatever turbo - Page 8 - Cummins 4BT & Diesel Conversions Forums This thread Refback 10-18-09 09:39 AM
Untitled document This thread Refback 10-16-09 09:10 AM
74 Fj40 - Page 3 - Cummins 4BT & Diesel Conversions Forums This thread Refback 10-10-09 11:22 PM
Has anyone actually used a 4L80E??? - Page 3 - Cummins 4BT & Diesel Conversions Forums This thread Refback 10-09-09 06:56 PM
ARAMP1's Ultimate TowRig Buld Thread - Page 2 - Cummins 4BT & Diesel Conversions Forums This thread Refback 10-06-09 02:19 PM
Has anyone actually used a 4L80E??? - Page 2 - Cummins 4BT & Diesel Conversions Forums This thread Refback 10-03-09 10:05 AM
FJ60 drivetrain swap questions - Page 3 - Expedition Portal Forum This thread Refback 09-19-09 04:03 PM
6bt in 87 V3500....progress thread - Page 2 - Cummins 4BT & Diesel Conversions Forums This thread Refback 08-15-09 04:29 AM
The new and improved Tiny-Tach - Cummins 4BT & Diesel Conversions Forums This thread Refback 08-12-09 06:45 PM
anyone actually using a 4l80? - Cummins 4BT & Diesel Conversions Forums This thread Refback 08-09-09 04:26 PM
THE 4L80/85E information thread - Cummins 4BT & Diesel Conversions Forums This thread Refback 08-09-09 09:24 AM
Lift pump pre filter - Cummins 4BT & Diesel Conversions Forums This thread Refback 08-07-09 05:04 PM
Mini Mercedes, Mod Haulin Mercedes, Mercedes Service Atlanta - Felprocatalogw This thread Refback 07-09-09 11:19 AM
Completed '74 Plymouth Satellite 4bt swap - Cummins 4BT & Diesel Conversions Forums This thread Refback 07-01-09 09:19 PM
New to Diesel Swap Questions - Plumbing Electrical Etc - Cummins 4BT & Diesel Conversions Forums This thread Refback 06-06-09 11:23 AM
Electric Vacuum Pumps - Cummins 4BT & Diesel Conversions Forums This thread Refback 05-27-09 11:00 AM
Show off ur motor mounts. - Page 6 - Cummins 4BT & Diesel Conversions Forums This thread Refback 05-20-09 07:40 PM
Official Cummins 4BT video thread! - Page 3 - Cummins 4BT & Diesel Conversions Forums This thread Refback 05-20-09 03:25 AM
'85 FJ60 Landcruiser 4BT/4L480e SOA - Cummins 4BT & Diesel Conversions Forums This thread Refback 05-17-09 01:41 AM
Here's the Descrambler - Page 4 - Cummins 4BT & Diesel Conversions Forums This thread Refback 05-16-09 10:44 AM
Here's the Descrambler - Page 6 - Cummins 4BT & Diesel Conversions Forums This thread Refback 04-23-09 12:49 PM
April 18 - SOLV @ Tillamook State Forest This thread Refback 04-18-09 09:41 PM
Family Trucksters? - Colorado4x4.org Forums This thread Refback 04-14-09 07:50 AM
700r4 feasibility study - Page 6 - Cummins 4BT & Diesel Conversions Forums This thread Refback 03-25-09 09:15 PM
Jeep Cj2A Bikini Top, Jeep Cj Exhaust Manifold Gasket Replacement, Jeep Cj5 Exhaust Flange - Polarisdiesel This thread Refback 03-08-09 11:24 AM
Gm Card Points For Chevy Malibu, Gm Automotive Warranty Audit, Gm Cars With 200 Plus Amp Alternators - Shadowdemon This thread Refback 03-08-09 09:51 AM
Scout Engine Conversion Headers, Scottie Kit Car Parts, Scranton Area Rental Cars - Marshlandboar This thread Refback 03-08-09 08:44 AM
1992 80 Series - Cummins 4BT & Diesel Conversions Forums This thread Refback 03-07-09 11:34 AM
Buy Ford Bronco 4X4 Lifted, Buy Electric Cars, Buy Geo Metro - Yvonneridley This thread Refback 03-07-09 03:24 AM
