07-17-09, 01:06 AM
#991 (permalink)
awesome truck and awesome rubicon report!! Is that front bumper the 4 plus from man a fre or custom?
07-17-09, 08:42 AM
#992 (permalink)
I've returned your PM and included brokenparts on it to answer your questions. Hope it works out.
build-up: Family Haulin' FJ60
07-17-09, 08:48 AM
#993 (permalink)
It's a 4plus bumper. I'll PM ya.
07-17-09, 01:52 PM
#994 (permalink)
ummm... bumper sold. I promise I'll stop hi-jacking your thread now Mike.
07-17-09, 02:56 PM
#995 (permalink)
Great news! Dora came in handy as a model. Looks like I'll be working on mounting up my front bumper this week.
07-17-09, 03:48 PM
#996 (permalink)
hahaaha, thanks for doing the modeling. I should have some time during the next few weekends or week nights if you want to come over and bend up some more tube. Plasma is up and running again too.
07-18-09, 03:46 PM
#997 (permalink)
Rum Runnin'
Trac bar is coming up really fast on my list. I was dreaming up something on the drive home today and it pretty much looked like what you've got there.
Did you start with the ruffstuff kit and widen up the bracket on one side to slide up on the housing like that? Think it will provide any protection for your d-shaft out on the trail?
Johnny C
Waiting to be installed:
Previous Rig:
1987 FJ60 - Big Red
ΦΚΤ - Fall 06
07-18-09, 06:52 PM
#998 (permalink)
Yes I copied the axle mounts from Brokenparts or Dirtgypsy (they both had the same plates from Ruffstuff and I grabbed one of them to trace). Then I bolted them to one of my links to keep them straight/aligned, positioned them on the axle and clearanced the plate closest to the 3rd member. I wanted to position the bar on the middle of the axle and that's pretty close. I moved it just a hair driverside to eliminate interferance with the 3rd. Again I'd suggest bushings/bolts that go together (there are several places offering DIY kits). I'm pretty sure the JJoint is my weakest link in the system so you might consider a 2.5 instead of the 2.0 I'm using but it's probably strong enough and I won't have any problems. I just won't know for certain until I get some wheeling time on it.
The driveshaft hangs lower so mine probably won't offer any rock bashing protection.
07-19-09, 07:57 AM
#999 (permalink)
Rum Runnin'
Yes it does, I should use my eyes when looking at pictures.
Johnny C
Previous Rig:
1987 FJ60 - Big Red
ΦΚΤ - Fall 06
07-23-09, 10:28 AM
#1000 (permalink)
weekly update
I've been putting off the front bumper because I needed to cut out some mounts from that 3/4" plate that I got for free. I didn't try very hard to find a local shop to cut it out so I got on a mask, put on my glasses, and started up the angle grinder. It only took me about 3 hrs to cut them out and I only used up 3 cutting disks. I went over to brokenparts place to return his bumper and once we got that one out I found my measurements were off and the plates were too tall  . With some plasma and a little more grinder action I took off 1/4" more and they slid in the frame. Then my crossbrace ended up being 1/2" too short. Zach swapped out a longer piece with me and I ended up headind home. So I pretty much only got the plates cut and drilled. I decided to step up to 1/2" bolts so I drilled the holes in the plate and enlarged the holes in the frame. Zack's drillpress and sharp drill bits made cutting holes in 3/4" steel easy! I'll have to add one of those to the growing tool wanting list. I started on it the next day. Here is the mounting plates and crossbrace. I wanted a sturdy crossbrace for possible winch support in the future.
I used my engine hoist to play with positioning the bumper. My pregnant  can't lift much anymore (yes for those following along that will be #3 due in Nov). I also added in a tube crossbrace.
I measured the height and angle when the bumper was where I wanted it and cut and notched some tube supports. Did some test fits and welded them on.
Tube supply is getting minimal and I'll probably have to buy some more to complete the fender protection. To save on uncut length I took some scrape pieces and rejointed them.
I cut and shaped those pieces to fit as more supports for the lower main tube. Did a little filling and took it off the truck to weld it all up.
Here is a couple of shots with it attached to Dora.
I'll eventually add the fender protection and tie it into the sliders. It will be bolted so the whole thing can be removed. I did want to put holes for shackles in the mounting plates but forgot so I'll try and add those later. I will also add something to the lower part on the front. Zack's got some dimple dies I might try out and I've also got some expanded metal from a sliding door that was in the stepvan that I'm thinking about too. It will be a solid piece in front and whenever the right winch comes along I'll open it up to fit. So what do you guys think will look better: Dimple died plate or expanded metal on the lower section?
07-23-09, 10:34 AM
#1001 (permalink)
Turbo Diesel Lover
you are not wasting time dude ..
HJ-60 2H-T Intercooled Tencha
Originally Posted by crushers
07-23-09, 11:30 AM
#1002 (permalink)
dimple dies...The steel yard has plenty of 1/8th inch plate in stock which I'm pretty sure my press and dies can handle.
Looks great Mike. I should have time in the next week or two so we can bend up some tube for the fenders are at least to attach the top and bottom corners.
07-23-09, 11:45 AM
#1003 (permalink)
Zach, I can't remember but do you have different hole sized dies? The ends might look nice going smaller towards the points (does that make sense?).
07-23-09, 11:47 AM
#1004 (permalink)
That bumper is pimp, awesome work. I vote dimple dies.
07-23-09, 12:17 PM
#1005 (permalink)
yep three different sizes. I believe 1.5, 1, and 3/4" if I remember correctly. I check tonight for ya though.
07-30-09, 11:13 AM
#1006 (permalink)
trip report
Dirtgypsy attended the Mcgrew trail ride in southern OR and invited us to camp after the event. We packed up Dora and took the kids on their first camping trip. It was a decent drive (~5 hrs) and we met in O'brien OR to follow him in. It was 18 miles in on a hot, dusty road. Of course this week ends up being a record breaking heat wave here in oregon so combined with the dust they weren't the most enjoyable conditions but the company was good and the nearby river had several good swimming spots. We did a very short hike with the oldest kids and found a great spot where the water was as warm as a swimming pool! Besides that we just hung around enjoying the downtime from life. My family stayed two nights and we all left on tuesday morning. Dora was running pretty warm on the way in and out of the hills to the road. I found the TC lock-up not working and once I got to the pavement I found a wire had jiggled off. Slipping the TC just generated more heat so I saw a peak of 225F engine and 210 tranny on the climbs but it would cool down on the decents. Once back on pavement I reconnected the wire and lock-up was restored. With an expected 105F travel day Dora stuck around 210F engine temp and 185F tranny temp on the hwy all with one little fan pulling through the radiator. Yup, still haven't hooked up the other fan. I have also found another spot where I'm loosing coolant at the block intake piece that bolts on. I might make one and size it to my lower radiator port but for now I just keep adding fluid to my overflow tank. It's pretty much all water now. We ended up going ahead of Dirtgypsy and aimed for 70mph.
The heat was crazy and we refilled our squirt bottle 5 times to help keep us and the kids cooler durning the trip. We'd soak our clothes at the rest stops too. We switched drivers and  was driving. She had just passed a couple of cars and a semi, we were going straight with no one around, I was just entering a vegitative state in the passenger seat and then we heard a loud bang like a gun was triggered in the cab. The driver side immediately dropped 8 inches and immediately we knew the driver front tire had just blown. My  calmly let off the throttle and guided us to the side of the road. She did a fantastic job and kept her cool, I was very proud of her. I asked her what it felt like afterwards and she said it was just a slight tug at the wheel but that it was easy to control. Hydroassist definitely paid for itself here because that ram probably dampened the blow and kept things straight. 38's on 15" rims is a long way down.
We had to unpack a few things to get to the highlift that I forgot to give back to brokenparts and fish out the spare. When I looked at the blown tire the sidewall had about a 1-2' tear where it blew. I'll get pics tomorrow but it was a massive failure. I got the tire replaced and can cross that off my list of things I want to do again in 105F heat especially with no vehicle AC. At that time Dirtgypsy caught up to us and pulled over to help. With everything packed back up we merged back on the hwy. I drove to test out the tire to see how it behaved. This is a spare 38 bogger and those things are LOUD. I don't care what kind of engine you are running those tires are going to hum louder. Handling felt good so we switched drivers again and made it home without anymore drauma. Dora is going to sit for the week.