Toyota Collapsed Top Radiator Hose, Toyota Cold Fusion France, Toyota Concept Cars - Newavengers This thread Refback 03-07-09 01:43 AM
Official Cummins 4BT video thread! - Page 5 - Cummins 4BT & Diesel Conversions Forums This thread Refback 03-06-09 03:21 PM
Dually Fenders For Van, Dual Sport Motorcycle Tires, Dubai Car Rentals - Tiresbicycle This thread Refback 03-06-09 02:04 AM
Ford Truck Exhaust Manifold Leak, Ford Truck Clutch Kits, Ford Truck Front Fenders My My Messages - Polarisclothing This thread Refback 03-06-09 02:04 AM
Gmc Truck Plastic Bed Liners Plainfield Illinois, Gmc Truck Mud Flaps, Gmc Truck Tune Up - Balljoint This thread Refback 03-06-09 01:40 AM
JacobPadilla's Bookmarks on Delicious This thread Refback 02-20-09 07:21 PM
Mufflers - Cummins 4BT & Diesel Conversions Forums Post #0 Refback 02-16-09 07:58 PM
Here's the Descrambler - Page 5 - Cummins 4BT & Diesel Conversions Forums This thread Refback 02-13-09 12:48 PM
FJ60 Build - Page 6 - Pirate4x4.Com Bulletin Board This thread Refback 02-12-09 08:54 AM
74 Fj40 - Cummins 4BT & Diesel Conversions Forums This thread Refback 02-02-09 06:13 PM
PNWJeep.com • View topic - My Build... This thread Refback 01-31-09 10:16 PM
Do I really need two 12-volt batteries? - Cummins 4BT & Diesel Conversions Forums This thread Refback 01-25-09 11:58 AM
Dodge intake horns - Cummins 4BT & Diesel Conversions Forums This thread Refback 01-20-09 07:22 PM
Here's the Descrambler - Page 3 - Cummins 4BT & Diesel Conversions Forums This thread Refback 01-11-09 01:57 PM
Snow wheeling TSF Browns camp this weekend Jan 3 or 4 2009? This thread Refback 01-02-09 12:38 PM
how come my trans shifts? - Page 2 - Cummins 4BT & Diesel Conversions Forums This thread Refback 01-02-09 02:49 AM
Name that thing-a-ma-jig - Cummins 4BT & Diesel Conversions Forums This thread Refback 12-19-08 03:10 PM
Fuel Log - Cummins 4BT & Diesel Conversions Forums This thread Refback 12-07-08 01:06 PM
toyota fj62 swap - Cummins 4BT & Diesel Conversions Forums This thread Refback 12-04-08 09:27 AM
CAC Intake Manifold Part Numbers-ATTN: boots4 - Cummins 4BT & Diesel Conversions Forums This thread Refback 11-28-08 08:09 PM
Sound proofing on sump - Page 2 - Cummins 4BT & Diesel Conversions Forums This thread Refback 11-11-08 10:05 PM
video request plz - Cummins 4BT & Diesel Conversions Forums This thread Refback 11-06-08 09:23 AM
Bosch VE timing question - Cummins 4BT & Diesel Conversions Forums This thread Refback 11-02-08 09:29 PM
Using 2-stroke oil - Cummins 4BT & Diesel Conversions Forums This thread Refback 10-30-08 07:03 PM
4runnerclub.org :: Zobrazit téma - oprava šedesátky This thread Refback 10-26-08 12:05 PM
Need serious help with egt's - Page 2 - Cummins 4BT & Diesel Conversions Forums This thread Refback 10-22-08 01:26 PM
Hydroboost setup question - Cummins 4BT & Diesel Conversions Forums This thread Refback 10-22-08 12:35 PM
Power and economy and reliability where is the happy medium - Page 4 - Cummins 4BT & Diesel Conversions Forums This thread Refback 10-21-08 04:53 PM
Opinions please - Cummins 4BT & Diesel Conversions Forums This thread Refback 10-21-08 02:41 PM
Diesel questions This thread Refback 10-19-08 11:45 AM