Ironically I've previously been doing some tire/wheel research on what I'd want to run next. I know I still have 3 other good tires but it's a good time to make a change plus I can sell those. What I want to run are H1 12bolts recentered and rock ringed so I'm in the process of tracking some down and have worked out my costs already. For tires, it looks like the budget will determine those and I may end up running some 37" military goodyears. I can groove and sipe those to get better performance. What I'd like to run are some pitbulls but I'll have to save to get those. Overall Dora held up in some harsh conditions.
07-30-09, 12:34 PM
#1007 (permalink)
good to hear that you are all safe Mike... Hydro assist IS one of the best steering stabilizers out there and it sounds like it payed off for you. There is a vendor in the vendor section of Pirate that looked like he had a good price on 37" military tires.
95% tread 37" H1 Goodyear radials SoCal - Pirate4x4.Com Bulletin Board
Go pitbull though.
07-30-09, 02:51 PM
#1008 (permalink)
Turbo Diesel Lover
glad to ear all of your family it's safe .. and finally enjoy a great trip ..
Just a side thread question ... are the Pitbulls that good compared to a TSL tires ?
I'm looking ( maybe for christmas ) new tires for Tencha ( 5 years with the same MTR .. enough ) and will be nice 38" - 39" range tires .. but I don't want to go any wider than 13.5 or 14 ..
07-30-09, 03:08 PM
#1009 (permalink)
I've read a couple favorable reviews for the pitbulls and I wanted to step up to a biasply for the sidewall strength. While they are biasply they are suppost to do well on the hwy. While I like the looks of the wide tires I'd like to try out a skinnier set too. Of course my definition of skinny would be 12.50.
Pitbull offerings.
I just don't know how spendy these are.
07-30-09, 03:15 PM
#1010 (permalink)
my only gripe with the pitbulls (so far) is how difficult is was to get them here to the west coast. Its like they didnt want to sell me a set. After numerous calls to tire vendors around my local area I ended up getting mine through 4x4groupbuy.com which ended up being a reasonable transaction. I think you would see a lot more pitbull tires around this area if they were eaiser to get.
07-30-09, 03:50 PM
#1011 (permalink)
Thanks for that site. The prices are better than I thought. How much was shipping on your tires if you don't mind sharing.
07-30-09, 05:04 PM
#1012 (permalink)
I dont recall it being too bad... something like $100- 150ish?
07-31-09, 06:19 AM
#1013 (permalink)
KOOL AAROW
SWEET bumper... truck looks GREAT ...I need mine back so I can start builden cool stuff too
82 FJ60 5.3, 4l60E, OME Heavy, 33 KM2's 410's, ARB bull & side bars ...SOA in the works
85 FJ60 Trail beater SM 420 crawler box lockers 456, 4D's bobed & choped with a Metal Tech cage
GIT-R-DONE!!!!
TLCA #15374
low riders want SWITCHES... 4 wheelers want SHIFTERS
www.jkcustoms.com
07-31-09, 06:40 AM
#1014 (permalink)
Ramblin Wreck
When my 38.5 SX's got worn out, I started looking at the Pitbulls...
While in shop asking about them, I ended up getting 4 new biasply Irocks for less than the price of 2 Pitbulls.
IMO- Watch classifieds and pick up a deal.
Bailey Quintrell
'74 FJ40--37 Irocks-32 Bolt 'Locks-SM420-ARB-XD9000i-FJ60 PS-MetalTech Cage
'93 FZJ80-DD-P.T. 4wd-locked-5" lifted-snorkel-bullbar-315 AT's
'53 Willys Wagon
ΣΧ
07-31-09, 08:43 AM
#1015 (permalink)
True, I should surf the classifieds more often. Shipping always seems to get me.
07-31-09, 09:05 AM
#1016 (permalink)
Thanks. I'm focusing on my tire/wheel change so once I get that worked out I can continue on the bumper. It held up fine on the trip.
07-31-09, 01:22 PM
#1017 (permalink)
The Anti-Leafer
 Man, if I posted something in my build thread about using 3/4" plate, 10 purist newbs would be asking how much it was gonna weigh
I'm diggin the design  . What size winch & how will it fit into the bumper design?