Turbo Info, HY35s, Photos/info... Etc - Page 12 - Cummins 4BT & Diesel Conversions Forums This thread Refback 10-18-08 11:42 AM
Boost gauge location? - Cummins 4BT & Diesel Conversions Forums This thread Refback 10-16-08 11:59 AM
Isuzu Commercial Diesel - Pirate4x4.Com Bulletin Board This thread Refback 10-14-08 11:14 PM
Use orginal gas tank question - Cummins 4BT & Diesel Conversions Forums This thread Refback 10-05-08 08:59 AM
View the profile of boots4 This thread Refback 10-04-08 09:05 PM
tuning for an HX35 - Cummins 4BT & Diesel Conversions Forums This thread Refback 09-28-08 07:09 AM
Full Power Screw.... - Cummins 4BT & Diesel Conversions Forums This thread Refback 09-27-08 11:46 PM
4x4.ee :: Vaata teemat - Tõsine HJ-60 project This thread Refback 09-15-08 02:15 PM
Weldernator - Cummins 4BT Forums This thread Refback 09-05-08 04:56 AM
Engine Choices --3.3l vs. 3.9l - Cummins 4BT Forums This thread Refback 08-16-08 04:45 PM
Noob EGT question. - Cummins 4BT Forums This thread Refback 08-13-08 06:15 PM
New Guy - Cummins 4BT Forums This thread Refback 08-01-08 05:56 AM
Which Dodge automatic to use in FJ80? - Cummins 4BT Forums This thread Refback 07-28-08 08:25 AM
Let's See Your Trucks! - Page 8 - Cummins 4BT Forums This thread Refback 07-24-08 09:37 PM
74 Fj40 - Page 4 - Cummins 4BT Forums This thread Refback 07-21-08 10:13 AM
IDEAS? EGT's Hot at stock and pump turned up any ideas? - Page 2 - Cummins 4BT Forums This thread Refback 07-12-08 01:40 PM
Build-up: Jeep YJ w/ Isuzu diesel - Page 11 - Pirate4x4.Com Bulletin Board This thread Refback 07-10-08 10:32 AM
Arrrgg....it always works this way - Cummins 4BT Forums This thread Refback 06-28-08 05:56 PM
Can You Still Hear After running you're 4BT? - Page 3 - Cummins 4BT Forums This thread Refback 06-27-08 06:10 AM
What gears for 37 This thread Refback 06-25-08 12:58 PM
What gears for 37 This thread Refback 06-23-08 08:33 AM
Exhaust Routing - Cummins 4BT Forums This thread Refback 06-21-08 11:29 PM
74 Fj40 - Page 2 - Cummins 4BT Forums This thread Refback 06-13-08 05:28 PM
Kdp ? - Cummins 4BT Forums This thread Refback 06-13-08 06:24 AM
IDEAS? EGT's Hot at stock and pump turned up any ideas? - Cummins 4BT Forums This thread Refback 06-10-08 10:47 AM
vacuum booster for brakes? - Cummins 4BT Forums This thread Refback 06-08-08 04:39 PM
Timbercrawler -- View topic - Who owns... This thread Refback 06-06-08 11:05 AM
Hot rod gets a 4BT - Cummins 4BT Forums This thread Refback 06-05-08 07:32 PM
Timbercrawler -- View topic - Who owns... This thread Refback 06-04-08 10:01 PM
Timbercrawler -- View topic - Who owns... This thread Refback 06-04-08 09:46 PM
VE Pump Question - Cummins 4BT Forums This thread Refback 06-04-08 07:51 PM
Your max GCVW with a 4BT? - Cummins 4BT Forums This thread Refback 06-04-08 02:57 PM
2nd maiden voyage - Cummins 4BT Forums This thread Refback 05-30-08 12:06 PM
Sound proofing on sump - Page 2 - Cummins 4BT Forums This thread Refback 05-18-08 09:21 PM
Pullys - Cummins 4BT Forums This thread Refback 05-17-08 08:28 AM
Muffler or no muffler? Exhaust diameter? - Page 3 - Cummins 4BT Forums This thread Refback 05-13-08 07:25 PM
Mongos 4BT Firewood Monster Truck - Page 4 - Cummins 4BT Forums This thread Refback 05-12-08 12:05 PM
Muffler or no muffler? Exhaust diameter? - Page 2 - Cummins 4BT Forums This thread Refback 05-11-08 04:20 PM