07-31-09, 07:21 PM
#1018 (permalink)
I'm sure purists think I'm driving around a bastard rig anyways.
Honestly I've really done no research on winches and I probably won't pick one up for a while. Although my bro-in-law has a Warn 9000 on a receiver I could play with for fitment. I'm not oppose to trimming out the valance if need be to keep it tucked behind the bumper. That 2x2 .250 wall crossmember should give me something solid to build some mounts off of when a winch comes my way and then I'd make a new front piece to house the fairlead on the center lower section where I plan to put some dimple-died plate.
08-01-09, 08:35 AM
#1019 (permalink)
tire carnage
Here are pics of my tire failure. I wonder what would have happened if I were still running my airsoft or BB's, if they would have shot out of the tire when it blew.
The inner bead stayed on the rim somehow. Rims didn't get damaged so I'll be able to sell those when my new tire setup arrives.
08-01-09, 03:13 PM
#1020 (permalink)
Forget the military 37's. You need 40" tires. I like the look of the 40X12.5X17 GY Mt/r's. Used tires are not worth it IMOP. Generally people ask way too much for them anyways.
Clint
LinkBack to this Thread: http://forum.ih8mud.com/hardcore-corner/160807-family-haulin.html
| Posted By |
For |
Type |
Date |
| Here's the Descrambler - Page 8 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
11-01-09 03:53 PM |
| Untitled document |
This thread |
Refback |
10-25-09 05:08 PM |
| cool thread on using a VNT,VVT or whatever turbo - Page 8 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
10-18-09 09:39 AM |
| Untitled document |
This thread |
Refback |
10-16-09 09:10 AM |
| 74 Fj40 - Page 3 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
10-10-09 11:22 PM |
| Has anyone actually used a 4L80E??? - Page 3 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
10-09-09 06:56 PM |
| ARAMP1's Ultimate TowRig Buld Thread - Page 2 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
10-06-09 02:19 PM |
| Has anyone actually used a 4L80E??? - Page 2 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
10-03-09 10:05 AM |
| FJ60 drivetrain swap questions - Page 3 - Expedition Portal Forum |
This thread |
Refback |
09-19-09 04:03 PM |
| 6bt in 87 V3500....progress thread - Page 2 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
08-15-09 04:29 AM |
| The new and improved Tiny-Tach - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
08-12-09 06:45 PM |
| anyone actually using a 4l80? - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
08-09-09 04:26 PM |
| THE 4L80/85E information thread - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
08-09-09 09:24 AM |
| Lift pump pre filter - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
08-07-09 05:04 PM |
| Mini Mercedes, Mod Haulin Mercedes, Mercedes Service Atlanta - Felprocatalogw |
This thread |
Refback |
07-09-09 11:19 AM |
| Completed '74 Plymouth Satellite 4bt swap - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
07-01-09 09:19 PM |
| New to Diesel Swap Questions - Plumbing Electrical Etc - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
06-06-09 11:23 AM |
| Electric Vacuum Pumps - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
05-27-09 11:00 AM |
| Show off ur motor mounts. - Page 6 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
05-20-09 07:40 PM |
| Official Cummins 4BT video thread! - Page 3 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
05-20-09 03:25 AM |
| '85 FJ60 Landcruiser 4BT/4L480e SOA - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
05-17-09 01:41 AM |