Rebuild H1 turbo - Cummins 4BT Forums This thread Refback 05-10-08 04:16 PM
4bt radiator - Cummins 4BT Forums This thread Refback 05-08-08 05:14 PM
Radiator hose adapters - Cummins 4BT Forums This thread Refback 05-03-08 09:09 PM
Vibration Issues Affecting Me?? - Cummins 4BT Forums This thread Refback 05-01-08 05:42 AM
H1C rebuild kits on EBAY - Cummins 4BT Forums This thread Refback 04-21-08 08:59 PM
Vote: 4bt or 6bt in Jeep J20 - Cummins 4BT Forums This thread Refback 04-16-08 09:18 PM
Hydroboost or Vacuum pump - Cummins 4BT Forums This thread Refback 04-16-08 02:32 PM
$3k step van or $2k used motor - Cummins 4BT Forums This thread Refback 04-08-08 05:49 PM
$3k step van or $2k used motor - Cummins 4BT Forums This thread Refback 04-08-08 03:12 PM
4bt swap - Cummins 4BT Forums This thread Refback 04-06-08 02:42 PM
trailer mod haulin This thread Refback 04-06-08 11:50 AM
Here is the truck for those who care - Cummins 4BT Forums This thread Refback 04-03-08 05:26 PM
insurance - Cummins 4BT Forums This thread Refback 04-01-08 12:12 PM
my bronco build - Page 2 - Cummins 4BT Forums This thread Refback 03-31-08 07:02 PM
Engine/Transmission Adapter P/N - Cummins 4BT Forums This thread Refback 03-26-08 09:36 PM
Hi Case mount AC - Cummins 4BT Forums This thread Refback 03-26-08 06:38 PM
Hi Case mount AC - Cummins 4BT Forums This thread Refback 03-26-08 06:21 PM
My '68 Kaiser M715 - Cummins 4BT Forums This thread Refback 03-26-08 02:51 PM
Please Help! Need inout on Trans - Cummins 4BT Forums This thread Refback 03-26-08 12:51 PM
My '68 Kaiser M715 - Cummins 4BT Forums This thread Refback 03-25-08 08:55 PM
FZJ80 w/ 4BT, couple questions - Cummins 4BT Forums This thread Refback 03-25-08 05:06 PM
mod za haulin This thread Refback 03-25-08 08:13 AM
Bought a 4BT with turbo missing....which one to buy? - Cummins 4BT Forums This thread Refback 03-18-08 08:17 PM
Questions before the swap starts - Cummins 4BT Forums This thread Refback 03-18-08 06:37 AM
Step Van????s - Page 2 - Cummins 4BT Forums This thread Refback 03-07-08 08:01 PM
tater chip tuck??? - Cummins 4BT Forums This thread Refback 03-07-08 05:48 AM
swapping a 4bt into a 1988 28 ft pace arrow MH - Cummins 4BT Forums This thread Refback 03-06-08 05:04 PM
Hydroboost, Steering, A/C and gearing questions questions - Cummins 4BT Forums This thread Refback 03-06-08 01:36 PM
74 Fj40 - Cummins 4BT Forums This thread Refback 03-05-08 01:45 PM
74 Fj40 - Cummins 4BT Forums This thread Refback 03-05-08 12:11 PM
my Yj is complete pics inside!!!!!! - Cummins 4BT Forums This thread Refback 03-04-08 07:56 PM
intercooler cooling - Cummins 4BT Forums This thread Refback 03-02-08 07:49 PM
repower with a 4l80? - Page 3 - Cummins 4BT Forums This thread Refback 03-01-08 06:37 AM
RPM's with gears and tires - Cummins 4BT Forums This thread Refback 02-28-08 08:33 PM
What is need to 4l80e? - Cummins 4BT Forums This thread Refback 02-27-08 08:37 PM
Tranny explosions, parts all over! - Cummins 4BT Forums This thread Refback 02-27-08 07:13 PM
4l80e converter - Cummins 4BT Forums This thread Refback 02-26-08 06:55 PM
4bt radiator - Cummins 4BT Forums This thread Refback 02-25-08 05:58 PM
4bt swap into a TJ - Cummins 4BT Forums This thread Refback 02-22-08 11:48 AM