| Here's the Descrambler - Page 4 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
05-16-09 10:44 AM |
| Here's the Descrambler - Page 6 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
04-23-09 12:49 PM |
| April 18 - SOLV @ Tillamook State Forest |
This thread |
Refback |
04-18-09 09:41 PM |
| Family Trucksters? - Colorado4x4.org Forums |
This thread |
Refback |
04-14-09 07:50 AM |
| 700r4 feasibility study - Page 6 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
03-25-09 09:15 PM |
| Jeep Cj2A Bikini Top, Jeep Cj Exhaust Manifold Gasket Replacement, Jeep Cj5 Exhaust Flange - Polarisdiesel |
This thread |
Refback |
03-08-09 11:24 AM |
| Gm Card Points For Chevy Malibu, Gm Automotive Warranty Audit, Gm Cars With 200 Plus Amp Alternators - Shadowdemon |
This thread |
Refback |
03-08-09 09:51 AM |
| Scout Engine Conversion Headers, Scottie Kit Car Parts, Scranton Area Rental Cars - Marshlandboar |
This thread |
Refback |
03-08-09 08:44 AM |
| 1992 80 Series - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
03-07-09 11:34 AM |
| Buy Ford Bronco 4X4 Lifted, Buy Electric Cars, Buy Geo Metro - Yvonneridley |
This thread |
Refback |
03-07-09 03:24 AM |
| Toyota Collapsed Top Radiator Hose, Toyota Cold Fusion France, Toyota Concept Cars - Newavengers |
This thread |
Refback |
03-07-09 01:43 AM |
| Official Cummins 4BT video thread! - Page 5 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
03-06-09 03:21 PM |
| Dually Fenders For Van, Dual Sport Motorcycle Tires, Dubai Car Rentals - Tiresbicycle |
This thread |
Refback |
03-06-09 02:04 AM |
| Ford Truck Exhaust Manifold Leak, Ford Truck Clutch Kits, Ford Truck Front Fenders My My Messages - Polarisclothing |
This thread |
Refback |
03-06-09 02:04 AM |
| Gmc Truck Plastic Bed Liners Plainfield Illinois, Gmc Truck Mud Flaps, Gmc Truck Tune Up - Balljoint |
This thread |
Refback |
03-06-09 01:40 AM |
| JacobPadilla's Bookmarks on Delicious |
This thread |
Refback |
02-20-09 07:21 PM |
| Mufflers - Cummins 4BT & Diesel Conversions Forums |
Post #0 |
Refback |
02-16-09 07:58 PM |
| Here's the Descrambler - Page 5 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
02-13-09 12:48 PM |
| FJ60 Build - Page 6 - Pirate4x4.Com Bulletin Board |
This thread |
Refback |
02-12-09 08:54 AM |
| 74 Fj40 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
02-02-09 06:13 PM |
| PNWJeep.com • View topic - My Build... |
This thread |
Refback |
01-31-09 10:16 PM |
| Do I really need two 12-volt batteries? - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
01-25-09 11:58 AM |
| Dodge intake horns - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
01-20-09 07:22 PM |
| Here's the Descrambler - Page 3 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
01-11-09 01:57 PM |
| Snow wheeling TSF Browns camp this weekend Jan 3 or 4 2009? |
This thread |
Refback |
01-02-09 12:38 PM |
| how come my trans shifts? - Page 2 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
01-02-09 02:49 AM |
| Name that thing-a-ma-jig - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
12-19-08 03:10 PM |
| Fuel Log - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
12-07-08 01:06 PM |
| toyota fj62 swap - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
12-04-08 09:27 AM |
| CAC Intake Manifold Part Numbers-ATTN: boots4 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
11-28-08 08:09 PM |
| Sound proofing on sump - Page 2 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
11-11-08 10:05 PM |
| video request plz - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
11-06-08 09:23 AM |
| Bosch VE timing question - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
11-02-08 09:29 PM |
| Using 2-stroke oil - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
10-30-08 07:03 PM |
| 4runnerclub.org :: Zobrazit téma - oprava šedesátky |
This thread |
Refback |
10-26-08 12:05 PM |
| Need serious help with egt's - Page 2 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
10-22-08 01:26 PM |
| Hydroboost setup question - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
10-22-08 12:35 PM |
| Power and economy and reliability where is the happy medium - Page 4 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
10-21-08 04:53 PM |
| Opinions please - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
10-21-08 02:41 PM |
| Diesel questions |
This thread |
Refback |
10-19-08 11:45 AM |
| Turbo Info, HY35s, Photos/info... Etc - Page 12 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
10-18-08 11:42 AM |
| Boost gauge location? - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
10-16-08 11:59 AM |
| Isuzu Commercial Diesel - Pirate4x4.Com Bulletin Board |
This thread |
Refback |
10-14-08 11:14 PM |
| Use orginal gas tank question - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
10-05-08 08:59 AM |
| View the profile of boots4 |
This thread |
Refback |
10-04-08 09:05 PM |
| tuning for an HX35 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
09-28-08 07:09 AM |
| Full Power Screw.... - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
09-27-08 11:46 PM |
| 4x4.ee :: Vaata teemat - Tõsine HJ-60 project |
This thread |
Refback |
09-15-08 02:15 PM |
| Weldernator - Cummins 4BT Forums |
This thread |
Refback |
09-05-08 04:56 AM |
| Engine Choices --3.3l vs. 3.9l - Cummins 4BT Forums |
This thread |
Refback |
08-16-08 04:45 PM |
| Noob EGT question. - Cummins 4BT Forums |
This thread |
Refback |
08-13-08 06:15 PM |
| New Guy - Cummins 4BT Forums |
This thread |
Refback |
08-01-08 05:56 AM |
| Which Dodge automatic to use in FJ80? - Cummins 4BT Forums |
This thread |
Refback |
07-28-08 08:25 AM |
| Let's See Your Trucks! - Page 8 - Cummins 4BT Forums |
This thread |
Refback |
07-24-08 09:37 PM |
| 74 Fj40 - Page 4 - Cummins 4BT Forums |
This thread |
Refback |
07-21-08 10:13 AM |
| IDEAS? EGT's Hot at stock and pump turned up any ideas? - Page 2 - Cummins 4BT Forums |
This thread |
Refback |
07-12-08 01:40 PM |
| Build-up: Jeep YJ w/ Isuzu diesel - Page 11 - Pirate4x4.Com Bulletin Board |
This thread |
Refback |
07-10-08 10:32 AM |
| Arrrgg....it always works this way - Cummins 4BT Forums |
This thread |
Refback |
06-28-08 05:56 PM |
| Can You Still Hear After running you're 4BT? - Page 3 - Cummins 4BT Forums |
This thread |
Refback |
06-27-08 06:10 AM |
| What gears for 37 |
This thread |
Refback |
06-25-08 12:58 PM |
| What gears for 37 |
This thread |
Refback |
06-23-08 08:33 AM |
| Exhaust Routing - Cummins 4BT Forums |
This thread |
Refback |
06-21-08 11:29 PM |
| 74 Fj40 - Page 2 - Cummins 4BT Forums |
This thread |
Refback |
06-13-08 05:28 PM |
| Kdp ? - Cummins 4BT Forums |
This thread |
Refback |
06-13-08 06:24 AM |
| IDEAS? EGT's Hot at stock and pump turned up any ideas? - Cummins 4BT Forums |
This thread |
Refback |
06-10-08 10:47 AM |
| vacuum booster for brakes? - Cummins 4BT Forums |
This thread |
Refback |
06-08-08 04:39 PM |
| Timbercrawler -- View topic - Who owns... |
This thread |
Refback |
06-06-08 11:05 AM |
| Hot rod gets a 4BT - Cummins 4BT Forums |
This thread |
Refback |
06-05-08 07:32 PM |
This thread |
Refback |
06-04-08 10:01 PM |
This thread |
Refback |
06-04-08 09:46 PM |
| VE Pump Question - Cummins 4BT Forums |
This thread |