6bt in 87 V3500....progress thread - Page 3 - Cummins 4BT Forums This thread Refback 02-21-08 11:38 PM
Feb Dovebid vans - Cummins 4BT Forums This thread Refback 02-21-08 08:51 PM
Mpg<auto<man - Page 2 - Cummins 4BT Forums This thread Refback 02-19-08 01:56 PM
6bt in 87 V3500....progress thread - Page 4 - Cummins 4BT Forums This thread Refback 02-18-08 09:13 PM
Big Line Kit???? - Cummins 4BT Forums This thread Refback 02-10-08 09:04 PM
better auto transmission for 4bt - Cummins 4BT Forums This thread Refback 02-07-08 03:49 PM
My new Shop Class - Cummins 4BT Forums This thread Refback 02-07-08 01:23 PM
3/4 ton Suburban, Expedition/Overlander RV 4bt or 6bt - Cummins 4BT Forums This thread Refback 02-07-08 11:04 AM
better auto transmission for 4bt - Cummins 4BT Forums This thread Refback 02-06-08 04:03 PM
Turbo Upgrade...remove exh. manifold or not - Cummins 4BT Forums This thread Refback 02-04-08 05:29 PM
Turbo Compressor Housings - Cummins 4BT Forums This thread Refback 01-28-08 05:46 PM
Identify this engine - Cummins 4BT Forums This thread Refback 01-25-08 07:53 PM
6bt in 87 V3500....progress thread - Page 4 - Cummins 4BT Forums This thread Refback 01-24-08 08:38 PM
Turbo Compressor Housings - Cummins 4BT Forums This thread Refback 01-22-08 07:54 PM
Battery specs??? - Cummins 4BT Forums This thread Refback 01-21-08 09:35 PM
Turbo Compressor Housings - Cummins 4BT Forums This thread Refback 01-20-08 05:29 PM
Where to buy tan Cummins engine paint? - Cummins 4BT Forums This thread Refback 01-19-08 09:23 PM
Turning Up The Pump - a pictoral 'how to' - Cummins 4BT Forums This thread Refback 01-18-08 12:08 PM
Sound proofing on sump - Page 2 - Cummins 4BT Forums This thread Refback 01-18-08 10:30 AM
repower with a 4l80? - Page 2 - Cummins 4BT Forums This thread Refback 01-17-08 10:08 AM
Got a 4b, now what truck?? - Cummins 4BT Forums This thread Refback 01-16-08 04:28 PM
Anyone tried this in a 90's GMC Vandura? - Cummins 4BT Forums This thread Refback 01-16-08 03:36 PM
Anyone tried this in a 90's GMC Vandura? - Cummins 4BT Forums This thread Refback 01-16-08 12:52 PM
Who is in the PNW? - Cummins 4BT Forums This thread Refback 01-12-08 03:19 PM
Newbie needin help. Calling NOVA Guys - Cummins 4BT Forums This thread Refback 01-11-08 12:18 PM
H1C rebuild kits on EBAY - Cummins 4BT Forums This thread Refback 01-10-08 11:30 AM
H1C rebuild kits on EBAY - Cummins 4BT Forums This thread Refback 01-10-08 10:21 AM
95yj - Cummins 4BT Forums This thread Refback 01-08-08 04:07 PM
air filter flow rates - Cummins 4BT Forums This thread Refback 01-07-08 06:28 PM
Show off ur motor mounts. - Page 10 - Cummins 4BT Forums This thread Refback 01-07-08 05:38 PM
Exhaust Done (New video) - Cummins 4BT Forums This thread Refback 01-06-08 10:19 PM
Cummins 4BT Forums - View Profile: boots4 This thread Refback 12-29-07 07:31 PM
fuel line - Page 2 - Cummins 4BT Forums This thread Refback 12-28-07 04:59 AM
intercooler cooling - Cummins 4BT Forums This thread Refback 12-24-07 06:56 PM
Bypass filter setups - Cummins 4BT Forums This thread Refback 12-23-07 08:18 PM
Shaker - Cummins 4BT Forums This thread Refback 12-18-07 08:19 PM
hydroboost fitting sizes - Cummins 4BT Forums This thread Refback 12-18-07 02:44 PM