Refback |
06-04-08 07:51 PM |
| Your max GCVW with a 4BT? - Cummins 4BT Forums |
This thread |
Refback |
06-04-08 02:57 PM |
| 2nd maiden voyage - Cummins 4BT Forums |
This thread |
Refback |
05-30-08 12:06 PM |
| Sound proofing on sump - Page 2 - Cummins 4BT Forums |
This thread |
Refback |
05-18-08 09:21 PM |
| Pullys - Cummins 4BT Forums |
This thread |
Refback |
05-17-08 08:28 AM |
| Muffler or no muffler? Exhaust diameter? - Page 3 - Cummins 4BT Forums |
This thread |
Refback |
05-13-08 07:25 PM |
| Mongos 4BT Firewood Monster Truck - Page 4 - Cummins 4BT Forums |
This thread |
Refback |
05-12-08 12:05 PM |
| Muffler or no muffler? Exhaust diameter? - Page 2 - Cummins 4BT Forums |
This thread |
Refback |
05-11-08 04:20 PM |
| Rebuild H1 turbo - Cummins 4BT Forums |
This thread |
Refback |
05-10-08 04:16 PM |
| 4bt radiator - Cummins 4BT Forums |
This thread |
Refback |
05-08-08 05:14 PM |
| Radiator hose adapters - Cummins 4BT Forums |
This thread |
Refback |
05-03-08 09:09 PM |
| Vibration Issues Affecting Me?? - Cummins 4BT Forums |
This thread |
Refback |
05-01-08 05:42 AM |
| H1C rebuild kits on EBAY - Cummins 4BT Forums |
This thread |
Refback |
04-21-08 08:59 PM |
| Vote: 4bt or 6bt in Jeep J20 - Cummins 4BT Forums |
This thread |
Refback |
04-16-08 09:18 PM |
| Hydroboost or Vacuum pump - Cummins 4BT Forums |
This thread |
Refback |
04-16-08 02:32 PM |
| $3k step van or $2k used motor - Cummins 4BT Forums |
This thread |
Refback |
04-08-08 05:49 PM |
This thread |
Refback |
04-08-08 03:12 PM |
| 4bt swap - Cummins 4BT Forums |
This thread |
Refback |
04-06-08 02:42 PM |
| trailer mod haulin |
This thread |
Refback |
04-06-08 11:50 AM |
| Here is the truck for those who care - Cummins 4BT Forums |
This thread |
Refback |
04-03-08 05:26 PM |
| insurance - Cummins 4BT Forums |
This thread |
Refback |
04-01-08 12:12 PM |
| my bronco build - Page 2 - Cummins 4BT Forums |
This thread |
Refback |
03-31-08 07:02 PM |
| Engine/Transmission Adapter P/N - Cummins 4BT Forums |
This thread |
Refback |
03-26-08 09:36 PM |
| Hi Case mount AC - Cummins 4BT Forums |
This thread |
Refback |
03-26-08 06:38 PM |
This thread |
Refback |
03-26-08 06:21 PM |
| My '68 Kaiser M715 - Cummins 4BT Forums |
This thread |
Refback |
03-26-08 02:51 PM |
| Please Help! Need inout on Trans - Cummins 4BT Forums |
This thread |
Refback |
03-26-08 12:51 PM |
This thread |
Refback |
03-25-08 08:55 PM |
| FZJ80 w/ 4BT, couple questions - Cummins 4BT Forums |
This thread |
Refback |
03-25-08 05:06 PM |
| mod za haulin |
This thread |
Refback |
03-25-08 08:13 AM |
| Bought a 4BT with turbo missing....which one to buy? - Cummins 4BT Forums |
This thread |
Refback |
03-18-08 08:17 PM |
| Questions before the swap starts - Cummins 4BT Forums |
This thread |
Refback |
03-18-08 06:37 AM |
| Step Van????s - Page 2 - Cummins 4BT Forums |
This thread |
Refback |
03-07-08 08:01 PM |
| tater chip tuck??? - Cummins 4BT Forums |
This thread |
Refback |
03-07-08 05:48 AM |
| swapping a 4bt into a 1988 28 ft pace arrow MH - Cummins 4BT Forums |
This thread |
Refback |
03-06-08 05:04 PM |
| Hydroboost, Steering, A/C and gearing questions questions - Cummins 4BT Forums |
This thread |
Refback |
03-06-08 01:36 PM |
| 74 Fj40 - Cummins 4BT Forums |
This thread |
Refback |
03-05-08 01:45 PM |
This thread |
Refback |
03-05-08 12:11 PM |
| my Yj is complete pics inside!!!!!! - Cummins 4BT Forums |
This thread |
Refback |
03-04-08 07:56 PM |
| intercooler cooling - Cummins 4BT Forums |
This thread |
Refback |
03-02-08 07:49 PM |
| repower with a 4l80? - Page 3 - Cummins 4BT Forums |
This thread |
Refback |
03-01-08 06:37 AM |
| RPM's with gears and tires - Cummins 4BT Forums |
This thread |
Refback |
02-28-08 08:33 PM |
| What is need to 4l80e? - Cummins 4BT Forums |
This thread |
Refback |
02-27-08 08:37 PM |
| Tranny explosions, parts all over! - Cummins 4BT Forums |
This thread |
Refback |
02-27-08 07:13 PM |
| 4l80e converter - Cummins 4BT Forums |
This thread |
Refback |
02-26-08 06:55 PM |
This thread |
Refback |
02-25-08 05:58 PM |
| 4bt swap into a TJ - Cummins 4BT Forums |
This thread |
Refback |
02-22-08 11:48 AM |
| 6bt in 87 V3500....progress thread - Page 3 - Cummins 4BT Forums |
This thread |
Refback |
02-21-08 11:38 PM |
| Feb Dovebid vans - Cummins 4BT Forums |
This thread |
Refback |
02-21-08 08:51 PM |
| Mpg<auto<man - Page 2 - Cummins 4BT Forums |
This thread |
Refback |
02-19-08 01:56 PM |
| 6bt in 87 V3500....progress thread - Page 4 - Cummins 4BT Forums |
This thread |
Refback |
02-18-08 09:13 PM |
| Big Line Kit???? - Cummins 4BT Forums |
This thread |
Refback |
02-10-08 09:04 PM |
| better auto transmission for 4bt - Cummins 4BT Forums |
This thread |
Refback |
02-07-08 03:49 PM |
| My new Shop Class - Cummins 4BT Forums |
This thread |
Refback |
02-07-08 01:23 PM |
| 3/4 ton Suburban, Expedition/Overlander RV 4bt or 6bt - Cummins 4BT Forums |
This thread |
Refback |
02-07-08 11:04 AM |
This thread |
Refback |
02-06-08 04:03 PM |
| Turbo Upgrade...remove exh. manifold or not - Cummins 4BT Forums |
This thread |
Refback |
02-04-08 05:29 PM |
| Turbo Compressor Housings - Cummins 4BT Forums |
This thread |
Refback |
01-28-08 05:46 PM |
| Identify this engine - Cummins 4BT Forums |
This thread |
Refback |
01-25-08 07:53 PM |
This thread |
Refback |
01-24-08 08:38 PM |
This thread |
Refback |
01-22-08 07:54 PM |
| Battery specs??? - Cummins 4BT Forums |
This thread |
Refback |
01-21-08 09:35 PM |
This thread |
Refback |
01-20-08 05:29 PM |
| Where to buy tan Cummins engine paint? - Cummins 4BT Forums |
This thread |
Refback |
01-19-08 09:23 PM |
| Turning Up The Pump - a pictoral 'how to' - Cummins 4BT Forums |
This thread |
Refback |
01-18-08 12:08 PM |
This thread |
Refback |
01-18-08 10:30 AM |
| repower with a 4l80? - Page 2 - Cummins 4BT Forums |
This thread |
Refback |
01-17-08 10:08 AM |
| Got a 4b, now what truck?? - Cummins 4BT Forums |
This thread |
Refback |
01-16-08 04:28 PM |
| Anyone tried this in a 90's GMC Vandura? - Cummins 4BT Forums |
This thread |
Refback |
01-16-08 03:36 PM |
This thread |
Refback |
01-16-08 12:52 PM |
| Who is in the PNW? - Cummins 4BT Forums |
This thread |
Refback |
01-12-08 03:19 PM |
| Newbie needin help. Calling NOVA Guys - Cummins 4BT Forums |
This thread |
Refback |
01-11-08 12:18 PM |
This thread |
Refback |
01-10-08 11:30 AM |
This thread |
Refback |
01-10-08 10:21 AM |
| 95yj - Cummins 4BT Forums |
This thread |
Refback |
01-08-08 04:07 PM |
| air filter flow rates - Cummins 4BT Forums |
This thread |
Refback |
01-07-08 06:28 PM |
| Show off ur motor mounts. - Page 10 - Cummins 4BT Forums |
This thread |
Refback |
01-07-08 05:38 PM |
| Exhaust Done (New video) - Cummins 4BT Forums |
This thread |
Refback |
01-06-08 10:19 PM |
| Cummins 4BT Forums - View Profile: boots4 |
This thread |
Refback |
12-29-07 07:31 PM |
| fuel line - Page 2 - Cummins 4BT Forums |
This thread |
Refback |
12-28-07 04:59 AM |
This thread |
Refback |
12-24-07 06:56 PM |
| Bypass filter setups - Cummins 4BT Forums |
This thread |
Refback |
12-23-07 08:18 PM |
| Shaker - Cummins 4BT Forums |
This thread |
Refback |
12-18-07 08:19 PM |
| hydroboost fitting sizes - Cummins 4BT Forums |
This thread |
Refback |
12-18-07 02:44 PM |
